1.25mm Pitch Miniature Crimping Connector (UL Listed)
DF13 Series
Right Angle Type
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Straight Type
Type
Mounting Type
Mounting Height(h)
DIP
5.3mm
SMT
5.8mm
DIP
3.6mm
SMT
■Features
Correspond to Automatic Mounting
1. Miniature Size
Secure the automatic plain area for the absorption
type automatic mounting machine.
Designed in the low profile at mounting height 5.8mm.
(SMT mounting straight type)
(For DIP type, the mounting height is to 5.3mm to the
straight and 3.6mm at the right angle)
Straight Type
Absorption area
2. Multi-contact
The double row type achieves the multi-contact up to 40
contacts, and secures 30% higher density in the mounting
area, compared with the single row type.
3. Correspond to Automatic Mounting
The header provides the grade with the vacuum absorption
area, and secures automatic mounting by the embossed
tape packaging.
In addition, the tube packaging can be selected. (Fig.1)
Metal fitting
4. Integral Basic Function Despite Miniature Size
The header is designed in a scoop-proof box structure, and
completely prevents mis-insertion.
In addition, the surface mounting (SMT) header is equipped
with the metal fitting to prevent solder peeling. (Fig.1)
Right Angle Type
Absorption area
5. UL Certifled
■Applications
Note PC, mobile terminal, miniature type business equipment,
and other various consumer equipment, including video
camera
Fig.1
2022.4
1
DF13 Series●1.25mm Pitch Miniature Crimping Connector (UL Listed)
■Product Specifications
Specification
1A/pin
UL
Specification 150V AC/DC
Voltage rating
UL
29.9V AC/DC
Current rating
Rating
Item
Operating Temperature Range : -35 to +85ç (Note 1) Storage Temperature Range : -10 to +60ç (Note 2)
Operating Moisture Range : 20 to 80% (Note 3)
Storage Moisture Range : 40 to 70% (Note 2)
Specification
Condition
1.Insulation Resistance
500Mø min.
100V DC
2.Withstanding voltage
No flashover or insulation breakdown.
500V AC/1 minute
3.Contact Resistance
30mø max.
100mA
4.Vibration
No electrical discontinuity of 1μs or more
Frequency : 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions.
5.Humidity (Steady state) Contact resistance : 30mø max. Insulation resistance : 500Mø min.
6.Temperature Cycle
96 hours at temperature of 40ç and humidity of 90% to 95%
(-55ç : 30 minutes➝ 5 to 35ç : 10 minutes➝ 85ç : 30 minutes➝ 5 to 35ç : 10 minutes) 5 cycles
7.Durability (Mating/un-mating) Contact resistance : 30mø max.
Tin plating : 30 cycles
Gold plating : 50 cycles
8.Resistance to Soldering heat
No deformation of components affecting performance.
Flow : 250ç for 10 seconds
Manual soldering : 300ç for 3 seconds
Reflow : At the recommended temperature profile
●UL File No. and Recognition
Note 1 : Includes temperature rise caused by current flow.
Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. No. UL : E52653
Operating Temperature Range and Humidity range covers non conducting condition of
installed connectors in storage, shipment or during transportation.
Note 3 : Use without condensation on parts.
Note 4 : Information contained in ths catalog represents general requirements for this Series.
Contact us for the drawings and specifications for a specific part number shown.
■Materials/Finish
Product
Crimping Socket
Crimping Contact for Socket
Pin Header (Through hole)
Pin Header (SMT Single row)
Pin Header (SMT Double row)
Part
Insulator
Contact
Insulator
Contact
Insulator
Contact
Metal Fitting
Insulator
Contact
Metal Fitting
Material
Polyamide
Phosphor copper
Polyamide
Brass
Polyamide
Brass
Phosphor copper
Polyamide
Brass
Phosphor copper
Finish
Beige
Tin plated or gold plated
Beige
Tin plated
Beige
Tin plated
Beige
Tin plated
Remarks
UL94V-0
UL94V-0
UL94V-0
UL94V-0
RoHS2
Yes
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Connector
DF13 - * S - 1.25 C
q
q Series Name : DF13
w
e
r
t
e Connector Type
t Connection Form / Contact Style.
