0.5mm and 1mm Pitch FPC/FFC Connectors
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
FH12 Series
■Features
1. Rotating one-touch ZIF mechanism
The one-touch rotating ZIF mechanism is easier
to operate and works with a light force.
q
2. Clear tactile click
A clear tactile click is delivered upon the
successful completion of the mating process
3. Supports high density mounting
The FH12’s one-touch ZIF system requires less
space than a slide locking connector and can be
mounted in the center of the PCB.
4. Top & Bottom Contact and Vertical
Mount type
w
There are three connection types available : top
contact, bottom contact and a Vertical mount.
5. 1mm pitch product
Contact surface of the FPC+FFC
In addition to the 0.5mm pitch connector, we also
offer a 1mm pitch connector.
6. Reinforced actuator
The FH12S version in 30, 40, 45, 50, and 53 pin
counts are offered with a reinforced actuator that
provides an extra measure of security against
actuator breakage.
e
2017.1③
1
FH12 Series●0.5mm and 1mm Pitch Connectors For FPC/FFC
■Product Specifications
Current rating : 0.5A DC(Note 1) Operating Temperature Range : _40 to +85ç (Note 2) Storage Temperature Range : _10 to +50ç (Note 3)
Voltage rating : 50V AC Operating Humidity Range : Relative humidity, 90% max. Storage Humidity Range : Relative humidity, 90% max.
Rating
(Not dewed)
t=0.3±0.05 Gold plated
Adaptive FPC/FFC contact specifications
Item
1. Insulation resistance
2. Withstanding voltage
3. Contact resistance
Specification
500Mø minimum
No flashover or insulation breakdown.
50mø maximum
4. Durability (Insertion/withdrawal) Contact resistance : 50mø maximum
No damage, cracks, or parts dislocation.
No electrical discontinuity of 1μs or more
5. Vibration
Contact resistance : 50mø maximum.
6. Shock
7. Humidity(Steady state) Insulation resistance : 50Mø minimum.
8. Temperature Cycle
(Not dewed)
Conditions
100V DC
150V AC/1 minute
1mA
20 cycles
Frequency : 10 to 55Hz, single amplitude of 0.75mm,
for 10 cycles in 3 axial directions
Acceleration of 981m/s2, 6ms duaration,
sine half-wave waveform, 3 cycles in each of the 3 axis
96 hours at 40ç and humidity of 90% to 95%
Temperature : -40ç / 15 to 35ç / 85ç / 15 to 35ç,
Time: 30 / 2 to 3 / 30 / 2 to 3(minutes)
5 cycles
No deformation of
Reflow : At the recommended temperature profile
Manual soldering : 350±10ç for 5 seconds
components affecting performance.
Note 1 : When passing the current through all of the contacts,use 70% of the current rating.
Note 2 : Includes temperature rise caused by current flow.
Note 3 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature
Range and Humidity range covers nonconducting condition of installed connectors in storage, shipment or during
transportation.
9.Resistance to Soldering heat
■Materials / Finish
Part
Material
Finish
Polyamide, LCP(60 pos.)
Insulator
Remarks
Color : Beige
PPS
UL94V-0
Color : Dark brown
Contact
Phosphor bronze
Metal Fittings
Brass
Gold plated
Tin plated
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
FH 12 A - 10 (4)
q
w
e
r
t
q Series Name : FH
w Series No.
: 12
e Blank : standard type
A : Top contact type
S : Type with strengthed flip-lock actuator
r Standard type : Number of contacts
Eccentric type : Number of contacts in 0.5mm housing
t Standard type : Blank
2
S A - 0.5 SH (*
y
u
i
o
!0
y Contact alignment : Single
u Eccentric direction :
A : Eccentric type
i Contacts Pitch : 0.5mm, 1mm
o Contact type
SH : SMT horizontal mounting type
SVA : SMT vertical mounting type
!0 Plating specification
(54)
: Selective gold plated
(55)
: Gold plated
(1)(98) : Gold plated 500 pieces/reel
■Series Configuration
Pitch
Bottom Contact Type
Top Contact Type
Vertical mounting Type
FPC/FFC conductive
surface(bottom side)
FPC/FFC conductive
surface
0.5mm
FH12- ** S-0.5SH
P.4
Number of contacts 6, 8, 10, 11, 12, 13,
14, 15, 16, 17, 18, 19,
20, 22, 24, 25, 26, 28,
30, 32, 33, 34, 35, 36,
40, 45, 50, 53
Type with Strengthened Lock Lever
FH12S- ** S-0.5SH
P.5
Number of contacts 30, 40, 45, 50, 53
FH12A- ** S-0.5SH
P.6
Number of contacts 10, 12 ,15, 16, 18, 20,
22, 24, 26, 28, 29, 30,
32, 33, 34, 36, 40, 42,
45, 50
FH12- ** S-0.5SVA
P.7
Number of contacts 6, 10, 12, 13, 15, 16,
17, 18, 20, 22, 24, 26,
30, 32, 33, 34, 36, 40,
45, 49, 50, 60
FPC/FFC conductive
1mm
FH12- ** S-1SH P.8
Eccentric FH12- ** (**) SA-1SH
Standard
Standard
Number of contacts 5, 6, 7, 8, 9, 11,
12,16,17,22,26
Eccentric
FH12- ** S-1SVA
P.9
Number of contacts 6, 7, 8, 16, 20, 22,
Number of contacts 4, 6, 8, 10, 11,
14, 19, 24
24
3
■0.5mm Pitch Bottom Contact Type
A
1.2
2
0.8
0.5
( 0.2)
polarizing mark indicator
Number of Contacts indicator
5
2
1.85
B
C
D
Note 1
Note 2
Note 3
Note 4
Note 5
: The coplanarity of each terminal lead within specified dimension is 0.1mm Max.
