U444-06N-HU-C
U444-06N-HU-C
    TRIPPLITE
    USB 3.1 GEN 1 USB-C TO HDMI EXTE
U444-06N-HU-C 数据手册
USB-C to HDMI Adapter with USB-A Port and PD Charging, HDCP, White MODEL NUMBER: U444-06N-HU-C Highlights ● Supports USB DisplayPort Alternate Mode for transmitting audio/video ● Supports HD video resolutions up to 1920 x 1080 (1080p) @ 60 Hz ● PD Charging port supports power input up to 20V 3A ● Reversible USB-C plug connects in either direction ● USB-A port provides up to 5V/1.5A (7.5W) of fast charging power ● Plug-and-play operation with no software or drivers required System Requirements Adds HDMI, USB-A and USB-C PD ports to the USB-C or Thunderbolt 3 port on your tablet, laptop, notebook, MacBook, Chromebook, smartphone or PC. Features ● Plug-and-play operation with no software, drivers or external power required ● About the size of a credit card for easy carrying in a pocket, purse or laptop bag Transmit Crystal-Clear 1080p Video and Digital Audio to HDMI Display ● Compatible with USB-C or Thunderbolt 3 source devices that support USB DisplayPort Alternate Mode Supports HD video resolutions up to 1920 x 1080 (1080p) @ 60 Hz ● Extends video from your primary display to another ● Duplicates the same video on 2 displays ● Converts a secondary display to your primary display Connect a USB Peripheral ● USB-A port accepts flash drives, mice, keyboards, printers and other USB peripherals ● Supports USB 3.2 Gen 1 data transfer rates up to 5 Gbps ● Backward compatible with USB 2.0 and USB 1.1 ● Provides up to 5V/1.5A (7.5W) of fast-charging power to mobile devices Note: Host must support USB OTG (On-the-Go) Charge a Connected Device ● USB-C PD port connects to wall charger to power and charge the connected PD Charging-compliant USB-C/Thunderbolt 3 device ● Source device with USB-C or Thunderbolt 3 port that supports USB DisplayPort Alternate Mode ● Display device with HDMI input (HDMI port) Package Includes Turn Your Device’s USB-C Port into a Multiport Workstation ● Ideal for transmitting audio/video to a large display, adding a USB peripheral, and powering and charging a PD Charging-compliant mobile device simultaneously ● ● Supports power input up to 20V 3A (60W) Note: USB-C PD port does not support Quick Charge (QC). Built-In Cable with Reversible USB-C Connector ● Fumble-free reversible USB-C plug connects in either direction for quick connection every time Specifications 1/4 ● U444-06N-HU-C USB 3.2 Gen 1 USB-C to HDMI Adapter ● Owner’s manual OVERVIEW UPC Code 037332193933 Technology HDMI VIDEO Video Input USB C (MALE) Video Output HDMI (FEMALE) Number of Monitors Supported 1 Video Ports HDMI (FEMALE) Video Ports Details HDMI 1.3; HDCP 1.3 Supported Resolutions 1280x720 (720p); 1920x1080 (1080p) Max Supported Video Resolution HDMI: 1920 X 1080 (1080P) @ 60HZ Max Supported Color Depth 30-bit Deep Color HDR Support No 3D Video Supported No EDID Support No INPUT Built-In Cable Length (ft.) 0.36 Built-In Cable Length (m) 0.11 Built-In Cable Length (in.) 4.33 Bus Powered Yes Product Length (in.) 6 Product Length (cm.) 15.24 Product Length (ft.) 0.5 Product Length (m.) 0.15 BATTERY Battery Charging (5V/1.5A Port) Yes POWER Power Consumption (Watts) 1.30 USB Power Delivery (PD) Charging Support Yes USB Power Delivery (PD) Charging Specification 2.0 CHARGING 2/4 Number of Charging Ports 2 Total Charging Watts 60 Charging Port Type USB A (FEMALE); USB C (FEMALE) Charging Ports Details USB-A Port supports fast charging up to 5V/1.5A (7.5W)USB-C Port supports PD Charging up to 20V/3A (60W) Charging Ports USB-A: 5V 1.5A (7.5W); USB-C: 60W (20V 3A) Power Delivery (PD 2.0) Charging Ports / Amps 1.5A; 3A PHYSICAL Material of Construction PVC, ABS Color White Cable Jacket Color White Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 3.9mm Wire Gauge (AWG) 28+34 Shipping Dimensions (hwd / cm) 2.01 x 11.99 x 10.01 Shipping Dimensions (hwd / in.) 0.79 x 4.72 x 3.94 Shipping Weight (kg) 0.04 Shipping Weight (lbs.) 0.09 Unit Dimensions (hwd / in.) 0.55 x 1.57 x 2.32 Unit Dimensions (hwd / cm) 1.4 x 4 x 5.9 Unit Packaging Type Box Unit Weight (lbs.) 0.07 Unit Weight (kg) 0.03 ENVIRONMENTAL Operating Temperature Range 32 to 113 F (0 to 45 C) Storage Temperature Range 14 to 158 F (-10 to 70 C) BTUs 4.4 BTU/Hr Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing Power Provided to Connected Device(s) USB-A: 5V/1.5A (7.5W); USB-C: PD Charging 20V/3A (60W) CONNECTIONS Number of Ports 3 Side A - Connector 1 USB C (MALE) 3/4 Side B - Connector 1 HDMI (FEMALE) Side B - Connector 2 USB A (FEMALE) Side B - Connector 3 USB C (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS HDCP Specification 1.3 USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps); USB 3.2 Gen 1 (up to 5 Gbps) Driver Required No UASP Support No Auto MDIX Support No Full Duplex Support No Suspend Mode Support Yes Remote Wakeup Support Yes Multi-Resolution Support No Ethernet Support No STANDARDS & COMPLIANCE Certification & Compliance CE (Europe); RoHS; REACH; FCC (USA) WARRANTY Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 4/4
U444-06N-HU-C 价格&库存
很抱歉,暂时无法提供与“U444-06N-HU-C”相匹配的价格&库存,您可以联系我们找货
U444-06N-HU-C
    • 1+49.56912
