WorkWise Standing Desk Base, Electric
Adjustable-Height, White
MODEL NUMBER: WWBASE-WH
Highlights
Steel construction with white
powder-coated finish
Height adjusts in precise 0.1 in.
increments from 23.5 to 49 in.
Width adjusts to fit all WorkWise
Desk Tops (sold separately)
Create up to 4 convenient
preset positions
Electric motor adjusts height 1.5
in. per second
Package Includes
WWBASE-WH (Base Only)
● Control box
Electric adjustable-height desk base attaches to a desk top (sold separately) to create a more ergonomic
workspace that accommodates sitting, standing and the comfort of different users.
Description
Tripp Lite's WWBASE-WH WorkWise™ Standing Desk Base lets you change the height of your
workspace at the touch of a button. The DC linear actuator motor lifts or lowers a desk top at a speed of
1.5 inches per second. Base height adjusts from 23.5 to 49 inches in precise 0.1-inch increments for
standing and sitting positions perfectly customized for your comfort.
The included control handset mounts beneath a desk top and connects to the motor. It features buttons
for up/down movement and a digital readout that displays height in inches. You can create up to four
Handset
(2) Legs
(2) Feet
(2) Frame ends
(2) Center rails
(2) Side brackets
(8) M6 x 10 screws
(16) M6 x 14 screws
(4) M6 x 35 screws
(7) M5 x 20 wood screws
(2) M5 x 16 wood screws
(10) Cable clips
Hex key, 4 mm
AC power cord w/NEMA 1-15
plug, 10-ft. (3.05 m)
Male-to-female extension cable,
4.3-ft. (1.31 m)
Owner's manual
convenient preset positions, making it easy to instantly adjust the WWBASE-WH to the perfect height for
you, as well as the officemate who shares your workspace. You can also set upper and lower limits if you
prefer a narrower range of heights.
The WWBASE-WH is made of steel with a white powder-coated finish. You can adjust its width between
42.5 and 72 inches to accommodate a variety of desk tops (sold separately). It perfectly matches the
threaded mounting inserts on Tripp Lite WorkWise Desk Tops, including WWTOP48-BK, WWTOP48-ES,
WWTOP60-BKC, WWTOP60-ESC, WWTOP60-WHC, WWTOP72-BK and WWTOP72-ES. Pre-installed
leveling feet keep it stable on uneven floors. Includes a 10-ft. (3.05 m) power cord with two-prong plug that
connects to a 120V AC outlet. Meets ANSI/BIFMA X5.5-2014 standards. Maximum load capacity of 365
lbs (165.6 kgs.). Assembles in less than 30 minutes.
Features
Precise Electric Height Adjustment
● Height adjusts in precise 0.1 in. increments from 23.5 to 49 in.
Powerful DC linear actuator motor moves base legs 1.5 in. per second
1/3
Create up to 4 convenient preset positions for one-touch adjustment
Set programmable upper and lower height limits
10-ft. (3.05 m) power cord with two-prong plug connects to 120V AC outlet
Control Handset
● Digital readout displays height in inches
Up/down buttons adjust height with just a touch
Mounts beneath desk top
Width Adjusts to Fit a Variety of Desk Tops (Sold Separately)
● Width adjusts from 42.5 to 72 in.
Base perfectly matches threaded mounting inserts on Tripp Lite WorkWise Desk Tops, including
WWTOP48-BK, WWTOP48-ES, WWTOP60-BKC, WWTOP60-ESC, WWTOP60-WHC, WWTOP72-BK
and WWTOP72-ES
Durable Construction
● Made of steel with a white powder-coated finish
Pre-installed leveling feet for stability on uneven floors
Maximum load capacity of 365 lbs (165.6 kgs)
Assembles in less than 30 min.
Specifications
OVERVIEW
UPC Code
037332196880
INPUT
Voltage Compatibility (VAC)
120
Input Frequency
60 Hz
PHYSICAL
Color
White
Maximum Weight Capacity (kg)
166
Maximum Weight Capacity (lbs.)
365
Shipping Dimensions (hwd / cm)
23.37 x 26.92 x 105.49
Shipping Dimensions (hwd / in.)
9.20 x 10.60 x 41.53
Shipping Weight (kg)
29.94
Shipping Weight (lbs.)
66.00
Standing Desk Base Color
White
Unit Dimensions (hwd / cm)
59.69-124.46 x 107.95-182.88 x 57.51
2/3
Unit Dimensions (hwd / in.)
23.5-49 x 42.5-72 x 22.64
Unit Weight (kg)
24.95
Unit Weight (lbs.)
55
STANDARDS & COMPLIANCE
Certifications
UL 1004-7, UL 1004-1, UL 508:1999, CSA C22.2 100-04, CSA C22.2 77-95, CSA C22.2 14-10
Approvals
WARRANTY
Product Warranty Period (U.S. &
Canada)
5-year limited warranty
© 2021 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
3/3
很抱歉,暂时无法提供与“WWBASE-WH”相匹配的价格&库存,您可以联系我们找货
