142-0307-011
    CINCH
    CONNSMAJACKSTR50OHMCRIMP
142-0307-011 数据手册
SMA Type Straight Plugs, Straight Jacks, and Straight Bulkhead Jacks for Flexible Cable – Crimp or Solder Contacts 1. Identify connector parts. (3 piece parts – except bulkhead) 2. Strip cable to dimensions shown. Do not nick braid or center conductor. Tin center conductor if contact will be solder attached. Do not tin center conductor if contact is to be crimp attached. When stripping LMR-100 low loss cable, remove foil back to where cable jacket is stripped. A wire stripper of correct size is recommended for this step. Slide heat shrink (as applicable) and crimp sleeve onto jacket of cable. 3. Assemble contact onto cable as shown. Solder Attachment: Solder contact to center conductor through solder hole using .020 (0.51) diameter solder. Use a minimum amount of solder for a good joint. Crimp Attachment: Crimp contact to center conductor using Johnson Hand Tool 144-0000-910, setting #2, with positioner 141-0000-907. Crimp location should be centered between end of contact and X-hole. Crimp attachment to solid center conductor cables is not recommended. 4. Flare braid and slide body assembly over contact and under braid. Then seat body assembly firmly onto contact. The cable may have to be held in a clamping fixture. Arrange braid uniformly around crimp stem. Slide crimp sleeve forward and crimp using recommended crimp tool. Slide heat shrink forward and shrink (as applicable). 238 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17 SMA Type Straight Plugs, Straight Jacks, and Straight Bulkhead Jacks for Flexible Cable – Crimp or Solder Contacts (cont’d from last page ) Cable Group RG-316/U, 161, 174, 188; LMR-100 RG-316 DS, 188 DS RG-58/U, 141, 303 RG-55/U, 142, 223, 400 RG-316/U, 161, 174, 188; LMR-100 RG-316 DS, 188 DS RG-58/U, 141, 303 RG-55/U, 142, 223, 400 RG-316/U, 161, 174, 188; LMR-100 RG-316 DS, 188 DS RG-58/U, 141, 303 RG-55/U, 142, 223, 400 RG-179/U, 187 RG-316/U, 161, 174, 188; LMR-100 RG-316 DS, 188 DS RG-58/U, 141, 303 RG-55/U, 142, 223, 400 RG-179/U, 187 RG-316/U, 161, 174, 188; LMR-100 RG-316 DS, 188 DS RG-58/U, 141, 303 RG-55/U, 142, 223, 400 RG-316/U, 161, 174, 188; LMR-100 RG-316 DS, 188 DS RG-58/U, 141, 303 RG-55/u, 142, 223, 400 RG-316/U, 161, 174, 188; LMR-100 RG-316 DS, 188 DS RG-58/U, 141, 303 RG-55/U, 142, 223, 400 RG-316/U, 161, 174, 188; LMR-100 RG-316 DS, 188 DS RG-58/U, 141, 303 RG-55/U, 142, 223, 400 RG-316/U, 161, 174, 188; LMR-100 RG-316 DS, 18 DS RG-58/U, 141, 303 RG-55/U, 142, 223, 400 RG-316/U, 161, 174, 188; LMR-100 RG-316 DS, 188 DS RG-58/U, 141, 303 239 Part No. “A” “B” Crimp Hex 141-0303-412 141-0304-412 141-0307-412 141-0308-412 141-0403-012 141-0404-012 141-0407-012 141-0408-012 142-0303-011/016 142-0303-411/416 142-9303-411 142-0304-011/016 142-0304-411/416 142-0307-011/016 142-0307-411/416 142-0308-011/016 142-0308-411/416 142-0333-011/016 142-0333-411/416 142-0403-011/016 142-0404-011/016 142-0407-011/016 142-0408-011/016 142-0433-011/016 142-1403-001/006 142-1404-001/006 142-1407-001/006 142-1408-001/006 142-4303-401/406 142-4304-401/406 142-4307-401/406 142-4308-401/406 142-4403-001/006 142-4404-001/006 142-4407-001/006 142-4408-001/006 142-5303-401/406 142-5304-401/406 142-5307-401/406 142-5308-401/406 142-5403-001/006 142-5404-001/006 142-5407-001/006 142-5408-001/006 142-9403-011 142-9404-011 142-9407-011 .128 (3.25) .151 (3.83) .213 (5.41) .213 (5.41) .128 (3.25) .151 (3.83) .213 (5.41) .213 (5.41) .270 (6.86) .270 (6.86) .270 (6.86) .270 (6.86) .270 (6.86) .270 (6.86) .270 (6.86) .295 (7.49) .105 (2.67) .128 (3.25) .151 (3.83) .128 (3.25) .105 (2.67) .128 (3.25) .151 (3.83) .213 (5.41) .215 (5.46) .215 (5.46) .278 (7.06) .278 (7.06) .128 (3.25) .128 (3.25) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .280 (7.11) .280 (7.11) .280 (7.11) .280 (7.11) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .715 (18.16) .715 (18.16) .715 (18.16) .715 (18.16) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .151 (3.83) .151 (3.83) .213 (5.41) .213 (5.41) .213 (5.41) .213 (5.41) .128 (3.25) .128 (3.25) .128 (3.25) .151 (3.83) 213 (5.41) .213 (5.41) .128 (3.25) .128 (3.25) .151 (3.83) .213 (5.41) .213 (5.41) .128 (3.25) .151 (3.83) .213 (5.41) .213 (5.41) .128 (3.25) .151 (3.83) .213 (5.41) .213 (5.41) .128 (3.25) .151 (3.83) .213 (5.41) .213 (5.41) .128 (3.25) .151 (3.83) .213 (5.41) .213 (5.41) .128 (3.25) .151 (3.83) 213 (5.41) Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
142-0307-011 价格&库存
很抱歉,暂时无法提供与“142-0307-011”相匹配的价格&库存,您可以联系我们找货
