2975-6200
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMAJACKSTR50OHMSOLDER
2975-6200 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING M DCN 41797 DATE APPROVED 10/15 DAL .531 13.49 .080 2.03 .040 1.02 .451 11.46 .020±.001 0.51±0.03 .061±.002 1.55±0.05 1/4-36 UNS-2A MATERIAL: BODY: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULATORS: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B GLASS: EN1 OR EQUIVALENT PIN: KOVAR FINISH: GLASS SEAL ASSEMBLY & CONTACT: GOLD PER ASTM B488, TYPE II, CODE C, CLASS .76, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: PERFORMANCE: N/A PROPRIETARY IMPEDANCE: FREQ. RANGE: 50 OHMS DC TO 18.0 GHz THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: BNK 10/29/15 CHECKED: APPROVED: DAL 10/29/15 DGG 12/19/75 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMA JACK HERMETIC SEAL SIZE CAGE CODE DWG. NO. B 95077 SCALE: 10:1 2975-6200 SHEET 1 OF 1
2975-6200 价格&库存
很抱歉,暂时无法提供与“2975-6200”相匹配的价格&库存,您可以联系我们找货
库存:250
