8
7
6
0.748
19.00
5
4
3
2
1
RJ45 SHIELDED
IDC CONNECTOR
0.374
9.50
SWITCHCRAFT
HOUSING
0.945
24.00
F
F
RJ45 IDC
CONNECTOR
FRONT VIEW
CAT 5e SHIELDED
OR UNSHIELDED
0.945
24.00
FRONT VIEW
CAT 6 SHIELDED
OR UNSHIELDED
0.473
12.00
WIRING LABEL
SEE NOTE 5
2X
FIGURE 1
RECOMMENDED PANEL CUT-OUT
E
WIRING LABEL
SEE NOTE 5
SHIELD COVER
1.25
31.8
0.76
19.2
0.71
18.0
FIGURE 2
RECOMMENDED CABLE STRIPPING DETAIL
TYPICAL FOR ALL BREAKOUTS
SEE NOTE 4
D
IDC CAPS (2)
ASSEMBLY INSTRUCTIONS:
C
1.72
43.8
A. INSTALL THE CABLE CONDUCTORS INTO THE RJ45 IDC
CONNECTOR. SEE NOTE 5 AND FIGURE 2.
B. TERMINATE THE CABLE USING A KRONE/110
PUNCHDOWN TOOL.
C. (FOR SHIELDED VERSION) WRAP THE DRAIN WIRE
AROUND THE CABLE DRAIN TIE BAR. USE THE CABLE
TIE (NOT SHOWN) TO SECURE THE CABLE TO THE BAR.
D. SNAP THE IDC CAPS OVER THE IDC BLOCK.
E. (FOR SHIELDED VERSION) SLIDE THE SHIELDED COVER
INTO PLACE.
F. ASSEMBLE THE SWITCHCRAFT HOUSING ONTO THE
FRONT OF THE PANEL USING THE RECOMMENDED
PANEL CUT-OUT. SEE FIGURE 1.
G. SNAP THE RJ45 IDC CONNECTOR INTO THE
SWITCHCRAFT HOUSING FROM THE BACK OF THE
PANEL.
1.13
28.8
CAT5e SHIELDED
EHRJ45P5EIDC
CAT5e UNSHIELDED
EHRJ45P6SIDC
CAT6 SHIELDED
EHRJ45P6IDC
CAT6 UNSHIELDED
0.083
2.11
1.02
26.0
0.083
2.11
C
0.94
24.0
RJ45 IDC CONNECTOR
EHRJ45P5ESIDC
D
1.17
29.8
1.02
26.0
PART NUMBER
E
IDC CAPS (2)
DRAIN WIRE
(ONLY NEEDED FOR
SHIELDED VERSION)
RJ45 CABLE
SWITCHCRAFT
HOUSING
0.138
3.51
CABLE DRAIN
TIE BAR
SEE NOTE 3
0.945
24.00
0.945
24.00
1.22
31.0
1.22
31.0
0.88
22.4
PIN 8
PIN 1
B
B
NOTES:
PIN 1
PIN 8
1. THE RJ45 CAT 5e AND CAT 6 IDC CONNECTORS MEET
TIA/EIA 568 B.2 STANDARD.
2. MATERIALS:
SWITCHCRAFT HOUSING - THERMOPLASTIC, BLACK
RJ45 IDC CONNECTOR
INSULATOR BODY- THERMOPLASTIC, BLACK
CONTACTS- COPPER ALLOY, GOLD PLATED (CONTACT AREA)
IDC TERMINALS- COPPER ALLOY, TIN PLATED
IDC CAPS- THERMOPLASTIC, WHITE
(SHIELEDED VERSION ONLY)
SHIELD- COPPER ALLOY, NICKEL PLATED
DRAIN WIRE TIE BAR - COPPER ALLOY, NICKEL PLATED
A
0.748
19.00
2X
0.138
3.51
SHEILDED RJ45
UNLESS OTHERWISE SPECIFIED
5. THE RJ45 CONNECTOR CONTAINS A WIRING LABEL FOR T568A & T568B
WIRING.
A
REV
RELEASE TO PROD.
10/23/14
27394
ECO NUMBER
DATE
REVISIONS
6
5
4
PC
BY
SIZE
- TWO PLACE DECIMALS
0.02
MULT
- THREE PLACE DECIMALS
0.005 [0.13]
DATE DRAWN
BY
10/03/14
AB
DO NOT SCALE DRAWING
SolidWorks CAD File
NAME
LBS/M
TEMPER
MATERIAL
SPEC No.
FIRST USED ON
[0.5]
TJK
APVD
WIDTH
FINISH
1. ALL DIMENSIONS IN INCHES [mm]
6. THIS ASSEMBLY IS RoHS COMPLIANT.
CUSTOMER DRAWING
THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED
BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY.
4. 22-26 AWG STRANDED OR SOLID WIRE IS RECOMMENDED.
7
0.138
3.51
UNSHEILDED RJ45
3. (SHIELDED VERSION ONLY) FOR SHIELDING, TIE SHIELD/DRAIN WIRE TO THE
TIE BAR AND SECURE WITH CABLE TIE PROVIDED (NOT SHOWN).
8
2X
0.748
19.00
A
SPEC No.
SCALE
CHKD
AB
10/03/14
2:1
APVD
TJK
09/21/15
SHEET
PART No.
1
OF
1
EH SERIES RJ45 RA IDC, RoHS EHRJ45P__IDC_SERIES
C
REV
A
很抱歉,暂时无法提供与“EHRJ45P5ESIDC”相匹配的价格&库存,您可以联系我们找货
