1000 Eaton Boulevard
Cleveland, OH 44122
United States
7-Port USB 3.0 SuperSpeed Hub with BC 1.2
Charging, USB-A
MODEL NUMBER: U360-007
Highlights
Adds webcam, flash drive,
scanner—up to 7 devices—to
your host computer
USB 3.0 ports support
SuperSpeed rates up to 5 Gbps
to ensure fast data transfers
7 USB-A ports support BC 1.2
specifications for charging
mobile devices at 5V 2.4A
Compact unit works with USBenabled operating systems,
including Windows and Mac
Plug-and-play operation with no
software required for easy,
immediate installation
Applications
Adds 7 external USB 3.0 ports to your computer, MacBook or Chromebook for connecting hard drives,
webcams and other USB devices.
Connect up to 7 USB
peripherals, such as an external
hard drive, MP3 player, power
meter and printer, to your
MacBook, Chromebook or
Surface
Add easy-to-access USB ports
to computers stored in a
cabinet, behind furniture or other
hard-to-reach location
Features
USB 3.0 Hub Adds up to 7 USB Devices to Your Computer, MacBook or ChromebookThis 7-port
USB 3.0 hub connects directly to the USB-A port on your computer, laptop, MacBook, Surface or
Chromebook. It allows you to use as many as seven USB devices, such as flash drives, external hard
drives, printers, barcode scanners, webcams, keyboards/mice and power meters, all at the same time.
The hub is backward compatible with previous USB standards, so you can also continue using older
peripherals while getting maximum performance from current devices.
Supports SuperSpeed USB 3.0 to Ensure Fast Data Transfers and Device ChargingThe hub
supports USB 3.0 SuperSpeed data transfer rates up to 5 Gbps, which is 10 times faster than USB 2.0. It
is especially recommended for high-bandwidth USB 3.0 devices, such as security cameras and highresolution webcams. All seven USB-A ports support USB BC (Battery Charging) 1.2 specifications for fastcharging compatible devices at 5V 2.4A.
Plug-and-Play Hub Comes Ready to Connect Right AwayThe plug-and-play U360-007 works with
Windows and Mac computers and requires no software or drivers to download and install. An external
power supply with five-foot cord and NEMA 1-15P plug is included. The hub protects connected devices
against overcurrent. An easy-to-see blue LED indicates the unit is providing power.
Sleek and Slim Housing Designed for Everyday Workspace Use or Connecting on the GoThe
compact unit is designed for convenient positioning within your reach, making USB ports accessible while
not taking up much workspace. It is slim enough to pack in your pocket, purse or laptop bag for use in a
hotel, conference room or airport.
Specifications
OVERVIEW
UPC Code
037332178480
1/4
System Requirements
Compatible with all USBenabled operating systems
(USB 3.0 port needed to
achieve USB 3.0 speeds)
Package Includes
U360-007 7-Port USB 3.0
SuperSpeed Hub
USB 3.0 cable, 3 ft.
External power supply with 5 ft.
(Input: 100–240V, 50/60 Hz,
1.5A Max; Output: 12V 3A)
Cleveland, OH 44122
United States
Product Type
Hub
Host Connector
USB A (MALE)
VIDEO
Number of Monitors Supported
Extended Mode
No
Mirror Mode
No
DATA
Data Ports
(7) USB A (FEMALE)
Data Ports Details
(7) USB-A - USB 3.2 Gen 1 (5 Gbps)
INPUT
Voltage Compatibility (VAC)
100; 110; 120; 125; 127; 200; 208; 220; 230; 240
Bus Powered
No
Product Length (in.)
6.102
Product Length (cm.)
15.5
Product Length (ft.)
0.508
Product Length (m.)
0.155
POWER
Power Source Type
AC Adapter
External Power Supply Plug(s)
NEMA 1-15P North America
External Power Supply Input Specs
(V / Hz / A)
100-240V / 50/60Hz / 1.5A
External Power Supply Output
Specs (V / A)
12V / 3A
External Power Supply Cord Length
(ft.)
5
(m.)
1.5
AC Adapter
Input: 100-240V, 50/60Hz, 0.8A Max / Output: 12V, 2A
DC Barrel Plug
OD: 5.5 x 2.5 x 10mm, Positive Pin, Negative Sleeve
Power Consumption (Watts)
1.4
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Blue (Power)
CHARGING
Charging Ports
USB-A: 5V 1.5A (7.5W); 2.4A Quick Charge
2/4
Cleveland, OH 44122
United States
Charging Ports / Amps
(1) 2A
PHYSICAL
Color
Black
Material of Construction
ABS
Shipping Dimensions (hwd / in.)
5.51 x 5.91 x 3.54
Shipping Dimensions (hwd / cm)
14.00 x 15.01 x 8.99
Shipping Weight (lbs.)
0.79
Shipping Weight (kg)
0.36
Unit Dimensions (hwd / in.)
0.875 x 5.500 x 2.875
Unit Packaging Type
Box
Unit Weight (lbs.)
0.00
Unit Weight (kg)
0.00
ENVIRONMENTAL
Operating Temperature Range
-4 to 158 F (-20 to 70 C)
Storage Temperature Range
-4 to 185 F (-20 to 85 C)
Relative Humidity
20% to 80% RH, Non-Condensing
BTUs
4.8 BTU/Hr
Power Provided to Connected
Device(s)
5V 0.9A (4.5W) Output (USB-A 3.0), 5V 2A (10W) Output (USB 2A Charger)
CONNECTIONS
Number of Ports
7
Side A - Connector 1
USB 3.0 A (MALE)
Side B - Connector 1
(7) USB 3.0 A (FEMALE)
Connector Plating
Nickel
FEATURES & SPECIFICATIONS
Over Current Protection
2.93A
USB Specification
USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps)
Driver Required
No
STANDARDS & COMPLIANCE
External Power Supply Certifications
cUL; RoHS
Product Compliance
RoHS; EAC (Belarus, Kazakhstan, Russia); WEEE; FCC (USA)
WARRANTY & SUPPORT
3/4
Cleveland, OH 44122
United States
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
