U90-B205-4081-100
U90-B205-4081-100
    ARDUINO
    CONN QSFP+ RCPT W/CAGE 2X2 R/A
U90-B205-4081-100 数据手册
A B C D E G F AMPHENOL PART NUMBER CONFIGURATION U90-B205-XXX1-XX0 VENT HOLES AND EMI COVER 0 = WITH LAGE HOLES & WITH EMI COVER 1 = WITH LARGE VENT HOLES, NO EMI COVER 2 = WITH SMALL VENT HOLES & WITH EMI COVER 3 = WITH SMALL VENT HOLES, NO EMI COVER 4 = WITH RECTANGULAR VENT HOLES & WITH EMI COVER 5 = WITH RECTANGULAR VENT HOLES, NO EMI COVER CAGE & CONNECTOR CONTACT PLATING 2 = 0.76 μm MIN. GOLD ON MATING AREA, 3.81-7.62 μm TIN/LEAD ON TERMINATION. Ni PLATING FOR CAGE 1 3 = 0.38 μm MIN. GOLD ON MATING AREA, 3.81-7.62 μm TIN/LEAD ON TERMINATION. Ni PLATING FOR CAGE 4 = 0.76 μm MIN. GOLD OVER 1.27-3.81 μm OF NICKEL ON MATING AREA 0.381-1.52 μm OF MATTE TIN OVER 1.27-3.81 μm OF NICKEL ON PRESS FIT TAIL AREA. Ni PLATING FOR CAGE (RoHS COMPLIANT PER RoHS DIRECTIVE 2011/65/EU; OPTION 4 ONLY) 2 OPTIONAL DUST COVER 0 = WITHOUT DUST COVER D = WITH DUST COVER REV DESCRIPTION, ECN, EAR NO. DATE A PROPOSAL DRAWING JUL 06/11 ZLJ JAN 24/12 ZLJ B OTHER CONFIGURATION ADDED APP'D C HEAT SINK CONFIGURATION ADDED FEB 09/12 ZLJ D AHSI DESIGNATION ADDED MAY 17/12 ZLJ E HEAT SINK OPTION REMOVED SEP 12/12 ZLJ DEC 3/12 ZLJ F RoHS DIRECTIVE ADDED 1 THIS IS A CAD DRAWING. DO NOT MANUALLY REVISE EMI GASKET 1 = CHOMERICS 1273 CONDUCTIVE ELASTOMER 2 = CHOMERICS S6305 CONDUCTIVE ELASTOMER OPTIONAL LIGHT PIPES 6 = WITH LIGHT PIPE (TRIANGULAR OUTLET) LEFT ARROW POINTING BOTTOM PORT & RIGHT ARROW POINTING TOP PORT 7 = WITHOUT LIGHT PIPE 8 = WITH LIGHT PIPE (REVERSED DIRECTION) LEFT ARROW POINTING TOP PORT & RIGHT ARROW POINTING BOTTOM PORT REFERENCE VIEW FOR OPTION 6 ONLY 2 REFERENCE VIEW FOR OPTION 8 ONLY PART # U90-B205-X071-X50 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITHOUT DUST COVER AND WITHOUT LIGHT PIPE) PART # U90-B205-X071-X10 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITHOUT DUST COVER AND WITHOUT LIGHT PIPE) PART # U90-B205-XD71-X30 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITH DUST COVER AND WITHOUT LIGHT PIPE) H REVISIONS 3 3 PART # U90-B205-X061-X10 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITHOUT DUST COVER AND WITH LIGHT PIPE) PART # U90-B205-X061-X30 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITHOUT DUST COVER AND WITH LIGHT PIPE) PART # U90-B205-X061-X50 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITHOUT DUST COVER AND WITH LIGHT PIPE) OPTIONAL DUST COVER P/N U90-1401-8000-BP (SHIPPED LOOSE) 4 4 PART # U90-B205-X081-X10 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITHOUT DUST COVER AND WITH LIGHT PIPE) PART # U90-B205-X081-X30 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITHOUT DUST COVER AND WITH LIGHT PIPE) PART # U90-B205-X081-X50 SHOWN (CAGE & CONNECTOR ASSEMBLY, WITHOUT DUST COVER AND WITH LIGHT PIPE) 5 5 NOTES: 6 UNLESS SPECIFIED OTHERWISE 1. MATERIAL CAGE-PRESS FIT: COPPER ALLOY, NICKEL PLATED CONNECTOR-PRESS FIT: PLASTIC HOUSING,FLAMMABILITY RATING UL94 V-0. CONTACTS : PHOSPHOR BRONZE PLATING OPTION: SEE AMPHENOL PART NO CONFIGURATION EMI GASKET: CONDUCTIVE ELASTOMER EMI FINGERS: PHOSPHOR BRONZE WITH NICKEL PLATING LIGHT PIPE: GE LEXAN, OPTICAL GRADE PRIMARY UNITS SECONDARY B Q.A. APP'D GENERAL TOLERANCES DWG APPR. 2. DECIMAL PLACES THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. A REFERENCE IN PARENTHESES 1. DECIMAL PLACE 2. CONNECTOR AND CAGE ASSEMBLY IS RoHS COMPLIANT. C D DRAWN 3. ANGULAR DEGREES 4. ANGULAR DEGREES E M.HASAN JUL 04/11 ZLJ JUL 06/11 TBA TBD MILLIMETERS CHECKED MILLIMETERS M.E. APP'D 0.X 0.25 