: Packaged on tape and reel only. Check packaging specification.
: Slight variations in color of the plastic compounds do not affect form, fit or function of the connector.
: After reflow, the terminal plating may change color, however this does not represent a quality issue.
: If there is no problem with the connector height, we recommend the type with the strengthened Fliplock actuator (FH12S-*S-0.5SH). Standard type connector height : 2mm Connector height of type with
strengthened Flip-lock actuator : 2.4mm
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
D
FH12-6S-0.5SH(**)
586-0582-5 **
6
2.5
06.1
7.1
3.57
FH12-8S-0.5SH(**)
586-0744-5 **
8
3.5
07.1
8.1
4.57
FH12-10S-0.5SH(**)
586-0522-3 **
10
4.5
08.1
9.1
5.57
FH12-11S-0.5SH(**)
586-0600-5 **
11
5.0
08.6
9.6
6.07
FH12-12S-0.5SH(**)
586-0704-0 **
12
5.5
09.1
10.1
6.57
FH12-13S-0.5SH(**)
586-0549-0 **
13
6.0
09.6
10.6
7.07
FH12-14S-0.5SH(**)
586-0533-0 **
14
6.5
10.1
11.1
7.57
FH12-15S-0.5SH(**)
586-0523-6 **
15
7.0
10.6
11.6
8.07
FH12-16S-0.5SH(**)
586-0531-4 **
16
7.5
11.1
12.1
8.57
FH12-17S-0.5SH(**)
586-0606-1 **
17
8.0
11.6
12.6
9.07
FH12-18S-0.5SH(**)
586-0530-1 **
18
8.5
12.1
13.1
9.57
FH12-19S-0.5SH(**)
586-0534-2 **
19
9.0
12.6
13.6
10.07
FH12-20S-0.5SH(**)
586-0524-9 **
13.1
14.1
10.57
FH12-22S-0.5SH(**)
586-0532-7 **
22
10.5
14.1
15.1
11.57
FH12-24S-0.5SH(**)
586-0521-0 **
24
11.5
15.1
16.1
12.57
FH12-25S-0.5SH(**)
586-0692-3 **
25
12.0
15.6
16.6
13.07
FH12-26S-0.5SH(**)
586-0576-2 **
26
12.5
16.1
17.1
13.57
FH12-28S-0.5SH(**)
586-0612-4 **
28
13.5
17.1
18.1
14.57
FH12-30S-0.5SH(**)
586-0525-1 **
30
14.5
18.1
19.1
15.57
FH12-32S-0.5SH(**)
586-0681-7 **
32
15.5
19.1
20.1
16.57
FH12-33S-0.5SH(**)
586-0520-8 **
33
16.0
19.6
20.6
17.07
FH12-34S-0.5SH(**)
586-0617-8 **
34
16.5
20.1
21.1
17.57
FH12-35S-0.5SH(**)
586-0740-4 **
35
17.0
20.6
21.6
18.07
FH12-36S-0.5SH(**)
586-0526-4 **
36
17.5
21.1
22.1
18.57
Note 5
FH12-40S-0.5SH(**)
586-0527-7 **
40
19.5
23.1
24.1
20.57
Note 5
FH12-45S-0.5SH(**)
586-0528-0 **
45
22.0
25.6
26.6
23.07
Note 5
FH12-50S-0.5SH(**)
586-0529-2 **
50
24.5
28.1
29.1
25.57
Note 5
Note 5
4
4.6
5.6
53
26.0
30.6
29.6
27.07
FH12-53S-0.5SH(**) 586-0595-7 **
Note 1 : Embossed tape reel packaging (2,000 pcs/reel, 500 pcs/reel). Order by number of reels.
■0.5mm Pitch Bottom Contact Type with Strengthened Flip-lock Actuator
1.2
2
0.8
A
0.5
(0.2)
2
2.4
2.25
B
C
D
4.6
5.6
Note 1 : The coplanarity of each terminal lead within specified dimension is 0.1mm Max.
