Interface Coaxial Switches
MS-145 Series
■Overview and applications
Designed primarily as interface coaxial switch for
a mobile phones, they are also used in variety of
other applications requiring redirecting of signals
when mating with corresponding plug.
The mating action redirects the signals from the
receptacle side to the plug side.
Receptacle
■Features
01. Frequency range
Can be used from DC to 2.5 GHz and with GSM, PCS, cdmaOne,W-CDMA, etc.
02. Low profile
Low protrusion of only 6mm above the mounting surface
(receptacle).
03. Durability
High durability(mating/unmating) of 10 000 cycles.
04. Self alignment of mating parts
Inducement to floating is ±0.5mm.
05. Light weight
Plug
Weight is only 0.18g.
06. Small board surface solder area
The area is 7 ∞4.6mm(excluding leads).
07. Automatic mounting
Receptacle designed for placement on board with automated
equipment.
08. Solder wicking
Receptacle terminations are designed to prevent solder wicking
into the critical contact areas.
MS-145-C(LP)-1
MS-145-C(LP)-A
MS-145-HRMJ
MS-145-HRMP
09. Plugs
Wide variety of mating heights are available.
10. Adaptors
Different adaptors are available.
■Applications
Mobile Phone antenna switching
Checks of microwave boards, etc.
■Materials
Part
Material
Outer shell
Phosphor bronze
Insulator
Polyamide resin
Common contact
Beryllium copper
Board circuit side (N.C.) contact
Beryllium copper
Color/Finish
UL standard
UL94HB
Mounting area : Solder over Nickel plating
Contact area
: Gold over Nickel plating
Others
: Nickel Plating
Gold plating
Contact area
Others
: Nickel Plating
113
■Performance
Specification
Operating temperature range
-30ç to +85ç
Power
2 W (4W : at 1/8 duty ratio)
Frequency range
DC to 2.5 GHz
0.3 dB or less (DC to 1 GHz)
Insertion loss
0.4 dB or less (1 GHz to 2 GHz)
0.6 dB or less (2 GHz to 2.5 GHz)
20 dB or greater (DC to 1 GHz)
Isolation
15 dB or greater (1 GHz to 2 GHz)
12 dB or greater (2 GHz to 2.5 GHz)
1.3 or less (DC to 2 GHz)
V.S.W.R.
1.5 or less (2 GHz to 2.5 GHz)
Item
Requirement
Test Condition
1. Insulation resistance
1 Gø or more
Measured at 100 V DC
2. Voltage proof
No arcing or insulation breakdown
100 V AC applied for one minute
3. Contact resistance
Center: 75 mø or less
Outside: 50 mø or less
Measured at 100 mA or less
4. Vibration
No momentary disconnections of 10 µs or more
Contact resistance Center: 100 mø or less
Outside: 75 mø or less
Frequency 10 to 50 Hz, amplitude 1.5 mm,
at 2 h, for 3 directions
490 m/s2, half-sine waveform, at 3 times for 3 directions
Insulation resistance 10 Mø or more
Temperature : -55ç / 5 to 35ç
/ to 85ç / 5 to 35ç
Time
: -30 min / Within 5 min / 30 min / Within 5 min
100 cycles
No excessive corrosion
Exposed in 5% salt water spray for 48 h, at 35ç
5. Shock
Contact resistance
6. Thermal shock
Contact resistance
7. Corrosion salt spray
8. Durability
(Mating/Unmating)
Contact resistance
■Typical performance
dB
40
N.O.
10
Isolation
N.O.
0.6
0.4
0.2
Insertion loss
N.C.
N.O.
1.40
VSWR
1.20
N.C.
1.00
DC
114
1
Frequercy GHZ
2
2.5
10000 Mating/Unmating cycles
■Receptacle dimensions
BCircuit configuration
Parts No : MS-145(06)
Package condition (1,000 pieces per reel)
All dimensions in mm.
Not mated with plug
(Normally closed)
Mated with plug
(Normally open)
6
4 5.4
G
G
A
G
G
A
B
G
C
G
B
G
C
G
B
Ø5.06
Ø3
Plug
MS-145
BRecommended solder board
3.65
6
2-0.2
2-0.15
mounting pattern
7
2.4
0.9
1
A
G
G
6.4
C
R2
2-
4.6
2.3
0.5
1.4
BTape and reel dimensions
12
4
2
Ø1.5
Unwinding direction
1.75
2
16.4
7.5
16
Ø380
Ø80
Unwinding direction
7.5
Ø13:
Center
Opening
115
■Plug
MS-145-C(LP)-1
MS-145-C(LP)-A
7
MS-145-C(LP)-MI
7
7
13.7
13.7
13.7
10.2
10.2
10.2
Ø1.8
Ø1.8
Ø1.8
1.7
Ø5.55
14.2
Ø5.55
15.5
13.15
15.5
4.65
5.95
Ø4.15
Ø4.15
Ø5.55
8.2
Ø4.15
■MS-145 to SMA adaptor
MS-145 to SMA Male
MS-145 to SMA Female
Straight type
Panel mount type
Straight type
MS-145-HRMP-A
MS-145-HRMJ
MS-145-HRMJ-A-D
12.7
8.64
8HEX
6.3
8.64
12.7
1/4-36UNS-2B
4-Ø
2.6
Ø7.3
1/4-36UNS-2A
1/4-36UNS-2A
6
19.87
14.03
18
5.3
11.37
7
23.13
6.7
1.7
Ø4.3
Ø4.9
7.4
Ø4.15
Ø4.15
116
BUsage precautions
1. Please select plugs according to the following applications.
Part No.
MS-145-C(LP)-1
Engagement position
Engages up to a position (Q point) of 1.3 mm from the 5.06 mm diameter shoulder of the MS-145
Effective engagement
length (Nominal)
0.82mm
MS-145-C(LP)-A
MS-145-C(LP)-MI
Engages by pushing up to the 5.06 mm diameter shoulder (P surface)
MS-145-HRMJ-A-D
of the MS-145
1.32mm
MS-145-HRMP-A
MS-145-HRMJ
Engages by pushing up to the 5.06 mm diameter shoulder (P surface) of the MS-145
0.82mm
Ø5.06
"Q"point
"P" urface
3.65
1.3
2. Applicable cable for plugs: 1.5D-HQEW or 1.5D-QEW (manufactured by Fujikura Ltd.).
3. No cleaning is needed after soldering or cable termination.
4. Please design avoiding holes so that force is not applied to this product from the case
when dropped in the board mounted condition.
5. When mounted as the RF interface of a Mobile Phone, please consider using a rubber
cap when the plug is not engaged to prevent dust from entering.
117
BApplication examples
receptacle
Plug
O-ring
Cable
17
BRecommended solder temperature profile
BRecommended nozzle configuration
(For receptacle board placement
with automatic equipment)
Ø1
Ø1.5
Ø3
118
很抱歉,暂时无法提供与“MS-145-HRMP-A”相匹配的价格&库存,您可以联系我们找货
