NOTES:
2. MATERIALS:
C
HOUSING: ABS OR PBT, UL-94HB, BLACK
C
COLOR INSERT: POM OR PBT, UL-94HB
SHELL & SLEEVE TERMINAL: COPPER ALLOY,
SEE TABLE FOR PLATING.
SHELL AND SLEEVE
TERMINAL FINISH
TIP TERMINAL
FRONT PLATE &
GROUND TERMINAL
PJRAS1X1S01X
BLACK
NICKEL PLATED
MATTE TIN PLATED
MATTE TIN PLATED
PJRAS1X1S01AUX
BLACK
GOLD PLATED
MATTE TIN PLATED
MATTE TIN PLATED
PJRAS1X1S01AUALLX
BLACK
GOLD PLATED
GOLD PLATED
GOLD PLATED
PJRAS1X1S02X
WHITE
NICKEL PLATED
MATTE TIN PLATED
MATTE TIN PLATED
PJRAS1X1S02AUX
WHITE
GOLD PLATED
MATTE TIN PLATED
MATTE TIN PLATED
PJRAS1X1S03X
RED
NICKEL PLATED
MATTE TIN PLATED
MATTE TIN PLATED
PJRAS1X1S03AUX
RED
GOLD PLATED
MATTE TIN PLATED
MATTE TIN PLATED
PJRAS1X1S03AUALLX
B
TIP TERMINAL: COPPER ALLOY,
B
FRONT PLATE & GROUND TERMINAL: COPPER ALLOY,
3. THIS PART IS RoHS COMPLIANT
RED
GOLD PLATED
GOLD PLATED
GOLD PLATED
PJRAS1X1S04X
YELLOW
NICKEL PLATED
MATTE TIN PLATED
MATTE TIN PLATED
PJRAS1X1S04AUX
YELLOW
GOLD PLATED
MATTE TIN PLATED
MATTE TIN PLATED
PJRAS1X1S05X
BLUE
NICKEL PLATED
MATTE TIN PLATED
MATTE TIN PLATED
PJRAS1X1S05AUALLX
BLUE
GOLD PLATED
GOLD PLATED
GOLD PLATED
PJRAS1X1S06X
GREEN
NICKEL PLATED
MATTE TIN PLATED
MATTE TIN PLATED
PJRAS1X1S06AUALLX
GREEN
GOLD PLATED
GOLD PLATED
GOLD PLATED
PJRASIXIS07X
ORANGE
NICKEL PLATED
MATTE TIN PLATED
MATTE TIN PLATED
PJRAS1X1S07AUX
ORANGE
GOLD PLATED
MATTE TIN PLATED
MATTE TIN PLATED
0.394
[10,0]
0.094 HOUSING
[2,4]
0.098 PLATE
[2.5]
0.276
[7,0]
0.728
[18,5]
0.532
[13,5]
B
INSERT
COLOR
PART NUMBER
1. ALL DIMENSIONS ARE REFERENCE.
B
INSERT
0.256
[6,5]
0.394
[10,0]
0.417
[10,6]
0.148
[3,75]
R0.008
[0,2]
TYP (8)
0.051
[1,3]
0.118
[3,0]
T
G
0.492
[12,5]
S
0.345
[8,75]
0.207
[5,25]
0.059
[1,5]
0.551
[14,0]
0.323
[8,2]
0.047
[1,2]
SHELL
0.512
[13,0]
P.C. BOARD LAYOUT
COMPONENT SIDE
T
HOUSING
0.327
[8,3]
S
FRONT PLATE
G
INSULATOR
0.158
[4,0]
0.197
[5,0]
0.417
[10,6]
0.345
[8,75]
TIP (T)
TERMINAL
0.148
[3,75]
UNLESS OTHERWISE SPECIFIED
1. ALL DIMENSIONS IN INCHES
-TWO PLACE DECIMALS
0.01
-THREE PLACE DECIMALS
0.005
-ANGLES
1
-ALL DIA. CONCENTRIC WITHIN 0.005 T.I.R.
C
27929
08-17-17
PC
TJK
B
25738
10-26-07
TJK
TJK
2. FEATURES ON THE SAME CENTERLINE
MUST BE ALIGNED WITHIN 0.002
A
25181
1-13-06
JL
TJK
3. REMOVE ALL BURRS
REV
ECO NUMBER
DATE
BY
APVD
REVISIONS
SIZE
WIDTH
CUSTOMER DRAWING
MULT
FINISH
SCALE
DATE DRAWN
BY
CHKD
13-Jan-06
JL
TJK
1-13-06
2:1
APVD
TJK
1-13-06
PHONO JACK, RIGHT ANGLE,
1 POS. SCREW MOUNT, SHIELDED, RoHS
B
TEMPER
SPEC No.
FIRST USED ON
DO NOT SCALE DRAWING
LBS/M
MATERIAL
SPEC No.
NAME
Pro/Engineer CAD File
SCHEMATIC
THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED
BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY.
STAR SYMBOL DENOTES CRITICAL DIMENSION
0.276
[7,0]
0.039
[1,0]
SLEEVE (S)
TERMINAL
0.492
[12,5]
0.512
[13,0]
0.148
[3,75]
GROUND (G)
TERMINAL
SHEET
1
OF
1
PART No.
PJRAS1X1S__X SERIES
REV
C
很抱歉,暂时无法提供与“PJRAS1X1S04AUX”相匹配的价格&库存,您可以联系我们找货