Note 2 : Packaged on tape and reel only. Check packaging specification.
Note 3 : Slight variations in color of the plastic compounds do not affect form, fit or function of the connector.
Note 4 : After reflow, the terminal plating may change color, however this does not represent a quality issue.
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
D
FH12S-30S-0.5SH(**)
586-0667-6 **
30
14.5
18.1
19.1
15.57
FH12S-40S-0.5SH(**)
586-0640-0 **
40
19.5
23.1
24.1
20.57
FH12S-45S-0.5SH(**)
586-0665-0 **
45
22.0
25.6
26.6
23.07
FH12S-50S-0.5SH(**)
586-0642-5 **
50
24.5
28.1
29.1
25.57
FH12S-53S-0.5SH(**)
586-0691-0 **
53
26.0
29.6
30.6
27.07
5
■0.5mm Pitch Top Contact Type
A
B
C
(1.85 )
0.5
( 0.2)
6.2
2
(3.6)
polarizing mark indicator D
( 0.45 )
0.8
E
2.2
0.85
1.45
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
D
E
FH12A-10S-0.5SH(**)
586-0550-9 **
10
9.1
8.35
4.5
9.5
5.57
FH12A-12S-0.5SH(**)
586-0696-4 **
12
10.1
9.35
5.5
10.5
6.57
FH12A-15S-0.5SH(**)
586-0551-1 **
15
11.6
10.85
7.0
12.0
8.07
FH12A-16S-0.5SH(**)
586-0552-4 **
16
12.1
11.35
7.5
12.5
8.57
FH12A-18S-0.5SH(**)
586-0553-7 **
18
13.1
12.35
8.5
13.5
9.57
FH12A-20S-0.5SH(**)
586-0554-0 **
13.35
9.5
14.5
10.57
FH12A-22S-0.5SH(**)
586-0686-0 **
22
15.1
14.35
10.5
15.5
11.57
FH12A-24S-0.5SH(**)
586-0555-2 **
24
16.1
15.35
11.5
16.5
12.57
FH12A-26S-0.5SH(**)
586-0663-5 **
26
17.1
16.35
12.5
17.5
13.57
FH12A-28S-0.5SH(**)
586-0725-0 **
28
18.1
17.35
13.5
18.5
14.57
FH12A-29S-0.5SH(**)
586-0585-3 **
29
18.6
17.85
14.0
19.0
15.07
FH12A-30S-0.5SH(**)
586-0556-5 **
30
19.1
18.35
14.5
19.5
15.57
FH12A-32S-0.5SH(**)
586-0687-3 **
32
20.1
19.35
15.5
20.5
16.57
FH12A-33S-0.5SH(**)
586-0570-6 **
33
20.6
19.85
16.0
21.0
17.07
FH12A-34S-0.5SH(**)
586-0670-0 **
34
21.1
20.35
16.5
21.5
17.57
FH12A-36S-0.5SH(**)
586-0662-2 **
36
22.1
21.35
17.5
22.5
18.57
FH12A-40S-0.5SH(**)
586-0557-8 **
40
24.1
23.35
19.5
24.5
20.57
FH12A-42S-0.5SH(**)
586-0698-0 **
42
25.1
24.35
20.5
25.5
21.57
FH12A-45S-0.5SH(**)
586-0558-0 **
45
26.6
25.85
22.0
27.0
23.07
FH12A-50S-0.5SH(**)
586-0559-3 **
50
29.1
28.35
24.5
29.5
25.57
Note 1 : Embossed tape reel packaging (2,000 pcs/reel).
