8
7
F
6
5
BUSHING
HOUSING
4
3
2
1
F
BUSHING
HOUSING
TIP SHUNT
SPRING
HEX NUT
SEE NOTE 4
WASHER
SEE NOTE 4
E
1.34
TIP SPRING
TIP SPRING
SLEEVE SPRING
0.238 REF
0.016 X 0.375 SQUARE
SHOULDER ON BUSHING
SLEEVE SPRING
E
0.615±0.010
0.375
CL
T
T
TB
S
S
2 CONDUCTOR SINGLE OPEN CIRCUIT
2 CONDUCTOR SINGLE CLOSED CIRCUIT
SN70C12A
SN70C11
D
0.25
DIM "B"
SEE NOTE 2
D
DIM "A"
SEE NOTE 2
3/8-32 UNEF-2A
THREAD
0.025
SEE NOTE 2
BUSHING
0.15
SEE NOTE 2
BUSHING
0.075
C
HOUSING
TIP SHUNT
SPRING
0.123±0.020
SEE NOTE 2
0.224
RING SHUNT
SPRING
C
SN70C14B
SHOWN
HOUSING
1.162
0.700
0.057
TYP
0.762
0.450
0.050
0.300
RING SPRING
TIP SPRING
SLEEVE SPRING
TIP SPRING
RING SPRING
SLEEVE SPRING
CL
0.390
R
RB
T
TB
S
R
B
T
S
3 CONDUCTOR DOUBLE OPEN CIRCUIT
R
CL
0.390
B
TB
0.128
TYP
0.500
SN70C14B
RB
CUSTOMER DRAWING
1. MAY BE USED WITH PC BOARD THICKNESSES
RANGING FROM 0.054 - 0.070.
2. THESE DIMENSIONS VARY DEPENDING ON PCB THICKNESS.
DIMENSIONS SHOWN ARE FREE STATE AS SHIPPED.
3. MATERIAL SPECIFICATIONS:
HOUSING - THERMOPLASTIC, BLACK.
SPRINGS - SPECIAL COPPER ALLOY, TINNED.
BUSHING - COPPER ALLOY, NICKEL PLATED.
SLEEVE TERMINAL - SPECIAL COPPER ALLOY, TINNED.
HARDWARE - COPPER ALLOY, NICKEL PLATED.
PART
NUMBER
DIM "A"
DIM "B"
FREE
STATE
WITH 0.062
THICK PCB
FREE
STATE
WITH 0.062
THICK PCB
SN70C11
0.720
0.708
0.970
0.958
SN70C12A
0.720
0.708
0.970
0.958
SN70C12B
0.720
0.708
0.970
0.958
SN70C14B
0.720
0.708
0.970
THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED
BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY.
UNLESS OTHERWISE SPECIFIED
0.958
REV
5. THESE PRODUCTS ARE RoHS COMPLIANT.
CAD REDRAW
ECO #27409
ECO NUMBER
11/17/14
DATE
REVISIONS
7
6
5
4
PC
BY
SIZE
- TWO PLACE DECIMALS
0.02
MULT
- THREE PLACE DECIMALS
0.005
DATE DRAWN
BY
11/21/83
EB
DO NOT SCALE DRAWING
SolidWorks CAD File
NAME
C
LBS/M
TEMPER
MATERIAL
SPEC No.
FIRST USED ON
TJK
APVD
WIDTH
FINISH
1. ALL DIMENSIONS IN INCHES
D
4. HARDWARE SHIPPED UNASSEMBLED.
8
S
RECOMMENDED
PC BOARD LAYOUT
COMPONENT SIDE
0.462
NOTES:
A
S
0.187
3 CONDUCTOR DOUBLE CLOSED CIRCUIT
SN70C12B
T
0.187
A
SPEC No.
SCALE
CHKD
AM
01/02/85
3:1
APVD
RV
01/04/85
PHONE JACK
METAL BUSHING
SHEET
PART No.
1
OF
SN70C SERIES
1
REV
D
很抱歉,暂时无法提供与“SN70C12B”相匹配的价格&库存,您可以联系我们找货
