U444-06N-DGU-C
U444-06N-DGU-C
    TRIPPLITE
    USB 3.1 GEN 1 USB-C TO DVI EXTER
U444-06N-DGU-C 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB-C Multiport Adapter, DVI, USB-A Port, Gbe and PD Charging, White MODEL NUMBER: U444-06N-DGU-C Highlights ● Supports USB DisplayPort Alternate Mode for transmitting video ● Supports DVI video resolutions up to 1920 x 1080 (1080p) @ 60 Hz ● Supports true 10/100/1000 Mbps Ethernet network speeds ● PD Charging port supports power input up to 20V 3A ● BC 1.2-compliant USB-A port provides up to 1.5A of fastcharging power ● Plug-and-play operation with no software or drivers required Applications Mini docking station adds DVI, USB-A, USB-C PD charging and Gigabit Ethernet ports to the USB-C or Thunderbolt 3 port on your tablet, laptop, notebook, MacBook, Chromebook, smartphone or PC. ● Establish a connection with a Gigabit Ethernet network via the RJ45 port ● Charge the host computer with up to 20V/3A (60W) of power ● Connect a USB peripheral or charge a connected device via the USB-A port ● Connect to a DVI monitor via the USB-C port on your computer, laptop or tablet Features Mini Docking Station Turns Your Device’s USB-C Port into a Multiport WorkstationIdeal for transmitting video to a large display, adding a USB peripheral, powering and charging a PD Chargingcompliant mobile device, and connecting to a Gigabit Ethernet network simultaneouslyPlug-and-play operation with no software, drivers or external power requiredAbout the size of a credit card for easy carrying in a pocket, purse or laptop bag Transmit Crystal-Clear 1080p Video to DVI DisplayCompatible with USB-C or Thunderbolt 3 source devices that support USB DisplayPort Alternate ModeSupports DVI single-link video resolutions up to 1920 x 1080 (1080p) @ 60 HzSupports DVI digital transfer rates up to 6.75 Gbps (2.25 Gbps per channel)Extends video from your primary display to anotherDuplicates the same video on 2 displaysConverts a secondary display to your primary display Connect a USB PeripheralUSB-A port accepts flash drives, mice, keyboards, printers and other USB peripheralsSupports USB 3.1 Gen 1 data transfer rates up to 5 GbpsBackward compatible with USB 2.0 and USB 1.1BC 1.2-compliant port provides up to 1.5A of fast-charging power to mobile devicesNote: Host must support USB OTG (On-the-Go) Charge a Connected DeviceUSB-C PD port connects to wall charger to power and charge the connected PD Charging-compliant USB-C/Thunderbolt 3 deviceSupports power input up to 20V 3A (60W)Note: USB-C PD port does not support Quick Charge (QC). Access a Wired Gigabit Ethernet NetworkRJ45 port supports true 10/100/1000 Mbps network speedsRecommended for a faster wired network connection or getting online when no Wi-Fi is available Built-In Cable with Reversible USB-C ConnectorFumble-free reversible USB-C plug connects in either direction for quick connection every time Specifications 1/4 System Requirements ● Source device with USB-C or Thunderbolt 3 port that supports USB DisplayPort Alternate Mode ● Display device with DVI input (DVI port) Package Includes ● U444-06N-DGU-C USB 3.1 Gen 1 USB-C to DVI Adapter ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332193919 Product Type USB-C to DVI Adapter Technology Cat5/5e; Cat6; DVI Host Connector USB C (MALE) VIDEO Video Input USB C (MALE) Video Output DVI-I DUAL LINK (FEMALE) Number of Monitors Supported 1 Video Ports DVI-I DUAL LINK (FEMALE) Video Ports Details HDCP 1.3 Resolutions Supported 1080P @ 60Hz (1920 x 1200) Supported Resolutions 1920x1080 (1080p) Max Supported Video Resolution DVI: 1920 X 1080 (1080P) @ 60HZ Extended Mode No Mirror Mode No 3D Video Supported No AUDIO Audio Specification Pass-through audio DATA Data Ports USB A (FEMALE) Data Ports Details USB-A - USB 3.2 Gen 1 (5 Gbps) NETWORK Network Ports RJ45 (FEMALE) INPUT Built-In Cable Length (ft.) 0.36 Built-In Cable Length (m) 11.0 Built-In Cable Length (in.) 4.33 Bus Powered Yes Product Length (in.) 6 Product Length (cm.) 15.24 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Length (ft.) 0.5 Product Length (m.) 0.15 BATTERY Battery Charging (5V/1.5A Port) Yes POWER Power Consumption (Watts) 2.40 USB Power Delivery (PD) Charging Support Yes USB Power Delivery (PD) Charging Specification 2.0 USER INTERFACE, ALERTS & CONTROLS LED Indicators Green = Connected, Orange = Activity CHARGING Total Charging Watts 60 Charging Ports Details Charge the host PC with up to 20V/3A (60W) of power Charging Ports USB-C: 60W (20V 3A) Power Delivery (PD 2.0); USB-A: 5V 1.5A (7.5W) Charging Ports / Amps 1.5A; 3A PHYSICAL Color White Material of Construction PVC, ABS Cable Jacket Rating VW-1 Shipping Dimensions (hwd / in.) 0.91 x 3.99 x 5.51 Shipping Dimensions (hwd / cm) 2.31 x 10.13 x 14.00 Shipping Weight (lbs.) 0.11 Shipping Weight (kg) 0.05 Unit Dimensions (hwd / in.) 0.650 x 3.800 x 1.600 Unit Packaging Type Box Unit Weight (lbs.) 0.09 Unit Weight (kg) 0.04 ENVIRONMENTAL Operating Temperature Range 32 to 113 F (0 to 45 C) Storage Temperature Range 14 to 158 F (-10 to 70 C) BTUs 8.3 BTU/Hr 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing Power Provided to Connected Device(s) 5V 1.5A (7.5W) Output (USB-A), Up to 20V 3A (60W) Input (USB-C) CONNECTIONS Number of Ports 4 Side A - Connector 1 USB C (MALE) Side B - Connector 1 DVI-I DUAL LINK (FEMALE) Side B - Connector 2 USB 3.0 A (FEMALE) Side B - Connector 3 RJ45 (FEMALE) Side B - Connector 4 USB C (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS HDCP Specification 1.3 USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps) Driver Required No UASP Support No Auto MDIX Support No Full Duplex Support No Suspend Mode Support No Remote Wakeup Support No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
U444-06N-DGU-C 价格&库存
很抱歉,暂时无法提供与“U444-06N-DGU-C”相匹配的价格&库存,您可以联系我们找货