6
■0.5mm Pitch Vertical mounting Type
( 0.2 )
Mated Cross-sectional Diagram
( 0.15)
FPC/FFC Contact Surface
(1.4 )
( 2.15 )
1
1
0.5
F
2.5
( 4.25 )
(1.75 )
3.6
5.5
( 4.85 )
A
B
0.5
0.5
C
D
E
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
D
E
F
FH12-6S-0.5SVA(54)
FH12-10S-0.5SVA(54)
586-0756-4 54
6
6.4
4.9
2.5
4.5
6.2
4
586-0806-0 54
10
8.4
6.9
4.5
6.5
8.2
4
FH12-12S-0.5SVA(54)
586-0757-7 54
12
9.4
7.9
5.5
7.5
9.2
4
FH12-13S-0.5SVA(54)
586-0807-3 54
13
9.9
8.4
6.0
8.0
9.7
4
FH12-15S-0.5SVA(54)
586-0808-6 54
15
10.9
9.4
7.0
9.0
10.7
4
FH12-16S-0.5SVA(54)
586-0809-9 54
16
11.4
9.9
7.5
9.5
11.2
4
FH12-17S-0.5SVA(54)
586-0810-8 54
17
11.9
10.4
8.0
10.0
11.7
4
FH12-18S-0.5SVA(54)
586-0811-0 54
18
12.4
10.9
8.5
10.5
12.2
4
FH12-20S-0.5SVA(54)
586-0812-3 54
11.9
9.5
11.5
13.2
4
FH12-22S-0.5SVA(54)
586-0813-6 54
22
14.4
12.9
10.5
12.5
14.2
8
FH12-24S-0.5SVA(54)
586-0814-9 54
24
15.4
13.9
11.5
13.5
15.2
8
FH12-26S-0.5SVA(54)
586-0815-1 54
26
16.4
14.9
12.5
14.5
16.2
8
FH12-30S-0.5SVA(54)
586-0750-8 54
30
18.4
16.9
14.5
16.5
18.2
8
FH12-32S-0.5SVA(54)
586-0816-4 54
32
19.4
17.9
15.5
17.5
19.2
8
FH12-33S-0.5SVA(54)
586-0818-0 54
33
19.9
18.4
16.0
18.0
19.7
8
FH12-34S-0.5SVA(54)
586-0817-7 54
34
20.4
18.9
16.5
18.5
20.2
8
FH12-36S-0.5SVA(54)
586-0819-2 54
36
21.4
19.9
17.5
19.5
21.2
8
FH12-40S-0.5SVA(54)
586-0804-5 54
40
23.4
21.9
19.5
21.5
23.2
8
FH12-45S-0.5SVA(54)
586-0820-1 54
45
25.9
24.4
22.0
24.0
25.7
8
FH12-49S-0.5SVA(54)
586-0821-4 54
49
27.9
26.4
24.0
26.0
27.7
8
FH12-50S-0.5SVA(54)
586-0805-8 54
50
28.4
26.9
24.5
26.5
28.2
8
FH12-60S-0.5SVA(54)
586-0749-9 54
60
33.4
31.9
29.5
31.5
33.2
8
Note 1 : Embossed tape reel packaging (1,000 pcs/reel, 500 pcs/reel).
7
■1mm Pitch Type Bottom Contact Type
2.3
E
A
1.0
(0.2)
1.2
2
0.8
(2.1)
(3.1)
2
(4.8)
1.85
B
C
D
4.6
5.6
Unit : mm
Standard type
Part No.
Eccentric type
HRS No.
No. of Contacts
A
B
C
D
E
FH12-5S-1SH(**)
586-0591-6 **
5
4
8.6
9.6
6.07
2.3
FH12-6S-1SH(**)
586-0607-4 **
6
5
9.6
10.6
7.07
2.3
FH12-7S-1SH(**)
586-0535-5 **
7
6
10.6
11.6
8.07
2.3
FH12-8S-1SH(**)
586-0579-0 **
8
7
11.6
12.6
9.07
2.3
FH12-9S-1SH(**)
586-0540-5 **
9
8
12.6
13.6
10.07
2.3
FH12-11S-1SH(**)
586-0668-9 **
11
10
14.6
15.6
12.07
2.3
FH12-12S-1SH(**)
586-0741-7 **
12
11
15.6
16.6
13.07
2.3
FH12-16S-1SH(**)
586-0536-8 **
16
15
19.6
20.6
17.07
2.3
FH12-17S-1SH(**)
586-0739-5 **
17
16
20.6
21.6
18.07
2.3
FH12-22S-1SH(**)
586-0547-4 **
22
21
25.6
26.6
23.07
2.3
FH12-26S-1SH(**)
586-0592-9 **
26
25
29.6
30.6
27.07
2.3
FH12-10(4)SA-1SH(**) 586-0537-0 **
4
3
8.1
9.1
5.57
2.8
FH12-14(6)SA-1SH(**) 586-0538-3 **
6
5
10.1
11.1
7.57
2.8
FH12-18(8)SA-1SH(**) 586-0539-6 **
8
7
12.1
13.1
9.57
2.8
FH12-22(10)SA-1SH(**) 586-0541-8 **
10
9
14.1
15.1
11.57
2.8
FH12-24(11)SA-1SH(**) 586-0542-0 **
11
10
15.1
16.1
12.57
2.8
FH12-30(14)SA-1SH(**) 586-0543-3 **
14
13
18.1
19.1
15.57
2.8
FH12-40(19)SA-1SH(**) 586-0546-1 **
19
18
23.1
24.1
20.57
2.8
FH12-50(24)SA-1SH(**) 586-0548-7 **
24
23
28.1
29.1
25.57
2.8
8
(1.3)
■1mm Pitch Vertical Mounting Type
2
(0.15)
(1.4)
(2.15)
(0.2)
2
0.5
F
2.5
(4.25)
(1.75)
3.6
5.5
(4.85)
A
B
0.5
1.0
3.8(Metal fitting dimension)
C
D
E
Unit : mm
HRS No.
No. of Contacts
A
B
C
D
E
F
FH12-06S-1SVA(54)
Part No.
