Coaxial Switches for Check Purposes (DC to 3.0 GHz)
MS-136 Series
■ Features
1.Simplification of Internal Output Checks
The high frequency signal can be simply switched
by coupling or uncoupling.
2.Small, Lightweight Design
Switches are small and lightweight with a height of
3.6 mm, length of 11.5 mm, width of 4.6 mm, and
weight of 0.5 g.
Inspection Plug MS-136-C (P)
3.Suited to Automatic Mounting
Embossed tape packaging permits automatic
mounting.
MS-136
■ Product Specifications
Rating
Frequency range
Characteristic impedance
Maximum usable power
DC to 3 GHz
50ø
2W
Operating temperature range
Operating relative humidity
Item
Standard
1.Contact resistance 50 mømax.
2.Insulation resistance 1000 Mø min.
3.Withstand voltage No line or insulation breakdown
1.3
1.4
4.VSWR
N•C 1.35 or less
N•O 1.7 or less
1.4
1.8
0.3 dB
0.3 dB
5.Insertion loss
N•C 0.4 dB or less
N•O 0.6 dB or less
0.5 dB
0.8 dB
20 dB
6.Reverse Direction Loss 16 dB or greater
14 dB
No electrical disconnections of 1µs or greater
7.Vibration resistance Contact resistance: 70 mø max.
No damage, cracks, or parts looseness
8.Shock resistance
9.Insertion/Withdrawal life 70 mø or less
10.Humidity resistance Insulation resistance: 10 Mø min.
11.Temperature resistance cycle Insulation resistance: 1000 Mø min.
12.Corrosion resistance
No serious corrosion
-30ç to +85ç
(No freezing)
90% or less
Conditions
Measured at 10 mA
Measured at 100 V DC
100 V AC for one minute
Measured at DC to 1 GHz
Measured at 1 to 2 GHz
Measured at 2 to 3 GHz
Frequency of 10 to 55 Hz, overall amplitude of 1.5 mm,
in 3 axial directions, 2 hours each
490 m/s 2 acceleration, half sine wave, in 3 axial
directions, 6 times each
5000 insertion/withdrawal cycles
Leave for 96 hours at a temperature of 40ç and
humidity of 90 to 95%
(-55ç: 30 min. → 5 to 35ç: 5 min. → 85ç: 30 min. →5
to 35ç: 5 min.) for 5 cycles
Continuous immersion in 5% salt water for 48 hours
●The test method conforms to JIS.
●The temperature resistance cycle, humidity resistance, and shock resistance tests are verification tests of part deterioration and
looseness, not tests to be conducted at time of switching or when conducting.
■ Applications
Portable terminals and mobile wireless equipment.
110
■Materials
MS-136
MS-136-C (P)
Part
Material
Processing
Part
Material
Processing
External conductor (B)
Phosphor bronze
Gold plating
External ring
Phosphor bronze
Gold plating
Insulation
Polyamide resin
External conductor
Phosphor bronze
Nickel plating
Contact (A)
Phosphor bronze
Gold plating
Male contact
Phosphor bronze
Gold plating
Contact (B)
Beryllium copper
Gold plating
Insulation
Teflon
Crimp sleeve
Copper
Nickel plating
■Product Number Breakdown
■Application Diagram
MS - 136 - C (P)
1
2
(When normally closed)
3
(When normally open)
1 MS: Indicates coaxial switches (i.e., Mobile Switches)
2 Series No.: 136
3 C (P): Indicates a straight plug
■External Dimensions
■Circuit Structure Diagram
■Recommended Board Pattern Diagram
Aperture surface
The circuit structure is as described below.
C : Normally closed
Between K
A and K
C : Normally open
Between K
B and K
Product Number
Weight
MS-136
0.5g
Aperture surface
NOTE: When ordering embossed tape packaged items, affix (06) to
the end of the product number.
Product Number
Weight
Suitable Cable
MS-136-C (P)
1g
1.5D-2W (JIS standard)
111
Coaxial Switches for Check Purposes (DC to 1.0 GHz)
■Typical Data
■Recommended Temperature Profile
(VPS Reflow and IR Reflow)
Temperature (Åé)
When normally open
When normally open
5 s Max
When
normally closed
60 s
When
normally closed
112
Time
When hand soldering is used, use a tip
temperature of 280Åé or less and a soldering time
of 3 seconds or less.
When normally open
30 s
45 s
When normally closed: MS-135 single
item condition
When normally open: MS-135 and MS135-C (P) coupled condition
很抱歉,暂时无法提供与“MS-136-C(P)”相匹配的价格&库存,您可以联系我们找货
