1000 Eaton Boulevard
Cleveland, OH 44122
United States
Note: The cloning function will not work if the U339-002 is connected to a computer or any other source
via a USB cable.
USB 3.0 SuperSpeed to Dual SATA External Hard
Drive Docking Station with Cloning for 2.5 in./3.5
in. HDD
Highlights
Read and Write to two drives
simultaneously
Supports 2.5" or 3.5" SATA
drives up to 6TB
Docking functionality compatible
with Windows, MAC, and Linux
systems
MODEL NUMBER: U339-002
System Requirements
(x2) 2.5” or 3.5” SATA Hard
Drive.
Computer with an available USB
port. Note: A USB 3.0 port is
required to achieve maximum
transfer speeds up to 5Gbps.
Cloning functionality will not
connected to a computer.
with Windows, Mac and Linux
systems.
Offline clone copies data from
the master drive to the slave
drive, leaving the remaining data
unallocated. Windows
computers will be able to
reallocate the remaining data,
whereas Mac and Linux
computers will not.
SuperSpeed ( 5Gbps ) Data Transfer over USB 3.0
Description
Tripp Lites U339-002 USB 3.0 SuperSpeed to Dual SATA External Hard Drive Docking Station allows two
SATA 2.5in or 3.5in hard drives (HDD) or solid state drives (SSD) to be connected simultaneously to a
computer through USB. Supports 2.5" and 3.5" drives up to 6TB. Will support larger capacity drives as
they become available. Off-line cloning allows hard drive duplication without being connected to a
computer.
Utilizing SuperSpeed USB 3.0, this docking station provides data transfer rates of up to 5 Gbps, but is
also backward compatible with USB 2.0 systems (data transfer rates up to 480 Mbps).
Package Includes
2.5-ft. USB 3.0 Device Cable
External Power Supply with
NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 1.5A;
Output:12V, 3A)
Owner’s Manual
Features
Dual SATA docking station enables the connection of two 2.5” or 3.5” hard drives via a computer’s USB
port.
Easy set-up eliminates the need for time-consuming internal installation and facilitates access to a hard
drive’s contents.
Offline cloning functionality allows hard drive duplication with the touch of a button – a host computer
connection is not needed.
An LED progress bar displays cloning status.
Supports USB 3.0 connections with data transfer rates up to 5Gbps.
Compliant with SATA HDD or SSD drives up to SATA III
Backwards compatible with USB 2.0 and USB 1.1 standards.
Docking functionality compatible with Windows, MAC, and Linux systems
Specifications
1/3
Cleveland, OH 44122
United States
OVERVIEW
UPC Code
037332181299
Technology
SATA/eSATA
INPUT
Voltage Compatibility (VAC)
100; 110; 120; 127; 200; 208; 220; 230; 240
Bus Powered
No
POWER
Power Source Type
AC Adapter
External Power Supply Plug(s)
NEMA 1-15P North America
External Power Supply Input Specs
(V / Hz / A)
100-240V / 50/60Hz / 1.5A
External Power Supply Output
Specs (V / A)
12V / 3A
External Power Supply Cord Length
(ft.)
4.9
(m.)
1.5
AC Adapter
Input: 100-240V, 50/60Hz, 1.5A; Output: 12V, 3A
DC Barrel Plug
OD: 5.5 x 2.1 x 10mm, Positive Pin, Negative Sleeve
Power Consumption (Watts)
36
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Red (Read, Write, Power); Blue (Clone)
PHYSICAL
Color
Black
Material of Construction
ABS
Shipping Dimensions (hwd / in.)
2.70 x 6.30 x 8.00
Shipping Dimensions (hwd / cm)
6.86 x 16.00 x 20.32
Shipping Weight (lbs.)
1.70
Shipping Weight (kg)
0.77
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
Unit Dimensions (hwd / cm)
6.2 x 15.3 x 11.1
Unit Packaging Type
Box
Unit Weight (lbs.)
0.9
Unit Weight (kg)
0.41
2/3
Cleveland, OH 44122
United States
ENVIRONMENTAL
Operating Temperature Range
50 to 122 F (10 to 50 C)
Storage Temperature Range
32 to 149 F (0 to 65 C)
Relative Humidity
10% to 80% RH, Non-Condensing
BTUs
122.8 BTU/Hr
CONNECTIONS
Number of Ports
2
Side A - Connector 1
USB 3.0 A (MALE)
Side B - Connector 1
(2) 22 PIN SATA + POWER (FEMALE)
Connector Plating
Nickel
FEATURES & SPECIFICATIONS
USB Specification
USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps)
Driver Required
No
UASP Support
Yes
IP68 Rated
No
IP20 Rated
No
STANDARDS & COMPLIANCE
External Power Supply Certifications
FCC; UL; cUL; RoHS
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“U339-002”相匹配的价格&库存,您可以联系我们找货