586-0822-0 54
6
9.9
8.4
5
8
9.7
4
FH12-07S-1SVA(54)
586-0823-0 54
7
10.9
9.4
6
9
10.7
4
FH12-08S-1SVA(54)
586-0824-0 54
8
11.9
10.4
7
10
11.7
4
FH12-16S-1SVA(54)
586-0825-0 54
16
19.9
18.4
15
18
19.7
8
FH12-20S-1SVA(54)
586-0826-0 54
22.4
19
22
23.7
8
FH12-22S-1SVA(54)
586-0827-0 54
22
25.9
24.4
21
24
25.7
8
FH12-24S-1SVA(54)
586-0828-0 54
24
27.9
26.4
23
26
27.7
8
9
BRecommended FPC/FFC dimensions and Land/Metal Mask dimensions
●0.5mm Pitch Product
0.5±0.1
0.3±0.03(Land)
0.5±0.05
0.25±0.03(Metal mask)
A±0.05
*Set the stiffener thickness to 0.188 (7.5mil) min.
Number
of Contacts
6
8
10
11
12
13
14
15
16
17
18
19
24
Dimension
A
B
2.5
3.5
4.5
5.0
5.5
6.0
6.5
7.0
7.5
8.0
8.5
9.0
9.5
10.5
11.5
3.5
4.5
5.5
6.0
6.5
7.0
7.5
8.0
8.5
9.0
9.5
10.0
10.5
11.5
12.5
Number
of Contacts
25
26
28
29
30
32
33
34
35
36
40
42
45
50
53
A
B
12.0
12.5
13.5
14.0
14.5
15.5
16.0
16.5
17.0
17.5
19.5
20.5
22.0
24.5
26.0
13.0
13.5
14.5
15.0
15.5
16.5
17.0
17.5
18.0
18.5
20.5
21.5
23.0
25.5
27.0
6
8
10
11
12
13
14
15
16
17
18
19
24
A
B
2.5
3.5
4.5
5.0
5.5
6.0
6.5
7.0
7.5
8.0
8.5
9.0
9.5
10.5
11.5
8.1
9.1
10.1
10.6
11.1
11.6
12.1
12.6
13.1
13.6
14.1
14.6
15.1
16.1
17.1
C
Dimension
Number
of Contacts
A
B
C
4.5
5.5
6.5
7.0
7.5
8.0
8.5
9.0
9.5
10.0
10.5
11.0
11.5
12.5
13.5
25
26
28
29
30
32
33
34
35
36
40
42
45
50
53
12.0
12.5
13.5
14.0
14.5
15.5
16.0
16.5
17.0
17.5
19.5
20.5
22.0
24.5
26.0
17.6
18.1
19.1
19.6
20.1
21.1
21.6
22.1
22.6
23.1
25.1
26.1
27.6
30.1
31.6
14.0
14.5
15.5
16.0
16.5
17.5
18.0
18.5
19.0
19.5
21.5
22.5
24.0
26.5
28.0
0.5±0.05
0.35±0.03(FPC)
0.3±0.05
1±0.05
1±0.05
0.5±0.1
10
0.6±0.1(Land)
B±0.05
Number
of Contacts
6
10
12
13
15
16
17
18
24
A
B
02.5
04.5
05.5
06.0
07.0
07.5
08.0
08.5
09.5
10.5
11.5
03.5
05.5
06.5
07.0
08.0
08.5
09.0
09.5
10.5
11.5
12.5
Dimension
Number
of Contacts
26
30
32
33
34
36
40
45
49
50
60
0.5±0.05(Metal mask)
1±0.05
1.8±0.1
1.8±0.1
Recommended metal mask thickness : 0.15mm
Unit : mm
Dimension
No.1 contact
A±0.1
0.8±0.1(Land)
0.65±0.05(Metal mask)
0.6±0.1(Land) 0.5±0.05
0.5±0.05(Metal mask) 1±0.05
1±0.05
1±0.05
B±0.05
0.5mm
Pitch
Vertical
Mountin
g Type
1.5±0.1
1.5±0.1
4.5±0.1
0.5±0.05
0.3±0.03(FFC)
A±0.05
B±0.07
Odd contact number
No.1 contact
A±0.1
0.8±0.1(Land)
1.8±0.1
1.8±0.1
2MIN
3MIN
Even contact number
0.5±0.1
Unit : mm
Dimension
Number
of Contacts
1.5±0.1
Unit : mm
Dimension
1.5±0.1
4.5±0.1
0.5mm
Pitch
Top
Contact
Type
0.3±0.05
1.3±0.1
A±0.05
B±0.07
B±0.1
C±0.1
1.5±0.1
4.5MIN
3.5MIN
0.35±0.03(FPC)
0.3±0.03(FFC)
0.5±0.05
0.5±0.1
0.5mm
Pitch
Bottom
Contact
Type
Land / Metal Mask dimensions
2.2±0.1
FPC/FFC dimensions
A
B
12.5
14.5
15.5
16.0
16.5
17.5
19.5
22.0
24.0
24.5
29.5
13.5
15.5
16.5
17.0
17.5
18.5
20.5
23.0
25.0
25.5
30.5
Unit : mm
Dimension
Number
of Contacts
10
12
13
15
16
17
18
24
A
B
06.5
07.5
08.0
09.0
09.5
10.0
10.5
11.5
12.5
13.5
04.5
05.5
06.0
07.0
07.5
08.0
08.5
09.5
10.5
11.5
Dimension
Number
of Contacts
26
30
32
33
34
36
40
45
49
50
60
A
B
14.5
16.5
17.5
18.0
18.5
19.5
21.5
24.0
26.0
26.5
31.5
12.5
14.5
15.5
16.0
16.5
17.5
19.5
22.0
24.0
24.5
29.5
●1mm Pitch Product
1mm
Pitch
Vertical
Mounting
Type
πSet the stiffener thickness to 0.188 (7.5mil) min.
