CFP2 1xN Cage Assembly, Heat Sink, Heat Sink Clip,
and Connector Cover
Product Specification S6080C Rev 1.0
About Amphenol
Commercial Products
Amphenol’s commercial
connector products are
used in a variety of end
user applications
including networking,
telecom, server &
computer, storage &
HDD, consumer
electronics and
entertainment,
professional audio &
Industrial &
Military/Aerospace.
CFP2 1x1 U98-B121-X00X
CAGE ASSEMBLY WITH HEAT
SINK AND CONNECTOR COVER
CFP2 1x2 U98-B221-X00X
Related Products
QSFP+
38 POSITION CONNECTOR
CFP2 1x1 U98-B111-X0AX
CAGE ASSEMBLY WITHOUT HEAT
SINK OR CONNECTOR COVER
THRU THE BEZEL CAGE
ASSEMBLY WITH HEAT SINK
CFP2 1x2 U98-B211-X0AX
Overview
This short form Product Specification defines the general use and performance parameters for
Amphenol’s CFP2 series 1xN cage assembly.
Availability: 1x1 and 1x2 cages with heat sink and heat sink cage
1x3 BEHIND THE BEZEL CAGE
ASSEMBLY WITH HEAT SINK AND
LIGHT PIPES
Usage
The connector system is capable of data rates up to 10 Gbps per channel (up to 10 channels) or 25
Gbps per channel (up to 8 channels) and is intended for external connections (104 positions per
port) using active cabling.
CXP
Applications
CAGE AND CONNECTOR
ASSEMBLY WITH ROUND PIN
HEAT SINK AND ELASTOMER
GASKET
Revision Date: May 7, 2013
Intended for use in high speed serial interconnect applications such as:
Clusters
Servers
Storage devices
Page 1 of 3
S6080C Rev 1.0
General Requirements
About Amphenol
Commercial Products
user applications
telecom, server &
computer, storage &
HDD, consumer
electronics and
entertainment,
Industrial &
Military/Aerospace.
RoHS compliant
Footprint compatible with other industry suppliers
Press-fit cage and connector combo for minimum 3.00 mm (0.118in) PCB thickness in belly-tobelly application
Cages are tray packed
Dust cover for front face is available (bulk packed)
Proper support for cage is required during insertion into PCB
Extraction tool required for removing the combo from PCB (consult factory)
Connector Electrical Characteristics
Operating Voltage: 3.3V
Operating Current: 1.875A
Connector Mechanical Characteristics
Related Products
QSFP+
Insertion Force: 80 N
Withdrawal Force: 50 N
Durability: 200 mating cycles
Material Requirements
Unless otherwise specified, the materials for each component shall be:
Cage: Copper alloy, matte tin over nickel or nickel only plating
Heat Sink: Aluminum alloy, anodized or nickel plated
Heat Sink Clip: Steel alloy
Connector Cover: Zinc alloy, nickel plated
Temperature rise: Meets the requirement of 30° C ΔT
Operating and storage temperature: -40° to +85° C
THRU THE BEZEL CAGE
Process Characteristics
Cage assembly is press-fit to customer PCB
Connector cover is screw-mounted
PCB Specifications
LIGHT PIPES
Compliant Pin Holes must be drilled and plated through to specific dimensions to prevent damage
during placement of cage assembly on the PCB. See table below.
Recommended torque for connector cover mounting screws is 0.90±0.10 in·lb
CXP
CAGE AND CONNECTOR
GASKET
Amphenol Canada Corp.
605 Milner Avenue
Toronto, Ontario, Canada, M1B 5X6
+1 416 291 4401
Page 2 of 3
Copyright © Amphenol Corporation 2013 • All rights reserved
www.amphenolcanada.com
THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES
WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP.
S6080C Rev 1.0
About Amphenol
Commercial Products
user applications
telecom, server &
computer, storage &
HDD, consumer
electronics and
entertainment,
Industrial &
Military/Aerospace.
Related Products
QSFP+
THRU THE BEZEL CAGE
Surface Finish
Drilled Hole Diameter
HASL SnPb
Immersion Sn
OSP
1.15±0.02
1.15±0.02
1.15±0.02
Finished Hole
Diameter
1.05 Ref
1.05 Ref
1.05 Ref
Immersion Au/Ni
1.15±0.02
1.05 Ref
Surface Finish
Thickness
0.004-0.010
0.0005 Min.
0.0002-0.0005
0.004-0.0076 (Ni)
0.0001-0.0005 (Au)
Available Documents
Drawing Numbers:
LIGHT PIPES
P-U98-B1X1-X0XX
CFP2 series 1x1 cage assembly
P-U98-B2X1-X0XX
CFP2 series 1x2 cage assembly
Contact factory or Authorized Amphenol representative for alternate configurations
CXP
CAGE AND CONNECTOR
GASKET
605 Milner Avenue
+1 416 291 4401
Page 3 of 3
很抱歉,暂时无法提供与“U98-B221-1001”相匹配的价格&库存,您可以联系我们找货
