Female Card Edge
.100” [2.54 mm] Contact Centers, .431” [10.95 mm] Insulator Height,
Dip Solder/Eyelet/Right Angle for .062” [1.57 mm] or .031” [0.79 mm] Mating PCB
SPECIFICATIONS
• Accommodates .062” ± .008” [1.57 mm ± 0.20 mm] or
.031” ± .006” [0.79 mm ± 0.15 mm] mating PCB
(for .093” [2.36 mm] PC board see following pages)
• PBT, PPS, PA9T or PEEK insulator
• Molded-in key available
• 3 Amps current rating for one contact energized
• 30 milli Ohms maximum at rated current
• UL Flammability Rating: 94V-0
POLARIZING KEYS (For .062” Mating PCB Only)
READOUT
FULL BELLOWS
PLA-K1
KEY IN BETWEEN CONTACTS
(ORDER SEPARATELY)
BACK-UP
SPRING
CANTILEVER
Female Card Edge
.230” [5.84]
.030” [0.76]
LETTER
'A' SIDE
DUAL (D)
.200” [5.08]
CONSULT FACTORY FOR MOLDED-IN KEY
HALF LOADED (H)
TERMINATION TYPE
FULL BELLOW
TAIL LENGTH
'B' SIDE
ROW SPACING MIN HOLE SIZE
FULL BELLOW
EYELET ACCEPTS 3-#26 AWG
STRAIGHT
.185” RIGHT ANGLE
[4.70]
.125” [3.18] (RA)
.050”
[1.27]
.156” [3.96]
STRAIGHT
.200” [5.08] (RT)
.440” [11.19] (RY)
.140” [3.56]
Ø.043” [1.09]
.275” [6.98]
.225” [5.72]
.140” [3.56]
Ø.043” [1.09]
Ø.043” [1.09]
.007”[0.18] THICK (RE)
CARD EXTENDER
.014”[0.36] THICK (TE)
ACCEPTS .062” [1.57] PCB
TAIL LENGTH
.185” [4.70] (RX)
.200” [5.08]
.165” [4.19] (RJ)
.250” [6.35]
.210” [5.33] EYELET (RE)
.185” [4.70] (RT)
.425” [10.80] (RY)
Ø.043” [1.09]
Ø.043” [1.09]
MODIFICATION CODE
-S13
-S13
-S13
SURFACE MOUNT (RT)
MODIFICATION CODE
CRIMP TO CENTER (SX)
.160” [4.06]
-S924
Ø.043” [1.09]
.600” [15.24]
CANTILEVER
RIGHT ANGLE SURFACE MOUNT (RA)
TAIL LENGTH
ROW SPACING
MIN HOLE SIZE
.200” [5.08] (ET)
.140” [3.56]
Ø.040” [1.02]
.440” [11.19] (EY)
.140” [3.56]
Ø.040” [1.02]
MODIFICATION CODE
-S2106
.150” [3.81]
.350” [8.88]
MOUNTING STYLE
Ø.125”
[3.18]
#4-40
Ø.116” [2.95],
CLEARANCE FOR
#4 SCREW
.100” [2.54]
Ø.125”
[3.18]
.135” [3.43]
CLEARANCE
HOLE (H)
50
THREADED
INSERT (I)
FLOATING
BOBBIN (F)
NO MOUNTING EARS
(N)
SIDE MOUNTING
(S)
OPEN CARDSLOT
(B)
www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com
Female Card Edge
Dip Solder/Eyelet/Right Angle for .062”[1.57 mm] or .031” [0.79 mm] Mating PCB
PART NUMBER OPTIONS
E B C 43 D RE H - Sxxx
CONTACT FINISH - RoHS Compliant
All platings are Lead Free and have .000050” Nickel underplate
Contact Surface
.000010” Gold
.000030” Gold
.000010” Gold
.000030” Gold
Contact Surface
S = .000010” Gold
M = .000030” Gold
E = .000100” Pure Tin, Matte
B
C
G
Y
Termination
.000005” Gold
.000005” Gold
Overall Plating
.000010” Gold
.000010” Gold
CONTACT CENTERS
C = .100” [2.54 mm]
DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches.
B
A
F
D
E
.265 [6.73] INSERTION DEPTH
REFER TO
MOUNTING
STYLE
C
.025[0.64]
.100 [2.54] TYP.