1mm
Pitch
Bottom
Contact
Type
Unit : mm
B
C
5
6
7
8
9
11
12
16
17
22
26
04
05
06
07
08
10
11
15
16
21
25
06
07
08
09
10
12
13
17
18
23
27
1
1
1
1
1
1
1
1
1
1
1
A
B
C
4
6
8
10
11
14
19
24
03
05
07
09
10
13
18
23
05.5
07.5
09.5
11.5
12.5
15.5
20.5
25.5
1.5
1.5
1.5
1.5
1.5
1.5
1.5
1.5
Unit : mm
Dimension
A
Number
of Contacts
5
6
7
8
9
11
12
16
17
22
26
04
05
06
07
08
10
11
15
16
21
25
B
C
D
10.6
11.6
12.6
13.6
14.6
16.6
17.6
21.6
22.6
27.6
31.6
07
08
09
10
11
13
14
18
19
24
28
1.5
1.5
1.5
1.5
1.5
1.5
1.5
1.5
1.5
1.5
1.5
Number
of Contacts
A
B
6
7
8
16
24
05
06
07
15
19
21
23
07
08
09
17
21
23
25
03
05
07
09
10
13
18
23
4
6
8
10
11
14
19
24
B
C
10.1 06.5
12.1 08.5
14.1 10.5
16.1 12.5
17.1 13.5
20.1 16.5
25.1 21.5
30.1 26.5
D
2
2
2
2
2
2
2
2
Unit : mm
Dimension
Dimension
A
Number
of Contacts
Eccentric Type
A
Dimension
Number
of Contacts
Standard Type
Dimension
Number
of Contacts
Eccentric Type
Standard Type
FPC/FFC dimensions
Unit : mm
Dimension
Number
of Contacts
A
B
6
7
8
16
24
08
09
10
18
22
24
26
05
06
07
15
19
21
23
11
BPackaging Specification
Embossed Carrier Tape Dimensions
Horizontal Type (Common to Bottom/Top Contact, 0.5mm/1mm Pitch)
(2.0)
Flat surface for placement
with Automatic equipment
3)
Reel Dimensions (Common to All Types)
(ø1
(D : INSIDE)
Mounting portion
Lead portion (400mm min.)
End portion
Embossed carrier tape
Blank portion
( E : OUTSIDE)
(10 pockets min.)
●0.5mm Pitch Bottom/Top Contact Type
Dimension
Number
of Contacts
A
B
C
D
6
8
10
11
12
13
14
15
16
17
18
19
24
16
16
16
16
24
24
24
24
24
24
24
24
24
24
24
07.5
07.5
07.5
07.5
11.5
11.5
11.5
11.5
11.5
11.5
11.5
11.5
11.5
11.5
11.5
17.4
17.4
17.4
17.4
25.4
25.4
25.4
25.4
25.4
25.4
25.4
25.4
25.4
25.4
25.4
Top cover tape
Blank portion
(10 pockets min.)
