1
2
DWG. NO.
USE
MAXIMUM
CURRENT (AMP)
MAXIMUM
VOLTAGE (VAC)
MAXIMUM
WIRE
(mm)
2,4
POWER
44
600
6.3
1,3,5
SIGNAL
13
250
3.3
CIRCUIT
S100057
NOTES:
1.
MATES WITH UTS7__18X2M3P.
2.
CIRCUITS 2 & 4 USE
SEPARATELY.
3.
CIRCUITS 1, 3, AND 5 USE 1.6mm TRIM TRIO SOCKET CONTACTS ORDERED
SEPARATELY.
4.
4.1
4.2
MATERIALS: ALL RoHS COMPLIANT
PLUG: COUPLING AND INSULATOR: POLYAMIDE UL94VO, COLOR-BLACK.
BACKSHELL: POLYAMIDE UL94VO, COLOR-BLACK.
5.
5.1
5.2
5.3
5.4
5.5
5.6
MECHANICAL / ENVIRONMENTAL PERFORMANCE
OPERATING TEMPERATURE: -40$TO +105°C.
CORROSION: SALT SPRAY, 500 HOURS.
DURABILITY: 250 MATE-UNMATE CYCLES.
VIBRATION: SINUSOIDAL PER CEI 60512-4; 10-TO-2,000 Hz.
THERMAL SHOCK: 5 CYCLES X 30-MINUTES: -40$TO +105°C.
SEALING IN MATED CONDITION: IEC 60529-IP68: 10M WATER, 1-WEEK;
DYNAMIC-IP69K: HIGH-PRESSURE WATER, DIN 40050.
6.
ELECTRICAL PERFORMANCE:
DIELECTRIC WITHSTANDING VOLTAGE / INSULATION RESISTANCE
2200 VRMS MAX. BETWEEN CIRCUITS 2,4 / 5000 M Ohm MIN. @ 500 VDC.
1500 VRMS MAX. BETWEEN CIRCUITS 1,3,5 / 5000 M Ohm MIN. @ 500 VDC.
7
PACKAGING: SOURIAU LABEL INCLUDES PART NO.,QTY. & UL INFORMATION.
8.
UL 1977 RECOGNIZED
9.
U.S. PATENT 7,955,125.
10
MOLDING VOID CORES ARE INDICATED "X".
THIS DRAWING IS A CONTROLLED DOCUMENT FOR SOURIAU USA, INC.
IT IS SUBJECT TO CHANGE WITHOUT NOTIFICATION.
CONTACT THE DOCUMENT CONTROL CENTER FOR THE LATEST REVISION.
3.15
1.56
X
X
X
X
CABLE RANGE
7-16mm
WITH REDUCING SEAL
X
SCALE
X
2:1
3.6mm TRIM TRIO SOCKET CONTACTS ORDERED
B
THE INFORMATION CONTAINED IN THIS DRAWING IS CONFIDENTIAL AND MAY NOT BE
DISCLOSED WITHOUT WRITTEN CONSENT FROM SOURIAU USA, INC.
BACKSHELL
ASSEMBLY
PLUG
A
RELEASED PER ECN 11932
RSK
03-12-13
NPP
03-12-13
REV
DESCRIPTION
BY
DATE
CHKD
DATE
A
DRAWING TITLE
UTS CABLE PLUG, SIZE-18, SOCKET, 2X#8, 3X#16
CAT NO.
X
UTS6JC18X2M3S
CAGE NO: 09922
APPROVAL
LINEAR
Client Drawing Approval
Authorized SignatureMEASURE:
Option
THIRD ANGLE PROJECTION
& Date
Approved with no Exceptions
Approved with Exceptions Noted
TOLERANCES
UNLESS OTHERWISE SPECIFIED
No. OF PLACES
INCH [mm]
Rejected
ONE PLACE
#.1 [ #3]
The signature above indicates the client's authorized representative has
TWO PLACES
#0.02 [ #.5]
reviewed, understands, and concurrs with the requirements defined
#0.010 [ #.25]
herein If no signature is provided, placement of a purchase order by theTHREE PLACES
client is considered drawing acceptance.
ANGLES #1 $
F99930
Revision/Resubmission Required
2
Company Name
CUSTOMER
INTERPRET THIS DRAWING IN ACCORDANCE
WITH ASME Y14.5M - 1994.
03-06-13
DRAWN: RSK
03-06-13
CHKD :
NPP
03-06-13
DSGN :
NPP
03-06-13
MFG :
DH
03-06-13
QC
BB
DRAWING SCALE: 1:1
DRAWING NO.
REV
A
S100057
www.souriau.com
1
1 OF 1
PRO-E
很抱歉,暂时无法提供与“UTS6JC18X2M3S”相匹配的价格&库存,您可以联系我们找货