CONTACT MARKINGS
B 1 2 3 . . . 58 59 60 B
A 1 2 3 . . . 58 59 60 A
.431 [10.95]
B 1 2
59 60 B
A 1 2
59 60 A
Female Card Edge
MODIFICATIONS (Consult Factory)
OMIT FOR STANDARD
-S13 = Card Extender Accepts .062” [1.57 mm] PCB
(RE, RT, RY Terminations Only)
-S734 = .031”±.006” [0.79 mm ± 0.15 mm] Mating PCB
-S924 = Surface Mount
-S2106 = Right Angle Surface Mount
MOUNTING STYLE (Opposite Page)
H = .125” [3.18 mm] Clearance Holes
N = No Mounting
B = Open Card slot
S = Side Mounting
I = Threaded Insert
F = Floating Bobbin
TERMINATION TYPE (Opposite Page)
RA = Right Angle
RE = Eyelet (Standard)
TE = Eyelet (Overall Plated Only)
**ET, RT = .140” [3.56 mm] X .200” [5.08 mm] Dip Solder
**EY, RY = .140” [3.56 mm] X .440” [11.19 mm] Dip Solder
RX = .200” [5.08 mm] X .185” [4.70 mm] Dip Solder
RJ = .250” [6.35 mm] X .165” [4.19 mm] Dip Solder
SX = .110” [2.79 mm] Centered Dip Solder
READOUT (Opposite Page)
D = Dual
H = Half Loaded
NUMBER OF CONTACT POSITIONS
See Chart Below
**'ET' & 'EY' Only available in 'B' & 'C' Plating code
MATERIALS (INSULATOR/CONTACT)
E = PBT/Phosphor Bronze (Standard)
R = PPS/Phosphor Bronze
G = PA9T/Phosphor Bronze
H = PBT/Beryllium Copper
A = PPS/Beryllium Copper
J = PA9T/Beryllium Copper
*F = PPS/Spinodal (Overall Gold Plating Only)
Consult Factory for Special Soldering Guidelines
*C = PPS/Beryllium Nickel (Overall Gold Plating Only)
*W = PEEK/Beryllium Nickel (Overall Gold Plating Only)
*Consult factory for availability.
Refer to Page 7 for Operating/Processing Temperatures
.245 [6.22]
REFER TO TERMINATION TYPE
Tolerances on non-critical dimensions may very slightly due to shrinkage differential per insulator material; Consult factory.
POSITIONS/
CONTACTS
04/08*
05/10
06/12
07/14
08/16
10/20
12/24
13/26
15/30
17/34
18/36
19/38
20/40
22/44
23/46*
25/50
26/52
28/56
30/60
31/62
35/70
36/72
40/80
43/86
44/88
49/98
50/100
52/104*
60/120
65/130
INCHES
A±.008 B±.008 C±.015 D±.010 E±.020
0.300
0.500
0.675
0.975
1.275
0.400
0.600
0.775
1.075
1.375
0.500
0.700
0.875
1.175
1.475
0.600
0.800
0.975
1.275
1.575
0.700
0.900
1.075
1.375
1.675
0.900
1.100
1.275
1.575
1.875
1.100
1.300
1.475
1.775
2.075
1.200
1.400
1.575
1.875
2.175
1.400
1.600
1.775
2.075
2.375
1.600
1.800
1.975
2.275
2.575
1.700
1.900
2.075
2.375
2.675
1.800
2.000
2.175
2.475
2.775
1.900
2.100
2.275
2.575
2.875
2.100
2.300
2.475
2.775
3.075
2.200
2.400
2.575
2.875
3.175
2.400
2.600
2.775
3.075
3.375
2.500
2.700
2.875
3.175
3.475
2.700
2.900
3.075
3.375
3.675
2.900
3.100
3.275
3.575
3.875
3.000
3.200
3.375
3.675
3.975
3.400
3.600
3.775
4.075
4.375
3.500
3.700
3.875
4.175
4.475
3.900
4.100
4.275
4.575
4.875
4.200
4.400
4.575
4.875
5.175
4.300
4.500
4.675
4.975
5.275
4.800
5.000
5.175
5.475
5.775
4.900
5.100
5.275
5.575
5.875
5.100
5.300
5.475
5.775
6.075
5.900
6.100
6.275
6.575
6.875
6.400
6.600
6.775
7.075
7.375
MILLIMETERS
F+.005/-.015
0.330
0.400
A±0.20
7.62
10.16
12.70
15.24
17.78
22.86
27.94
30.48
35.56
40.64
43.18
45.72
48.26
53.34
55.88
60.96
63.50
68.58
73.66
76.20
86.36
88.90
99.06
106.68
109.22
121.92
124.46
129.54
149.86
162.56
B±0.20
12.70
15.24
17.78
20.32
22.86
27.94
33.02
35.56
40.64
45.72
48.26
50.80
53.34
58.42
60.96
66.04
68.58
73.66
78.74
81.28
91.44
93.98
104.14
111.76
114.30
127.00
129.54
134.62
154.94
167.64
C±0.38
17.15
19.69
22.23
24.77
27.31
32.39
37.47
40.01
45.09
50.17
52.71
55.25
57.79
62.87
65.41
70.49
73.03
78.11
83.19
85.73
95.89
98.43
108.59
116.21
118.75
131.45
133.99
139.07
159.39
172.09
D±0.25
24.77
27.31
29.85
32.39
34.93
40.01
45.09
47.63
52.71
57.79
60.33
62.87
65.41
70.49
73.03
78.11
80.65
85.73
90.81
93.35
103.51
106.05
116.21
123.83
126.37
139.07
141.61
146.69
167.01
179.71
E±0.51
32.39
34.93
37.47
40.01
42.55
47.63
52.71
55.25
60.33
65.41
67.95
70.49
73.03
78.11
80.65
85.73
88.27
93.35
98.43
100.97
111.13
113.67
123.83
131.45
133.99
146.69
149.23
154.31
174.63
187.33
F+0.13/-0.38
8.38
10.16
* Consult factory for availability.
51
很抱歉,暂时无法提供与“HSC18DREN”相匹配的价格&库存,您可以联系我们找货
