Additional Resources:
Product Page
3D Model
PCB Footprint
date
08/05/2022
page 1 of 4
MODEL: UJ2-MIBH-4-MSMT | DESCRIPTION: USB RECEPTACLE
FEATURES
• USB micro B type jack
• USB 2.0
• horizontal orientation
• mid-mount SMT
SPECIFICATIONS
parameter
conditions/description
USB standard
USB 2.0
min
typ
rated input voltage
rated input current
pins 1, 5
pins 2, 3, 4
contact resistance2
between terminals and mating plug
insulation resistance
at 250 Vdc for 1 minute
voltage withstand
for 1 minute
units
30
Vac
1.8
0.5
A
A
30
mΩ
100
MΩ
insertion force
withdrawal force
250
Vac
35
N
85
°C
8
operating temperature
N
-25
life
10,000
flammability rating
UL94V-0
RoHS
yes
Note:
max
cycles
1. Add suffix “-TR” to the model for tape and reel packaging.
2. When measured at a current of less than 100 mA/1 kHz
3. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted.
SOLDERABILITY
parameter
min
typ
max
units
reflow soldering
see reflow profile
245
250
255
°C
260
250
240
217
180
150
120
60
50
°C
70
60
140
120
250
180
240
Time (second)
cuidevices.com
340
300
380
360
430
420
480
Product Page
3D Model
PCB Footprint
CUI DEVICES | MODEL: UJ2-MIBH-4-MSMT | DESCRIPTION: USB RECEPTACLE
date 08/05/2022 | page 2 of 4
MECHANICAL DRAWING
units: mm
tolerance:
X.X ±0.2 mm
X.XX ±0.1 mm
PCB layout tolerance:
±0.05 mm
MATERIAL
PLATING
contact terminals
copper alloy
contact: 30 µ” gold over
nickel
solder: 30 µ” gold over
nickel
shield
stainless steel
nickel
insulator
LCP (black)
Recommended PCB Layout
Top View
cuidevices.com
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 3 of 4
PACKAGING
units: mm
Reel Size: Ø330 mm
Reel QTY: 1,300 pcs per reel
A: Empty 160 mm min.
B: Empty 100 mm min.
C: Cover 400 mm min.
cuidevices.com
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 4 of 4
REVISION HISTORY
rev.
description
date
1.0
initial release
08/08/2016
1.01
brand update
02/05/2020
1.02
added USB standard
04/07/2022
logo, datasheet style update
08/05/2022
1.03
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“UJ2-MIBH-4-MSMT-TR”相匹配的价格&库存,您可以联系我们找货