ENG. REL. NO. 0.XX 0.13 REF. X 1 THIRD ANGLE X.X 0.5 Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenol-highspeed.com QSFP+ 2X2 STACKED COMBO 6 ECN EXXXXX DWG. NO. PROJECTION F REV P-U90-B205-XXX1-XX0 DO NOT SCALE DRAWING CODE ID NO. 03554 DWG SIZE: X G SCALE: F SHEET 1 OF 4 2:1 H A B C D E G F H REVISIONS 38.75 REV DESCRIPTION, ECN, EAR NO. DATE APP'D F SEE PAGE 1 DEC 3/12 ZLJ 1 1 PART NUMBER DATE CODE 2 2 73.27 3 3 38.41 PART # U90-B205-X061-X30 SHOWN 43.35 19.00 4 4 8.84(4X) 30.05 25.60 24.95 15.45 9.38 5 5 10.70 43.35 9.00 (3X) 1.25 0.8 TYP. 2.06 12.21 44.30 UNLESS SPECIFIED OTHERWISE PRIMARY UNITS SECONDARY 6 REFERENCE IN PARENTHESES GENERAL TOLERANCES 1. DECIMAL PLACE 2. DECIMAL PLACES THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. A B C D 3. ANGULAR DEGREES 4. ANGULAR DEGREES E DRAWN M.HASAN JUL 04/11 ZLJ JUL 06/11 TBA TBD MILLIMETERS CHECKED MILLIMETERS M.E. APP'D Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenol-highspeed.com QSFP+ 2X2 STACKED COMBO Q.A. APP'D DWG APPR. 6 ECN EXXXXX ENG. REL. NO. 0.X 0.25 0.XX 0.13 REF. X 1 THIRD ANGLE X.X 0.5 PROJECTION DWG. NO. DO NOT SCALE DRAWING CODE ID NO. F P-P-U90-B205-XXX1-XX0 03554 DWG SIZE: X G SCALE: REV SHEET 2 OF 4 2:1 H F A B C D E G F H REVISIONS REV DESCRIPTION, ECN, EAR NO. DATE APP'D F SEE SHEET 1 DEC 3/12 ZLJ 1 1.57 MIN. Y 0 2.30 0.41 0 19.41 19.00 17.35 38.00 36.35 1 0.80 TYP. 1.60 TYP. 0.37±0.05 (228 X) PTH 0.10 M X Y A 2 2 2.50±0.05 (4X) TH 37 21 38 PIN 1 TOP PORT 3 X 3 1.05±0.05 (15X) PTH 0.10 M X Y 9.45 19 8.25 21 37 6.60 12.25 18 2 1 0 13.45 20 5.45 20 38 3 4.25 1.45 18 2 1 3 0.25 19 0 17.30 1.72 PIN 1 BOTTOM PORT 3.30 TYP 26.30 1.20 4 1.25 TYP 3.37 TYP CROSS HATCHED REPRESENTS LED SOLDER PAD SEATING AREA 35.30 4 1.03 TYP 0.90 TYP DETAIL A SCALE 6 : 1 44.30 5 5 RECOMMENDED PCB BOARD LAYOUT COMPONENT SIDE SHOWN UNLESS SPECIFIED OTHERWISE PRIMARY UNITS SECONDARY 6 DRAWN MASROOR H. JUL 04/11 MILLIMETERS CHECKED MILLIMETERS M.E. APP'D REFERENCE IN PARENTHESES GENERAL TOLERANCES 1. DECIMAL PLACE A B C D 4. ANGULAR DEGREES E X.X 0.5 TBA TBD Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenol-highspeed.com QSFP+ 2X2 STACKED COMBO 6 ECN EXXXXX ENG. REL. NO. DWG. NO. 0.XX 0.13 REF. THIRD 3. ANGULAR DEGREES X 1 2. DECIMAL PLACES THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. JUL 06/11 Q.A. APP'D DWG APPR. 0.X 0.25 ZLJ P-U90-B205-XXX1-XX0 DO NOT SCALE DRAWING CODE ID NO. ANGLE PROJECTION F 03554 DWG SIZE: C G SCALE: REV F SHEET 3 OF 4 2:1 H A B C D E G F H REVISIONS REV DESCRIPTION, ECN, EAR NO. DATE APP'D F SEE SHEET 1 DEC 3/12 ZLJ PANEL CUTOUT BOTTOM LATCH 1 1 0.27±0.10 2 2 PCB DETAIL B SCALE 10 : 1 FRONT PANEL (CUSTOMER SUPPLIED) CAGE ASSEMBLY 3 3 PCB (CUSTOMER SUPPLIED) LIGHTPIPE 38.85 71.88 4 ELASTOMER EMI GASKET 4 25.51 25.60 B 5 5 37.00 MAX. 0.27 REF. UNLESS SPECIFIED OTHERWISE PRIMARY UNITS SECONDARY 6 DRAWN MASROOR H. JUL 04/11 MILLIMETERS CHECKED MILLIMETERS M.E. APP'D REFERENCE IN PARENTHESES Q.A. APP'D GENERAL TOLERANCES DWG APPR. 1. DECIMAL PLACE 0.X 0.25 A B C D E ZLJ JUL 06/11 TBA TBD Amphenol High Speed Interconnects A Division of Amphenol Corp. www.amphenol-highspeed.com QSFP+ 2X2 STAKED COMBO 6 ECN EXXXXX ENG. REL. NO. DWG. NO. 0.XX 0.13 REF. 3. ANGULAR DEGREES X 1 THIRD ANGLE 4. ANGULAR DEGREES X.X 0.5 PROJECTION 2. DECIMAL PLACES THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. 1.57 MIN. 43.00±0.30 P-U90-B205-XXX1-XX0 DO NOT SCALE DRAWING CODE ID NO. F 03554 DWG SIZE: C G SCALE: REV F SHEET 4 OF 4 2:1 H
U90-B205-4081-100 价格&库存
很抱歉,暂时无法提供与“U90-B205-4081-100”相匹配的价格&库存,您可以联系我们找货
