1000 Eaton Boulevard
Cleveland, OH 44122
United States
USB-C to HDMI 4K Adapter with USB-A Port and
PD Charging, HDCP, White
MODEL NUMBER: U444-06N-H4U-C
Highlights
Supports USB DisplayPort
Alternate Mode for transmitting
audio/video
Supports UHD video resolutions
up to 3840 x 2160 (4K x 2K) @
30 Hz
USB-C port supports both data
transfer and USB Power
Delivery (PD) charging with
power input up to 20V 3A (60W)
USB-A port provides up to
5V/1.5A (7.5W) of fast-charging
power
Reversible USB-C plug
connects in either direction
Plug-and-play operation with no
software or drivers required
Applications
Adds HDMI, USB-A and USB-C PD ports to the USB-C port on your tablet, laptop, notebook, MacBook,
Chromebook, smartphone or PC.
Transmit 4K video from a USBC source to an HDMI display
Charge the host device with up
to 60W (20V/3A) of power
Connect USB peripherals
Features
Turn Your Device’s USB-C Port into a Multiport Workstation
● Ideal for transmitting audio/video to a large display, adding a USB peripheral, and powering and
charging a PD Charging-compliant mobile device simultaneously
Plug-and-play operation with no software, drivers or external power required
About the size of a credit card for easy carrying in a pocket, purse or laptop bag
System Requirements
Source device with USB-C port
that supports USB DisplayPort
Alternate Mode
Display device with HDMI input
(HDMI port)
Transmit Crystal-Clear 4K Video and Digital Audio to HDMI Display
● Compatible with USB-C source devices that support USB DisplayPort Alternate Mode
Supports HD video resolutions up to 3840 x 2160 (4K x 2K) @ 30 Hz
Extends video from your primary display to another
Duplicates the same video on 2 displays
Converts a secondary display to your primary display
Package Includes
Connect a USB Peripheral
● USB-A port accepts flash drives, mice, keyboards, printers and other USB peripherals
Supports USB 3.1 Gen 1 data transfer rates up to 5 Gbps
Backward compatible with USB 2.0 and USB 1.1
Provides up to 5V/1.5A (7.5W) of fast-charging power to mobile devices
Note: Host must support USB OTG (On-the-Go)
Charge a Connected Device
● USB-C PD port connects to wall charger to power and charge the connected PD Charging-compliant
USB-C device
Supports power input up to 20V 3A (60W)
USB-C port also supports data transfer
Note: USB-C PD port does not support Quick Charge (QC).
Built-In Cable with Reversible USB-C Connector
● Fumble-free reversible USB-C plug connects in either direction for quick connection every time
1/4
U444-06N-H4U-C USB 3.1 Gen
1 USB-C to HDMI 4K Adapter
Owner’s manual
Cleveland, OH 44122
United States
Specifications
OVERVIEW
UPC Code
037332193957
Product Type
USB-C Multiport Adapter
Technology
HDMI
Host Connector
USB C (MALE)
VIDEO
Video Input
USB C (MALE)
Video Output
HDMI (FEMALE)
Number of Monitors Supported
1
Video Ports
HDMI (FEMALE)
Video Ports Details
HDMI 1.4; HDCP 1.4
Max Supported Video Resolution
HDMI: 3840 X 2160 (4K X 2K) @ 30HZ
Extended Mode
Yes
Extended Mode Details
Extend a 4K/30 Hz video signal to an HDMI display
Mirror Mode
Yes
Mirror Mode Details
Mirror a 4K/30 Hz video signal to an HDMI display
HDR Support
No
3D Video Supported
Yes
Chroma Sub Sampling
4:4:4
DATA
Data Ports
USB A (FEMALE); USB C (FEMALE)
Data Ports Details
USB-A - USB 3.2 Gen 1 (5 Gbps); USB-C - USB 3.2 Gen 1 (5 Gbps)
INPUT
Built-In Cable Length (ft.)
0.36
Built-In Cable Length (in.)
4.33
Bus Powered
Yes
BATTERY
Battery Charging (5V/1.5A Port)
Yes
POWER
2/4
Cleveland, OH 44122
United States
USB Power Delivery (PD) Charging
Support
Yes
Specification
2.0
CHARGING
Number of Charging Ports
2
Total Charging Amps
3
Total Charging Watts
60
Charging Method
USB
Charging Port Type
Charging Ports Details
Provides up to 60W (20V/3A) of power to the host device via the PD Charging portCharge a peripheral device with
up to 7.5W (5V/1.5A) of power via the USB-A port
Charging Ports
USB-A: 5V 1.5A (7.5W); USB-C: 60W (20V 3A) Power Delivery (PD 2.0)
Charging Ports / Amps
1.5A; 3A
PHYSICAL
Color
White
Material of Construction
PVC, ABS
Shipping Weight (lbs.)
0.50
Shipping Weight (kg)
0.23
Unit Dimensions (hwd / in.)
0.550 x 1.570 x 2.320
Unit Dimensions (hwd / cm)
1.4 x 4 x 5.9
Unit Packaging Type
Box
Unit Weight (lbs.)
0.07
Unit Weight (kg)
0.03
ENVIRONMENTAL
Operating Temperature Range
32 to 113 F (0 to 45 C)
Storage Temperature Range
14 to 158 F (-10 to 70 C)
Operating Humidity Range
10% to 85% RH
Storage Humidity Range
5% to 90% RH
Power Provided to Connected
Device(s)
7.5W (5V/1.5A) USB-A Port; 60W (20V/3A) USB-C PD Charging
CONNECTIONS
Number of Ports
3
Side A - Connector 1
USB C (MALE)
Side B - Connector 1
HDMI (FEMALE)
3/4
Cleveland, OH 44122
United States
Side B - Connector 2
USB A (FEMALE)
Side B - Connector 3
USB C (FEMALE)
Connector Plating
Nickel
FEATURES & SPECIFICATIONS
HDCP Specification
1.4
USB Hub Ports
Yes
Number of USB Hub Ports
2
USB Specification
USB 3.2 Gen 1 (up to 5 Gbps)
Driver Required
No
Quick Charge Compliant
No
STANDARDS & COMPLIANCE
Product Certifications
EN 55024; EN 55032
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA); UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“U444-06N-H4U-C”相匹配的价格&库存,您可以联系我们找货
