Features
• Single 2.7V - 3.6V Supply
• Dual-interface Architecture
– RapidS Serial Interface: 66MHz Maximum Clock Frequency
SPI Compatible Modes 0 and 3
– Rapid8 8-bit Interface: 50MHz Maximum Clock Frequency
User Configurable Page Size
– 1024-Bytes per Page
– 1056-Bytes per Page
– Page Size Can Be Factory Pre-configured for 1024-Bytes
Page Program Operation
– Intelligent Programming Operation
– 8192 Pages (1024-/1056-Bytes/Page) Main Memory
Flexible Erase Options
– Page Erase (1-Kbyte)
– Block Erase (8-Kbytes)
– Sector Erase (256-Kbytes)
– Chip Erase (64Mbits)
Two SRAM Data Buffers (1024-/1056-Bytes)
– Allows Receiving of Data while Reprogramming the Flash Array
Continuous Read Capability through Entire Array
– Ideal for Code Shadowing Applications
Low-power Dissipation
– 10mA Active Read Current Typical – Serial Interface
– 10mA Active Read Current Typical – 8-bit Interface
– 25µA Standby Current Typical
– 15µA Deep Power Down Typical
Hardware and Software Data Protection Features
– Individual Sector
Permanent Sector Lockdown for Secure Code and Data Storage
– Individual Sector
Security: 128-byte Security Register
– 64-byte User Programmable Space
– Unique 64-byte Device Identifier
JEDEC Standard Manufacturer and Device ID Read
100,000 Program/Erase Cycles Per Page Minimum
Data Retention – 20 Years
Green (Pb/Halide-free/RoHS Compliant) Packaging Options
Temperature Range
– Industrial: -40C to +85C
64-megabit
2.7V Dual-interface
DataFlash
AT45DB642D
3542M–DFLASH–11/2012
1. Description
AT45DB642D is a 2.7V, dual-interface sequential access Flash memory ideally suited for a wide
variety of digital voice-, image-, program code- and data-storage applications. AT45DB642D
supports RapidS™ serial interface and Rapid8™ 8-bit interface. RapidS serial interface is SPI
compatible for frequencies up to 66MHz. The dual-interface allows a dedicated serial interface
to be connected to a DSP and a dedicated 8-bit interface to be connected to a microcontroller or
vice versa. However, the use of either interface is purely optional. Its 69,206,016-bits of memory
are organized as 8,192 pages of 1,024-bytes (binary page size) or 1,056-bytes (standard
DataFlash® page size) each. In addition to the main memory, the AT45DB642D also contains
two SRAM buffers of 1,024-(binary buffer size) bytes/1,056-bytes (standard DataFlash buffer
size) each. The buffers allow receiving of data while a page in the main Memory is being reprogrammed, as well as writing a continuous data stream. EEPROM emulation (bit or byte
alterability) is easily handled with a self-contained three step read-modify-write operation. Unlike
conventional Flash memories that are accessed randomly with multiple address lines and a parallel interface, the DataFlash uses either a RapidS serial interface or a 8-bit Rapid8 interface to
sequentially access its data. The simple sequential access dramatically reduces active pin
count, facilitates hardware layout, increases system reliability, minimizes switching noise, and
reduces package size. The device is optimized for use in many commercial and industrial applications where high-density, low-pin count, low-voltage and low-power are essential.
To allow for simple in-system reprogrammability, the AT45DB642D does not require high input
voltages for programming. The device operates from a single power supply, 2.7V to 3.6V, for
both the program and read operations. The AT45DB642D is enabled through the chip select pin
(CS) and accessed via a three-wire interface consisting of the Serial Input (SI), Serial Output
(SO), and the Serial Clock (SCK), or an 8-bit interface consisting of the input/output pins (I/O7 I/O0) and the clock pin (CLK).
All programming and erase cycles are self-timed.
2
AT45DB642D
AT45DB642D
2. Pin Configurations and Pinouts
Table 2-1.
Pin Configurations
Asserted
State
Type
CS
Chip Select: Asserting the CS pin selects the device. When the CS pin is deasserted, the device
will be deselected and normally be placed in the standby mode (not Deep Power-Down mode),
and the output pins (SO or I/O7 - I/O0) will be in a high-impedance state. When the device is
deselected, data will not be accepted on the input pins (SI or I/O7 - I/O0).
A high-to-low transition on the CS pin is required to start an operation, and a low-to-high
transition is required to end an operation. When ending an internally self-timed operation such as
a program or erase cycle, the device will not enter the standby mode until the completion of the
operation.
Low
Input
SCK/CLK
Serial Clock: This pin is used to provide a clock to the device and is used to control the flow of
data to and from the device. Command, address, and input data present on the SI or I/O7 - I/O0
pins are always latched on the rising edge of SCK/CLK, while output data on the SO or I/O7 I/O0 pins are always clocked out on the falling edge of SCK/CLK.
Input
SI
Serial Input: The SI pin is used to shift data into the device. The SI pin is used for all data input
including command and address sequences. Data on the SI pin is always latched on the rising
edge of SCK. If the SER/BYTE pin is always driven low, the SI pin should be a “no connect”.
Input
SO
Serial Output: The SO pin is used to shift data out from the device. Data on the SO pin is always
clocked out on the falling edge of SCK. If the SER/BYTE pin is always driven low, the SO pin
Output
I/O7 - I/O0
8-bit Input/Output: The I/O7-I/O0 pins are bidirectional and used to clock data into and out of the
device. The I/O7-I/O0 pins are used for all data input, including opcodes and address sequences.
The use of these pins is optional, and the pins should be treated as “no connect” if the SER/BYTE
pin is not connected or if the SER/BYTE pin is always driven high externally.
Input/
Output
WP
Write Protect: When the WP pin is asserted, all sectors specified for protection by the Sector
Protection Register will be protected against program and erase operations regardless of whether
the Enable Sector Protection command has been issued or not. The WP pin functions
independently of the software controlled protection method.
If a program or erase command is issued to the device while the WP pin is asserted, the device
will simply ignore the command and perform no operation. The device will return to the idle state
once the CS pin has been deasserted. The Enable Sector Protection command and Sector
Lockdown command, however, will be recognized by the device when the WP pin is asserted.
The WP pin is internally pulled-high and may be left floating if hardware controlled protection will
not be used. However, it is recommended that the WP pin also be externally connected to VCC
whenever possible.
Low
Input
RESET
Reset: A low state on the reset pin (RESET) will terminate the operation in progress and reset
the internal state machine to an idle state. The device will remain in the reset condition as long as
a low level is present on the RESET pin. Normal operation can resume once the RESET pin is
brought back to a high level.
The device incorporates an internal power-on reset circuit, so there are no restrictions on the
RESET pin during power-on sequences. If this pin and feature are not utilized it is recommended
that the RESET pin be driven high externally.
Low
Input
RDY/BUSY
Ready/Busy: This open drain output pin will be driven low when the device is busy in an
internally self-timed operation. This pin, which is normally in a high state (through an external
pull-up resistor), will be pulled low during programming/erase operations, compare operations,
and page-to-buffer transfers.
The busy status indicates that the Flash memory array and one of the buffers cannot be
accessed; read and write operations to the other buffer can still be performed.
Output
Symbol
Name and Function
3
Table 2-1.
Symbol
Pin Configurations (Continued)
Name and Function
SER/BYTE
Asserted
State
Type
Low
Input
Serial/8-bit Interface Control: The DataFlash may be configured to utilize either its serial port or
8-bit port through the use of the serial/8-bit control pin (SER/BYTE). When the SER/BYTE pin is
held high, the serial port (SI and SO) of the DataFlash will be used for all data transfers, and the
8-bit port (I/O7 - I/O0) will be in a high impedance state. Any data presented on the 8-bit port
while SER/BYTE is held high will be ignored. When the SER/BYTE is held low, the 8-bit port will
be used for all data transfers, and the SO pin of the serial port will be in a high impedance state.
While SER/BYTE is low, any data presented on the SI pin will be ignored. Switching between the
serial port and 8-bit port should only be done while the CS pin is high and the device is not busy
in an internally self-timed operation.
The SER/BYTE pin is internally pulled high; therefore, if the 8-bit port is never to be used, then
connection of the SER/BYTE pin is not necessary. In addition, if the SER/BYTE pin is not
connected or if the SER/BYTE pin is always driven high externally, then the 8-bit input/output pins
(I/O7-I/O0), the VCCP pin, and the GNDP pin should be treated as “no connect”.
VCC
Device Power Supply: The VCC pin is used to supply the source voltage to the device.
Operations at invalid VCC voltages may produce spurious results and should not be attempted.
Power
GND
Ground: The ground reference for the power supply. GND should be connected to the system
ground.
Ground
VCCP
8-bit Port Supply Voltage: The VCCP pin is used to supply power for the 8-bit input/output pins
(I/O7-I/O0). The VCCP pin needs to be used if the 8-bit port is to be utilized; however, this pin
should be treated as “no connect” if the SER/BYTE pin is not connected or if the SER/BYTE pin is
Power
GNDP
8-bit Port Ground: The GNDP pin is used to provide ground for the 8-bit input/output pins (I/O7I/O0). The GNDP pin needs to be used if the 8-bit port is to be utilized; however, this pin should
Ground
Figure 2-1.
RDY/BUSY
RESET
WP
NC
NC
VCC
GND
NC
NC
NC
CS
SCK/CLK
SI
SO
TSOP Top View: Type 1
1
2
3
4
5
6
7
8
9
10
11
12
13
14
Figure 2-2.
28
27
26
25
24
23
22
21
18
17
16
15
BGA Package Ball-Out (Top View)
1
NC
NC
I/O7
I/O6
I/O5
I/O4
VCCP
GNDP
I/O3
I/O2
I/O1
I/O0
SER/BYTE
NC
2
3
4
5
NC
NC
NC
NC
NC
SCK
GND
VCC
NC
NC
CS
RDY/BSY
WP
NC
NC
SO
SI
RESET
NC
NC
NC
NC
NC
NC
A
B
C
D
E
Figure 2-3.
CASON Top View through Package
SI
SCK
RESET
CS
4
1
8
2
7
3
6
4
5
SO
GND
VCC
WP
AT45DB642D
AT45DB642D
3. Block Diagram
FLASH MEMORY ARRAY
WP
PAGE (1024-/1056-BYTES)
BUFFER 1 (1024-/1056-BYTES)
SCK/CLK
CS
RESET
VCC
GND
RDY/BUSY
SER/BYTE
BUFFER 2 (1024-/1056-BYTES)
I/O INTERFACE
SI SO
I/O7 - I/O0
4. Memory Array
To provide optimal flexibility, the memory array of the AT45DB642D is divided into three levels of
granularity comprising of sectors, blocks, and pages. The “Memory Architecture Diagram” illustrates the breakdown of each level and details the number of pages per sector and block. All
program operations to the DataFlash occur on a page by page basis. The erase operations can
be performed at the chip, sector, block or page level.
SECTOR 0b = 248 Pages
253,952/261,888 bytes
SECTOR 0
SECTOR 1
SECTOR 0a = 8 Pages
8192/8,448 bytes
BLOCK ARCHITECTURE
SECTOR 2 = 256 Pages
262,144/270,336 bytes
SECTOR 30 = 256 Pages
SECTOR 31 = 256 Pages
SECTOR 2
SECTOR 1 = 256 Pages
BLOCK 0
BLOCK 1
BLOCK 2
BLOCK 30
BLOCK 31
BLOCK 32
BLOCK 33
BLOCK 62
BLOCK 63
BLOCK 64
BLOCK 65
BLOCK 1022
BLOCK 1023
Block = 8,192-/8,448-bytes
PAGE ARCHITECTURE
8 Pages
BLOCK 0
SECTOR ARCHITECTURE
BLOCK 1
Figure 4-1.
PAGE 0
PAGE 1
PAGE 6
PAGE 7
PAGE 8
PAGE 9
PAGE 14
PAGE 15
PAGE 16
PAGE 17
PAGE 18
PAGE 8,190
PAGE 8,190
Page = 1,024-/1,056-bytes
5
5. Device Operation
The device operation is controlled by instructions from the host processor. The list of instructions
and their associated opcodes are contained in Table 15-1 on page 28 through Table 15-6 on
page 31. A valid instruction starts with the falling edge of CS followed by the appropriate 8-bit
opcode and the desired buffer or main memory address location. While the CS pin is low, toggling the SCK/CLK pin controls the loading of the opcode and the desired buffer or main memory
address location through either the SI (serial input) pin or the 8-bit input pins (I/O7 - I/O0). All
instructions, addresses, and data are transferred with the most significant bit (MSB) first.
Buffer addressing for standard DataFlash page size (1056-bytes) is referenced in the datasheet
using the terminology BFA10 - BFA0 to denote the 11 address bits required to designate a byte
address within a buffer. Main memory addressing is referenced using the terminology PA12 PA0 and BA10 - BA0, where PA12 - PA0 denotes the 13 address bits required to designate a
page address and BA10 - BA0 denotes the 11 address bits required to designate a byte address
within the page.
For “Power of 2” binary page size (1024-bytes) the Buffer addressing is referenced in the datasheet using the conventional terminology BFA9 - BFA0 to denote the 10 address bits required to
designate a byte address within a buffer. Main memory addressing is referenced using the terminology A22 - A0.
6. Read Commands
By specifying the appropriate opcode, data can be read from the main memory or from either
one of the two SRAM data buffers. The DataFlash supports RapidS and Rapid8 protocols for
Mode 0 and Mode 3. Please refer to the “Detailed Bit-level Read Timing” diagrams in this datasheet for details on the clock cycle sequences for each mode.
