Mini-SAS HD
Features:
tSFF-8643 compliance
t.FFUTSAS 3.0 (12Gbps) electrical performance
t0.75mm pitch connector system
tImproved signal integrity & minimized cross-talk
tEliminates need for mechanical key
tPinouts map easily with existing Mini SAS product
tPress-fit pin design provides one step placement
onto PCB
Overview:
Amphenol’s Mini-SAS High Density connector system is the next generation SAS
system that provides faster data rates and more bandwidth. It provides double the
port density of current Mini-SAS connectors with 1X1 (4x), 1X2 (8x) and 1X4 (16x)
port options. The Mini-SAS HD connector system has a two-row, right-angle connector with 12Gbps of data rate per channel. Each connector (port) handles 4
lanes of data rate for up to 48Gbps. of total bandwidth.
Applications:
t.FEJDBM
t5FMFDPN
t/FUXPSLJOH
t4FSWFS
t4UPSBHF
To learn more about Mini-SAS HD connectors:
web: amphenolcanada.com
email: sales@amphenolcanada.com
t5FTU*OEVTUSJBM
Mini-SAS HD
Technical Characteristics:
Mechanical
Electrical
0.5A max. per contact
Operating Current
307 AC(rms)/DC max.
Operating Voltage
3007 DC
DWV
1000MΩ min.
Insulation Resistance
100Ω ±10Ω
Differential Impedance
Mating Force
Unmating Force
Durability
100/ max.
50/ max.
250 cycles
Series
ConĮguraƟon Type
TerminaƟon Style
Impedance Spec
Port
Wall Version
G40H11
G40H12
G40H13
G40HA1
G40HA2
G40HA3
G40H21
G40H22
G40H31
G40H32
G40H41
G40H42
G40HB1
G40HB2
G40HC1
G40HC2
G40HD1
G40HD2
Right Angle
Right Angle
Right Angle
Right Angle
Right Angle
Right Angle
Press Fit
Press Fit
Press Fit
Press Fit
Press Fit
Press Fit
100 ohm
100 ohm
100 ohm
85 ohm
85 ohm
85 ohm
Single
Single
Single
Single
Single
Single
VerƟcal
SMT
100 ohm
VerƟcal
SMT
100 ohm
VerƟcal
SMT
100 ohm
VerƟcal
SMT
85 ohm
VerƟcal
SMT
85 ohm
VerƟcal
SMT
85 ohm
1x1
1x2
1x4
1x1
1x2
1x4
1x1
1x2
1x1
1x2
1x1
1x2
1x1
1x2
1x1
1x2
1x1
1x2
Dimensions:
Single
Dual
Four
Single
Dual
Four
All drawings are measured in inches (mm).
* Please visit amphenolcanada.com to find drawings for other products in this series.
很抱歉,暂时无法提供与“G40HA2331HR”相匹配的价格&库存,您可以联系我们找货
