Multi-Port With Metal Board Locks
2 To 6 Contacts - 2 To Twelve Ports
No. of Ports
Dimensions 2
3
4
5
6
7
8
9
10
11
12
A
23.3 34.3 45.3 56.3 67.3 78.3 89.3 100.3 111.3 122.3 133.3
0.92 1.3 1.78 2.22 2.65 3.08 3.52 3.95 4.38 4.82 5.25
B
23.5 34.5 45.5 56.5 67.5 78.5 89.5 100.5 111.5 122.5 133.5
0.93 1.36 1.79 2.22 2.66 3.09 3.52 3.96 4.39 4.82 5.26
C
11.0 22.0 33.0 44.0 55.0 66.0 77.0 88.0 99.0 110.0 121.0
0.43 0.86 1.299 1.732 2.165 2.598 3.031 3.465 3.898 4.331 4.764
Materials
Housing:
Standard Material Glass filled Polyester UL94V-0
Standard Color Medium Gray
Contact:
0.46mm Diameter Alloy C5210. Gold Plating Over Nickel.
Gold Plating: As Per Customer Request
Ordering Information
Positions/
Contacts
4P2C
4P4C
6P2C
6P4C
6P6C
Description
Multi-Port Solderable Board Lock
Jack
Jack
Jack
Jack
Jack
RoHS compliant wave solder only
Part Number
301542B-*
301544B-*
301562B-*
301564B-*
301566B-*
Standard contact plating is 15 micro
inches of gold. For optional platings add
dash number as follows:
-6 = 6 Micro inches
-30 = 30 Micro inches
* Add -02 for 2 port, -03 for 3 port, etc.
Two to twelve ports available.
FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX973-347-2111
Back to Index
Multi-Port Press Fit
Dimensions
A
B
C
2
28.2
1.11
23.0
0.90
11.0
0.433
3
34.3
1.35
34.0
1.34
22.0
0.866
4
45.3
1.78
45.0
1.77
33.0
1.299
5
56.3
2.22
56.0
2.20
44.0
1.732
6
67.3
2.65
67.0
2.64
55.0
2.165
No. of Ports
7
8
78.3
89.3
3.08
3.52
78.0
89.0
3.07
3.50
66.0
77.0
2.598
3.031
9
100.3
3.95
100.0
3.94
88.0
3.465
10
111.3
4.38
111.0
4.37
99.0
3.898
11
122.3
4.82
122.0
4.80
110.0
4.331
12
133.3
5.25
133.0
5.24
121.0
4.764
Materials
Housing:
Standard Material Glass Filled Polyester UL 94V-0
Contact:
Positions/
Contacts
4P2C
4P4C
6P2C
6P4C
6P6C
Description
Part Number
Multi-Port Press-Fit Jack
301642-*
301644-*
301662-*
301664-*
301666-*
is 15 micro inches of
gold. For optional
platings add the dash
numbers as follows:
-6 = 6 Micro inches
13
-50 = 50 Micro inches
s
* Add -02 for 2 port, -03 for 3 port, etc. Two to twelve ports available
Back to Index
14
Single and Multi Port Jacks
Non-Shielded, Shielded and Shielded with
Grounding Tabs are available.
Single position and up to twelve positions are
standard as listed below in these moderate
profile RJ45 jacks.
Materials
Shielded:
Housing:
0.35mm Thickness Alloy C5210. Tin Plating Over Nickel in Solder Area
Standard Material: Glass Filled Polyester UL 94V-O
Standard Color Black
Contact:
0.35mm (0.014”) Thickness Alloy C5210. Gold Plating Over Nickel in Contact Area
Gold Plating: 0.76 um / 30 u inch
Click Part Numbers Listed Below For Detailed Drawings
Ports
Unshielded
Shielded
1
2
4
5
6
8
10
12
301201
301202
301204
301205
301206
301208
301210
301212
301201S
301202S
301204S
301205S
301206S
301208S
3012010S
3012012S
Shielded
W/ Ground
Tabs
301201ST
301202ST
301204ST
N/A
301206ST
301208ST
301210ST
N/A
s
s
s
Back to Index
15
Multi Port RJ11 &RJ12 Jacks
4 Contact and 6 Contac
Non-Shielded
S
Materials
Housing:
Standard Material ZYTEL FR-550 UL 94V-0
Contact:
0.35mm (0.014”) Thickness Alloy C5210. Gold Plating Over Nickel Over Tin
Gold Plating: 0.76u m / 30 u inch
Contacts
Description
Non-Shielded
Shielded
6P4C
6P6C
2 Port RJ11, 6 Position, 4 Contact Each Port
2 Port RJ12, 6 Position, 6 Contact Each Port
306504
306506
306504S
306506S
Dual Row Multi Port Right Angle
s
s
s
Standard contact
plating is 15 micro
inches of gold. For
dash number as
follows:
s
s
Materials
Shielded:
Housing:
0.25mm Thickness Copper Alloy with Tin Plated
Contact:
0.35mm (0.014”) Diameter Alloy C5210. Gold Plating Over Nickel Over Tin.
Ports/
2 High by Wide
1 (2)
2 (4)
4 (8)
5 (10)
6 (12)
8 (16)
s
Non-Shielded
Shielded
302201
302202
302204
302205
302206
302208
302201S
302202S
302204S
N/A
302206S
302208S
Shielded
W/ Tabs
302201ST
302202ST
302204ST
N/A
302206ST
302208ST s
Click Part Number
for Drawing
s
RoHS compliant wave solder onlyRoHS compliant
wave solder onl
Back to Index
17
很抱歉,暂时无法提供与“301664-2”相匹配的价格&库存,您可以联系我们找货