6.1
Continuous Array Read (Legacy Command: E8H): Up to 66MHz
By supplying an initial starting address for the main memory array, the Continuous Array Read
command can be utilized to sequentially read a continuous stream of data from the device by
simply providing a clock signal; no additional addressing information or control signals need to
be provided. The DataFlash incorporates an internal address counter that will automatically
increment on every clock cycle, allowing one continuous read operation without the need of
additional address sequences. To perform a continuous read from the standard DataFlash page
size (1056-bytes), an opcode of E8H must be clocked into the device followed by three address
bytes (which comprise the 24-bit page and byte address sequence) and a series of don’t care
bytes (4-bytes if using the serial interface or 19-bytes if using the 8-bit interface). The first 13-bits
(PA12 - PA0) of the 24-bit address sequence specify which page of the main memory array to
read, and the last 11 bits (BA10 - BA0) of the 24-bit address sequence specify the starting byte
address within the page. To perform a continuous read from the binary page size (1024-bytes),
the opcode (E8H) must be clocked into the device followed by three address bytes and a series
of don’t care bytes (4-bytes if using the serial interface, or 19-bytes if using the 8-bit interface).
The first 13 bits (A22 - A10) of the 24-bits sequence specify which page of the main memory
array to read, and the last 10 bits (A9 - A0) of the 24-bits address sequence specify the starting
byte address within the page. The don’t care bytes that follow the address bytes are needed to
initialize the read operation. Following the don’t care bytes, additional clock pulses on the
SCK/CLK pin will result in data being output on either the SO (serial output) pin or the eight output pins (I/O7- I/O0).
6
AT45DB642D
AT45DB642D
The CS pin must remain low during the loading of the opcode, the address bytes, the don’t care
bytes, and the reading of data. When the end of a page in main memory is reached during a
Continuous Array Read, the device will continue reading at the beginning of the next page with
no delays incurred during the page boundary crossover (the crossover from the end of one page
to the beginning of the next page). When the last bit (or byte if using the 8-bit interface mode) in
the main memory array has been read, the device will continue reading back at the beginning of
the first page of memory. As with crossing over page boundaries, no delays will be incurred
when wrapping around from the end of the array to the beginning of the array.
A low-to-high transition on the CS pin will terminate the read operation and tri-state the output
pins (SO or I/O7-I/O0). The maximum SCK/CLK frequency allowable for the Continuous Array
Read is defined by the fCAR1 specification. The Continuous Array Read bypasses both data buffers and leaves the contents of the buffers unchanged.
6.2
Continuous Array Read (High Frequency Mode: 0BH): Up to 66MHz
This command can be used with the serial interface to read the main memory array sequentially
in high speed mode for any clock frequency up to the maximum specified by fCAR1. To perform a
continuous read array with the page size set to 1056-bytes, the CS must first be asserted then
an opcode 0BH must be clocked into the device followed by three address bytes and a dummy
byte. The first 13 bits (PA12 - PA0) of the 24-bit address sequence specify which page of the
main memory array to read, and the last 11 bits (BA10 - BA0) of the 24-bit address sequence
specify the starting byte address within the page. To perform a continuous read with the page
size set to 1024-bytes, the opcode, 0BH, must be clocked into the device followed by three
address bytes (A22 - A0) and a dummy byte. Following the dummy byte, additional clock pulses
on the SCK pin will result in data being output on the SO (serial output) pin.
The CS pin must remain low during the loading of the opcode, the address bytes, and the reading of data. When the end of a page in the main memory is reached during a Continuous Array
Read, the device will continue reading at the beginning of the next page with no delays incurred
during the page boundary crossover (the crossover from the end of one page to the beginning of
the next page). When the last bit in the main memory array has been read, the device will continue reading back at the beginning of the first page of memory. As with crossing over page
boundaries, no delays will be incurred when wrapping around from the end of the array to the
beginning of the array. A low-to-high transition on the CS pin will terminate the read operation
and tri-state the output pin (SO). The maximum SCK frequency allowable for the Continuous
Array Read is defined by the fCAR1 specification. The Continuous Array Read bypasses both
6.3
Continuous Array Read (Low Frequency Mode: 03H): Up to 33MHz
without a dummy byte up to maximum frequencies specified by fCAR2. To perform a continuous
read array with the page size set to 1056-bytes, the CS must first be asserted then an opcode,
03H, must be clocked into the device followed by three address bytes (which comprise the 24-bit
page and byte address sequence). The first 13 bits (PA12 - PA0) of the 24-bit address sequence
specify which page of the main memory array to read, and the last 11 bits (BA10 - BA0) of the
24-bit address sequence specify the starting byte address within the page. To perform a continuous read with the page size set to 1024-bytes, the opcode, 03H, must be clocked into the
device followed by three address bytes (A22 - A0). Following the address bytes, additional clock
pulses on the SCK pin will result in data being output on the SO (serial output) pin.
7
and tri-state the output pin (SO). The Continuous Array Read bypasses both data buffers and
6.4
Main Memory Page Read
A main memory page read allows the user to read data directly from any one of the 8,192 pages
in the main memory, bypassing both of the data buffers and leaving the contents of the buffers
unchanged. To start a page read from the standard DataFlash page size (1056-bytes), an
opcode of D2H must be clocked into the device followed by three address bytes (which comprise
the 24-bit page and byte address sequence) and a series of don’t care bytes (4-bytes if using the
serial interface or 19-bytes if using the 8-bit interface). The first 13 bits (PA12 - PA0) of the 24-bit
address sequence specify the page in main memory to be read, and the last 11 bits (BA10 BA0) of the 24-bit address sequence specify the starting byte address within that page. To start
a page read from the binary page size (1024-bytes), the opcode D2H must be clocked into the
device followed by three address bytes and a series of don’t care bytes (4-bytes if using the
serial interface or 19-bytes if using the 8-bit interface). The first 13 bits (A22 - A10) of the 24-bits
sequence specify which page of the main memory array to read, and the last 10 bits (A9 - A0) of
the 24-bits address sequence specify the starting byte address within the page. The don’t care
bytes that follow the address bytes are sent to initialize the read operation. Following the don’t
care bytes, additional pulses on SCK/CLK result in data being output on either the SO (serial
output) pin or the eight output pins (I/O7 - I/O0). The CS pin must remain low during the loading
of the opcode, the address bytes, the don’t care bytes, and the reading of data. When the end of
a page in main memory is reached, the device will continue reading back at the beginning of the
same page. A low-to-high transition on the CS pin will terminate the read operation and tri-state
the output pins (SO or I/O7 - I/O0). The maximum SCK/CLK frequency allowable for the Main
Memory Page Read is defined by the fSCK specification. The Main Memory Page Read bypasses
6.5
Buffer Read
The SRAM data buffers can be accessed independently from the main memory array, and utilizing the Buffer Read Command allows data to be sequentially read directly from the buffers. In
serial mode, four opcodes, D4H or D1H for buffer 1 and D6H or D3H for buffer 2 can be used for
the Buffer Read Command. The use of each opcode depends on the maximum SCK frequency
that will be used to read data from the buffer. The D4H and D6H opcode can be used at any
SCK frequency up to the maximum specified by fCAR1. The D1H and D3H opcode can be used
for lower frequency read operations up to the maximum specified by fCAR2.
In 8-bit mode, two opcodes, 54H for buffer 1 and 56H for buffer 2 can be used for the Buffer
Read Command. The two opcodes, 54H and 56H, can be used at any SCK frequency up to the
maximum specified by fCAR1. To perform a buffer read from the standard DataFlash buffer (1056bytes), the opcode must be clocked into the device followed by three address bytes comprised
of 13 don’t care bits and 11 buffer address bits (BFA10 - BFA0). To perform a buffer read from
the binary buffer (1024-bytes), the opcode must be clocked into the device followed by three
address bytes comprised of 14 don’t care bits and 10 buffer address bits (BFA9 - BFA0).
8
AT45DB642D
AT45DB642D
Following the address bytes, additional don’t care bytes (one byte if using the serial interface or
two bytes if using the 8-bit interface) must be clocked in to initialize the read operation. The CS
pin must remain low during the loading of the opcode, the address bytes, the don’t care bytes,
and the reading of data. When the end of a buffer is reached, the device will continue reading
back at the beginning of the buffer. A low-to-high transition on the CS pin will terminate the read
operation and tri-state the output pins (SO or I/O7 - I/O0).
7. Program and Erase Commands
7.1
Buffer Write
Data can be clocked in from the input pins (SI or I/O7 - I/O0) into either buffer 1 or buffer 2. To
load data into the standard DataFlash buffer (1056-bytes), a 1-byte opcode, 84H for buffer 1 or
87H for buffer 2, must be clocked into the device, followed by three address bytes comprised of
13 don’t care bits and 11 buffer address bits (BFA10 - BFA0). The 11 buffer address bits specify
the first byte in the buffer to be written. To load data into the binary buffers (1024 bytes each), a
1-byte opcode 84H for buffer 1 or 87H for buffer 2, must be clocked into the device, followed by
three address bytes comprised of 14 don’t care bits and 10 buffer address bits (BFA9 - BFA0).
The 10 buffer address bits specify the first byte in the buffer to be written. After the last address
byte has been clocked into the device, data can then be clocked in on subsequent clock cycles.
If the end of the data buffer is reached, the device will wrap around back to the beginning of the
buffer. Data will continue to be loaded into the buffer until a low-to-high transition is detected on
the CS pin.
7.2
Buffer to Main Memory Page Program with Built-in Erase
Data written into either buffer 1 or buffer 2 can be programmed into the main memory. A 1-byte
opcode, 83H for buffer 1 or 86H for buffer 2, must be clocked into the device. For the standard
DataFlash page size (1056-bytes), the opcode must be followed by three address bytes consist
of 13 page address bits (PA12 - PA0) that specify the page in the main memory to be written and
11 don’t care bits. To perform a buffer to main memory page program with built-in erase for the
binary page size (1024-bytes), the opcode 83H for buffer 1 or 86H for buffer 2, must be clocked
into the device followed by three address bytes consisting of 13 page address bits (A22 - A10)
that specify the page in the main memory to be written and 10 don’t care bits. When a low-tohigh transition occurs on the CS pin, the part will first erase the selected page in main memory
(the erased state is a logic 1) and then program the data stored in the buffer into the specified
page in main memory. Both the erase and the programming of the page are internally self-timed
and should take place in a maximum time of tEP. During this time, the status register and the
RDY/BUSY pin will indicate that the part is busy.
7.3
Buffer to Main Memory Page Program without Built-in Erase
A previously-erased page within main memory can be programmed with the contents of either
buffer 1 or buffer 2. A 1-byte opcode, 88H for buffer 1 or 89H for buffer 2, must be clocked into
the device. For the standard DataFlash page size (1056-bytes), the opcode must be followed by
three address bytes consist of 13 page address bits (PA12 - PA0) that specify the page in the
main memory to be written and 11 don’t care bits. To perform a buffer to main memory page program without built-in erase for the binary page size (1024-bytes), the opcode 88H for buffer 1 or
89H for buffer 2, must be clocked into the device followed by three address bytes consist of
13-page address bits (A22 - A10) that specify the page in the main memory to be written and
10 don’t care bits. When a low-to-high transition occurs on the CS pin, the part will program the
data stored in the buffer into the specified page in the main memory. It is necessary that the
9
page in main memory that is being programmed has been previously erased using one of the
erase commands (Page Erase or Block Erase). The programming of the page is internally selftimed and should take place in a maximum time of tP. During this time, the status register and
the RDY/BUSY pin will indicate that the part is busy.
7.4
Page Erase
The Page Erase command can be used to individually erase any page in the main memory array
allowing the Buffer to Main Memory Page Program to be utilized at a later time. To perform a
page erase in the standard DataFlash page size (1056-bytes), an opcode of 81H must be
loaded into the device, followed by three address bytes comprised of 13 page address bits
(PA12 - PA0) that specify the page in the main memory to be erased and 11 don’t care bits. To
perform a page erase in the binary page size (1024-bytes), the opcode 81H must be loaded into
the device, followed by three address bytes consist of 13 page address bits (A22 - A10) that
specify the page in the main memory to be erased and 10 don’t care bits. When a low-to-high
transition occurs on the CS pin, the part will erase the selected page (the erased state is a logical 1). The erase operation is internally self-timed and should take place in a maximum time of
tPE. During this time, the status register and the RDY/BUSY pin will indicate that the part is busy.
7.5
Block Erase
A block of eight pages can be erased at one time. This command is useful when large amounts
of data has to be written into the device. This will avoid using multiple Page Erase Commands.
To perform a block erase for the standard DataFlash page size (1056 bytes), an opcode of 50H
must be loaded into the device, followed by three address bytes comprised of 10 page address
bits (PA12 -PA3) and 14 don’t care bits. The 10 page address bits are used to specify which
block of eight pages is to be erased. To perform a block erase for the binary page size (1024bytes), the opcode 50H must be loaded into the device, followed by three address bytes consisting of 10 page address bits (A22 - A13) and 13 don’t care bits. The 10 page address bits are
used to specify which block of eight pages is to be erased. When a low-to-high transition occurs
on the CS pin, the part will erase the selected block of eight pages. The erase operation is internally self-timed and should take place in a maximum time of tBE. During this time, the status
Table 7-1.
Block Erase Addressing
PA12/
A22
PA11/
A21
PA10/
A20
PA9/
A19
PA8/
A18
PA7/
A17
PA6/
A16
PA5/
A15
PA4/
A14
PA3/
A13
PA2/
A12
PA1/
A11
PA0/
A10
Block
X
X
X
X
X
X
1
X
X
X
2
1
X
X
X
3
1
1
1
1
1
1
1
1
X
X
X
1020
1
1
1
1
1
1
1
1
X
X
X
1021
1
1
1
1
1
1
1
1
1
X
X
X
1022
1
1
1
1
1
1
1
1
1
1
X
X
X
1023
10
AT45DB642D
AT45DB642D
7.6
Sector Erase
The Sector Erase command can be used to individually erase any sector in the main memory.
