FTY.00.250.CTF
www.lemo.com
SUMMARY
# Wires
Coax
1
Image is for illustrative purpose only
Series
00
Termination type
Coupler/adapter/bridge
IP rating
50
AWG wire size
0.00 - 0.00
Cable Ø
0.00 - 0.00 mm
Status
active
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FTY*: Straight plug with two parallel receptacles
Keying
Circular (can rotate)
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
12.28 g
Performance
Configuration
00.250 : 1 Coax (50 Ohm)
Insulator
T: PTFE
Rated Current
4 Amps
Specifications
Contact Type: Coaxial 50 Ohm
Test voltage: 1.1 kV (rms)
Others
Endurance (Shell): 5000 mating cycles
F ret (min): 100 N
Salt Spray Corrosion: >1000 hr
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/2
DRAWINGS
Dimensions
A
L
mm.
7
29.5
in.
0,28
1,16
RECOMMENDED BY LEMO
Tools
2/2
很抱歉,暂时无法提供与“FTY.00.250.CTF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+382.78160
- 10+371.29513
- 50+359.81908
- 100+352.17532
- 250+344.52114
