Female Card Edge
.100” [2.54 mm] Contact Centers, .610” [15.49 mm] Insulator Height,
Dip Solder/Wire Wrap/Right Angle/Card Extender
Sullins Female Card Edge
SPECIFICATIONS
• Accommodates .062” ± .008” [1.57 mm ± 0.20 mm] mating PCB
(For .093” [2.36 mm] or .125” [3.18 mm] mating PCB see following pages)
• PBT, PPS or PA9T insulator
• Molded-in key available
• 3 Amps current rating for one contact energized
• 30 milli Ohms maximum at rated current
READOUT
• UL Flammability Rating: 94V-0
POLARIZING KEY
PLC-K1
.038”
[0.97]
.285”
[7.24]
EVEN
NUMBER
SIDE
DUAL (D)
.100” [2.54]
KEY IN BETWEEN CONTACTS
(ORDER SEPARATELY)
HALF LOADED (H)
TERMINATION TYPE
HAIRPIN
BELLOWS
TERMINATION
TYPE
CW
DIP SOLDER
CT
CS
CM
CA
CB
CC
DIP SOLDER
DIP SOLDER
WIRE WRAP
RIGHT ANGLE
RIGHT ANGLE
RIGHT ANGLE
POST LENGTH FITS MIN.
L
HOLE SIZE
.025” [0.64]
.015ʺ X .025ʺ[0.38 X 0.64] .125ʺ [3.18] .035ʺ [0.89]
POST CROSS SECTION
K
.025ʺ [0.64] SQUARE
.025ʺ [0.64] SQUARE
.025ʺ [0.64] SQUARE
.025ʺ [0.64] SQUARE
.025ʺ [0.64] SQUARE
.170ʺ
.160ʺ
.560ʺ
.100ʺ
.180ʺ
.250ʺ
[4.32]
[4.06]
[14.20]
[2.54]
[4.57]
[6.35]
POST LENGTH
L
.025”ʺ [0.64]
.190ʺ [4.83]
.190ʺ [4.83]
.560ʺ [14.20]
.100ʺ [2.54]
.180ʺ [4.57]
.250ʺ [6.35]
.035ʺ
.040ʺ
.040ʺ
.043ʺ
.043ʺ
.043ʺ
[0.89]
[1.02]
[1.02]
[1.09]
[1.09]
[1.09]
L
.030” [0.76]
.275”
[6.98]
L
K
.200” [5.08]
ODD NUMBER
SIDE
(CW, CT, CS, CM)
.150” [3.81]
K
(CA, CB, CC, TA, TB, TM, KA, KE, KU, KJ)
HAIRPIN or LOOP CARD EXTENDER
LOOP
BELLOWS
TERMINATION
TYPE
POST CROSS SECTION
K
TK,CK
RS
RM
TA
TB
TM
DIP SOLDER
DIP SOLDER
WIRE WRAP
RIGHT ANGLE
RIGHT ANGLE
RIGHT ANGLE
.025ʺ [0.64] ROUND
.025ʺ [0.64] SQUARE
.025ʺ [0.64] SQUARE
.025ʺ [0.64] SQUARE
.025ʺ [0.64] SQUARE
.025ʺ [0.64] SQUARE
CANTILEVER
TERMINATION
TYPE
KS
DIP SOLDER
POST CROSS SECTION POST LENGTH
L
K
.025”ʺ [0.64]
.025ʺ [0.64] SQUARE .190ʺ [4.83]
.040ʺ [1.02]
KD
DIP SOLDER
.025ʺ [0.64] SQUARE
.160ʺ [4.06]
.043ʺ [1.09]
KM
WIRE WRAP
.025ʺ [0.64] SQUARE
.560ʺ [14.20]
.040ʺ [1.02]
*KA
RIGHT ANGLE
.025ʺ [0.64] SQUARE
.100ʺ [2.54]
.043ʺ [1.09]
*KE
RIGHT ANGLE
.025ʺ [0.64] SQUARE
.180ʺ [4.57]
.043ʺ [1.09]
*KU
RIGHT ANGLE
.025ʺ [0.64] SQUARE
.250ʺ [6.35]
.043ʺ [1.09]
FITS MIN.
HOLE SIZE
RIGHT ANGLE
.025ʺ [0.64] SQUARE
.033ʺ
.040ʺ
.040ʺ
.043ʺ
.043ʺ
.043ʺ
[0.84]
[1.02]
[1.02]
[1.09]
[1.09]
[1.09]
LOOP BELLOWS
L - .015” [0.38]
L
K
.200” [5.08]
(TK, CK, RS, RM)
FITS MIN.