There are 32 sectors and only one sector can be erased at one time. To perform sector 0a or
sector 0b erase for the standard DataFlash page size (1056-bytes), an opcode of 7CH must be
loaded into the device, followed by three address bytes comprised of 10 page address bits
(PA12 - PA3) and 14 don’t care bits. To perform a sector 1-31 erase, the opcode 7CH must be
loaded into the device, followed by three address bytes comprised of five page address bits
(PA12 - PA8) and 19 don’t care bits. To perform sector 0a or sector 0b erase for the binary page
size (1024-bytes), an opcode of 7CH must be loaded into the device, followed by three address
bytes comprised of one don’t care bit and 10 page address bits (A22 - A13) and 13 don’t care
bits. To perform a sector 1-31 erase, the opcode 7CH must be loaded into the device, followed
by three address bytes comprised of one don’t care bit and five page address bits (PA12 - PA8)
and 18 don’t care bits. The page address bits are used to specify any valid address location
within the sector which is to be erased. When a low-to-high transition occurs on the CS pin, the
part will erase the selected sector. The erase operation is internally self-timed and should take
place in a maximum time of tSE. During this time, the status register and the RDY/BUSY pin will
Table 7-2.
Sector Erase Addressing
PA12/
A22
PA11/
A21
PA10/
A20
PA9/
A19
PA8/
A18
PA7/
A17
PA6/
A16
PA5/
A15
PA4/
A14
PA3/
A13
PA2/
A12
PA1/
A11
PA0/
A10
Sector
X
X
X
0a
X
X
X
0b
X
X
X
X
X
X
X
X
1
X
X
X
X
X
X
X
X
2
1
1
1
X
X
X
X
X
X
X
X
28
1
1
1
X
X
X
X
X
X
X
X
29
1
1
1
1
X
X
X
X
X
X
X
X
30
1
1
1
1
1
X
X
X
X
X
X
X
X
31
7.7
Chip Erase(1)
The entire main memory can be erased at one time by using the Chip Erase command.
To execute the Chip Erase command, a 4-byte command sequence C7H, 94H, 80H and 9AH
must be clocked into the device. Since the entire memory array is to be erased, no address
bytes need to be clocked into the device, and any data clocked in after the opcode will be
ignored. After the last bit of the opcode sequence has been clocked in, the CS pin can be deasserted to start the erase process. The erase operation is internally self-timed and should take
place in a time of tCE. During this time, the Status Register will indicate that the device is busy.
The Chip Erase command will not affect sectors that are protected or locked down; the contents
of those sectors will remain unchanged. Only those sectors that are not protected or locked
down will be erased.
11
The WP pin can be asserted while the device is erasing, but protection will not be activated until
the internal erase cycle completes.
Table 7-3.
Chip Erase Command
Command
Byte 1
Byte 2
Byte 3
Byte 4
Chip Erase
C7H
94H
80H
9AH
Figure 7-1.
Chip Erase
CS
SI
Opcode
Byte 1
Opcode
Byte 2
Opcode
Byte 3
Opcode
Byte 4
Each transition
represents 8 bits
Note:
7.8
1. Refer to the errata regarding Chip Erase on page 56
Main Memory Page Program Through Buffer
This operation is a combination of the Buffer Write and Buffer to Main Memory Page Program
with Built-in Erase operations. Data is first clocked into buffer 1 or buffer 2 from the input pins (SI
or I/O7-I/O0) and then programmed into a specified page in the main memory. To perform the
main memory page program through buffer for the standard DataFlash page size (1056-bytes),
a 1-byte opcode, 82H for buffer 1 or 85H for buffer 2, must first be clocked into the device, followed by three address bytes. The address bytes are comprised of 13 page address bits,
(PA12-PA0) that select the page in the main memory where data is to be written, and 11 buffer
address bits (BFA10-BFA0) that select the first byte in the buffer to be written. To perform a
main memory page program through buffer for the binary page size (1024-bytes), the opcode
82H for buffer 1 or 85H for buffer 2, must be clocked into the device followed by three address
bytes consisting of 13 page address bits (A22 - A10) that specify the page in the main memory
to be written, and 10 buffer address bits (BFA9 - BFA0) that selects the first byte in the buffer to
be written. After all address bytes are clocked in, the part will take data from the input pins and
store it in the specified data buffer. If the end of the buffer is reached, the device will wrap
around back to the beginning of the buffer. When there is a low-to-high transition on the CS pin,
the part will first erase the selected page in main memory to all 1s and then program the data
stored in the buffer into that memory page. Both the erase and the programming of the page are
internally self-timed and should take place in a maximum time of tEP. During this time, the status
8. Sector Protection
Two protection methods, hardware and software controlled, are provided for protection against
inadvertent or erroneous program and erase cycles. The software controlled method relies on
the use of software commands to enable and disable sector protection while the hardware controlled method employs the use of the Write Protect (WP) pin. The selection of which sectors
that are to be protected or unprotected against program and erase operations is specified in the
nonvolatile Sector Protection Register. The status of whether or not sector protection has been
enabled or disabled by either the software or the hardware controlled methods can be determined by checking the Status Register.
12
AT45DB642D
AT45DB642D
8.1
8.1.1
Software Sector Protection
Enable Sector Protection Command
Sectors specified for protection in the Sector Protection Register can be protected from program
and erase operations by issuing the Enable Sector Protection command. To enable the sector
protection using the software controlled method, the CS pin must first be asserted as it would be
with any other command. Once the CS pin has been asserted, the appropriate 4-byte command
sequence must be clocked in via the input pins (SI or I/O7-I/O0). After the last bit of the command sequence has been clocked in, the CS pin must be deasserted after which the sector
protection will be enabled.
Table 8-1.
Command
Byte 1
Byte 2
Byte 3
Byte 4
3DH
2AH
7FH
A9H
Figure 8-1.
CS
SI or IO7 - IO0
Opcode
Byte 1
Opcode
Byte 2
Opcode
Byte 3
Opcode
Byte 4
Each transition
represents 8 bits
8.1.2
Disable Sector Protection Command
To disable the sector protection using the software controlled method, the CS pin must first be
asserted as it would be with any other command. Once the CS pin has been asserted, the
appropriate 4-byte sequence for the Disable Sector Protection command must be clocked in via
the CS pin must be deasserted after which the sector protection will be disabled. The WP pin
must be in the deasserted state; otherwise, the Disable Sector Protection command will be
ignored.
Table 8-2.
Disenable Sector Protection Command
Command
Byte 1
Byte 2
Byte 3
Byte 4
3DH
2AH
7FH
9AH
Figure 8-2.
CS
SI or IO7 - IO0
Opcode
Byte 1
Opcode
Byte 2
Opcode
Byte 3
Opcode
Byte 4
Each transition
represents 8 bits
13
8.1.3
Various Aspects About Software Controlled Protection
Software controlled protection is useful in applications in which the WP pin is not or cannot be
controlled by a host processor. In such instances, the WP pin may be left floating (the WP pin is
internally pulled high) and sector protection can be controlled using the Enable Sector Protection
and Disable Sector Protection commands.
If the device is power cycled, then the software controlled protection will be disabled. Once the
device is powered up, the Enable Sector Protection command should be reissued if sector protection is desired and if the WP pin is not used.
9. Hardware Controlled Protection
and erase operations by asserting the WP pin and keeping the pin in its asserted state. Any sector specified for protection cannot be erased or reprogrammed as long as the WP pin is
asserted.
The WP pin will override the software controlled protection method but only for protecting the
sectors. For example, if the sectors were not previously protected by the Enable Sector Protection command, then simply asserting the WP pin would enable the sector protection within the
maximum specified tWPE time. When the WP pin is deasserted; however, the sector protection
would no longer be enabled (after the maximum specified tWPD time) as long as the Enable Sector Protection command was not issued while the WP pin was asserted. If the Enable Sector
Protection command was issued before or while the WP pin was asserted, then simply deasserting the WP pin would not disable the sector protection. In this case, the Disable Sector
Protection command would need to be issued while the WP pin is deasserted to disable the sector protection. The Disable Sector Protection command is also ignored whenever the WP pin is
asserted.
A noise filter is incorporated to help protect against spurious noise that may inadvertently assert
or deassert the WP pin.
The table below details the sector protection status for various scenarios of the WP pin, the
Enable Sector Protection command, and the Disable Sector Protection command.
Figure 9-1.
WP Pin and Protection Status
1
3
2
WP
Table 9-1.
Time
Period
WP Pin
Command
Sector Protection
Status
1
High
Command Not Issued Previously
Issue Command
X
Issue Command
Disabled
Disabled
Enabled
2
Low
X
X
Enabled
3
High
Command Issued During Period 1 or 2
Issue Command
Not Issued Yet
Issue Command
Enabled
Disabled
Enabled
14
AT45DB642D
AT45DB642D
9.1
The nonvolatile Sector Protection Register specifies which sectors are to be protected or unprotected with either the software or hardware controlled protection methods. The Sector Protection
Register contains 32-bytes of data, of which byte locations 0 through 31 contain values that
specify whether sectors 0 through 31 will be protected or unprotected. The Sector Protection
Register is user modifiable and must first be erased before it can be reprogrammed. Table 9-3
illustrates the format of the Sector Protection Register.:
Table 9-2.
Sector Number
0 (0a, 0b)
1 to 31
Protected
FFH
See Table 9-3
Unprotected
Table 9-3.
Sector 0 (0a, 0b)
0a
0b
(Page 0-7)
(Page 8-255)
Bit 7, 6
Bit 5, 4
Bit 3, 2
Bit 1, 0
Data
Value
Sectors 0a, 0b Unprotected
00
00
xx
xx
0xH
Protect Sector 0a
11
00
xx
xx
CxH
Protect Sector 0b (Page 8-255)
00
11
xx
xx
3xH
Protect Sectors 0a (Page 0-7), 0b
(Page 8-255)(1)
11
11
xx
xx
FxH
Note:
9.1.1
00H
1. The default value for bytes 0 through 31 when shipped from Adesto® is 00H
x = don’t care
Erase Sector Protection Register Command
In order to modify and change the values of the Sector Protection Register, it must first be
erased using the Erase Sector Protection Register command.
To erase the Sector Protection Register, the CS pin must first be asserted as it would be with
any other command. Once the CS pin has been asserted, the appropriate 4-byte opcode
sequence must be clocked into the device via the SI or I/O7 - I/O0 pin. The 4-byte opcode
sequence must start with 3DH and be followed by 2AH, 7FH, and CFH. After the last bit of the
opcode sequence has been clocked in, the CS pin must be deasserted to initiate the internally
self-timed erase cycle. The erasing of the Sector Protection Register should take place in a time
of tPE, during which time the Status Register will indicate that the device is busy. If the device is
powered-down before the completion of the erase cycle, then the contents of the Sector Protection Register cannot be guaranteed.
The Sector Protection Register can be erased with the sector protection enabled or disabled.
Since the erased state (FFH) of each byte in the Sector Protection Register is used to indicate
that a sector is specified for protection, leaving the sector protection enabled during the erasing
of the register allows the protection scheme to be more effective in the prevention of accidental
programming or erasing of the device. If for some reason an erroneous program or erase command is sent to the device immediately after erasing the Sector Protection Register and before
the register can be reprogrammed, then the erroneous program or erase command will not be
processed because all sectors would be protected.
15
Table 9-4.
Command
Byte 1
Byte 2
Byte 3
Byte 4
3DH
2AH
7FH
CFH
Figure 9-2.
CS
SI or IO7 - IO0
Opcode
Byte 1
Opcode
Byte 2
Opcode
Byte 3
Opcode
Byte 4
Each transition
represents 8 bits
9.1.2
Program Sector Protection Register Command
Once the Sector Protection Register has been erased, it can be reprogrammed using the Program Sector Protection Register command.
To program the Sector Protection Register, the CS pin must first be asserted and the appropriate 4-byte opcode sequence must be clocked into the device via the SI or I/O7 - I/O0 pin. The 4byte opcode sequence must start with 3DH and be followed by 2AH, 7FH, and FCH. After the
last bit of the opcode sequence has been clocked into the device, the data for the contents of the
Sector Protection Register must be clocked in. As described in Section 9.1, the Sector Protection Register contains 32-bytes of data, so 32-bytes must be clocked into the device. The first
byte of data corresponds to sector 0, the second byte corresponds to sector 1, and so on with
the last byte of data corresponding to sector 31.
After the last data byte has been clocked in, the CS pin must be deasserted to initiate the internally self-timed program cycle. The programming of the Sector Protection Register should take
place in a time of tP, during which time the Status Register will indicate that the device is busy. If
the device is powered-down during the program cycle, then the contents of the Sector Protection
If the proper number of data bytes is not clocked in before the CS pin is deasserted, then the
protection status of the sectors corresponding to the bytes not clocked in can not be guaranteed.
For example, if only the first two bytes are clocked in instead of the complete 32-bytes, then the
protection status of the last 30 sectors cannot be guaranteed. Furthermore, if more than 32bytes of data is clocked into the device, then the data will wrap back around to the beginning of
the register. For instance, if 33-bytes of data are clocked in, then the 33rd byte will be stored at
byte location 0 of the Sector Protection Register.
If a value other than 00H or FFH is clocked into a byte location of the Sector Protection Register,
then the protection status of the sector corresponding to that byte location cannot be guaranteed. For example, if a value of 17H is clocked into byte location 2 of the Sector Protection
Register, then the protection status of sector 2 cannot be guaranteed.
The Sector Protection Register can be reprogrammed while the sector protection enabled or disabled. Being able to reprogram the Sector Protection Register with the sector protection enabled
allows the user to temporarily disable the sector protection to an individual sector rather than disabling sector protection completely.
The Program Sector Protection Register command utilizes the internal SRAM buffer for processing. Therefore, the contents of the buffer will be altered from its previous state when this
command is issued.
16
AT45DB642D
AT45DB642D
Table 9-5.
Command
Figure 9-3.
Byte 1
Byte 2
Byte 3
Byte 4
3DH
2AH
7FH
FCH
CS
SI or IO7 - IO0
Opcode
Byte 1
Opcode
Byte 2
Opcode
Byte 3
Opcode
Byte 4
Data Byte
n
Data Byte
n+1
Data Byte
n + 31
Each transition
represents 8 bits
9.1.3
Read Sector Protection Register Command
To read the Sector Protection Register, the CS pin must first be asserted. Once the CS pin has
been asserted, an opcode of 32H and a series of dummy bytes (three dummy bytes if using the
serial interface or seven dummy bytes if using the 8-bit interface) must be clocked in via the SI or
I/O7 or I/O0 pins. After the last bit of the opcode and dummy bytes have been clocked in, any
additional clock pulses on the SCK/CLK pins will result in data for the content of the Sector Protection Register being output on the SO or I/O7-I/O0 pins. The first byte corresponds to sector 0
(0a, 0b), the second byte corresponds to sector 1 and the last byte (byte 32) corresponds to sector 31. Once the last byte of the Sector Protection Register has been clocked out, any additional
clock pulses will result in undefined data being output on the SO or I/O pins. The CS must be
deasserted to terminate the Read Sector Protection Register operation and put the output into a
Table 9-6.
