10-Port USB 2.0 Hub, White
Highlights
USB 2.0 Hi-Speed Hub, 10Ports
2 Swivel ports for easy
connection of MP3, flash drive
and similar devices
Backward compatible with USB
1.1
Compatible with all major
operating systems
Supports USB 2.0 spec up to
500mA per port
MODEL NUMBER: U222-010-R
Package Includes
Description
Tripp Lite's 10-port USB 2.0 hub is the most versatile and powerful hub on the market. This USB 2.0 hub
allows you to connect up to ten USB devices to a single USB port on your computer. Features two swivel
ports, for easy connection of MP3, flash drive and similar devices. This unit meets or exceeds USB 2.0
Specifications for Hi-Speed data transmission rates up to 480Mbps. Perfect for both the mobile and
desktop user. While the hub will function perfectly in virtually all cases without needing external power, a
multi-voltage AC adapter (100-240V) is included in the event you are connecting power hungry devices.
The U222-010-R is backwards compatible so that it will function with both USB 2.0 and USB 1.1 devices.
Over-current protection safeguards connected equipment from overvoltages. Includes a Hub to Computer
USB Cable - 3ft USB "A" Male to 5-pin Mini-B male.
Features
USB 2.0 Hi-Speed Hub, 10 Ports
Hub to Computer USB Cable - 3ft USB "A" Male to 5-pin Mini-B male
2 Swivel ports for easy connection of MP3, flash drive and similar devices
Backward compatible with USB 1.1
Supports data transfer rates up to 480Mbps
External power not required
Plug-and-play/hot-swappable allows you to add or remove a device at any time
Per-port overcurrent protection
Bus-powered or self-powered
Supports USB 2.0 spec up to 500mA per port
On bus-power, 500mA from the USB 2.0 computer port is shared between the hub ports
The included external power supply provides 2.5A of power, to be shared between the hub ports (up to
500mA per port)
Compact, multi-voltage power supply (100-240V) provided in the event you are connecting power
hungry devices
Compatible with all major operating systems
1/3
U222-010-R 10-Port USB 2.0
Hub
External Power Supply with
NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A; Output:
5V, 2.5A)
Hub to Computer USB Cable 3ft USB "A" Male to 5-pin Mini-B
male
Specifications
OVERVIEW
UPC Code
037332155443
Technology
USB 2.0 (High Speed)
INPUT
Voltage Compatibility (VAC)
100; 110; 120; 127; 200; 208; 220; 230; 240
Bus Powered
No
POWER
AC Adapter
Input: 100-240VAC, 50/60Hz, 0.5A; Output: 5V, 2.5A
External Power Supply Input Specs
(V / Hz / A)
100-240V / 50/60Hz / 0.5A
External Power Supply Output
Specs (V / A)
5V / 2.5A
External Power Supply Cord Length
(ft.)
5
DC Barrel Plug
OD: 3.5 x 1.35 x 9.5mm, Positive Pin, Negative Sleeve
External Power Supply Plug(s)
NEMA 1-15P North America
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Blue (Power)
PHYSICAL
Color
White
Material of Construction
ABS
Shipping Dimensions (hwd / in.)
8.70 x 6.30 x 3.20
Shipping Weight (lbs.)
0.90
Shipping Weight (kg)
0.41
Unit Dimensions (hwd / in.)
0.750 x 6.200 x 3.000
Unit Packaging Type
Clamshell
Unit Weight (lbs.)
0.4
Unit Weight (kg)
0.18
ENVIRONMENTAL
Operating Temperature Range
50 to 104 F (10 to 40 C)
Storage Temperature Range
14 to 176 F (-10 to 80 C)
2/3
Relative Humidity
0% to 90 RH, Non-Condensing
BTUs
8.5 BTU/Hr
CONNECTIONS
Number of Ports
10
Side A - Connector 1
USB MINI-B 5-PIN (FEMALE)
Side B - Connector 1
(10) USB A (FEMALE)
Connector Plating
Nickel
FEATURES & SPECIFICATIONS
USB Specification
USB 2.0 (up to 480 Mbps)
Driver Required
No
STANDARDS & COMPLIANCE
External Power Supply Certifications
FCC; UL; cUL; RoHS
WARRANTY
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
3/3
很抱歉,暂时无法提供与“U222-010-R”相匹配的价格&库存,您可以联系我们找货