HOLE SIZE
.500ʺ [12.70]
.043ʺ [1.09]
*KR
CARD EXTENDER .025ʺ [0.64] SQUARE
.235ʺ [5.97]
N/A
*KN
.605ʺ [15.37]
N/A
*KJ
RIGHT ANGLE
HAIRPIN BELLOWS
K
ACCOMMODATES
.062” [1.57] PCB
(CT, CS, CM,TK, CK, RS,RM)
Example P/N: EBC10DCSN-S288
(Requires -S288 Modification Code)
CANTILEVER CARD EXTENDER
CANTILEVER
.550” [13.97]
L
L
K
.200” [5.08]
(KS, KD, KM)
K
ACCOMMODATES
.062” [1.57] PCB
(KR, KN)
Example P/N: EBC10DKRN
(Omit Modification Code)
* KA, KE, KU, KJ, KR, KN have no standoffs, unless requested.
MOUNTING STYLE
Ø.125”
[3.18]
#4-40
Ø.125”
[3.18]
.250”
[6.35]
CLEARANCE
HOLE (H)
50
.245”
[6.22]
THREADED
INSERT(I)
SIDE MOUNTING
(S)
Ø.125” [3.18]
D = .250” [6.35]
W = .430” [10.92]
NO MOUNTING
EARS (N)
FLUSH MOUNTING
(D, W)
#4-40
T = .250” [6.35]
X = .430” [10.92]
FLUSH MOUNTING WITH
THREADED INSERT(T, X)
www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com
Female Card Edge
PART NUMBER OPTIONS
E B C 70 D CM H - Sxxx
All platings are Lead Free and have .000050” Nickel underplate
Contact Surface
Termination
.000010” Gold
.000100” Pure Tin, Matte
.000030” Gold
.000010” Gold
.000005” Gold
.000030” Gold
.000005” Gold
Contact Surface
Overall Plating
S = .000010” Gold
.000010” Gold
M = .000030” Gold
.000010” Gold
E = .000100” Pure Tin, Matte
CONTACT CENTERS
C = .100” [2.54 mm]
NUMBER OF CONTACT POSITIONS
See Chart Below
READOUT (Opposite Page)
D = Dual
H = Half Loaded
B
C
G
Y
MODIFICATION CODE (Consult Factory)
OMIT FOR STANDARD
-S189 = .200” [5.08 mm] Row to Row on Right Angle
-S288* = Card Extender Accepts .062” [1.57 mm] PCB
* Not Required on KR or KN Terminations
MOUNTING STYLE (Opposite Page)
H = Clearance Holes
I = Threaded Inserts
S = Side Mounting
N = No Mounting
D, W = Flush Mounting
T, X = Flush Mounting With Threaded Inserts
TERMINATION TYPE (Opposite Page)
Hairpin Bellows - Available with B or C plating and Phosphor Bronze Only
CS = .025” [0.64 mm] Square Dip Solder
CM = .025” [0.64 mm] Square Wire Wrap
CA, CB, CC = .025” [0.64 mm] Square Right Angle
CW, CT = .015” X .025” [0.38 mm X 0.64 mm] Dip Solder
Loop Bellows
RS = .025” [0.64 mm] Square Dip Solder
CK, TK = .025” [0.64 mm] Round Dip Solder
RM = .025” [0.64 mm] Square Wire Wrap
TA, TB, TM = .025” [0.64 mm] Square Right Angle
Cantilever Bellows - Available in Y, B, or C plating Only
KS, KD = .025” [0.64 mm] Square Dip Solder
KM = .025” [0.64 mm] Square Wire Wrap
KA, KE, KU, KJ = .025” [0.64 mm] Square Right Angle
KR, KN = .025” [0.64 mm] Square Card Extender
MATERIALS (INSULATOR/CONTACT)
E = PBT/Phosphor Bronze (Standard)
R = PPS/Phosphor Bronze
G = PA9T/Phosphor Bronze
H = PBT/Beryllium Copper
A = PPS/Beryllium Copper
J = PA9T/Beryllium Copper
(Consult factory for other materials.)
Refer to Page 7 for Operating/Processing Temperatures
CONTACT FINISH - RoHS Compliant
DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches.
.297 [7.54] INSERTION DEPTH
C
REFER TO MOUNTING STYLE
.610
[15.49]
.250[6.35]
A
B
D
E
.060[1.52]
CONTACT MARKINGS
1 3 5 . . . 137 139
2 4 6 . . . 138 140
.370 [9.40]
.180[4.57]
.100[2.54]
TYP.