Command
Note:
Figure 9-4.
xx = Dummy Byte
Byte 1
Byte 2
Byte 3
Byte 4
32H
xxH
xxH
xxH
Serial Interface = 3 Dummy Bytes
8-bit Interface = 7 Dummy Bytes
CS
SI or IO7 - IO0
Opcode
X
X
X
Data Byte
n
SO or IO7 - IO0
Data Byte
n+1
Data Byte
n + 31
Each transition
represents 8 bits
17
9.1.4
Various Aspects About the Sector Protection Register
The Sector Protection Register is subject to a limit of 10,000 erase/program cycles. Users are
encouraged to carefully evaluate the number of times the Sector Protection Register will be
modified during the course of the applications’ life cycle. If the application requires that the Sector Protection Register be modified more than the specified limit of 10,000 cycles because the
application needs to temporarily unprotect individual sectors (sector protection remains enabled
while the Sector Protection Register is reprogrammed), then the application will need to limit this
practice. Instead, a combination of temporarily unprotecting individual sectors along with disabling sector protection completely will need to be implemented by the application to ensure that
the limit of 10,000 cycles is not exceeded.
10. Security Features
10.1
Sector Lockdown
The device incorporates a Sector Lockdown mechanism that allows each individual sector to be
permanently locked so that it becomes read only. This is useful for applications that require the
ability to permanently protect a number of sectors against malicious attempts at altering program
code or security information. Once a sector is locked down, it can never be erased or programmed, and it can never be unlocked.
To issue the Sector Lockdown command, the CS pin must first be asserted as it would be for
sequence must be clocked into the device in the correct order. The 4-byte opcode sequence
must start with 3DH and be followed by 2AH, 7FH, and 30H. After the last byte of the command
sequence has been clocked in, then three address bytes specifying any address within the sector to be locked down must be clocked into the device. After the last address bit has been
clocked in, the CS pin must then be deasserted to initiate the internally self-timed lockdown
sequence.
The lockdown sequence should take place in a maximum time of tP, during which time the Status
Register will indicate that the device is busy. If the device is powered-down before the completion of the lockdown sequence, then the lockdown status of the sector cannot be guaranteed. In
this case, it is recommended that the user read the Sector Lockdown Register to determine the
status of the appropriate sector lockdown bits or bytes and reissue the Sector Lockdown command if necessary.
Table 10-1.
Sector Lockdown
Command
Sector Lockdown
Byte 1
Byte 2
Byte 3
Byte 4
3DH
2AH
7FH
30H
Figure 10-1. Sector Lockdown
CS
SI or IO7 - IO0
Opcode
Byte 1
Opcode
Byte 2
Opcode
Byte 3
Opcode
Byte 4
Address
Bytes
Address
Bytes
Address
Bytes
Each transition
represents 8 bits
18
AT45DB642D
AT45DB642D
10.1.1
Sector Lockdown Register is a nonvolatile register that contains 32-bytes of data, as shown
below:
Table 10-2.
Sector Number
0 (0a, 0b)
1 to 31
Locked
FFH
See Below
Unlocked
Table 10-3.
10.1.2
00H
Sector 0 (0a, 0b)
0a
0b
(Page 0-7)
(Page 8-255)
Bit 7, 6
Bit 5, 4
Bit 3, 2
Bit 1, 0
Data
Value
Sectors 0a, 0b Unlocked
00
00
00
00
00H
Sector 0a Locked
11
00
00
00
C0H
Sector 0b Locked (Page 8-255)
00
11
00
00
30H
Sectors 0a, 0b Locked (Page 0-255)
11
11
00
00
F0H
Reading the Sector Lockdown Register
The Sector Lockdown Register can be read to determine which sectors in the memory array are
permanently locked down. To read the Sector Lockdown Register, the CS pin must first be
asserted. Once the CS pin has been asserted, an opcode of 35H and a series of dummy bytes
(three dummy bytes if using the serial interface or seven dummy bytes if using the 8-bit interface) must be clocked into the device via the SI or I/O7-O0 pins. After the last bit of the opcode
and dummy bytes have been clocked in, the data for the contents of the Sector Lockdown Register will be clocked out on the SO pin or the I/O7-O0 pins. The first byte corresponds to sector 0
(0a, 0b) the second byte corresponds to sector 1 and the las byte (byte 32) corresponds to sector 31. After the last byte of the Sector Lockdown Register has been read, additional pulses on
the SCK pin will simply result in undefined data being output on the SO pin.
Deasserting the CS pin will terminate the Read Sector Lockdown Register operation and put the
SO pin or I/O7-O0 pins into a high-impedance state.
Table 10-4 details the values read from the Sector Lockdown Register.
Table 10-4.
Command
Note:
xx = Dummy Byte
Byte 1
Byte 2
Byte 3
Byte 4
35H
xxH
xxH
xxH
Figure 10-2. Read Sector Lockdown Register
CS
SI or IO7 - IO0
Opcode
X
X
X
Data Byte
n
SO or IO7 - IO0
Data Byte
n+1
Data Byte
n + 31
Each transition
represents 8 bits
19
10.2
Security Register
The device contains a specialized Security Register that can be used for purposes such as
unique device serialization or locked key storage. The register is comprised of a total of 128bytes that is divided into two portions. The first 64-bytes (byte locations 0 through 63) of the
Security Register are allocated as a one-time user programmable space. Once these 64-bytes
have been programmed, they cannot be reprogrammed. The remaining 64-bytes of the register
(byte locations 64 through 127) are factory programmed by Adesto and will contain a unique
value for each device. The factory programmed data is fixed and cannot be changed.
Table 10-5.
Security Register
Security Register Byte Number
Data Type
10.2.1
1
62
63
64
One-time User Programmable
65
126
127
Factory Programmed By Adesto
Programming the Security Register
The user programmable portion of the Security Register does not need to be erased before it is
programmed.
To program the Security Register, the CS pin must first be asserted and the appropriate 4-byte
opcode sequence must be clocked into the device in the correct order. The 4-byte opcode
sequence must start with 9BH and be followed by 00H, 00H, and 00H. After the last bit of the
opcode sequence has been clocked into the device, the data for the contents of the 64-byte user
programmable portion of the Security Register must be clocked in.
After the last data byte has been clocked in, the CS pin must be deasserted to initiate the internally self-timed program cycle. The programming of the Security Register should take place in a
time of tP, during which time the Status Register will indicate that the device is busy. If the device
is powered-down during the program cycle, then the contents of the 64-byte user programmable
portion of the Security Register cannot be guaranteed.
If the full 64-bytes of data is not clocked in before the CS pin is deasserted, then the values of
the byte locations not clocked in cannot be guaranteed. For example, if only the first two bytes
are clocked in instead of the complete 64-bytes, then the remaining 62-bytes of the user programmable portion of the Security Register cannot be guaranteed. Furthermore, if more than 64bytes of data is clocked into the device, then the data will wrap back around to the beginning of
the register. For instance, if 65-bytes of data are clocked in, then the 65th byte will be stored at
byte location zero of the Security Register.
The user programmable portion of the Security Register can only be programmed one
time. Therefore, it is not possible to only program the first two bytes of the register and then program the remaining 62-bytes at a later time.
The Program Security Register command utilizes the internal SRAM buffer for processing.
Therefore, the contents of the buffer will be altered from its previous state when this command is
issued.
Figure 10-3. Program Security Register
CS
SI or IO7 - IO0
Opcode
Byte 1
Opcode
Byte 2
Opcode
Byte 3
Opcode
Byte 4
Data Byte
n
Data Byte
n+1
Data Byte
n+x
Each transition
represents 8 bits
AT45DB642D
AT45DB642D
10.2.2
Reading the Security Register
The Security Register can be read by first asserting the CS pin and then clocking in an opcode
of 77H followed by three dummy bytes if using the serial interface and seven dummy bytes if
using the 8-bit interface. After the last don't care bit has been clocked in, the content of the
Security Register can be clocked out on the SO or I/O7 - I/O0 pins. After the last byte of the
Security Register has been read, additional pulses on the SCK/CLK pin will simply result in
undefined data being output on the SO or I/O7 - I/O0 pins.
Deasserting the CS pin will terminate the Read Security Register operation and put the SO or
I/O7 - I/O0 pins into a high-impedance state.
Figure 10-4. Read Security Register
CS
SI or IO7 - IO0
Opcode
X
X
X
Data Byte
n
SO or IO7 - IO0
Data Byte
n+1
Data Byte
n+x
Each transition
represents 8 bits
11. Additional Commands
11.1
Main Memory Page to Buffer Transfer
A page of data can be transferred from the main memory to either buffer 1 or buffer 2. To start
the operation for the standard DataFlash page size (1056-bytes), a 1-byte opcode, 53H for buffer 1 and 55H for buffer 2, must be clocked into the device, followed by three address bytes
comprised of 13 page address bits (PA12 - PA0), which specify the page in main memory that is
to be transferred, and 11 don’t care bits. To perform a main memory page to buffer transfer for
the binary page size (1024-bytes), the opcode 53H for buffer 1 or 55H for buffer 2, must be
clocked into the device followed by three address bytes consisting of 13 page address bits (A22
- A10) which specify the page in the main memory that is to be transferred, and 10 don’t care
bits. The CS pin must be low while toggling the SCK/CLK pin to load the opcode and the
address bytes from the input pins (SI or I/O7 - I/O0). The transfer of the page of data from the
main memory to the buffer will begin when the CS pin transitions from a low to a high state. During the transfer of a page of data (tXFR), the status register can be read or the RDY/BUSY can be
monitored to determine whether the transfer has been completed.
11.2
Main Memory Page to Buffer Compare
A page of data in main memory can be compared to the data in buffer 1 or buffer 2. To initiate
the operation for standard DataFlash page size, a 1-byte opcode, 60H for buffer 1 and 61H for
buffer 2, must be clocked into the device, followed by three address bytes consisting of 13 page
address bits (PA12 - PA0) that specify the page in the main memory that is to be compared to
the buffer, and 11 don’t care bits. To start a main memory page to buffer compare for a binary
page size, the opcode 60H for buffer 1 or 61H for buffer 2, must be clocked into the device followed by three address bytes consisting of 13 page address bits (A22 - A10) that specify the
page in the main memory that is to be compared to the buffer, and 10 don’t care bits. The CS pin
must be low while toggling the SCK/CLK pin to load the opcode and the address bytes from the
21
input pins (SI or I/O7 - I/O0). On the low-to-high transition of the CS pin, the data bytes in the
selected main memory page will be compared with the data bytes in buffer 1 or buffer 2. During
this time (tCOMP), the status register and the RDY/BUSY pin will indicate that the part is busy. On
completion of the compare operation, bit 6 of the status register is updated with the result of the
compare.
11.3
Auto Page Rewrite
This mode is only needed if multiple bytes within a page or multiple pages of data are modified in
a random fashion within a sector. This mode is a combination of two operations: Main Memory
Page to Buffer Transfer and Buffer to Main Memory Page Program with Built-in Erase. A page of
data is first transferred from the main memory to buffer 1 or buffer 2, and then the same data
(from buffer 1 or buffer 2) is programmed back into its original page of main memory. To start the
rewrite operation for standard DataFlash page size (1056-bytes), a 1-byte opcode, 58H for buffer 1 or 59H for buffer 2, must be clocked into the device, followed by three address bytes
comprised of 13 page address bits (PA12-PA0) that specify the page in main memory to be
rewritten and 11 don’t care bits. To initiate an auto page rewrite for a binary page size (1024bytes), the opcode 58H for buffer 1 or 59H for buffer 2, must be clocked into the device followed
by three address bytes consisting of 13 page address bits (A22 - A10) that specify the page in
the main memory that is to be written and 10 don’t care bits. When a low-to-high transition
occurs on the CS pin, the part will first transfer data from the page in main memory to a buffer
and then program the data from the buffer back into same page of main memory. The operation
is internally self-timed and should take place in a maximum time of tEP. During this time, the status register and the RDY/BUSY pin will indicate that the part is busy.
If a sector is programmed or reprogrammed sequentially page by page, then the programming
algorithm shown in Figure 26-1 (page 49) is recommended. Otherwise, if multiple bytes in a
page or several pages are programmed randomly in a sector, then the programming algorithm
shown in Figure 26-2 (page 50) is recommended. Each page within a sector must be
updated/rewritten at least once within every 20,000 cumulative page erase/program operations
in that sector. Please contact Adesto for availability of devices that are specified to exceed the
20K cycle cumulative limit.
11.4
Status Register Read
The status register can be used to determine the device’s ready/busy status, page size, a Main
Memory Page to Buffer Compare operation result, the Sector Protection status or the device
density. To read the status register, an opcode of D7H must be loaded into the device. After the
opcode is clocked in, the 1-byte status register will be clocked out on the output pins (SO or
I/O7 - I/O0), starting with the next clock cycle. In case of applications with 8-bit interface, opcode
D7H and two dummy clock cycles should be used. When using the serial interface, the data in
the status register, starting with the MSB (bit 7), will be clocked out on the SO pin during the next
eight clock cycles. After the one byte of the status register has been clocked out, the sequence
will repeat itself (as long as CS remains low and SCK/CLK is being toggled). The data in the status register is constantly updated, so each repeating sequence will output new data.
