SJ1-2533-SMT-TR
SJ1-2533-SMT-TR
    CUIDEVICES
    CONN JACK STEREO 3PIN 2.5MM SMD
SJ1-2533-SMT-TR 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date 10/04/2019 page 1 of 4 SERIES: SJ1-253X-SMT │ DESCRIPTION: 2.5 MM AUDIO JACK FEATURES • low profile design • switch options include: – no switch – tip switch – tip and ring switch • suitable for medical applications PART NUMBER KEY SJ1-253 X-SMT-TR Base Number Switch Options: 3 = no switch 4 = tip switch 5 = tip and ring switch Packaging: TR = Tape & Reel SPECIFICATIONS parameter conditions/description min rated input voltage typ 12 rated input current contact resistance1 between terminal and mating plug between terminal in a closed circuit insulation resistance at 500 Vdc voltage withstand for 1 minute 1 A 50 30 mΩ mΩ MΩ 0.3 operating temperature -25 life at a rate of 24 cycles/minute flammability rating UL94V-0 RoHS yes 500 Vac 3 kg 85 5,000 1. When measured at a current of less than 100 mA/1 kHz 2. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted. cuidevices.com units Vdc 100 insertion/withdrawal force Note: max °C cycles Additional Resources: Product Page | 3D Model | PCB Footprint CUI Devices │ SERIES: SJ1-253X-SMT │ DESCRIPTION: 2.5 MM AUDIO JACK date 10/04/2019 │ page 2 of 4 MECHANICAL DRAWING units: mm[inches] tolerance: X.X ±0.2 mm X.XX ±0.10 mm X.XXX ±0.050 mm PCB: ±0.05 mm 7.4 0.291 PLATING terminal 1 copper alloy gold flash terminal 2 copper alloy gold flash terminal 3 copper alloy gold flash terminal 4 brass gold flash terminal 5 copper alloy gold flash plastic PA6T or equivalent 2.600 0.102 3.60 0.142 10.4 0.409 1.20 0.047 0.30 0.012 3.1 0.122 (TYP) 3.00 0.118 1.35 0.053 MATERIAL 4.6 0.181 (TYP) 4.8 0.189 (TYP) 1.00 0.039 0.50 0.020 (2 PLCS) 5.40 0.213 7.7 0.303 4.7 0.185 1.3 0.051 +0.0 -0.1 1.7 0.067 1.8 0.071 +0.0 -0.1 1 3 5 2 4 3.6 0.142 Recommended PCB Layout Top View Model No. 0.80 0.031 (5 PLCS) 10.0 0.394 SJ1-2533-SMT SJ1-2534-SMT SJ1-2535-SMT 1 3 1 3 2 4 2 1 3 5 4 2 Schematic 11 Ø 2.5 MATING PLUG PIN 1 sleeve sleeve sleeve 2 tip tip tip 3 ring ring ring 4 NP tip switch tip switch 5 NP NP ring swtich cuidevices.com Additional Resources: Product Page | 3D Model | PCB Footprint CUI Devices │ SERIES: SJ1-253X-SMT │ DESCRIPTION: 2.5 MM AUDIO JACK date 10/04/2019 │ page 3 of 4 SOLDERABILITY parameter conditions/description reel storage at relative humidity
SJ1-2533-SMT-TR 价格&库存
很抱歉,暂时无法提供与“SJ1-2533-SMT-TR”相匹配的价格&库存,您可以联系我们找货