w Number of Contacts
S : Single row socket
C : Crimping socket
r Single row : 2 to 12, 14, 15
P : Single row pin header
DSA : Straight through hole
r Double row : 10, 20, 30, 40
DS : Double row socket
DS : Right angle through hole
DP : Double row pin header
V : Straight SMT
r Contact Pitch : 1.25mm
H : Right angle SMT
●Contact
DF13 # - 2630 SCF A
q
w
e
r
q Style Symbol
Blank : Standard
w Applicable Cable Size 2630 : 26 to 30 AWG
3032 : 30 to 32 AWG
2
e Packaging Type SCF : Socket Contact/Reel
G : Low insertion / extraction r Plating Type
Blank : Tin plated
A : Gold plated
■Single Row Socket
Photo: Contact insertion
Part No.
HRS No. No. of Contacts
A
536-0001-4
1.25
DF13-2S-1.25C
2
536-0002-7
2.50
DF13-3S-1.25C
3
536-0003-0
3.75
DF13-4S-1.25C
4
536-0004-2
5.00
DF13-5S-1.25C
5
536-0005-5
6.25
DF13-6S-1.25C
6
536-0006-8
7.50
DF13-7S-1.25C
7
536-0007-0
8.75
DF13-8S-1.25C
8
Note 1 : The quantity is delivered per bag (100pcs.).
B
Part No.
4.15
536-0008-3
DF13- 9S-1.25C
9
536-0009-6
5.40
DF13-10S-1.25C
10
6.65
536-0010-5
DF13-11S-1.25C
11
7.90
536-0011-8
DF13-12S-1.25C
12
9.15
536-0012-0
DF13-13S-1.25C
13
10.40
536-0013-3
DF13-14S-1.25C
14
11.65
536-0014-6
DF13-15S-1.25C
15
If needed, please select and order the products per bag.
Unit : mm
A
B
10.00 12.90
11.25 14.15
12.50 15.40
13.75 16.65
15.00 17.90
16.25 19.15
17.50 20.40
■Double Row Socket
Photo: Contact insertion state
Unit : mm
Part No.
A
B
DF13-10DS-1.25C
536-0550-2
10
10.40
5.00
DF13-20DS-1.25C
536-0555-6
11.25
DF13-30DS-1.25C(10) 536-0560-6 10
30
22.90
17.50
DF13-40DS-1.25C(10) 536-0565-0 10
40
29.15
23.75
Note : The quantity is delivered per bag (100pcs). If needed, please select and order the products per bag.
3
■Single Row Straight Pin Header (Through hole)
[Specific No.]
(05) : Tin plated
(25) : Tin plated, tube packaging
BTube Dimensions
10
5
●Board Through-hole Diameter : Ø0.6±0.03
Part No.
HRS No. No. of Contacts A
B Tube Packaging Quantity
Part No.
115
DF13-2P-1.25DSA(**) 536-0101-9 **
2
1.25 4.15
DF13- 9P-1.25DSA(**)
89
DF13-3P-1.25DSA(**) 536-0102-1 **
3
2.50 5.40
DF13-10P-1.25DSA(**)
72
DF13-4P-1.25DSA(**) 536-0103-4 **
4
3.75 6.65
DF13-11P-1.25DSA(**)
61
DF13-5P-1.25DSA(**) 536-0104-7 **
5
5.00 7.90
DF13-12P-1.25DSA(**)
52
DF13-6P-1.25DSA(**) 536-0105-0 **
6
6.25 9.15
DF13-13P-1.25DSA(**)
46
DF13-7P-1.25DSA(**) 536-0106-2 **
7
7.50 10.40
DF13-14P-1.25DSA(**)
41
DF13-8P-1.25DSA(**) 536-0107-5 **
8
8.75 11.65
DF13-15P-1.25DSA(**)
Note 1 : The quantity at the specific No."05" is delivered per bag (100pcs.). If needed,
Note 2 : Order the tube packaging product, multiplying the tube packaging quantity.
