0DT23010
0DT23010
    TRIPPLITE
    MINICOMKVMCONSOLESWITCHEXT
0DT23010 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Mini USB VGA over Cat5 UTP KVM Console Extender Kit - 230-ft. Highlights ● Manage a USB computer or KVM switch from a remote location up to 230-ft. (70M) away ● More security - Look after your investment by storing computers in locked, environmentally controlled room ● More flexibility - Place your KVM console where you want it and your computer where you need it ● More efficiency - Make your set up work for you instead of you working for your set up ● Plug and play solution ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: 0DT23010 System Requirements Description ● Compatible with all major operating systems ● Computer or KVM switch with VGA and USB ports ● VGA monitor and PS/2 keyboard and mouse The Mini KVM Extender USB is a high value, affordable solution for extending your KVM console from your computer or KVM switch to a distance of up to 230-ft. (70M) away over clutter free CAT5/6/7 cables. If you're working from a small, home office (SOHO), the Mini KVM Extender USB is your preferred extended control solution - just place the KVM console where you want and the computer where you need and you're all set to go! Package Includes ● Local Transmitter Unit ● Remote Receiver Unit ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60Hz Output: DC5V/1000mA) ● Owner's Manual For industrial applications such as manufacturing lines or clean rooms, the Mini KVM Extender USB provides maximum safety and security, allowing you to place computers and servers in a single centralized location, far away from any production hazards. IT managers seeking extended access to server rooms in a tightly secured environment will find the Mini KVM Extender USB particularly efficient and easy to use. Ideal also for presentation and training applications, the Mini KVM Extender USB provides flexibility and security coupled with highly attractive pricing. The Mini KVM Extender USB is made up of 2 micro sized, compact units on both ends: a Transmitter unit with VGA and USB connectors that connects to the computer / KVM switch, and a Receiver unit with VGA and PS/2 connectors that connects to the remote keyboard, monitor and mouse. The Mini KVM Extender USB is a pure hardware solution, making it both software and network independent. Features ● Manage a USB computer or KVM switch from a remote location up to 230-ft. (70M) away ● More security - Look after your investment by storing computers in locked, environmentally controlled room ● More flexibility - Place your KVM console where you want it and your computer where you need it 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States ● More efficiency - Make your set up work for you instead of you working for your set up ● Plug and play solution ● Micro sized - Smallest form factor for sleek Transmitter and Receiver units. Once installed you won't even know they exist! ● Transmitter unit features VGA and USB connectors for the computer / KVM swtich, and the Receiver unit features VGA and PS/2 connectors for the remote keyboard, monitor and mouse ● Simple to install and operate ● No external power needed at transmitter end ● Supports all major OS ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 654518301670 Accessory Type Extender Kit Technology VGA/SVGA INPUT Redundancy - Dual Power Inputs No Bus Powered No POWER AC Adapter (Input: 100-240V, 50/60Hz Output: DC5V/1000mA) PHYSICAL Color Black Rackmountable No Shipping Dimensions (hwd / in.) 6.00 x 4.20 x 6.80 Shipping Dimensions (hwd / cm) 15.24 x 10.67 x 17.27 Shipping Weight (lbs.) 1.30 Shipping Weight (kg) 0.59 ENVIRONMENTAL Storage Temperature Range -40 to 70 C / -40 to 158 F Operating Temperature 0 TO 40 C / 32 to 104 F CONNECTIONS PC/Server Connections VGA; USB 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States FEATURES & SPECIFICATIONS On-Screen Display (OSD) No Driver Required No REMOTE ACCESS Modem Port No WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
0DT23010 价格&库存
很抱歉,暂时无法提供与“0DT23010”相匹配的价格&库存,您可以联系我们找货
