476229
    AMERICANELECTRICAL(美国电气)
    JMPR10PMVK2.5PYK2.5AVK2.5
476229 数据手册
Colors Terminals End Plate Part Number Part Number GREY BLUE GREEN YELLOW RED BEIGE PYK 1.5 307 009 307 001 307 002 307 003 307 004 307 000 NPP 446 449 446 441 446 442 446 443 446 444 446 440 GREY BLUE GREEN YELLOW RED BEIGE PYK 2.5 307 109 307 101 307 102 307 103 307 104 307 100 NPP 446 449 446 441 446 442 446 443 446 444 446 440 GREY BLUE GREEN YELLOW RED BEIGE PYK 4 307 119 307 111 307 112 307 113 307 114 307 110 NPP 446 459 446 451 446 452 446 453 446 454 446 450 GREY BLUE GREEN YELLOW RED BEIGE PYK 6 307 129 307 121 307 122 307 123 307 124 307 120 NPP 446 469 446 461 446 462 446 463 446 464 446 469 GREY BLUE GREEN YELLOW RED BEIGE PYK 10 307 139 307 131 307 132 307 133 307 134 307 130 NPP 446 479 446 471 446 472 446 473 446 474 446 470 PYK 1.5 Practical Spring Clamp Feed Thru Terminal Blocks and Accessories Width 4.2 mm 307 009 MR 35 43.0 PYK Series Practical Spring Clamp Terminals. Screwdriver is not necessary to install wire into the terminal block. Suitable for usage with or without ferrules. To make connection, push the cable into the terminal. PYK Series 53.3 Electrical Ratings CE (EN 60947-7-1) UL / CSA VDE ATEX Connection Data Solid Strand, Screw Con. - Fine Strand, Screw Con. AWG Conductor / Fine Strand with Ferrule Insulation Stripping Length / Torque Ordering Data Polyamide 66 Grey Mounting Rails TS 35x7.5 solid TS 35x15 solid TS 35x7.5 slotted TS 35x15 slotted steel slot dim. 25mm on 36mm center 5.2mm slot width End Plate Thickness 1.2mm Polyamide 66 npp aluminum slot dim. 13mm on 26mm center 5mm slot width grey 0.5 - 2.5 mm² / 0.5 - 2.5 mm² 22 - 14 / 0.5 - 1.5 mm² 10 mm / ... Type Part. No. PYK 1.5 307 009 Type Part. No. slotted 35x7.5 TS3575SL 35x7.5 TS3575SL1 35x7.5 TS3575SL1-A 35x15 TS3515SL solid 35x7.5 TS3575SOL 35x15 TS3515SOL Qty. 80 std. pk. 2m 1m 1m 2m 2m 2m npp pyk 2.5 446 449 100 app pyk 1.5 463 180 25 uk 1.5/2 uk 1.5/3 uk 1.5/4 uk 1.5/10 476 602 476 603 476 604 476 609 25 20 15 5 IP 2 S IP 2 498 130 498 140 25 25 ge ge 2 496 119 496 250 50 25 app pyk Cross Connection Warning Label IP with symbol without symbol Group Marking grey ge ge2 Technical Data • Max.clamping range / Max. technical data • Rated Impulse Voltage / Pollution severity • Insulation material group / Gauge pin code according to IEC 60947-1 • Protection class / Protection conductor type Marking Tags See pages 104 & 105 for further detail 54 Voltage/Current/Cross-section 800 V / 17.5 A / 1.5 mm² 0.2-2.5 mm² / 24 A 8 kV / 3 1 / A3 IP 20 / - American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com PYK 6 PYK 10 Width 6 mm 307 119 Width 