Ready/busy status is indicated using bit seven of the status register. If bit seven is a one, then
the device is not busy and is ready to accept the next command. If bit seven is a zero, then the
device is in a busy state. Since the data in the status register is constantly updated, the user
must toggle SCK/CLK pin to check the ready/busy status. There are several operations that can
cause the device to be in a busy state: Main Memory Page to Buffer Transfer, Main Memory
Page to Buffer Compare, Buffer to Main Memory Page Program, Main Memory Page Program
through Buffer, Page Erase, Block Erase, Sector Erase, Chip Erase and Auto Page Rewrite.
22
AT45DB642D
AT45DB642D
The result of the most recent Main Memory Page to Buffer Compare operation is indicated using
bit 6 of the status register. If bit six is a zero, then the data in the main memory page matches
the data in the buffer. If bit six is a one, then at least one bit of the data in the main memory page
does not match the data in the buffer.
Bit one in the Status Register is used to provide information to the user whether or not the sector
protection has been enabled or disabled, either by software-controlled method or hardware-controlled method. A logic 1 indicates that sector protection has been enabled and logic 0 indicates
that sector protection has been disabled.
Bit zero in the Status Register indicates whether the page size of the main memory array is configured for “power of 2” binary page size (1024-bytes) or standard DataFlash page size (1056bytes). If bit zero is a one, then the page size is set to 1024-bytes. If bit zero is a zero, then the
page size is set to 1056-bytes.
The device density is indicated using bits five, four, three, and two of the status register. For the
AT45DB642D, the four bits are 1111 The decimal value of these four binary bits does not equate
to the device density; the four bits represent a combinational code relating to differing densities
of DataFlash devices. The device density is not the same as the density code indicated in the
JEDEC device ID information. The device density is provided only for backward compatibility.
Table 11-1.
Status Register Format
Bit 7
Bit 6
Bit 5
Bit 4
Bit 3
Bit 2
Bit 1
Bit 0
RDY/BUSY
COMP
1
1
1
1
PROTECT
PAGE SIZE
12. Deep Power-down
After initial power-up, the device will default in standby mode. The Deep Power-down command
allows the device to enter into the lowest power consumption mode. To enter the Deep Powerdown mode, the CS pin must first be asserted. Once the CS pin has been asserted, an opcode
of B9H command must be clocked in via input pins (SI or IO7-IO0). After the last bit of the command has been clocked in, the CS pin must be de-asserted to initiate the Deep Power-down
operation. After the CS pin is de-asserted, the will device enter the Deep Power-down mode
within the maximum tEDPD time. Once the device has entered the Deep Power-down mode, all
instructions are ignored except for the Resume from Deep Power-down command.
Table 12-1.
Deep Power-down
Command
Deep Power-down
Serial/8-bit
Opcode
Both
B9H
Figure 12-1. Deep Power-down
CS
SI or IO7 - IO0
Opcode
Each transition
represents 8 bits
23
3542M–DFLASH–11/2012
12.1
The Resume from Deep Power-down command takes the device out of the Deep Power-down
mode and returns it to the normal standby mode. To Resume from Deep Power-down mode, the
CS pin must first be asserted and an opcode of ABH command must be clocked in via input pins
(SI or IO7-IO0). After the last bit of the command has been clocked in, the CS pin must be deasserted to terminate the Deep Power-down mode. After the CS pin is de-asserted, the device
will return to the normal standby mode within the maximum tRDPD time. The CS pin must remain
high during the tRDPD time before the device can receive any commands. After resuming form
Deep Power-down, the device will return to the normal standby mode.
Table 12-2.
Command
Serial/8-bit
Opcode
Both
ABH
Figure 12-2. Resume from Deep Power-Down
CS
SI or IO7 - IO0
Opcode
Each transition
represents 8 bits
13. “Power of 2” Binary Page Size Option
“Power of 2” binary page size Configuration Register is a user-programmable nonvolatile register that allows the page size of the main memory to be configured for binary page size (1024bytes) or standard DataFlash page size (1056-bytes). The “power of 2” page size is a onetime programmable configuration register and once the device is configured for “power
of 2” page size, it cannot be reconfigured again. The devices are initially shipped with the
page size set to 1056-bytes. The user has the option of ordering binary page size (1024bytes) devices from the factory. For details, please refer to Section 27. ”Ordering Information” on
page 51.
For the binary “power of 2” page size to become effective, the following steps must be followed:
1. Program the one-time programmable configuration resister using opcode sequence
3DH, 2AH, 80H and A6H (please see Section 13.1).
2. Power cycle the device (i.e. power down and power up again).
3. User can now program the page for the binary page size.
If the above steps are not followed in setting the the page size prior to page programming, user
may expect incorrect data during a read operation.
24
AT45DB642D
AT45DB642D
13.1
Programming the Configuration Register
To program the Configuration Register for “power of 2” binary page size, the CS pin must first be
appropriate 4-byte opcode sequence must be clocked into the device in the correct order. The 4byte opcode sequence must start with 3DH and be followed by 2AH, 80H, and A6H. After the
last bit of the opcode sequence has been clocked in, the CS pin must be deasserted to initiate
the internally self-timed program cycle. The programming of the Configuration Register should
take place in a time of tP, during which time the Status Register will indicate that the device is
busy. The device must be power-cycled after the completion of the program cycle to set the
“power of 2” page size. If the device is powered-down before the completion of the program
cycle, then setting the Configuration Register cannot be guaranteed. However, the user should
check bit 0 of the status register to see whether the page size was configured for binary page
size. If not, the command can be re-issued again.
Table 13-1.
Command
Power of Two Page Size
Byte 1
Byte 2
Byte 3
Byte 4
3DH
2AH
80H
A6H
Figure 13-1. Erase Sector Protection Register
CS
Opcode
Byte 1
SI or IO7 - IO0
Opcode
Byte 2
Opcode
Byte 3
Opcode
Byte 4
Each transition
represents 8 bits
14. Manufacturer and Device ID Read
Identification information can be read from the device to enable systems to electronically query
and identify the device while it is in system. The identification method and the command opcode
comply with the JEDEC standard for “Manufacturer and Device ID Read Methodology for SPI
Compatible Serial Interface Memory Devices”. The type of information that can be read from the
device includes the JEDEC defined Manufacturer ID, the vendor specific Device ID, and the vendor specific Extended Device Information.
To read the identification information, the CS pin must first be asserted and the opcode of 9FH
must be clocked into the device. After the opcode has been clocked in, the device will begin outputting the identification data on the SO pin during the subsequent clock cycles. The first byte
that will be output will be the Manufacturer ID followed by two bytes of Device ID information.
The fourth byte output will be the Extended Device Information String Length, which will be 00H
indicating that no Extended Device Information follows. As indicated in the JEDEC standard,
reading the Extended Device Information String Length and any subsequent data is optional.
Deasserting the CS pin will terminate the Manufacturer and Device ID Read operation and put
the SO pin into a high-impedance state. The CS pin can be deasserted at any time and does not
require that a full byte of data be read.
25
14.1
14.1.1
Manufacturer and Device ID Information
Byte 1 – Manufacturer ID
JEDEC Assigned Code
Hex
Value
Bit 7
Bit 6
Bit 5
Bit 4
Bit 3
Bit 2
Bit 1
Bit 0
1FH
1
1
1
1
14.1.2
Manufacturer ID
Byte 2 – Device ID (Part 1)
Family Code
Density Code
Hex
Value
Bit 7
Bit 6
Bit 5
Bit 4
Bit 3
Bit 2
Bit 1
Bit 0
Family Code
28H
Density Code
14.1.3
001 = DataFlash
01000 = 64-Mbit
Byte 3 – Device ID (Part 2)
MLC Code
Product Version Code
Hex
Value
Bit 7
Bit 6
Bit 5
Bit 4
Bit 3
Bit 2
Bit 1
Bit 0
00H
1FH = Adesto
SLC Code
000 = 1-bit/Cell Technology
Product Version
00000 = Initial Version
Byte Count
00H = 0 Bytes of Information
Byte 4 – Extended Device Information String Length
Byte Count
Hex
Value
Bit 7
Bit 6
Bit 5
Bit 4
Bit 3
Bit 2
Bit 1
Bit 0
00H
CS
SI
9FH
Opcode
SO
Each transition
represents 8 bits
Note:
26
1FH
28H
00H
00H
Data
Data
Manufacturer ID
Byte n
Device ID
Byte 1
Device ID
Byte 2
Extended
Device
Information
String Length
Extended
Device
Information
Byte x
Extended
Device
Information
Byte x + 1
This information would only be output
if the Extended Device Information String Length
value was something other than 00H.
Based on JEDEC publication 106 (JEP106), Manufacturer ID data can be comprised of any number of bytes. Some manufacturers may have
Manufacturer ID codes that are two, three or even four bytes long with the first byte(s) in the sequence being 7FH. A system should detect code
7FH as a “Continuation Code” and continue to read Manufacturer ID bytes. The first non-7FH byte would signify the last byte of Manufacturer ID
data. For Adesto (and some other manufacturers), the Manufacturer ID data is comprised of only one byte.
AT45DB642D
AT45DB642D
14.2
Operation Mode Summary
The commands described previously can be grouped into four different categories to better
describe which commands can be executed at what times.
Group A commands consist of:
1.
2.
3.
4.
5.
Group B commands consist of:
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
Page Erase
Block Erase
Sector Erase
Chip Erase
Main Memory Page to Buffer 1 (or 2) Transfer
Main Memory Page to Buffer 1 (or 2) Compare
Buffer 1 (or 2) to Main Memory Page Program with Built-in Erase
Buffer 1 (or 2) to Main Memory Page Program without Built-in Erase
Main Memory Page Program through Buffer 1 (or 2)
Auto Page Rewrite
Group C commands consist of:
1.
2.
3.
4.
Buffer 1 (or 2) Read
Buffer 1 (or 2) Write
Group D commands consist of:
1.
2.
3.
4.
Sector Lockdown
If a Group A command is in progress (not fully completed), then another command in Group A,
B, C, or D should not be started. However, during the internally self-timed portion of Group B
commands, any command in Group C can be executed. The Group B commands using buffer 1
should use Group C commands using buffer 2 and vice versa. Finally, during the internally selftimed portion of a Group D command, only the Status Register Read command should be
executed.
27
15. Command Tables
Table 15-1.
Read Commands
Command
Serial/8-bit
Opcode
Both
D2H
Continuous Array Read (Legacy Command)
Both
E8H
Continuous Array Read (Low Frequency)
Serial
03H
Serial
0BH
Buffer 1 Read (Low Frequency)
Serial
D1H
Buffer 2 Read (Low Frequency)
Serial
D3H
Buffer 1 Read
Serial
D4H
Buffer 2 Read
Serial
D6H
Buffer 1 Read
8-bit
54H
Buffer 2 Read
8-bit
56H
Serial/8-bit
Opcode
Buffer 1 Write
Both
84H
Buffer 2 Write
Both
87H
Buffer 1 to Main Memory Page Program with Built-in Erase
Both
83H
Buffer 2 to Main Memory Page Program with Built-in Erase
Both
86H
Buffer 1 to Main Memory Page Program without Built-in Erase
Both
88H
Buffer 2 to Main Memory Page Program without Built-in Erase
Both
89H
Page Erase
Both
81H
Block Erase
Both
50H
Sector Erase
Both
7CH
Chip Erase
Both
C7H, 94H, 80H, 9AH
Main Memory Page Program Through Buffer 1
Both
82H
Main Memory Page Program Through Buffer 2
Both
85H
Table 15-2.
Command
28
AT45DB642D
AT45DB642D
Table 15-3.
Protection and Security Commands
Command
Serial/8-Bit
Opcode
Both
3DH + 2AH + 7FH + A9H
Both
3DH + 2AH + 7FH + 9AH
Both
3DH + 2AH + 7FH + CFH
3DH + 2AH + 7FH + FCH
Both
32H
Sector Lockdown
Both
3DH + 2AH + 7FH + 30H
Both
35H
Both
9BH + 00H + 00H + 00H
Both
77H
Serial/8-bit
Opcode
Main Memory Page to Buffer 1 Transfer
Both
53H
Main Memory Page to Buffer 2 Transfer
Both
55H
Main Memory Page to Buffer 1 Compare
Both
60H
Main Memory Page to Buffer 2 Compare
Both
61H
Auto Page Rewrite through Buffer 1
Both
58H
Auto Page Rewrite through Buffer 2
Both
59H
Deep Power-down
Both
B9H
Both
ABH
Both
D7H
Serial
9FH
Table 15-4.
Additional Commands
Command
29
Detailed Bit-level Addressing Sequence for Binary Page Size (1024-Bytes)
1
0Bh
50h
53h
54h
55h
56h
58h
59h
60h
1
61h
1
77h
7Ch
81h
1
82h
1
83h
1
84h
1
85h
1
86h
1
87h
1
88h
1
89h
9Fh
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
x
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
x
x
x
x
x
x
x
x
x
x
1
1
x
A
A
A
A
A
A
A
A
A
A
A
A
A
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
A
A
A
A
A
A
A
A
1
x
A
A
A
A
A
A
A
A
A
A
A
A
A
x
x
x
x
x
x
x
x
1
1
x
x
x
x
x
x
x
x
x
x
x
x
x
x
A
A
A
A
A
A
A
A
1
x
A
A
A
A
A
A
A
A
A
A
A
A
A
x
x
x
x
x
x
x
x
1
x
A
A
A
A
A
A
A
A
A
A
A
A
A
x
x
x
x
x
x
x
x
x
A
A
A
A
A
A
A
A
A
A
A
A
A
x
x
x
x
x
x
x
x
A
A
A
A
A
A
A
A
A
A
A
A
A
x
x
x
x
x
x
x
1
1
1
1
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
1
1
1
1
x
A
A
A
A
A
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
A
A
A
A
A
A
A
A
A
A
A
A
A
x
X
x
x
x
x
x
x
x
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
1
x
A
A
A
A
A
A
A
A
A
A
A
A
A
x
X
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
A
A
A
A
A
A
A
A
x
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
1
x
A
A
A
A
A
A
A
A
A
A
A
A
A
x
x
x
x
x
x
x
x
1
1
x
x
x
x
x
x
x
x
x
x
x
x
x
x
A
A
A
A
A
A
A
x
A
A
A
A
A
A
A
A
A
A
A
A
A
x
x
x
x
x
x
x
1
x
A
A
A
A
A
A
A
A
A
A
A
A
A
x
x
x
x
x
x
x
1
1
1
1
1
N/A
N/A
N/A
N/A
B9h
1
1
1
N/A
N/A
N/A
N/A
ABh
1
1
N/A
N/A
N/A
N/A
D1h
1
1
x
x
x
x
x
x
x
x
x
x
x
x
x
x
A
A
A
A
A
A
A
A
A
A
N/A
D2h
1
1
x
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
4 or 19*
D3h
1
1
1
x
x
x
x
x
x
x
x
x
x
x
x
x
x
A
A
A
A
A
A
A
A
A
A
N/A
D4h
1
1
x
x
x
x
x
x
x
x
x
x
x
x
x
x
A
A
A
A
A
A
A
A
A
A
1
D6h
1
1
1
x
x
x
x
x
x
x
x
x
x
x
x
x
x
A
A
A
A
A
A
A
A
A
A
1
D7h
1
1
1
1
E8h
1
1
1
N/A
A
A
A
A
A
A
A
A
A
A
A0
x
A
A
A2
1
x
A
A1
A
N/A
A
A3
A4
A5
A6
A7
A8
A9
A10
A12
A11
A14
A
A13
A15
A16
A18
A
Additional
Don’t Care
Bytes*
A
30
A
Address Byte
x
Notes:
A
Address Byte
A17
A19
Opcode
03h
A20
A23
Opcode
Address Byte
A22
Page Size = 1024-bytes
A21
Table 15-5.
