- Page 11 -
Specifications for TNC Connectors
TNC Series connectors are miniature sized, and weatherproof and are electrically similar to BNC Series, except that they
have a coupling method which utilizes a screw system giving them additional resistance against shock and vibration.
They are especially designed for use from DC to 18 GHz, in vibration exposed equipment like in commercial and
military radio telecommunications systems and avionics equipment. These connectors are particularly useful for
applications in computer and medical equipment and test instrumentation. TNC Series have a constant impedance of 50
ohms and are available in a variety of cable configurations.
MATERIALS
Connector Parts
Material
Equivalent Standard †
Connector Body and Parts
Brass
ISOCuZn38Pb2 Body Part
Male Contact Pin
Commercial Grade
Brass
Zinc Alloy/Brass
QQ-B-626
Outer Contact
Brass
QQ-B-750
Socket Contact
Socket Contact
Beryllium Copper
Phosphor Bronze
QQ-C-530/MIL-H-7199
CuBe2
Crimp Ferrule
Insulators, Standard Versions
Annealed Copper
Teflon
QQ-C-576
L-P403/BS4271
Rubber Gaskets
Delrin
Silicone Rubber
Grade B
ASTM-E1418PSI
Plating
Nickel (Silver Optional)
MIL-G-45204
ELECTRICAL
Requirement
Test †
Specification
Performance
50
Impedance
75
Frequency Range
VSWR
RF Insertion Loss
RF Leakage
0-18 GHz
0-1 GHz
1.30 Max.
0.2 dB Max. at 3 GHz
-60 dB Min. at 3 GHz
----MIL- C-39012
MIL- C-39012
MIL- C-39012
Test Voltage (At Sea Level)
1500V rms
MIL-STD-202
500V rms
MIL-STD-202
5000 Megohms Min.
MIL-STD-202
Working Voltage (At Sea
level)
Insulation Resistance
Contact Resistance
*Center Contact
*Outer Contact
5mW Maximum
2mW Maximum
MIL-C-39012
MECHANICAL & ENVIRONMENTAL
Requirement
Performance
Test †
Specification
Durability
500 Insertions & Extractions Min.
MIL-C-39012
Shock
50 G
MIL-STD-202
Vibration
20 G from 80-2000 Hz
MIL-STD-202
Cable Retention (Cable Types)
60 lbs. Minimum Pull Test
MIL-C-39012
Coupling Nut
60 lbs. Maximum
MIL-C-39012
Temperature Range
Teflon: -55 to +199 C
Delrin: -40 to +85 C
Moisture Resistance
Continuous Test
-------MIL-STD-202
Salt Spray
48 Hours
MIL-STD-202
†Products are made to conform to the Mil standard but are for commercial applications and not QPL
________________________
FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111
Back to Index
11
- Page 11 - Page 12 -
3 Piece Crimp
TNC three piece crimp connectors feature the same semi-captive contacts as the BNC which “click” into place assuring
perfect installation. Each crimp pin has a vent hole for optional soldering. Soldering is recommended for all stranded
conductors 26 AWG or smaller.
RG/U Cable
Fig.
No.
510A205F
510A204G
58A/U, 58C/U, Stranded, 141/U
59/U, 62/U, 210/U
57
57
510A204FV
58A/U, 58C/U, 141/U Plenum
58
Part Number
RoHS compliant
DRAWING
REQUEST QUOTE
Fig. 57
REQUEST
Fig. 58
s
Standard Clamp and Taper Grip
TNC standard clamp style is a simplified version of the original military style. It is required that the contact be soldered
to the center conductor of the cable. The Taper Grip style connectors require little cable preparation. Strip off all but a
length of center conductor, push the taper under the cable’s shield, solder the contact, and assemble.
Part Number
Fig. 51
Fig.50
RG/U Cable
510A104F
510A104G
510A304F
59/U, 62/U, 210/U
510A304G
59/U, 62/U, 210/U
RoHS compliant
DRAWING
REQUEST QUOTE
REQUES
Twist-On
TNC Twist-On connectors are field installable and require no tooling other than a stripping tool for the cable preparation.
The center conductor is inserted into Bomar’s unique Posi-Con™ contact, as the connector twists firmly onto the cable’s
outer jacket.
Part Number
Gender
RG/U Cable
Fig.
No.
510A405F
Male
510A405G
Male
520A405F
Female
520A405G
Female
RoHS compliant
141/U
59/U, 62/U, 210/U
53
53
141/U
59/U, 62/U, 210/U
REQUEST QUOTE
52
Fig. 53
52
Fig. 52
REQUEST DRAWING
s
Bulkhead Jacks
Versions are available for front mounting (F/M), rear mounting (R/M) , crimp types, bulkhead mount grounded, or
bulkhead mount isolated. These jacks are held into the panel by a hex-nut and lock washer. All units feature nickel
plated, brass bodies, and gold plated phosphor bronze contacts.
Part
Number
521A245F
521A245G
526A515
526R515
Fig. 54
Fig.
No.
RG/U Cable
141/U
RG59/U, RG62/U, RG210
56
56
Any Cable Size Non Isolated
Any Cable Size Isolated
RoHS compliant REQUEST QUOTE
DRAWING
54
55
REQUEST
s
Fig. 56
s
Fig. 55
s
s
Back to Index
12
- Page 12 - Page 13 -
TNC Connectors
Adapters
These sturdy within-series TNC adapters are available in all standard designs. All connector bodies are plated with bright
nickel. Male contacts are brass, female contacts are phosphor bronze. All contacts are plated with 5 micro-inches of gold.
Part
Number
Fig.
No.
Description
532A505
Female/Female Inline Splice
60
535A544
535R544
543A505
Female/Female Bulkhead Inline
Female/Female Bulkhead Inline, Isolated
Female/Male/Female “T” Adapter
61
61
62
545A505
Female/Female/Female “T” Adapter
63
551A505
Female/Male Right Angle"
64
RoHS compliant
DRAWING
REQUEST QUOTE
Fig. 62
REQUEST
Fig. 63
Fig. 60
Fig. 64
Fig. 61
PC Board Jacks
These TNC jacks are manufactured to the highest standards to assure stability in maintaining impedance matching at
rated frequencies. Applications are in cellular communications, broadcast, and computer data. Contacts are phosphor
bronze and will remain resilient even after 500 insertions.
Part Number
Body
Material
Description
Contact
Plating
Fig.
No.
561V504E
Metal
V-Bite W/ Teflon Reflow Solder
Gold
564A595
White Valox
Standard Profile W/ Posts
Gold
66
564A595B
564A595BL
BlackValox
White Valox
Low Profile W/ Posts
Gold
Gold
67
68
564A595BLB
BlackValox
Gold
69
564A595M
564S595
Metal
White Valox
Vertical Mounting
Gold
Gold
70
71
564S595B
564S595M
BlackValox
Metal
Vertical Mounting
Vertical Mounting
Gold
Gold
72
73
RoHS compliant reflow or wave solder
REQUEST QUOTE
Fig. 71
Fig. 72
Fig. 73
RoHS compliant wave solder only
REQUEST DRAWING
Fig. 66
Fig. 68
Fig. 69
Fig. 70
- Page 13 -
Back to Index
13