F
1
3
5
7
9 131 133 135137 139
2
4
6
8
10 132 134 136 138 140
REFER TO
TERMINATION TYPE
Tolerances on non-critical dimensions may very slightly due to shrinkage differential per insulator material; Consult factory.
INCHES
MILLIMETERS
POSITIONS/
CONTACTS
A±.008
B±.008
0.500
0.700
06/12
07/14
0.600
0.800
08/16
0.700
0.900
10/20
0.900
1.100
12/24
1.100
1.300
13/26
1.200
1.400
15/30
1.400
1.600
17/34
1.600
1.800
18/36
1.700
1.900
20/40
1.900
2.100
22/44
2.100
2.300
24/48
2.300
2.500
25/50
2.400
2.600
28/56
2.700
2.900
30/60
2.900
3.100
31/62
3.000
3.200
35/70
3.400
3.600
36/72
3.500
3.700
40/80
3.900
4.100
43/86
4.200
4.400
44/88
4.300
4.500
49/98*
4.800
5.000
50/100
4.900
5.100
55/110
5.400
5.600
60/120
5.900
6.100
61/122
6.000
6.200
65/130
6.400
6.600
70/140
6.900
7.100
80/160*
7.900
8.100
90/180*
8.900
9.100
100/200*
9.900
10.100
* Consult factory for availability.
C±.015
0.860
0.960
1.060
1.260
1.460
1.560
1.760
1.960
2.060
2.260
2.460
2.660
2.760
3.060
3.260
3.360
3.760
3.860
4.260
4.560
4.660
5.160
5.260
5.760
6.260
6.360
6.760
7.260
8.260
9.260
10.260
D±.010
1.175
1.275
1.375
1.575
1.775
1.875
2.075
2.275
2.375
2.575
2.775
2.975
3.075
3.375
3.575
3.675
4.075
4.175
4.575
4.875
4.975
5.475
5.575
6.075
6.575
6.675
7.075
7.575
8.575
9.575
10.575
E±.020
1.435
1.535
1.635
1.835
2.035
2.135
2.335
2.535
2.635
2.835
3.035
3.235
3.335
3.635
3.835
3.935
4.335
4.435
4.835
5.135
5.235
5.735
5.835
6.335
6.835
6.935
7.335
7.835
8.835
9.835
10.835
F±.015
0.750
0.850
0.950
1.150
1.350
1.450
1.650
1.850
1.950
2.150
2.350
2.550
2.650
2.950
3.150
3.250
3.650
3.750
4.150
4.450
4.550
5.050
5.150
5.650
6.150
6.250
6.650
7.150
8.150
9.150
10.150
A±0.20
12.70
15.24
17.78
22.86
27.94
30.48
35.56
40.64
43.18
48.26
53.34
58.42
60.96
68.58
73.66
76.20
86.36
88.90
99.06
106.68
109.22
121.92
124.46
137.16
149.86
152.40
162.56
175.26
200.66
226.06
251.46
B±0.20
17.78
20.32
22.86
27.94
33.02
35.56
40.64
45.72
48.26
53.34
58.42
63.50
66.04
73.66
78.74
81.28
91.44
93.98
104.14
111.76
114.30
127.00
129.54
142.24
154.94
157.48
167.64
180.34
205.74
231.14
256.54
C±0.38
21.84
24.38
26.92
32.00
37.08
39.62
44.70
49.78
52.32
57.40
62.48
67.56
70.10
77.72
82.80
85.34
95.50
98.04
108.20
115.82
118.36
131.06
133.60
146.30
159.00
161.54
171.70
184.40
209.80
235.20
260.60
D±0.25
29.85
32.39
34.93
40.01
45.09
47.63
52.71
57.79
60.33
65.41
70.49
75.57
78.11
85.73
90.81
93.35
103.51
106.05
116.21
123.83
126.37
139.07
141.61
154.31
167.01
169.55
179.71
192.41
217.81
243.21
268.61
E±0.51
36.45
38.99
41.53
46.61
51.69
54.23
59.31
64.39
66.93
72.01
77.09
82.17
84.71
92.33
97.41
99.95
110.11
112.65
122.81
130.43
132.97
145.67
148.21
160.91
173.61
176.15
186.31
199.01
224.41
249.81
275.21
F±0.38
19.05
21.59
24.13
29.21
34.29
36.83
41.91
46.99
49.53
54.61
59.69
64.77
67.31
74.93
80.01
82.55
92.71
95.25
105.41
113.03
115.57
128.27
130.81
143.51
156.21
158.75
168.91
181.61
207.01
232.41
257.81
51