Unit: mm
37
536-0108-8 **
9
10.00 12.90
34
536-0109-0 **
10
11.25 14.15
31
536-0110-0 **
11
12.50 15.40
29
536-0111-2 **
12
13.75 16.65
27
536-0112-5 **
13
15.00 17.90
25
536-0113-8 **
14
16.25 19.15
23
536-0114-0 **
15
17.50 20.40
■Single Row Right Angle Pin Header (Through hole)
[Specific No.] (**), **
(25) : Tin plated tube packaging
BTube Dimensions
Part No.
DF13-2P-1.25DS(25)
DF13-3P-1.25DS(25)
DF13-4P-1.25DS(25)
DF13-5P-1.25DS(25)
DF13-6P-1.25DS(25)
DF13-7P-1.25DS(25)
DF13-8P-1.25DS(25)
Note 1 : Order the
4
Part No.
2
1.25 4.15
115
536-0151-7 25
DF13- 9P-1.25DS(25)
3
2.50 5.40
89
536-0152-0 25
DF13-10P-1.25DS(25)
4
3.75 6.65
72
536-0153-2 25
DF13-11P-1.25DS(25)
5
5.00 7.90
61
536-0154-5 25
DF13-12P-1.25DS(25)
6
6.25 9.15
52
536-0155-8 25
DF13-14P-1.25DS(25)
7
7.50 10.40
46
536-0156-0 25
DF13-15P-1.25DS(25)
8
8.75 11.65
41
536-0157-3 25
9
536-0158-6 25
10
536-0159-9 25
11
536-0160-8 25
12
536-0161-0 25
14
536-0163-6 25
15
536-0164-9 25
Unit : mm
A
10.00 12.90
37
11.25 14.15
34
12.50 15.40
31
13.75 16.65
29
16.25 19.15
25
17.50 20.40
23
■Single Row Straight Pin Header (SMT)
■(Three-Wall/Correspond to Vacuum Absorption)
1.8
BPCB mounting pattern
Note 1.Shaded area must be free of any
electrically conductive traces to
avoid contact with soldered pin
header terminations.
This pin header is a three-wall type, header has sufficiently large flat areas to allow
pick-up with vacuum nozzles of automatic placement equipment.
(21) : Tin plated embossed tape packaging
(51) : Gold plated embossed tape packaging
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
D
E
F
1.25 4.15 7.15 5.65 1.95 2.20
2
536-0401-2 **
DF13C- 2P-1.25V(**)
2.50 5.40 8.40 6.90 3.20 3.45
3
536-0402-5 **
DF13C- 3P-1.25V(**)
3.75 6.65 9.65 8.15 4.45 3.10
4
536-0403-8 **
DF13C- 4P-1.25V(**)
5.00 7.90 10.90 9.40 5.70 4.35
5
536-0404-0 **
DF13C- 5P-1.25V(**)
6.25 9.15 12.15 10.65 6.95 5.60
6
536-0405-3 **
DF13C- 6P-1.25V(**)
7.50 10.40 13.40 11.90 8.20 6.85
7
536-0406-6 **
DF13C- 7P-1.25V(**)
8.75 11.65 14.65 13.15 9.45 8.10
8
536-0407-9 **
DF13C- 8P-1.25V(**)
10.00 12.90 15.90 14.40 10.70 9.35
9
536-0408-1 **
DF13C- 9P-1.25V(**)
11.25 14.15 17.15 15.65 11.95 10.60
10
536-0409-4 **
DF13C-10P-1.25V(**)
12.50 15.40 18.40 16.90 13.20 11.85
11
536-0410-3 **
DF13C-11P-1.25V(**)
13.75 16.65 19.65 18.15 14.45 13.10
12
536-0411-6 **
DF13C-12P-1.25V(**)
16.25 19.15 22.15 20.65 16.95 15.60
14
536-0413-1 **
DF13C-14P-1.25V(**)
17.50 20.40 23.40 21.90 18.20 16.85
15
536-0414-4 **