A
A
N/A
A
A
A
1
x
x
x
N/A
x
x
N/A
A
A
2*
x
x
N/A
A
A
2*
x
x
N/A
x
x
N/A
x
x
x
N/A
x
x
x
N/A
x
x
0 or 4*
x
x
N/A
x
x
N/A
A
A
N/A
x
x
N/A
A
A
N/A
A
A
N/A
x
x
N/A
A
A
A
N/A
x
x
x
N/A
x
x
x
N/A
N/A
A
A
A
A
A
A
A
A
2*
A
A
A
A
A
A
4 or 19*
x = Don’t Care
A = Address Bit
*The number with (*) is for 8-bit interface
AT45DB642D
AT45DB642D
Table 15-6.
Detailed Bit-level Addressing Sequence for Standard DataFlash Page Size (1056-Bytes)
Address Byte
Address Byte
P P P P P P P P
P P P P P x
x
x
x
x
x
x
x
x
x
x
N/A
x
x
B B B B B B B
B
2*
P P P P P P P P
P P P P P x
1
x
x
P P P P P P P P
P P P P P x
x
P P P P P P P P
P P P P P x
x
P P P P P P P P
P P P P P x
P P P P P P P P
P P P P P x
1
1
1
x
x
x
x
x
x
x
x
x
1
1
1
P P P P P x
x
x
x
x
x
x
x
P P P P P P P P
P P P P P x
P P P P P P P P
P P P P P B B B
1
P P P P P P P P
P P P P P x
x
1
x
x
1
1
1
x
P P P P P P P P
P P P P P x
x
x
P P P P P P P P
P P P P P x
x
x
x
1
1
1
1
N/A
N/A
N/A
N/A
1
1
N/A
N/A
N/A
N/A
1
N/A
N/A
N/A
N/A
1
x
B B B
B B B B B B B
B
N/A
1
P P P P P P P P
P P P P P B B B
B B B B B B B
B
4 or 19*
1
x
x
x
x
x
x
x
x
x
x
x
x
x
B B B
B B B B B B B
B
N/A
1
x
x
x
x
x
x
x
x
x
x
x
x
x
B B B
B B B B B B B
B
1
1
1
1
x
x
x
x
x
x
x
x
x
x
x
x
x
B B B
B B B B B B B
B
1
1
1
1
1
1
1
1
54h
1
55h
56h
58h
1
59h
1
60h
1
61h
1
77h
1
7Ch
1
81h
1
82h
1
83h
1
84h
1
85h
1
86h
1
87h
1
88h
1
89h
1
9Fh
1
B9h
1
ABh
1
D1h
1
D2h
1
D3h
1
D4h
1
D6h
D7h
E8h
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
B B B
x
x
x
x
N/A
B B B B B B B
B
2*
x
x
x
x
x
x
x
x
x
N/A
x
x
x
x
x
x
x
x
x
N/A
x
x
x
x
x
x
x
x
x
x
N/A
x
x
x
x
x
x
x
x
x
x
N/A
x
x
x
x
x
x
x
x
x
x
x
0 or 4*
x
x
x
x
x
x
x
x
x
x
x
N/A
x
x
x
x
x
x
x
x
x
x
N/A
B B B B B B B
B
N/A
B B B
N/A
N/A
P P P P P P P P
P P P P P B B B
B B B B B B B
B
N/A
P P P P P P P P
P P P P P x
x
x
x
N/A
B B B B B B B
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
N/A
P P P P P P P P
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
x
B B B
N/A
P P P P P B B B
x
x
x
x
x
x
x
x
x
B
x
x
x
x
x
x
x
B B B B B B B
x
x
x
B B B
x
x
x
BA1
1
53h
BA2
N/A
x
BA3
x
x
BA4
x
BA6
x
1
BA5
x
BA7
x
1
1
BA8
x
BA9
x
BA10
x
1
PA1
x
PA0
1
x
50h
PA3
B
x
0Bh
1
PA2
B B B B B B B
P P x
1
PA4
P P P P P B B B
PA5
P P P P P P P P
P P P P P P P P
PA7
1
PA6
N/A
PA8
B
PA9
B B B B B B B
Opcode
PA10
P P P P P B B B
PA12
P P P P P P P P
Opcode
PA11
Additional
Don’t Care
Bytes*
03h
Note:
Address Byte
BA0
Page Size = 1056-bytes
x
x
x
B
N/A
x
x
x
x
x
x
x
N/A
x
x
x
x
x
x
x
N/A
N/A
B B B B B B B
2*
B
4 or 19*
P = Page Address Bit
B = Byte/Buffer Address Bitx = Don’t Care
31
16. Power-on/Reset State
When power is first applied to the device, or when recovering from a reset condition, the device
will default to Mode 3. In addition, the output pins (SO or I/O7 - I/O0) will be in a high impedance
state, and a high-to-low transition on the CS pin will be required to start a valid instruction. The
mode (Mode 3 or Mode 0) will be automatically selected on every falling edge of CS by sampling
the inactive clock state.
16.1
Initial Power-up/Reset Timing Restrictions
At power up, the device must not be selected until the supply voltage reaches the VCC (min.) and
further delay of tVCSL. During power-up, the internal Power-on Reset circuitry keeps the device in
reset mode until the VCC rises above the Power-on Reset threshold value (VPOR). At this time, all
operations are disabled and the device does not respond to any commands. After power up is
applied and the VCC is at the minimum operating voltage VCC (min.), the tVCSL delay is required
before the device can be selected in order to perform a read operation.
Similarly, the tPUW delay is required after the VCC rises above the Power-on Reset threshold
value (VPOR) before the device can perform a write (Program or Erase) operation. After initial
power-up, the device will default in Standby mode.
Table 16-1.
Symbol
Parameter
tVCSL
VCC (min.) to Chip Select low
tPUW
Power-Up Device Delay before Write
allowed
VPOR
Power-ON Reset Voltage
Min
Typ
Max
50
1.5
Units
µs
ms
2.5
V
17. System Considerations
The RapidS serial interface is controlled by the clock SCK, serial input SI and chip select CS
pins. The sequential 8-bit Rapid8 is controlled by the clock CLK, eight I/Os and chip select CS
pins. These signals must rise and fall monotonically and be free from noise. Excessive noise or
ringing on these pins can be misinterpreted as multiple edges and cause improper operation of
the device. The PC board traces must be kept to a minimum distance or appropriately terminated to ensure proper operation. If necessary, decoupling capacitors can be added on these
pins to provide filtering against noise glitches.
As system complexity continues to increase, voltage regulation is becoming more important. A
key element of any voltage regulation scheme is its current sourcing capability. Like all Flash
memories, the peak current for DataFlash occur during the programming and erase operation.
The regulator needs to supply this peak current requirement. An under specified regulator can
cause current starvation. Besides increasing system noise, current starvation during programming or erase can lead to improper operation and possible data corruption.
The device uses an adaptive algorithm during program and erase operations. In order to optimize the erase and program time, use the RDY/BUSY bit of the status register or the
RDY/BUSY pin to determine whether the program or erase operation was completed. Fixed timing is not recommended.
32
AT45DB642D
AT45DB642D
18. Electrical Specifications
Table 18-1.
Absolute Maximum Ratings*
Temperature under Bias ................................ -55C to +125C
*NOTICE:
Storage Temperature..................................... -65C to +150C
All Input Voltages (except VCC but including NC pins)
with Respect to Ground ...................................-0.6V to +6.25V
All Output Voltages
with Respect to Ground .............................-0.6V to VCC + 0.6V
Table 18-2.
Stresses beyond those listed under “Absolute
Maximum Ratings” may cause permanent damage to the device. The "Absolute Maximum Ratings" are stress ratings only and functional
operation of the device at these or any other conditions beyond those indicated in the operational
sections of this specification is not implied. Exposure to absolute maximum rating conditions for
extended periods may affect device reliability.
Voltage Extremes referenced in the "Absolute
Maximum Ratings" are intended to accommodate short duration undershoot/overshoot conditions and does not imply or guarantee functional
device operation at these levels for any extended
period of time
DC and AC Operating Range
AT45DB642D
Operating Temperature (Case)
VCC Power Supply
Ind.
-40C to 85C
2.7V to 3.6V
33
Table 18-3.
DC Characteristics
Symbol
Parameter
Condition
IDP
Deep Power-down Current
ISB
Typ
Max
Units
CS, RESET, WP = VIH, all inputs at
CMOS levels
15
25
µA
Standby Current
CMOS levels
25
50
µA
ICC1(1)
Active Current, Read Operation,
Serial Interface
f = 33MHz; IOUT = 0mA;
VCC = 3.6V
10
15
mA
ICC2(1)
Rapid8 Interface
VCC = 3.6V
10
15
mA
ICC3
Active Current, Program Operation,
Page Program
VCC = 3.6V
25
mA
ICC4
Active Current, Page Erase, Block
Erase, Sector Erase Operation
VCC = 3.6V
25
mA
ILI
Input Load Current
VIN = CMOS levels
1
µA
ILO
Output Leakage Current
VI/O = CMOS levels
1
µA
VCC x 0.3
V
VIL
Input Low Voltage
VIH
Input High Voltage
VOL
Output Low Voltage
IOL = 1.6mA; VCC = 2.7V
Output High Voltage
IOH = -100µA
VOH
Notes:
Min
VCC x 0.7
V
0.4
VCC - 0.2V
V
V
1. AICC1 and ICC2 during a buffer read is 25mA maximum
2. All inputs (SI, SCK, CS#, WP#, and RESET#) are guaranteed by design to be 5-Volt tolerant
34
AT45DB642D
AT45DB642D
Table 18-4.
AC Characteristics – RapidS/Serial Interface
Symbol
Parameter
fSCK
Min
Typ
Max
Units
SCK Frequency
66
MHz
fCAR1
SCK Frequency for Continuous Array Read
66
MHz
fCAR2
(Low Frequency)
33
MHz
tWH
SCK High Time
6.8
ns
tWL
SCK Low Time
6.8
ns
tSCKR(1)
SCK Rise Time, Peak-to-Peak (Slew Rate)
0.1
V/ns
tSCKF(1)
SCK Fall Time, Peak-to-Peak (Slew Rate)
0.1
V/ns
tCS
Minimum CS High Time
50
ns
tCSS
CS Setup Time
5
ns
tCSH
CS Hold Time
5
ns
tCSB
CS High to RDY/BUSY Low
tSU
Data In Setup Time
2
ns
tH
Data In Hold Time
3
ns
tHO
Output Hold Time
ns
tDIS
Output Disable Time
tV
100
35
ns
Output Valid
6
ns
tWPE
WP Low to Protection Enabled
1
µs
tWPD
WP High to Protection Disabled
1
µs
tEDPD
CS High to Deep Power-down Mode
3
µs
tRDPD
CS High to Standby Mode
35
µs
tXFR
Page to Buffer Transfer Time
400
µs
tcomp
Page to Buffer Compare Time
400
µs
tEP
Page Erase and Programming Time (1,024-/1,056-bytes)
17
40
ms
tP
Page Programming Time (1,024-/1,056-bytes)
3
6
ms
tPE
Page Erase Time (1,024-/1,056-bytes)
15
35
ms
tBE
Block Erase Time (8,192-/8,448-bytes)
45
100
ms
tSE
Sector Erase Time (262,144-/270,336-bytes)
0.7
1.3
s
tCE
Chip Erase Time
TBD
TBD
s
tRST
RESET Pulse Width
tREC
RESET Recovery Time
Note:
27
ns
10
µs
1
µs
1. Values are based on device characterization, not 100% tested in production
35
Table 18-5.