Unit : mm
E
Dimension
Number
of Contacts
A
B
C
D
E
21.4
21.4
21.4
21.4
29.4
29.4
29.4
29.4
29.4
29.4
29.4
29.4
29.4
29.4
29.4
25
26
28
29
30
32
33
34
35
36
40
42
45
50
53
24
24
32
32
32
32
32
32
44
44
44
44
44
44
44
------------------28.4
28.4
28.4
28.4
28.4
28.4
40.4
40.4
40.4
40.4
40.4
40.4
40.4
11.5
11.5
14.2
14.2
14.2
14.2
14.2
14.2
20.2
20.2
20.2
20.2
20.2
20.2
20.2
25.4
25.4
33.4
33.4
33.4
33.4
33.4
33.4
45.4
45.4
45.4
45.4
45.4
45.4
45.4
29.4
29.4
37.4
37.4
37.4
37.4
37.4
37.4
49.4
49.4
49.4
49.4
49.4
49.4
49.4
12
Unit : mm
Dimension
Number
of Contacts
A
B
C
D
E
5
6
7
8
9
11
12
16
17
22
26
16
24
24
24
24
24
24
32
44
44
44
---------------------------------------------------------------28.4
40.4
40.4
40.4
07.5
11.5
11.5
11.5
11.5
11.5
11.5
14.2
20.2
20.2
20.2
17.4
25.4
25.4
25.4
25.4
25.4
25.4
33.4
45.4
45.4
45.4
21.4
29.4
29.4
29.4
29.4
29.4
29.4
37.4
49.4
49.4
49.4
Eccentric Type
Standard Type
● 1mm Pitch Bottom Contact Type
Dimension
Number
of Contacts
A
B
C
D
E
4
6
8
10
11
14
19
24
16
24
24
24
24
32
44
44
40.4
40.4
07.5
11.5
11.5
11.5
11.5
14.2
20.2
20.2
17.4
25.4
25.4
25.4
25.4
33.4
45.4
45.4
21.4
29.4
29.4
29.4
29.4
37.4
49.4
49.4
(1.75)
3)
(D : INSIDE)
(ø1
Mounting portion
End portion
Vertical Mounting Type (Common to 0.5mm/1mm Pitch)
( E : OUTSIDE)
Blank portion
(10 pockets min.)
●0.5mm Pitch Vertical mounting Type
Dimension
Number
of Contacts
A
B
C
D
Top cover tape
Blank portion
(10 pockets min.)
Unit : mm
E
Dimension
Number
of Contacts
A
B
C
D
E
6
16
07.5
17.4
21.4
26
24
11.5
25.4
29.4
10
16
07.5
17.4
21.4
30
32
28.4
14.2
33.4
37.4
12
16
07.5
17.4
21.4
32
32
28.4
14.2
33.4
37.4
13
24
11.5
25.4
29.4
33
32
28.4
14.2
33.4
37.4
15
24
11.5
25.4
29.4
34
44
40.4
20.2
45.4
49.4
16
24
11.5
25.4
29.4
36
44
40.4
20.2
45.4
49.4
17
24
11.5
25.4
29.4
40
44
40.4
20.2
45.4
49.4
18
24
11.5
25.4
29.4
45
44
40.4
20.2
45.4
49.4
11.5
25.4
29.4
49
44
40.4
20.2
45.4
49.4
22
24
11.5
25.4
29.4
50
44
40.4
20.2
45.4
49.4
24
24
11.5
25.4
29.4
60
56
52.4
26.2
57.4
61.4
●1mm Pitch Vertical mounting Type
Unit : mm
Dimension
Number
of Contacts
A
B
C
D
E
6
24
11.5
25.4
29.4
7
24
11.5
25.4
29.4
8
24
11.5
25.4
29.4
16
32
28.4
14.2
33.4
37.4
40.4
20.2
45.4
49.4
22
44
40.4
20.2
45.4
49.4
24
44
40.4
20.2
45.4
49.4
13
BFH12 Series FPC/FFC Construction (Recommended Specifications)
1. FFC
FFC : Flexible Flat Cable
Material Name
Material
Thickness (μm)
(12)
Polyester film
Adhesive
Thermoplastic polyester
(Nickel under plated / Gold plated),
soft copper film
35
Polyester type
Adhesive
(30)
30
12
Polyester
Adhesive
Polyester type
30
Stiffener
Polyester type
188
Total
295
(Note)
*Real tolerance of thickness dimension is on the order of ±20μm (275 to 315μm)
Note : Use of a thicker FFC results in a stiffer lock action and the lock is more easily released.
A factor that contributes to thicker FFC is the use of 250μm stiffener which is thicker than the standard (188μm)
product. This results in a total thickness of 357μm.
When using FFC, control of FFC thickness becomes easy if you indicate to us the thickness of the stiffener.
FPC : Flexible Printed Circuit
2. FPC
Material Name
Covering layer film
Material
Polyimide 1 mil
Thickness (μm)
(25)
(25)
Cover adhesive
Surface treatmenta
Nickel under plated 1to 5μm /
Gold plated 0.2μm
Copper foil
Cu
Base adhesive
Heat-hardened adhesive
25
Base film
Polyimide 1 mil
25
1oz
Reinforcement material adhesive Heat-hardened adhesive
Stiffener
3
35
30
Polyimide 7 mil
175
Total
293
3. Precautions
1. This specification is a recommendation for the construction of the FH12 Series FPC and FFC (t=0.3±0.05).
2. For details about the construction, please contact the FPC/FFC manufacturers.
■Recommended Temperature Profile
MAX 250ç
250
Temperature
230ç
200
200ç
150
150ç
(ç)
100
50
25ç
(60 seconds) 90 to 120 seconds
Preheating
Start
Time
14
30 seconds
Soldering
HRS test conditions
Solder method
: Reflow, IR/hot air
Environment
: Room air
Solder composition
: Paste, 96.5%Sn/3%Ag/0.5%Cu
(Senju Metal Industry, Co., Ltd.’s
Part Number: M705-221CM5-3210.5)
Test board
: Glass epoxy 40mm∞80mm∞1.6mm thick
Land dimensions
: Top and bottom
contact type 0.3mm∞1.3mm
Vertical mounting type
0.6mm∞1.5mm
Metal mask
: Top and bottom contact type
0.25mm∞1.3mm∞0.15mm thick
0.5mm∞1.5mm∞0.15mm thick
This temperature profile is based on the above conditions.
