8
7
6
5
4
3
2
1
F
F
RING CONTACT
0.50
12.7
TIP CONTACT
0.50
12.7
SLEEVE
E
0.50
12.7
0.41
10.3
0.44
11.2
0.28
7.1
0.31
7.7
E
0.07
1.8
0.06
1.5
RING CONTACT
0.47
11.8
0.15
3.8
0.50
12.7
SLEEVE
0.33
8.4
TIP CONTACT
D
0.50
12.7
0.141 REF
3.58
3/8 - 32 THREAD
0.33
8.4
35RM3L & 35RM3AUL
35RM3 & 35RM3AU
0.51
12.9
D
3/8 - 32 THREAD
LOCKING / NON-SEALED
NON-LOCKING / NON-SEALED
0.50
12.7
0.141 REF
3.58
M6 x 0.5 - 6g THREAD
0.40
10.0
0.30
7.5
0.07
1.8
B
A
C
C
0.50
12.7
0.33
8.4
A
0.141 REF
3.58
B
PANEL O-RING
0.390
9.91
MATING O-RING
B
B
SECTION A-A
SECTION B-B
35RM3S & 35RM3AUS
35RM3LS & 35RM3AULS
RECOMMENDED
PANEL MOUNTING HOLE
NON-LOCKING / SEALED
LOCKING / SEALED
NOTES:
1. MATES WITH SWITCHCRAFT'S 3.5MM LOCKING STEREO PLUG.
DESCRIPTION
CONTACTS
35RM3
REAR PANEL MOUNT, NON-LOCKING, NON-SEALED
SILVER
3. MATERIAL:
HOUSINGS, HEX NUT - COPPER ALLOY, NICKEL PLATED
FLAT WASHERS - STEEL, NICKEL PLATED
CONTACTS - BERYLLIUM COPPER, SILVER OR GOLD PLATED
SLEEVE - STEEL, TIN PLATED
O-RINGS - RUBBER
35RM3AU
GOLD
35RM3L
REAR PANEL MOUNT, LOCKING, NON-SEALED
SILVER
35RM3AUL
GOLD
35RM3LS
REAR PANEL MOUNT, LOCKING, SEALED
SILVER
4. THIS PRODUCT IS RoHS COMPLIANT.
35RM3AULS
GOLD
35RM3S
REAR PANEL MOUNT, NON-LOCKING, SEALED
SILVER
35RM3AUS
GOLD
2. HEX NUT, WASHER AND O-RINGS ARE PROVIDED ASSEMBLED
TO THE HOUSING ASSEMBLY. NO O-RINGS SUPPLIED WITH
NON-SEALED VERSIONS.
A
PART
NUMBER
8
7
6
5
CUSTOMER DRAWING
THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED
BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY.
UNLESS OTHERWISE SPECIFIED
REV
28206
ECO NUMBER
09/13/19
DATE
REVISIONS
4
PC
BY
- TWO PLACE DECIMALS
0.02
MULT
- THREE PLACE DECIMALS
0.005 [0.13]
DATE DRAWN
BY
02-10-17
AM
DO NOT SCALE DRAWING
SolidWorks CAD File
NAME
TEMPER
A
SPEC No.
SCALE
CHKD
PC
11-06-19
3:1
APVD
TJK
11-06-19
3.5MM JACK ASSEMBLY
REAR PANEL MOUNT, RoHS
C
LBS/M
MATERIAL
SPEC No.
FIRST USED ON
[0.5]
TJK
APVD
WIDTH
FINISH
1. ALL DIMENSIONS IN INCHES [mm]
A
SIZE
SHEET
PART No.
1
OF
1
35RM3_SERIES
REV
A
很抱歉,暂时无法提供与“35RM3LS”相匹配的价格&库存,您可以联系我们找货