AC Characteristics – Rapid8 8-bit Interface
Symbol
Parameter
fSCK1
Max
Units
CLK Frequency
50
MHz
fCAR1
CLK Frequency for Continuous Array Read
50
MHz
tWH
CLK High Time
9
ns
CLK Low Time
9
ns
tWL
(1)
Min
Typ
tCLKR
CLK Rise Time, Peak-to-Peak (Slew Rate)
0.1
V/ns
tCLKF(1)
CLK Fall Time, Peak-to-Peak (Slew Rate)
0.1
V/ns
tCS
50
ns
tCSS
CS Setup Time
5
ns
tCSH
CS Hold Time
5
ns
tCSB
tSU
Data In Setup Time
2
ns
tH
Data In Hold Time
5
ns
tHO
Output Hold Time
ns
tDIS
Output Disable Time
12
ns
tV
Output Valid
12
ns
tWPE
1
µs
tWPD
1
µs
tEDPD
3
µs
tRDPD
35
µs
tXFR
400
µs
tcomp
400
µs
tEP
17
40
ms
tP
3
6
ms
tPE
15
35
ms
tBE
45
100
ms
tSE
1.6
5
s
tRST
RESET Pulse Width
tREC
Note:
36
100
10
RESET Recovery Time
ns
µs
1
µs
AT45DB642D
AT45DB642D
19. Input Test Waveforms and Measurement Levels
AC
DRIVING
LEVELS
2.4V
1.5V
0.45V
AC
MEASUREMENT
LEVEL
tR, tF < 2ns (10% to 90%)
20. Output Test Load
DEVICE
UNDER
TEST
30pF
21. AC Waveforms
Six different timing waveforms are shown below. Waveform 1 shows the SCK/CLK signal being
low when CS makes a high-to-low transition, and waveform 2 shows the SCK/CLK signal being
high when CS makes a high-to-low transition. In both cases, output SO becomes valid while the
SCK/CLK signal is still low (SCK/CLK low time is specified as tWL). Timing waveforms 1 and 2
conform to RapidS serial interface but for frequencies up to 66MHz. Waveforms 1 and 2 are
compatible with SPI Mode 0 and SPI Mode 3, respectively.
Waveform 3 and waveform 4 illustrate general timing diagram for RapidS serial interface. These
are similar to waveform 1 and waveform 2, except that output SO is not restricted to become
valid during the tWL period. These timing waveforms are valid over the full frequency range (maximum frequency = 66MHz) of the RapidS serial case. Waveform 5 and waveform 6 are for 8-bit
Rapid8 interface over the full frequency range of operation (maximum frequency = 50MHz).
21.1
Waveform 1 – SPI Mode 0 Compatible (for Frequencies up to 66MHz)
tCS
CS
tWH
tCSS
tWL
tCSH
SCK/CLK
tHO
tV
SO
HIGH IMPEDANCE
tSU
SI
VALID OUT
tDIS
HIGH IMPEDANCE
tH
VALID IN
37
21.2
Waveform 2 – SPI Mode 3 Compatible (for Frequencies up to 66MHz)
tCS
CS
tCSS
tWL
tWH
tCSH
SCK/CLK
tV
SO
tHO
HIGH Z
tDIS
HIGH IMPEDANCE
VALID OUT
tSU
tH
VALID IN
SI
Note:
To operate the device at 50MHz in SPI mode, the combined CPU setup time and rise/fall time should be less than 2ns
21.3
Waveform 3 – RapidS Mode 0 (FMAX = 66MHz)
tCS
CS
tWH
tCSS
tWL
tCSH
SCK/CLK
tHO
tV
SO
HIGH IMPEDANCE
21.4
HIGH IMPEDANCE
VALID OUT
tSU
SI
tDIS
tH
VALID IN
Waveform 4 – RapidS Mode 3 (FMAX = 66MHz)
tCS
CS
tCSS
tWL
tWH
tCSH
SCK/CLK
tV
SO
tHO
HIGH Z
HIGH IMPEDANCE
VALID OUT
tSU
tH
VALID IN
SI
21.5
tDIS
Waveform 5 – Rapid8 Mode 0 (FMAX = 50MHz)
tCS
CS
tWH
tCSS
tWL
tCSH
SCK/CLK
tHO
tV
I/O7 - I/O0
(OUTPUT)
HIGH IMPEDANCE
I/O7 - I/O0
(INPUT)
38
tSU
VALID OUT
tDIS
HIGH IMPEDANCE
tH
VALID IN
AT45DB642D
AT45DB642D
21.6
Waveform 6 – Rapid8 Mode 3 (FMAX = 50MHz)
tCS
CS
tCSS
tWL
tWH
tCSH
SCK/CLK
tV
I/O7 - I/O0
(OUTPUT)
tHO
HIGH Z
VALID OUT
tSU
tH
VALID IN
I/O7 - I/O0
(INPUT)
21.7
tDIS
HIGH IMPEDANCE
Utilizing the RapidS Function
To take advantage of the RapidS function's ability to operate at higher clock frequencies, a full
clock cycle must be used to transmit data back and forth across the serial bus. The DataFlash is
designed to always clock its data out on the falling edge of the SCK signal and clock data in on
the rising edge of SCK.
For full clock cycle operation to be achieved, when the DataFlash is clocking data out on the falling edge of SCK, the host controller should wait until the next falling edge of SCK to latch the
data in. Similarly, the host controller should clock its data out on the rising edge of SCK in order
to give the DataFlash a full clock cycle to latch the incoming data in on the next rising edge of
SCK.
Figure 21-1. RapidS Mode
Slave CS
1
8
2
3
4
5
6
1
8
7
2
3
4
5
6
1
7
SCK
B
A
MOSI
E
C
D
MSB
LSB
BYTE-MOSI
H
G
I
F
MISO
MSB
LSB
BYTE-SO
MOSI = Master Out, Slave In
MISO = Master In, Slave Out
The Master is the host controller and the Slave is the DataFlash
The Master always clocks data out on the rising edge of SCK and always clocks data in on the falling edge of SCK.
The Slave always clocks data out on the falling edge of SCK and always clocks data in on the rising edge of SCK.
A.
B.
C.
D.
E.
F.
G.
H.
I.
Master clocks out first bit of BYTE-MOSI on the rising edge of SCK
Slave clocks in first bit of BYTE-MOSI on the next rising edge of SCK
Master clocks out second bit of BYTE-MOSI on the same rising edge of SCK
Last bit of BYTE-MOSI is clocked out from the Master
Last bit of BYTE-MOSI is clocked into the slave
Slave clocks out first bit of BYTE-SO
Master clocks in first bit of BYTE-SO
Slave clocks out second bit of BYTE-SO
Master clocks in last bit of BYTE-SO
39
21.8
Utilizing the Rapid8 Function
The Rapid8 functions like RapidS but with 8-bits of data instead of 1-bit. A full clock cycle must
be used to transmit data back and forth across the 8-bit bus. The DataFlash is designed to
always clock its data out on the falling edge of the SCK signal and clock data in on the rising
edge of SCK.
SCK.
Figure 21-2. Rapid8 Mode
Slave CS
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
SCK
tV
B
A
I/O7-0
C
BYTE 1
BYTE 2
BYTE 3
BYTE 4
D
BYTE 5
BYTE 6
E
F
BYTE a
G
BYTE b
BYTE c
BYTE d
BYTE e
BYTE f
BYTE g
BYTE h
The Master would be the ASIC/MCU and the Slave would be the memory device.
A.
B.
C.
D.
E.
F.
G.
21.9
Master clocks out BYTE 1 on the rising edge of SCK
Slave clocks in BYTE 1 on the next rising edge of SCK
Master clocks out BYTE 2 on the same rising edge of SCK
Slave clocks in BYTE 6 (last input byte)
Slave clocks out BYTE a (first output byte)
Master clocks in BYTE a
Master clocks in BYTE h (last output byte)
Reset Timing
CS
tREC
tCSS
SCK/CLK
tRST
RESET
HIGH IMPEDANCE
HIGH IMPEDANCE
SO or I/O7 - I/O0
(OUTPUT)
SI or I/O7 - I/O0
(INPUT)
Note:
40
The CS signal should be in the high state before the RESET signal is deasserted
AT45DB642D
AT45DB642D
21.10 Command Sequence for Read/Write Operations for Page Size 1024-Bytes (Except Status
Register Read, Manufacturer and Device ID Read)
SI or I/O7 - I/O0
(INPUT)?
CMD
8 bits
XXX XXXX
MSB
8 bits
8 bits
XXXX XXXX
Page Address
(A22 - A10)
XXXX XXXX
LSB
Byte/Buffer Address
(A9 - A0/BFA9 - BFA0)
21.11 Command Sequence for Read/Write Operations for Page Size 1056-Bytes (Except Status
SI or I/O7 - I/O0
(INPUT)?
MSB
CMD
XXXX XXXX
8 bits
8 bits
XXXX XXXX
XXXX XXXX
Page Address
(PA12 - PA0)
8 bits
LSB
Byte/Buffer Address
(BA10 - BA0/BFA10 - BFA0)
22. Write Operations
The following block diagram and waveforms illustrate the various write sequences available.
FLASH MEMORY ARRAY
PAGE (1024-/1056-BYTES)
BUFFER 1 TO
MAIN MEMORY
PAGE PROGRAM
BUFFER 2 TO
MAIN MEMORY
PAGE PROGRAM
BUFFER 1 (1024-/1056-BYTES)
BUFFER 2 (1024-/1056-BYTES)
BUFFER 2
WRITE
BUFFER 1
WRITE
I/O INTERFACE
SI
I/O7 - I/O0
41
22.1
Buffer Write
Completes writing into selected buffer
CS
BINARY PAGE SIZE
14 DON'T CARE + BFA9-BFA0
SI or I/O7 - I/O0
(INPUT)
22.2
CMD
X
X···X, BFA10-8
n
BFA7-0
n+1
Last Byte
Buffer to Main Memory Page Program (Data from Buffer Programmed into Flash Page)
Starts self-timed erase/program operation
CS
BINARY PAGE SIZE
A22-A10 + 10 DON'T CARE BITS
SI or I/O7 - I/O0
(INPUT)
CMD
PA12-5
PA4-0, XXX
XXXX XX
Each transition
represents 8 bits
n = 1st byte read
n+1 = 2nd byte read
23. Read Operations
The following block diagram and waveforms illustrate the various read sequences available.
FLASH MEMORY ARRAY
MAIN MEMORY
PAGE TO
BUFFER 2
MAIN MEMORY
PAGE TO
BUFFER 1
BUFFER 1
READ
MAIN MEMORY
PAGE READ
BUFFER 2
READ
I/O INTERFACE
SO
42
I/O7 - I/O0
AT45DB642D
AT45DB642D
23.1
Main Memory Page Read
CS
ADDRESS FOR BINARY PAGE SIZE
A15-A8
A22-A16
A7-A0
SI or I/O7 - I/O0
(INPUT)
CMD
PA12-5, PA4-0
BA10-8
BA7-0
X
X
4 Dummy Bytes for Serial
19 Dummy Bytes for Parallel
SO or I/O7 - I/O0
(OUTPUT)
23.2
n
n+1
Main Memory Page to Buffer Transfer (Data from Flash Page Read into Buffer)
Starts reading page data into buffer
CS
BINARY PAGE SIZE
SI or I/O7 - I/O0
(INPUT)
CMD
PA12-5
PA4-0, XXX
XXXX XXXX
SO or I/O7 - I/O0
(OUTPUT)
23.3
Buffer Read
CS
BINARY PAGE SIZE
SI or IO7 - IO0
CMD
X
X..X, BFA10-8
BFA7- 0
X
No Dummy Byte (Serial, opcodes D1H and D3H)
1 Dummy Byte (Serial, opcodes D4H and D6H)
2 Dummy Bytes (Parallel)
SO or IO7 - IO0
n
n+1
Each transition
represents 8 bits
43
24. Detailed Bit-level Read Waveform –
RapidS Serial Interface Mode 0/Mode 3
24.1
Continuous Array Read (Legacy Opcode E8H)
CS
2
3
4
5
6
7
8
9
10 11 12
29 30 31 32 33 34
62 63 64 65 66 67 68 69 70 71 72
SCK
OPCODE
SI
1
1
1
ADDRESS BITS
A
MSB
A
A
A
A
A
32 DON'T CARE BITS
A
A
A
MSB
X
X
X
X
X
X
MSB
DATA BYTE 1
SO
HIGH-IMPEDANCE
D
D
D
D
D
D
D
D
MSB
D
BIT 0 OF
PAGE n+1
BIT 8191/8447
OF PAGE n
24.2
D
MSB
Continuous Array Read (Opcode 0BH)
CS
2
3
4
5
6
7
8
9
29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
10 11 12
SCK
OPCODE
SI
ADDRESS BITS A23 - A0
1
A
MSB
A
A
A
A
A
A
DON'T CARE
A
A
MSB
X
X
X
X
X
X
X
X
MSB
DATA BYTE 1
SO
HIGH-IMPEDANCE
D
D
D
D
D
D
MSB
24.3
D
D
D
D
MSB
Continuous Array Read (Low Frequency: Opcode 03H)
CS
2
3
4
5
6
7
8
9
10 11 12
SCK
OPCODE
SI
ADDRESS BITS A23-A0
MSB
1
1
A
A
A
A
A
A
A
A
A
MSB
DATA BYTE 1
SO
HIGH-IMPEDANCE
D
MSB
44
D
D
D
D
D
D
D
D
D
MSB
AT45DB642D
AT45DB642D
24.4
Main Memory Page Read (Opcode: D2H)
CS
2
3
4
5
6
7
8
9
10 11 12
29 30 31 32 33 34
SCK
OPCODE
SI
1
1
ADDRESS BITS
A
MSB
A
A
A
A
A
32 DON'T CARE BITS
A
A
A
MSB
X
X
X
X
X
X
MSB
DATA BYTE 1
HIGH-IMPEDANCE
SO
D
D
D
D
D
D
D
D
MSB
24.5
D
D
MSB
Buffer Read (Opcode D4H or D6H)
CS
2
3
4
5
6
7
8
9
10 11 12
SCK
ADDRESS BITS
BINARY PAGE SIZE = 14 DON'T CARE + BFA9-BFA0
STANDARD DATAFLASH PAGE SIZE =
13 DON'T CARE + BFA10-BFA0
OPCODE
SI
1
1
MSB
X
X
X
X
X
X
A
A
A
MSB
X
DON'T CARE
X
X
X
X
X
X
X
MSB
DATA BYTE 1
SO
HIGH-IMPEDANCE
D
D
D
D
D
D
MSB
24.6
D
D
D
D
MSB
Buffer Read (Low Frequency: Opcode D1H or D3H)
CS
2
3
4
5
6
7
8
9
10 11 12
SCK
ADDRESS BITS
OPCODE
SI
1
1
MSB
X
X
X
X
X
X
A
A
A
MSB
DATA BYTE 1
SO
HIGH-IMPEDANCE
D
MSB
D
D
D
D
D
D
D
D
D
MSB
45
24.7
Read Sector Protection Register (Opcode 32H)
CS
2
3
4
5
6
7
8
9
10 11 12
SCK
OPCODE
SI
1
DON'T CARE
MSB
X
X
X
X
X
X
X
X
X
MSB
DATA BYTE 1
SO
HIGH-IMPEDANCE
D
D
D
D
D
D
D
D
MSB
24.8
D
MSB
Read Sector Lockdown Register (Opcode 35H)
CS
2
3