In individual applications the actual temperature may vary,
depending on solder paste type, volume/thickness and
board size/thickness. Consult your solder paste and
equipment manufacturer for specific recommendations.
BConnector Operating Instructions, precautions and recommendations
●Bottom Contact Type (common for 0.5mm/1mm Pitch)
Operation
Precautions
1. FPC/FFC Termination procedure.
Connector installed on the board.
1) Avoid grasping the actuator with two fingers or
lifting the actuator with fingernail.
1) Lift up the actuator. Use thumb or index finger.
2) Do not use a thin tool such as the tip of a
screwdriver to release the lock lever. Doing so
will cause deformation of the contacts.
3) Do not apply force in the direction of arrows A, B, or C
while the lock lever is open.
Doing so will cause the lock lever to become disen gaged,
or will damage the hook portion of the connector body.
2) Fully insert the FPC/FFC parallel to mounting
surface, with the exposed conductive traces
facing down.
4) When inserting the FPC/FFC, do not forcefully rub against
the surface beneath the connector insertion slot.
Doing so will result in the FPC/FFC forcefully striking the
contacts and this will cause contact deformation, peeling
of the FPC/FFC conductors, and other irregularities.
FPC/FFC conductive traces
5) Insert the FPC/FFC at the proper position of the connector
insertion slot, and insert perpendicularly with respect to the connector. Improper insertion will cause continuity problems, disengagement of the lock lever, and damage to the hook portion.
15
Operation
Precautions
3) Rotate down the actuator until firmly closed.
It is critical that the inserted FPC/FFC is not
moved and remains fully inserted. Should the
FPC/FFC be moved, open the actuator and
repeat the process, starting with Step 1.
6) Partial insertion of the FPC/FFC, offset insertion,
and diagonal insertion will result in an unfavorable engagement of the lock lever in which the
lock lever is raised. To correct this, first remove
the FPC/FFC and then reinsert it. Forcing the
lock will damage the connector.
Stiffener
7) When locking, handle the FPC/FFC so that a
load is not applied to the FPC/FFC as would
occur by pulling the FPC/FFC, or lifting it, etc.
When a load is applied in the opposite direction to the rotational movement of the lock, an
excessive load will be applied and this will
cause connector damage.
2. FPC/FFC Removal
2) Carefully remove the FPC/FFC.
8) At the time of lock operation, application of
force such as that indicated by the arrows in
the diagrams below will cause the lock lever to
disengage. When the lock lever has become
disengaged, please exchange the entire connector.
16
●Top Contact Type
Operation
Precautions
1) Avoid further lifting of the actuator once the lock has
been released. Doing so will cause the lock lever to
separate from the rotational shaft, and the lock lever
will become disengaged or the hook portion of the
connector body will be damaged.
actuator
Rotational shaft
facing UP.
C
FP
a
are
tion
r
e
ins
2) Avoid further pressing of the lock portion from
the locked condition when the FPC/FFC has
not yet been inserted. Doing so will cause the
lock lever to become disengaged from the
rotational shaft, and the hook portion of the
Stiffener
above.
3) Do not insert the FPC/FFC diagonally. D o i n g
so will result in the corners of the FPC/FFC
catching on the contacts and will cause deformation of the contacts.
2. FPC/FFC Removal
4) When closing down the actuator apply equal
pressure to both sides of the actuator.
17
●Vertical Mounting type (common for 0.5mm/1mm pitch)
Operation
Precautions
1) Avoid forcing the actuator up or down without
the FPC/FFC inserted.
1) Verify that the actuator is positioned upright.
If the actuator has rotated to the side, carefully rotate it upright. Actuator upright
2) Insert the FPC/FFC vertically in the connector
slot assuring that the conductive traces of the
FPC/FFC are facing away from the actuator.
Stiffener
2) Do not attempt to open or over rotate an already
released actuator (refer to the diagram below).
These actions may damage the actuator.
Sl
ot
3) Press down the actuator in the direction shown.
3) Do not insert the FPC/FFC diagonally. Doing so
will result in the corners of the FPC/FFC catching
contacts.
2. FPC/FFC Removal
Rotate the actuator upward and withdraw the FPC/FFC.
4) Do not press down vertically on the actuator when
the FPC/FFC already inserted, it needs to be rotated to engage the lock. Refer to the diagram below.
Doing so may cause actuator failure.
18
MEMO:
19
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 01/2017. Contents are subject to change without notice for the purpose of improvements.