DF13C-15P-1.25V(**)
Note 1 : Please order the embossed tape packaging product according to reel number. (1000pcs/reel)
Emboss
Width
16
16
24
24
24
24
24
24
24
32
32
32
44
5
■Single Row Right Angle Pin Header (SMT)
■(Four-Wall/Correspond to Vacuum Absorption)
1.8
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
D
Emboss
Width
1.25 4.15 7.15 5.65
16
2
536-0301-8 **
DF13A- 2P-1.25H(**)
2.50 5.40 8.40 6.90
16
3
536-0302-0 **
DF13A- 3P-1.25H(**)
3.75 6.65 9.65 8.15
24
4
536-0303-3 **
DF13A- 4P-1.25H(**)
24
5
536-0304-6 **
DF13A- 5P-1.25H(**)
24
6
536-0305-9 **
DF13A- 6P-1.25H(**)
24
7
536-0306-1 **
DF13A- 7P-1.25H(**)
24
536-0307-4 **
8
DF13A- 8P-1.25H(**)
24
9
536-0308-7 **
DF13A- 9P-1.25H(**)
24
10
536-0309-0 **
DF13A-10P-1.25H(**)
32
11
536-0310-9 **
DF13A-11P-1.25H(**)
32
12
536-0311-1 **
DF13A-12P-1.25H(**)
32
14
536-0313-7 **
DF13A-14P-1.25H(**)
44
15
536-0314-0 **
DF13A-15P-1.25H(**)
6
■Double Row Straight Pin Header (SMT)
Note 1. Shaded area must be free of any electrically
conductive traces to avoid contact with soldered
pin header terminations.
(22) : Tin plated embossed tape packaging
(52) : Gold plated embossed tape packaging
Unit : mm
Spec No. Spec No. Emboss
HRS No.
No. of Contacts
A
B
C
(22)
(52)
Width
DF13EA-10DP-1.25V(**)
536-0570-0
10
12.10
5.00
8.70
24
DF13EA-20DP-1.25V(**)
536-0571-0
18.35 11.25 14.95
32
44
44
Part No.
DF13EA-30DP-1.25V(**)
536-0572-0
30
24.60 17.50 21.20
DF13EA-40DP-1.25V(**)
536-0573-0
40
30.85 23.75 27.45
Note 2 : The absorption cap is attached to the embossed tape packaging product.
7
■Crimping Contact
KDF13
KDF13G
1
8
0.5
7.2
2
0.9
3.7
3.3
0.8
1.5
0.15
BApplication Pattern
Through hole
(Single Row Product)
SMT
(Double Row Product)
Right Angle
SMT
Straight
9
BEmbossed Carrier Tape Dimensions
A−A
(1.4)
3±
Ø370±2
B±0.1
A±0.3
Ø21±0.8
(Ø80)
Product name label
A
A
2±0.5
0.4±0.1
C±0.1
4±0.1
5.2±0.15
Ø1
12±0.1
A
1.75±0.1
Ø5.25 +0.1
2±0.1(A<44mm)
2±0.15(A≧44mm)
.2
KDF13C-*P-1.25V (**)
+2
D 0
(D+6)MAX
A
DIRECTION OF UNREELING
0.2
A−A
(1.1)
2±0.5
3±
4.1±0.15
0.3±0.1
Ø1
Ø21±
(Ø80)
A
C±0.1
B±0.1
A±0.3
Product name label
Ø330±2
2±0.1(A
很抱歉,暂时无法提供与“DF13B-5P-1.25V(21)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+2.158581000+0.26204
- 3000+2.148493000+0.26082
- 4000+2.148444000+0.26081
- 10000+2.1484010000+0.26081
- 15000+2.1483515000+0.26080
- 国内价格 香港价格
- 1000+2.653251000+0.32210
- 2000+2.640852000+0.32059
- 3000+2.640803000+0.32058
- 4000+2.640734000+0.32058
- 5000+2.640685000+0.32057
