U444-06N-VU-C
U444-06N-VU-C
    TRIPPLITE
    USB 3.1 GEN 1 USB-C TO VGA DISPL
U444-06N-VU-C 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB-C to VGA Adapter with USB-A Port and PD Charging, White MODEL NUMBER: U444-06N-VU-C Highlights ● Supports USB DisplayPort Alternate Mode for transmitting video ● Supports HD video resolutions up to 1920 x 1080 (1080p) @ 60 Hz ● USB-C port supports both data transfer and USB Power Delivery (PD) charging with power input up to 20V 3A (60W) ● Reversible USB-C plug connects in either direction ● USB-A port provides up to 5V/1.5A (7.5W) of fast-charging power. ● Plug-and-play operation with no software or drivers required System Requirements ● Source device with USB-C or Thunderbolt 3 port that supports USB DisplayPort Alternate Mode ● Display device with VGA input (VGA port) Adds VGA, USB-A and USB-C PD ports to the USB-C or Thunderbolt 3 port on your tablet, laptop, notebook, MacBook, Chromebook, smartphone or PC. Description The U444-06N-VU-C USB 3.1 Gen 1 USB-C to VGA Adapter expands the potential of your tablet, laptop, Chromebook, MacBook, smartphone or PC’s USB-C or Thunderbolt 3 port. It’s ideal for transmitting 1080p video to a large display, adding a thumb drive or other USB peripheral, and powering and charging a PD Charging-compliant mobile device—all at the same time. With a source device that also supports USB DisplayPort Alternate Mode, you can extend video from your primary display to another, duplicate the same video on both displays or change the second display to your primary. The plug-and-play U444-06N-VU-C requires no software, drivers or external power. Connect the reversible USB-C plug to your source device’s USB-C or Thunderbolt 3 port. The fumble-free USB-C plug connects in either direction to ensure fast, easy connection every time. To send HD video to a VGA television, projector or monitor, connect the VGA port to the display using a VGA cable (sold separately). The VGA port supports HD video resolutions up to 1920 x 1080 (1080p) at 60 Hz. The USB-A port accepts USB peripherals, such as a flash drive, mouse, keyboard or printer. It supports fast USB 3.1 Gen 1 data transfer rates up to 5 Gbps and is backward compatible with previous USB generations. The port provides up to 5V/1.5A (7.5W) for fast charging of mobile devices. Along with data transfer, the USB-C Power Delivery (PD) port provides power and charging to the PD Charging-compliant device (such as a MacBook or Chromebook) the U444-06N-VU-C is connected to. Connect the device’s AC wall charger to the USB-C PD port, which supports power input up to 20V 3A (60W). Features Turn Your Device’s USB-C Port into a Multiport Workstation ● Ideal for transmitting video to a large display, adding a USB peripheral, and powering and charging a PD Charging-compliant mobile device simultaneously ● Plug-and-play operation with no software, drivers or external power required ● About the size of a credit card for easy carrying in a pocket, purse or laptop bag Transmit Crystal-Clear 1080p Video to VGA Display ● Compatible with USB-C or Thunderbolt 3 source devices that support USB DisplayPort Alternate Mode ● Supports HD video resolutions up to 1920 x 1080 (1080p) @ 60 Hz ● Extends video from your primary display to another 1/4 Package Includes ● U444-06N-VU-C USB 3.1 Gen 1 USB-C to VGA Adapter ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Duplicates the same video on 2 displays ● Converts a secondary display to your primary display Connect a USB Peripheral ● USB-A port accepts flash drives, mice, keyboards, printers and other USB peripherals ● Supports USB 3.1 Gen 1 data transfer rates up to 5 Gbps ● Backward compatible with USB 2.0 and USB 1.1 ● Provides up to 5V/1.5A (7.5W) of fast-charging power. Note: Host must support USB OTG (On-the-Go) Charge a Connected Device ● USB-C PD port connects to wall charger to power and charge the connected PD Charging-compliant USB-C/Thunderbolt 3 device ● Supports power input up to 20V 3A (60W) ● USB-C port also supports data transfer Note: USB-C PD port does not support Quick Charge (QC). Built-In Cable with Reversible USB-C Connector ● Fumble-free reversible USB-C plug connects in either direction for quick connection every time Specifications OVERVIEW UPC Code 037332193711 Technology VGA/SVGA Host Connector USB C (MALE) VIDEO Max Supported Video Resolution VGA: 1920 X 1080 (1080P) @ 60HZ INPUT Bus Powered Yes Product Length (in.) 6 Product Length (cm.) 15.24 Product Length (ft.) 0.5 Product Length (m.) 0.15 BATTERY Battery Charging (5V/1.5A Port) Yes POWER Power Consumption (Watts) 1.8 USB Power Delivery (PD) Charging Support Yes 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States USB Power Delivery (PD) Charging Specification 2.0 CHARGING Total Charging Watts 60 Charging Ports / Amps 1.5A; 3A PHYSICAL Color White Material of Construction PVC, ABS Cable Jacket Rating VW-1 Shipping Dimensions (hwd / in.) 0.90 x 3.90 x 5.60 Shipping Weight (lbs.) 0.19 Unit Dimensions (hwd / in.) 0.570 x 3.100 x 1.600 Unit Packaging Type Box Unit Weight (lbs.) 0.09 Unit Weight (kg) 0.04 ENVIRONMENTAL Operating Temperature Range 32 to 113 F (0 to 45 C) Storage Temperature Range 14 to 158 F (-10 to 70 C) BTUs 6.1 BTU/Hr Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing Power Provided to Connected Device(s) 5V 0.9A (4.5W) Output (USB-A), Up to 20V 3A (60W) Input (USB-C) CONNECTIONS Number of Ports 3 Side A - Connector 1 USB C (MALE) Side B - Connector 1 HD15 (FEMALE) Side B - Connector 2 USB 3.0 A (FEMALE) Side B - Connector 3 USB C (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps) Driver Required No 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States UASP Support No Auto MDIX Support No Full Duplex Support No Suspend Mode Support No Remote Wakeup Support No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA); UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
U444-06N-VU-C 价格&库存
很抱歉,暂时无法提供与“U444-06N-VU-C”相匹配的价格&库存,您可以联系我们找货
U444-06N-VU-C
    • 1+167.62761
