HRM-601A(52)
HRM-601A(52)
    HRS(广濑)
    Terminator Coax Connector Plug, Male Pin SMA 50 Ohm
HRM-601A(52) 数据手册
2015/11/25 10:21:33(JST) EK.UCHIYAMA APPLICABLE STANDARD OPERATING TEMPERATURE RANGE RATING 0.25 W (at 65℃) POWER OPERATING RELATIVE HUMIDITY 95% MAX STORAGE TEMPERATURE RANGE CHARACTERISTIC IMPEDANCE -40℃ TO +85℃ 50Ω ( DC TO 26.5 GHz) USED CONNECTOR HRM-P(SMA-P) SPECIFICATIONS ITEM TEST METHOD REQUIREMENTS QT AT X X X X X X X X X - X - X - X - X - CONSTRUCTION GENERAL EXAMINATION VISUALLY AND BY MEASURING INSTRUMENT. MARKING CONFIRMED VISUALLY. ACCORDING TO DRAWING. ELECTRIC CHARACTERISTICS MUST BE UNDER THE STD.VALUE AT FREQENCY DC TO 4.0 GHz MUST BE UNDER THE STD.VALUE AT FREQENCY 4.0 TO 8.0 GHz MUST BE UNDER THE STD.VALUE AT FREQENCY 8.0 TO 12.4 GHz MUST BE UNDER THE STD.VALUE AT FREQENCY 12.4 TO 18.0 GHz MUST BE UNDER THE STD.VALUE AT FREQENCY 18.0 TO 26.5 GHz V.S.W.R. DRAWING FOR REFERENCE:This is subject to change without notice -40℃ TO +85℃ MAXIMUM OF 1.08 MAXIMUM OF 1.10 MAXIMUM OF 1.12 MAXIMUM OF 1.15 MAXIMUM OF 1.20 RESISTANCE VALUE MEASURE THE RESISTANCE VALUE AT DC1V. 48 TO 52 Ω TEMPERATURE RISE IMPRESSED THE POWER RATING(DC). MAXIMUM OF 40℃ MECHANICAL CHARACTERISTICS VIBRATION FREQUENCY 10 TO 2000 Hz, 2 TOTAL AMPLITUDE 1.52 mm, 98 m/s AT 4 HOURS FOR 3 DIRECTIONS. SHOCK ACCELERATION : 490 m/s2 DURATION : 11 ms , HALF SINE WAVE 3 BOTH AXIAL DIRECTIONS, 3 TIMES EACH ①ELECTRICAL CHARACTERISTIC SHALL BE MET. ②NO DAMAGE, CRACK, AND LOOSENESS, OF PARTS. ①ELECTRICAL CHARACTERISTIC SHALL BE MET. ②NO DAMAGE, CRACK, AND LOOSENESS, OF PARTS. ENVIRONMENTAL CHARACTERISTICS -55 →15~35 →85 →15~35℃ TIME 30 →2~3 → 30 →2~3 min TEST 5 CYCLES AND LEAVE IT FOR ONE HOUR OR TWO. SALT SOLUTION CONCENTRATION 5% SALT WATER SPRAY FOR 48 HOURS. TEMPERATURE RAPID CHANGE OF TEMPERATURE SALT ATMOSPHERE (CORROSION) △ 1 ①ELECTRICAL CHARACTERISTIC SHALL BE MET. ②NO DAMAGE, CRACK, AND LOOSENESS, OF PARTS. NO CORROSION WHICH AFFECTS THE OPERATION OF COMPONENT. COUNT DESCRIPTION OF REVISIONS DESIGNED 1 DIS-D-00000579 YI.FUNADA REMARK (1) ROHS COMPLIANT (2) USE LEAD FREE SOLDER(Sn3.0Ag0.5Cu). (3) MARKING IS HRM601A(26.5). 1 Unless otherwise specified, refer to IEC 60512. Note QT:Qualification Test AT:Assurance Test X:Applicable Test FORM HD0011-2 PART NO. HIROSE ELECTRIC CO., LTD. CODE NO. DATE TO.KATAYAMA 15.10.09 APPROVED KY.SHIMIZU 15.01.14 CHECKED TO.KATAYAMA 15.01.14 DESIGNED YI.FUNADA 15.01.14 DRAWN YI.FUNADA 15.01.14 DRAWING NO. SPECIFICATION SHEET CHECKED ELC-030012-52-52 HRM-601A(52) CL353-0017-3-52 1 △ 1/1 DRAWING FOR REFERENCE:This is subject to change without notice 2015/11/25 10:21:33(JST) EK.UCHIYAMA
HRM-601A(52) 价格&库存
很抱歉,暂时无法提供与“HRM-601A(52)”相匹配的价格&库存,您可以联系我们找货
