CFT-125-01-S-D-RA-01-SL 数据手册
REVISION M
(No OF POS x .0500 [1.27])
+.604 [15.34] REF
CFT-1XX-XX-XX-D-RA-XX-SL-XX
.327 8.31
No OF POSITIONS
-20, -25, -30, -34, -40, -50
(PER ROW)
C1
((No OF POS -1) x
.0500 [1.27]) .002 [.05]
POST OPTION
-SD: .120[3.05] POST
-BLANK: HOT PLUGGABLE
(25 POSITION ONLY)
LEAD STYLE
-01: STANDARD
(USE CFT-XX-D-S-XX-SL)
-02: ELEVATED
(USE CFT-XX-D-E-XX-SL)
DO NOT
SCALE FROM
THIS PRINT
.150 3.81 REF
-SL: SOLDER LOCK
CARD LENGTH
-01: 1.00 [25.4]
(USE CFT-XX-D-X-01-SL)
-02: 2.00 [50.8]
(USE CFT-XX-D-X-02-SL)
PLATING SPECIFICATION
-L: LIGHT SELECTIVE GOLD
(USE T-1S15-09-L)
-S: SELECTIVE GOLD
(USE T-1S15-09-S)
FIG. 1
-LM: SELECTIVE LIGHT GOLD, MATTE TIN TAIL
(USE T-1S15-09-L)
CFT-125-01-XX-D-RA-02-SL SHOWN
-SM: SELECTIVE HEAVY GOLD, MATTE TIN TAIL
(USE T-1S15-09-S)
"A"
REF
(SEE TABLE 1)
.398 10.11
REF
TAIL OPTION
-RA: RIGHT ANGLE
ROW SPECIFICATION
-D: DOUBLE (USE CFT-XX-D-X-XX-SL)
.170 4.32 (TYP) REF
TABLE 1
SECTION "A"-"A"
DETAIL 'A'
(SEE SHEET 2)
+.439 [11.15] REF
CARD LENGTH
"A"
-01
-02
1.00 [25.4]
2.00 [50.8]
"B"
.167 4.24 REF
01
13
TABLE 2
25
"A"
"A"
26
38
"B"
LEAD STYLE
"B"
-01
-02
.250 [6.35]
.350 [8.89]
50
.100 2.54 REF
.060 1.52 REF
"B" REF
(SEE TABLE 2)
T-1S15-09-XX
SECTION "B"-"B"
NOTES:
(No OF POS x .050 [1.27])
+ .434 [11.02] REF
1. C REPRESENTS A CRITICAL DIMENSION.
2. DELETED.
3. BURR ALLOWANCE: .0015[.038] MAX.
4. MINIMUM PUSHOUT FORCE: 1.5 LB.
5. MAXIMUM ALLOWABLE BOW: .002 INCH/INCH AFTER ASSEMBLY.
6. MAX HEIGHT VARIATION .005 BETWEEN ROWS.
7. DELETED.
8. TERMINALS TO BE SHEARED TO OBTAIN DIMENSION SPECIFICATION.
9. PARTS TO BE PACKAGED IN TUBES.
10. DIMENSION TO BE MEASURED AT BEND.
.085 2.16 REF (TYP)
.087 2.20 REF
(TYP)
"A"-.1700 [4.32]
REF
CFT-XX-D-X-XX-SL
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01 [.3]
.XXX: .005 [.13]
.XXXX: .002 [.051]
M
MATERIAL:
PATENT NUMBER
6159045
1.5 MAX SWAY
(ANY DIRECTION)
.016 0.41 SQ REF
2
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS INFORMATION
CONFIDENTIAL AND PROPRIETARY TO
SAMTEC, INC. AND SHALL NOT BE REPRODUCED
OR TRANSFERRED TO OTHER DOCUMENTS OR
DISCLOSED TO OTHERS OR USED FOR ANY
PURPOSE OTHER THAN THAT WHICH IT WAS
OBTAINED WITHOUT THE EXPRESSED WRITTEN
CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
SHEET SCALE: 1:1.25
INSULATOR: VECTRA E130i
COLOR: BLACK
TERMINAL: 510 PHOS BRONZE, SPRING TEMPER
F:\ DWG\ MISC\ MKTG\ CFT-1XX-XX-XX-D-RA-XX-SL-XX-MKT.SLDDRW
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Ma il: info @SAMTEC.c o m
c o d e: 55322
DESCRIPTION:
.050 [1.27] C.L. CARD GUIDE ASSEMBLY
DWG. NO.
BY: DEAN P
03/05/1999
SHEET 1 OF 2
REVISION M
POST OPTION
HOT PLUGGABLE
-SD (SEE NOTE 6)
TABLE 3
POSITION
25, 26
01, 13, 38, 50
ALL OTHERS
ALL
"C"
"D"
.138 [3.50]
.197 [5.00]
.167 [4.24]
.120 [3.05]
.662 [16.81
.603 [15.32]
.633 [16.84]
.680 [17.27]
"D" REF (SEE TABLE 3)
C4
* .100 2.54
C3
IN-PROCESS 1
C5
"C"
(SEE TABLE 3)
*.125 3.18
.050 1.27
.100 2.54
.090±.010 2.29±0.25
(SEE NOTE 8)
.090±.010 2.29±0.25
(SEE NOTE 8)
90°±1.5°
*.100 2.54
90°±1.5°
DETAIL 'A'
SCALE 4 : 1
IN-PROCESS 2
(* = SEE NOTE 10)
(* = SEE NOTE 10)
PACKAGING VIEWS
PACKAGING TABLE
HEIGHT
CARD LENGTH
TUBE
PLUG
-S
-S
-E
-E
-01
-02
-01
-02
PT-1-24-01-81
PT-1-24-02-81
PT-1-24-05-81
PT-1-24-06-81
TP-28
TP-28
TP-28
TP-28
(CFT-XX-D-S-02-SL SHOWN)
PLUNGS TO BE INSERTED
INTO THIS AREA.
PROPRIETARY NOTE
PHONE: 812-944-6733
FAX: 812-948-5047
c o d e: 55322
DESCRIPTION:
(CFT-XX-D-E-02-SL SHOWN)
SHEET SCALE: 1:0.833333
DWG. NO.
BY: DEAN P
03/05/1999
SHEET 2 OF 2
CFT-125-01-S-D-RA-01-SL 价格&库存
很抱歉,暂时无法提供与“CFT-125-01-S-D-RA-01-SL”相匹配的价格&库存,您可以联系我们找货
