U360-412
U360-412
    TRIPPLITE
    USB 3.0 CHARGING HUB 2X USB
U360-412 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 6-Port USB 3.0 SuperSpeed Charging Hub - 2x USB 3.0, 4x USB 2.0, 1 charging port MODEL NUMBER: U360-412 Highlights ● USB 3.0 Hub with two USB 3.0 SuperSpeed ports and four USB 2.0 High-Speed ports ● One dedicated port for Tablet charging ( 5V, 2A ) ● USB 3.0 ports support up to 900mA per port ● USB 2.0 ports support up to 500mA per port ● Plug-and-Play - no software or drivers required System Requirements ● USB 3.0 or 2.0 computer ● USB 3.0 or 2.0 peripherals Package Includes Charge an iPad or tablet via a USB hub. Description Tripp Lite's U360-412 USB 3.0 Charging Hub plugs into a computer's USB 3.0 port and provides two USB 3.0 SuperSpeed peripheral ports, four USB 2.0 High-Speed peripheral ports, and one charging port for charging tablets such as an iPad. Two of the USB 2.0 ports have convenient top plugging, for thumb drive access. Dedicated 2AMP charging port supplies the extra amperage needed to charge tablets, which most USB hubs do not include. Plug-and-Play... no software or drivers required. Automatically switches to the highest speed supported by the peripheral. Windows (compatible with Windows 10) and Mac compatible. Features ● USB 3.0 ports support 5Gbps transfer speeds when plugged into a USB 3.0 computer and peripheral ● USB 2.0 ports support High-Speed 480Mbps speeds ● Charging port provides 5V,2A for tablet ( iPad ) full battery charging ● USB 3.0 ports support up to 900mA per port ● USB 2.0 ports support up to 500mA per port ● The included external power supply provides 4A of power, to be shared between the hub ports (up to 2A for iPad charging port, up to 900mA per USB 3.0 port, up to 500mA per USB 2.0 port) ● Top mount ports for Thumb Drive connections Plug-and-Play ● No software or drivers required ● Windows (compatible with Windows 10) and Mac compatible ● Overcurrent protection ● LED power indicator light Specifications OVERVIEW 1/4 ● USB 7-port Hub ● USB 3.0 A-B cable, 3ft ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.9A; Output: 5V, 4A) 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332173560 Product Type Hub Host Connector USB A (MALE) VIDEO Number of Monitors Supported 0 Extended Mode No Mirror Mode No DATA Data Ports (6) USB A (FEMALE) Data Ports Details (2) USB-A - USB 3.2 Gen 1 (5 Gbps); (4) USB-A - USB 2.0 INPUT Voltage Compatibility (VAC) 100; 110; 120; 125; 127; 200; 208; 220; 230; 240 POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.6A External Power Supply Output Specs (V / A) 5V / 4A External Power Supply Cord Length (ft.) 5 External Power Supply Cord Length (m.) 1.5 AC Adapter Input: 100-240V, 50/60Hz, 0.9A; Output: 5V, 4A DC Barrel Plug OD: 3.5 x 1.35 x 10mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 1.6 USER INTERFACE, ALERTS & CONTROLS LED Indicators Green - Power CHARGING Charging Ports Details Dedicated charging port Charging Ports USB-A: 2A Charging Ports / Amps (1) 2A PHYSICAL 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Color Black Material of Construction ABS Shipping Dimensions (hwd / in.) 3.00 x 4.60 x 5.50 Shipping Dimensions (hwd / cm) 7.62 x 11.68 x 13.97 Shipping Weight (lbs.) 0.90 Shipping Weight (kg) 0.41 Unit Dimensions (hwd / in.) 0.900 x 4.000 x 2.400 Unit Packaging Type Box Unit Weight (lbs.) 0.18 Unit Weight (kg) 0.08 ENVIRONMENTAL Operating Temperature Range -4 to 158 °F (-20 to 70 °C) Storage Temperature Range -4 to 185 °F (-20 to 85 °C) Relative Humidity 20% to 80% RH, Non-Condensing BTUs 5.5 BTU/Hr Power Provided to Connected Device(s) 5V 0.5A (2.5W) Output (USB-A 2.0), 5V 0.9A (4.5W) Output (USB-A 3.0), 5V 2A (10W) Output (USB 2A Charger) CONNECTIONS Number of Ports 7 Side A - Connector 1 USB 3.0 A (MALE) Side B - Connector 1 (2) USB 3.0 A (FEMALE) Side B - Connector 2 (5) USB A (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS USB Specification USB 2.0 (up to 480 Mbps); USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps) Driver Required No STANDARDS & COMPLIANCE External Power Supply Certifications FCC; UL; cUL; RoHS Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
U360-412 价格&库存
很抱歉,暂时无法提供与“U360-412”相匹配的价格&库存,您可以联系我们找货