8 mm 307 129 Width 10 mm 307 139 MR 35 44.0 MR 35 43.0 53.3 55.90 MR 35 52.20 PYK 4 Width 5 mm 307 109 MR 35 46.20 PYK 2.5 65.60 75.40 Voltage/Current/Cross-section 800 V ~ / 24 A / 2.5 mm² 600 V ~ / 20 A / AWG 22-12 800 V ~ / 24 A / 2.5 mm² 800 V ~ / 24 A Voltage/Current/Cross-section 800 V ~ / 32 A / 4 mm² 600 V ~ / 30 A / AWG 22-10 800 V ~ / 32 A / 4 mm² 800 V ~ / 32 A Voltage/Current/Cross-section 800 V ~ / 41 A / 6 mm² 600 V ~ / 45 A / AWG 20-8 Voltage/Current/Cross-section 800 V ~ / 57 A / 10 mm² 600 V ~ / 55 A / AWG 20-6 800 V ~ / 41 A 800 V ~ / 57 A 0.5 - 4 mm² / 0.5 - 4 mm² 22 - 12 / 0.5 - 2.5 mm² 10 mm / ... Type Part. No. Qty. PYK 2.5 100 307 109 Type Part. No. std. pk. slotted 35x7.5 2m TS3575SL 35x7.5 1m TS3575SL1 1m 35x7.5 TS3575SL1-A 35x15 2m TS3515SL solid 35x7.5 2m TS3575SOL 35x15 2m TS3515SOL 0.5 - 6 mm² / 0.5 - 6 mm² 22 - 10 / 0.5 - 4 mm² 10 mm / ... Type Part. No. Qty. PYK 4 100 307 119 Type Part. No. std. pk. slotted 35x7.5 2m TS3575SL 35x7.5 1m TS3575SL1 1m 35x7.5 TS3575SL1-A 35x15 2m TS3515SL solid 35x7.5 2m TS3575SOL 35x15 TS3515SOL 2m 0.5 - 10 mm² / 0.5 - 10 mm² 20 - 8 / 0.5 - 6 mm² 13 mm / ... Type Part. No. Qty. PYK 6 60 307 129 Type Part. No. std. pk. slotted 35x7.5 2m TS3575SL 35x7.5 1m TS3575SL1 1m 35x7.5 TS3575SL1-A 35x15 2m TS3515SL solid 35x7.5 2m TS3575SOL 35x15 2m TS3515SOL 0.5 - 16 mm² / 0.5 - 16 mm² 20 - 6 / 0.5 - 10 mm² 15 mm / ... Type Part. No. Qty. PYK 10 50 307 139 Type Part. No. std. pk. slotted 35x7.5 2m TS3575SL 35x7.5 1m TS3575SL1 1m 35x7.5 TS3575SL1-A 35x15 2m TS3515SL solid 35x7.5 2m TS3575SOL 35x15 2m TS3515SOL npp pyk 2.5 446 449 100 npp pyk 4 446 459 100 npp pyk 6 446 469 50 npp pyk 10 446 479 50 app pyk 1.5-2.5-4 463 180 25 app pyk 4 463 180 25 app pyk 6 463 190 25 app pyk 10 463 200 25 uk 2.5/2 uk 2.5/3 uk 2.5/4 uk 2.5/10 476 222 476 223 476 224 476 229 25 20 15 5 uk 4/2 uk 4/3 uk 4/4 uk 4/10 476 232 476 233 476 234 476 239 25 20 15 5 uk 6/2 uk 6/3 uk 6/4 uk 6/10 476 242 476 243 476 244 476 249 25 20 15 5 uk 10/2 uk 10/3 uk 10/4 uk 10/10 476 252 476 253 476 254 476 259 25 20 15 5 IP 2 S IP 2 498 130 498 140 25 25 IP 2 S IP 2 498 130 498 140 25 25 IP 2 S IP 2 498 130 498 140 25 25 IP 2 S IP 2 498 130 498 140 25 25 ge ge 2 496 119 496 250 50 25 ge ge 2 496 119 496 250 50 25 ge ge 2 496 119 496 250 50 25 ge ge 2 496 119 496 250 50 25 0.2 - 4 mm² / 4 mm² / 32 A 8 kV / 3 1 / A3 IP 20 / - 0.2 - 6 mm² / 6 mm² / 41 A 8 kV / 3 1 / A4 IP 20 / - 0.2 - 10 mm² / 10 mm² / 57 A 8 kV / 3 1 / A5 IP 20 / - 0.2 - 16 mm² / 16 mm² / 76 A 8 kV / 3 1 / A4 IP 20 / - American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 55
476229 价格&库存
很抱歉,暂时无法提供与“476229”相匹配的价格&库存,您可以联系我们找货
