681M5W5203L001
681M5W5203L001
    NORCOMP
    5(电源) 位 D-Sub,组合式 插座,母形插口 连接器, 通孔 焊接
681M5W5203L001 数据手册
DESCRIPTION: POWER - VERTICAL - FEMALE - MACHINED SPECIFICATIONS: ELECTRICAL: INSULATION RESISTANCE: DIELECTRIC WITHSTANDING VOLTAGE: WORKING VOLTAGE: OPERATING TEMPERATURE: POWER CONTACT RESISTANCE: POWER CONTACT AMPERAGE: 2.088 [53.04] 1.852 [47.05] Ø 0.120 [3.05] 2-PLACES 1.512 [38.40 ] 0.570 [14.48] A5 A4 0.570 [14.48] A3 A2 A1 0.270 [6.86] 10° 250V -55°C TO +125°C 1.0 mΩ MAX. SEE P/N KEY MECHANICAL: CONTACT INSERTION FORCE: CONTACT SEPARATION FORCE: 4.5 Kg MAX. 0.3 Kg MIN. MATERIALS: CONTACTS: INSULATOR: COPPER ALLOY, GOLD FLASH PBT UL94V-0 RATED SHELL: HARDWARE: NICKEL PLATED STEEL NICKEL PLATED BRASS 0.492 [12.50] 0.270 [6.86] 0.330 [8.38] 5 GΩ MIN. 1000 VAC FOR 1 MIN 230°C PROCESS TEMP. 0.311 [7.90] 0.228 [5.80] 681M5W5203LYYY 0.031 [0.80] 0.421 [10.70] 0 = 40 AMP POWER // STANDARD PCB TAILS 1 = 40 AMP POWER // 2.22mm PCB TAILS 2 = 20 AMP POWER // STANDARD PCB TAILS 0 1 2 3 4 5 = NO HARDWARE = 0.098" CN PCB SIDE = 0.236" CN PCB SIDE = 0.236" CN MATING SIDE = 0.237" BOARDLOCK PCB SIDE = 0.224" BOARDLOCK PCB SIDE 1 = GOLD FLASH SEE SHEET 2 FOR CONTACT DIMENSION DETAILS RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = inches [mm] DRAWN: M. SIGMON DATE: 07/18/2013 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 1 3 681M5W5203LYYY 3 DESCRIPTION: POWER - VERTICAL - FEMALE - MACHINED NOTE: SIGNAL AND POWER CONTACTS COME PRE-LOADED INTO INSULATORS DIMENSIONS (in/mm) 1.852 [47.05] 0.570 [14.48] OPTION 0.570 [14.48] 0.330 [8.38] 0&2 Ø 0.130 [3.30] 2-PLACES 0.270 [6.86] P 0.177 4.50 0.087 1 2.22 POWER CONTACTS Ø 0.166 [4.22] 5-PLACES 0.030 [0.76] 0.059 [1.50] CL Ø 0.148 (40 AMP) [3.75] Ø 0.110 (20 AMP) [2.80] RECOMMENDED PCB LAYOUT P 0.031 [0.80] RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = inches [mm] DRAWN: M. SIGMON DATE: 07/18/2013 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 2 3 681M5W5203LYYY 3 DESCRIPTION: POWER - VERTICAL - FEMALE - MACHINED TOLERANCE: ALL CLINCH-NUTS ARE 4-40 INTERNAL THREADS 0 ..... NO HARDWARE 2 ..... 0.236" PCB SIDE 4 ..... 0.237" PCB SIDE 1 ..... 0.098" PCB SIDE 3 ..... 0.236" MATING SIDE 5 ..... 0.224" PCB SIDE RoHS COMPLIANT N C ALL DIMENSIONS ARE ±0.010 THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = inches [mm] DRAWN: M. SIGMON DATE: 07/18/2013 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 3 3 681M5W5203LYYY 3
681M5W5203L001 价格&库存
很抱歉,暂时无法提供与“681M5W5203L001”相匹配的价格&库存,您可以联系我们找货
681M5W5203L001
  • 1+93.04764
  • 10+89.32990
  • 50+85.61216
  • 100+83.73767
库存:33
