SJ1-3543
SJ1-3543
    CUIDEVICES
    CONN JACK STEREO 3.5MM R/A
SJ1-3543 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date 10/24/2022 page 1 of 4 SERIES: SJ1-354X | DESCRIPTION: AUDIO JACK FEATURES • PCB mount • stereo • right angle with kinked pins • threaded with nut • metal bushing PART NUMBER KEY SJ1 - 354 X Base Number Switch Options 3 = no switch 4 = tip switch 5 = tip and ring switch SPECIFICATIONS parameter conditions/description min rated input voltage typ max 12 rated input current contact resistance between terminal and mating plug between terminal in a closed circuit insulation resistance at 500 Vdc voltage withstand for 1 minute Vdc 1 A 50 30 mΩ mΩ 500 Vac kg 100 MΩ insertion/withdrawal force 0.3 3 operating temperature -25 85 life 5,000 flammability rating UL94V-0 RoHS yes cuidevices.com units °C cycles Additional Resources: Product Page | 3D Model | PCB Footprint CUI DEVICES | SERIES: SJ1-354X | DESCRIPTION: AUDIO JACK date 10/24/2022 | page 2 of 4 MECHANICAL DRAWING units: mm tolerance: X.X ±0.3 mm X.XX ±0.25 mm X.XXX ±0.20 mm PCB: ±0.05 mm unless otherwise specified DESCRIPTION MATERIAL PLATING/COLOR terminal 1 C2680 t=0.30 silver terminal 2 C5191 t=0.30 silver terminal 3 C5191 t=0.30 silver terminal 4 C2680 t=0.40 silver terminal 5 C2680 t=0.40 silver bushing copper alloy tin over copper cover PBT (UL94V-0) black housing PBT (UL94V-0) black Recommended PCB Layout Top View 1 3 2 14 Ø3.5 MATING PLUG Model No. SJ1-3543 SJ1-3544 SJ1-3545 1 3 1 3 2 4 2 1 3 5 4 2 Schematic PIN 1 sleeve sleeve sleeve 2 tip tip tip 3 ring ring ring 4 NP tip switch tip switch 5 NP NP ring switch cuidevices.com Additional Resources: Product Page | 3D Model | PCB Footprint CUI DEVICES | SERIES: SJ1-354X | DESCRIPTION: AUDIO JACK date 10/24/2022 | page 3 of 4 MECHANICAL DRAWING (CONTINUED) units: mm tolerance: ±0.3 mm unless otherwise specified DESCRIPTION MATERIAL PLATING/COLOR nut HPB59-3 nickel SOLDERABILITY parameter conditions/description min typ max units wave soldering for max 5 seconds 255 260 265 °C Pin Temperature Component Temperature A. Preheating B. Soldering C. Cooling cuidevices.com Additional Resources: Product Page | 3D Model | PCB Footprint CUI DEVICES | SERIES: SJ1-354X | DESCRIPTION: AUDIO JACK date 10/24/2022 | page 4 of 4 REVISION HISTORY rev. description date 1.0 initial release 02/07/2006 1.01 new template applied 04/12/2012 1.02 brand update 01/31/2020 1.03 product reengineered for improved manufacturability and production yield, see PCN for details 10/24/2022 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
SJ1-3543 价格&库存
很抱歉,暂时无法提供与“SJ1-3543”相匹配的价格&库存,您可以联系我们找货