4
5
6
7
8
9
10 11 12
SCK
OPCODE
SI
1
DON'T CARE
1
MSB
X
X
X
X
X
X
X
X
X
MSB
DATA BYTE 1
SO
HIGH-IMPEDANCE
D
D
D
D
D
D
D
D
MSB
24.9
D
MSB
Read Security Register (Opcode 77H)
CS
2
3
4
5
6
7
8
9
10 11 12
SCK
OPCODE
SI
1
1
DON'T CARE
1
MSB
1
1
X
X
X
X
X
X
X
X
X
MSB
DATA BYTE 1
SO
HIGH-IMPEDANCE
D
MSB
46
D
D
D
D
D
D
D
D
MSB
AT45DB642D
AT45DB642D
24.10 Status Register Read (Opcode D7H)
CS
2
3
4
5
6
7
8
9
10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
SCK
OPCODE
SI
1
1
1
1
MSB
STATUS REGISTER DATA
SO
HIGH-IMPEDANCE
D
D
D
D
D
D
D
MSB
D
D
D
D
D
D
D
D
D
MSB
D
D
MSB
24.11 Manufacturer and Device Read (Opcode 9FH)
CS
7
8
14 15 16
22 23 24
30 31 32
38
SCK
OPCODE
SI
SO
9FH
HIGH-IMPEDANCE
Note: Each transition
1FH
DEVICE ID BYTE 1
DEVICE ID BYTE 2
00H
shown for SI and SO represents one byte (8 bits)
47
25. Detailed 8-bit Read Waveforms – Rapid8 Mode 0/Mode 3
25.1
Continuous Array Read (Opcode: E8H)
CS
CLK
1
tSU
I/O7-I/O0
(INPUT)
2
3
21
BINARY & STANDARD
DATAFLASH PAGE SIZE
CMD
ADDR
ADDR
22
23
24
19 DUMMY BYTES
ADDR
X
X
X
tV
I/O7-I/O0
(OUTPUT)
26
25
DATA OUT
HIGH IMPEDANCE
DATA
DATA
DATA
DATA
DATA
DATA
BYTE 1023/1055
OF
PAGE n
25.2
DATA
DATA
DATA
BYTE 0
OF
PAGE n+1
CS
CLK
tSU
I/07-I/O0
(INPUT)
1
2
19
3
BINARY & STANDARD
DATAFLASH PAGE SIZE
CMD
ADDR
ADDR
21
22
23
24
X
X
X
X
X
tV
25.3
26
19 DUMMY BYTES
ADDR
DATA OUT
HIGH IMPEDANCE
I/07-I/O0
(OUTPUT)
25
DATA
DATA
DATA
DATA
Buffer Read (Opcode: 54H or 56H)
CS
CLK
3
ADDRESS BYTES
BINARY & STANDARD
DATAFLASH PAGE SIZE
tSU
I/O7-I/O0
(INPUT)
1
CMD
X
ADDR ADDR
4
5
6
DUMMY BYTES
X
X
tV
I/O7-I/O0
(OUTPUT)
48
7
DATA OUT
HIGH IMPEDANCE
DATA
DATA
DATA
AT45DB642D
AT45DB642D
25.4
Status Register Read (Opcode: D7H)
CS
CLK
2
3
X
DATA
tSU
I/O7-I/O0
(INPUT)
CMD
tV
I/O7-I/O0
(OUTPUT)
HIGH
IMPEDANCE
X
DATA
STATUS REGISTER
OUTPUT
26. Auto Page Rewrite Flowchart
Figure 26-1. Algorithm for Programming or Reprogramming of the Entire Array Sequentially
START
provide address
and data
BUFFER WRITE
(84H, 87H)
MAIN MEMORY PAGE PROGRAM
THROUGH BUFFER
(82H, 85H)
BUFFER TO MAIN
MEMORY PAGE PROGRAM
(83H, 86H)
END
Notes:
1. This type of algorithm is used for applications in which the entire array is programmed sequentially, filling the array page-bypage.
2. A page can be written using either a Main Memory Page Program operation or a Buffer Write operation followed by a Buffer
to Main Memory Page Program operation.
3. The algorithm above shows the programming of a single page. The algorithm will be repeated sequentially for each page
within the entire array.
49
Figure 26-2. Algorithm for Randomly Modifying Data
START
provide address of
page to modify
MAIN MEMORY PAGE
TO BUFFER TRANSFER
(53H, 55H)
If planning to modify multiple
bytes currently stored within
a page of the Flash array
BUFFER WRITE
(84H, 87H)
THROUGH BUFFER
(82H, 85H)
BUFFER TO MAIN
MEMORY PAGE PROGRAM
(83H, 86H)
AUTO PAGE REWRITE
(58H, 59H)
(2)
INCREMENT PAGE
(2)
ADDRESS POINTER
END
Notes:
1. To preserve data integrity, each page of an DataFlash sector must be updated/rewritten at least once within every 10,000
cumulative page erase and program operations.
2. A Page Address Pointer must be maintained to indicate which page is to be rewritten. The Auto Page Rewrite command
must use the address specified by the Page Address Pointer.
3. Other algorithms can be used to rewrite portions of the Flash array. Low-power applications may choose to wait until 10,000
cumulative page erase and program operations have accumulated before rewriting all pages of the sector. See application
note AN-4 (“Using Adesto Serial DataFlash”) for more details.
50
AT45DB642D
AT45DB642D
27. Ordering Information
27.1
Ordering Code Detail
AT 4 5 DB 6 4 2 D – CNU
Designator
Product Family
Device Grade
U = Matte Sn lead finish, industrial
temperature range (-40°C to +85°C)
Package Option
Device Density
CN = 8-lead, 6 x 8mm CASON
T = 28-lead, 8 x 13.4mm TSOP
C = 24 Ball BGA
64 = 64-megabit
Interface
2 = Dual
Device Revision
27.2
Green Package Options (Pb/Halide-free/RoHS Compliant)
Ordering Code(1)(2)
Package
AT45DB642D-CNU
AT45DB642D-CNU-SL954(3)
AT45DB642D-CNU-SL955(4)
8CN3
AT45DB642D-TU
28T
AT45DB642D-CU
24C1
Notes:
Lead Finish
Operating Voltage
fSCK (MHz)
Matte Sn
2.7V to 3.6V
66
Matte Sn
2.7V to 3.6V
66
Operation Range
Industrial
(-40C to 85C)
2.7V to 3.6V
1. The shipping carrier option is not marked on the devices
2. Standard parts are shipped with the page size set to 1056-bytes. The user is able to configure these parts to a 1024-byte
page size if desired
3. Parts ordered with suffix SL954 are shipped in bulk with the page size set to 1024-bytes. Parts will have a 954 or SL954
marked on them
4. Parts ordered with suffix SL955 are shipped in tape and reel with the page size set to 1024-bytes. Parts will have a 954 or
SL954 marked on them
Package Type
28T
28-lead, (8 x 13.4mm) Plastic Thin Small Outline Package, Type I (TSOP)
8CN3
8-pad (6mm x 8mm) Chip Array Small Outline No Lead Package (CASON)
24C1
24-Ball, 6mm x 8mm x 1,4mm Ball Grid Array with a 1mm pitch 5 x 5 Ball Matrix
51
28. Packaging Information
28.1
28T – TSOP, Type 1
PIN 1
0º ~ 5º
c
Pin 1 Identifier Area
D1 D
L
b
e
L1
A2
E
A
GAGE PLANE
SEATING PLANE
COMMON DIMENSIONS
(Unit of Measure = mm)
A1
SYMBOL
Notes:
1. This package conforms to JEDEC reference MO-183.
2. Dimensions D1 and E do not include mold protrusion. Allowable
protrusion on E is 0.15mm per side and on D1 is 0.25mm per side.
3. Lead coplanarity is 0.10mm maximum.
MIN
MAX
NOM
A
1.20
A1
0.05
0.15
NOTE
A2
0.90
1.00
1.05
D
13.20
13.40
13.60
D1
11.70
11.80
11.90
Note 2
Note 2
E
7.90
8.00
8.10
L
0.50
0.60
0.70
L1
0.25 BASIC
b
0.17
0.22
0.27
c
0.10
0.21
e
0.55 BASIC
12/06/02
Package Drawing Contact:
contact@adestotech.com
52
TITLE
28T, 28-lead (8 x 13.4mm) Plastic Thin Small Outline
DRAWING NO.
REV.
28T
C
AT45DB642D
AT45DB642D
28.2
8CN3 – CASON
Marked Pin1 Indentifier
E
A
A1
D
Top View
Side View
Pin1 Pad Corner
L1
0.10 mm
TYP
8
1
e
7
2
6
3
COMMON DIMENSIONS
b
SYMBOL
MIN
NOM
MAX
0.17
0.21
0.25
A
5
4
e1
L
Bottom View
A1
1.0
b
0.41 TYP
7.90
8.00
8.10
E
5.90
6.00
6.10
e
1.27 BSC
e1
1.095 REF
L
Notes:
1.
2.
3.
4.
All dimensions and tolerance conform to ASME Y 14.5M, 1994
The surface finish of the package shall be EDM Charmille #24-27
o
Unless otherwise specified tolerance: Decimal ±0.05, Angular ±2
Metal Pad Dimensions
4
D
L1
NOTE
0.67 TYP
0.92
0.97
4
1.02
4
7/10/03
TITLE
Package Drawing Contact: 8CN3, 8-pad (6 x 8 x 1.0mm Body), Lead Pitch 1.27mm,
DRAWING NO.
8CN3
REV.
B
53
28.3
24C1 - Ball Grid Array
Dimensions in Millimeters and (Inches).
Controlling dimension: Millimeters.
6.10(0.240)
5.90(0.232)
A1 ID
8.10(0.319)
7.90(0.311)
SIDE VIEW
0.30 (0.012)MIN
TOP VIEW
1.40 (0.055) MAX
1.00 (0.039) REF
4.0 (0.157)
5
4
3
2
1
2.00 (0.079) REF
A
B
1.00 (0.0394) BSC
NON-ACCUMULATIVE
4.0 (0.157)
C
D
E
0.46 (0.018)
DIA BALL TYP
1.00 (0.0394) BSC
NON-ACCUMULATIVE
BOTTOM VIEW
04/11/01
54
TITLE
24C1, 24-ball (5 x 5 Array), 6 x 8 x 1.4 mm Body, 1.0 mm Ball
Pitch Chip-scale Ball Grid Array Package (CBGA)
DRAWING NO.
24C1
REV.
A
AT45DB642D
AT45DB642D
29. Revision History
Revision Level – Release Date
History
A – September 2005
Initial release
B – November 2005
Changed tVCSL from 30µs to 50µs min.
Changed tPUW from 10ms to 20ms max.
Changed tDIS from 8ns to 6ns max.
Changed tV from 8ns to 6ns max.
C – March 2006
Added text, in “Programming the Configuration Register”, to indicate
that power cycling is required to switch to “power of 2” page size
after the opcode has been executed.
D – July 2006
Corrected typographical errors.
E – August 2006
Added errata regarding Chip Erase.
F – August 2006
Added tSCKR and tSCKF parameters to Table 18-4.
G – August 2007
Added additional text for “power of 2” binary page size option.
Changed tRDPD from 30µs to 35µs.
Added tCLKR and tCLKF parameters to Table 18-5.
H – April 2008
Added part number ordering code details for suffixes SL954/955.
Added ordering code details.
I – February 2009
Changed tDIS (Typ and Max) to 27ns and 35ns, respectively, for
RapidS interface.
J – March 2009
Changed Deep Power-Down Current values
- Increased typical value from 9µA to 15µA.
- Increased maximum value from 18µA to 25µA.
K – April 2009
Updated Absolute Maximum Ratings
Added 24C1 24 Ball BGA package Option
Deleted DataFlash Card Package Option
L – May 2010
M-November 2012
Changed tSE (Typ) 1.6 to 0.7 and (Max) 5 to 1.3
Changed from 10,000 to 20,000 cumulative page erase/program
operations and added the please contact Adesto statement in
section 11.3.
Update all Adesto Logos.
55
30. Errata
30.1
30.1.1
Chip Erase
Issue
In a certain percentage of units, the Chip Erase feature may not function correctly and may
adversely affect device operation. Therefore, it is recommended that the Chip Erase commands
(opcodes C7H, 94H, 80H, and 9AH) not be used.
30.1.2
Workaround
Use Block Erase (opcode 50H) as an alternative. The Block Erase function is not affected by the
Chip Erase issue.
30.1.3
Resolution
The Chip Erase feature may be fixed with a new revision of the device. Please contact Adesto®
for the estimated availability of devices with the fix.
56
AT45DB642D
Corporate Office
California | USA
Adesto Headquarters
1250 Borregas Avenue
Sunnyvale, CA 94089
Phone: (+1) 408.400.0578
Email: contact@adestotech.com
© 2012 Adesto Technologies. All rights reserved. / Rev.: 3542M–DFLASH–11/2012
Adesto®, the Adesto logo, CBRAM®, and DataFlash® are registered trademarks or trademarks of Adesto Technologies. All other marks are the property of their respective
owners.
Disclaimer: Adesto Technologies Corporation makes no warranty for the use of its products, other than those expressly contained in the Company's standard warranty which is detailed in Adesto's Terms
and Conditions located on the Company's web site. The Company assumes no responsibility for any errors which may appear in this document, reserves the right to change devices or specifications
detailed herein at any time without notice, and does not make any commitment to update the information contained herein. No licenses to patents or other intellectual property of Adesto are granted by the
Company in connection with the sale of Adesto products, expressly or by implication. Adesto's products are not authorized for use as critical components in life support devices or systems.
