RJ45 Weathertight
Weathertight Connectors
Connectors
RJ45
Features & Benefits
Applications
• Sealed to IP67 & IP68 NEMA 250 (6P)
(when mated)
• Molded cable assemblies available
• CAT 5E or CAT 6 available in shielded or
unshielded versions as standard
• Feed through or IDC panel terminals for
easy field installation
• Field installable design is easy to
assemble
• Dust cap available
• Any sealed data transmission
• Military or industrial GPS location
devices
• Instrumentation
• Medical data carts
• Data acquisition units
• General industrial electronic applications
Harsh Environment
Connectivity Solutions
www.conxall.com
MADE IN USA
601 E. Wildwood - Villa Park, IL 60181
Phone: 630-834-7504 Fax: 630-834-8540
Please check our website www.conxall.com for the most up-to-date product specifications
New Product Bulletin C709
RJ45 Weathertight Connectors
RJ45 Weathertight
Connectors
RJ45
Specifications
Materials:
Field Installable Plug Assembly:
Sealing Nut, Coupling Ring: Thermoplastic
Plug Housing, Insert: Thermoplastic
Sealing Ring: Elastomer
O-Ring: Elastomer
RJ45 Plug:
Insulator: Thermoplastic
Contacts: Copper Alloy, Gold Plated
Shield (Shielded Option Only): Copper Alloy, Tin
Plated
Panel Housing Jack Assembly:
Panel Housing, Hex Nut: Thermoplastic
Gasket: Elastomer
RJ45 Jack:
Housing: Thermoplastic
Printed Circuit Board (PCB): FR-4
IDC Contacts: Copper Alloy, Tin Plated
Electrical:
Contact Resistance: 20 milliohms Max
Insulation Resistance: 500M ohms Min
Withstanding Voltage: 1000V DC
Mechanical:
Vibration: Mil-Std 202G Method 201A
Environmental:
Operating Temperature: -10 °C to +60 °C
Moisture Resistance: Mil-Std 202G Method 106G
Insulation Resistance: Mil-Std 202G Method 302G
Thermal Shock: Mil-Std 202G Method 107G
Product Rating:
IP67 & IP68, NEMA 250 (6P) (when mated)
RJ45 Cable Plug (Category 6): TIA/EIA 568 C.2
RJ45 Panel Jack (Category 5e): TIA/EIA 568 B.2
RJ45 Panel Jack (Category 6): TIA/EIA 568 B.2
Other:
Recommended Panel Thickness:
Quick Connect Coupling: 1/32" to 3/16"
(0.8mm to 4.8mm)
Threaded Coupling: 1/32" to 5/32"
(0.8mm to 3.9mm)
Recommended Cable Type:
Conductor Type: Solid or Stranded Conductors
Outer Cable O.D. Range: Ø0.190 to Ø0.250
(4.83mm to 6.35mm)
Conductor insulator O.D. Range: Ø0.037 to Ø0.042
(0.94mm to 1.06mm)
Recommended Crimp/Termination Tools:
Sentinel Hand Ratchet Tool, Part Number “900005”
Sentinel Die Set, Part Number “900216”
1.190
30.2
1.155
29.3
RECOMMENDED PANEL CUT-OUT
(THREADED OR QUICK CONNECT COUPLING)
0.003 [ 0.07]
Molded Cable Assemblies
Custom overmolded cable assemblies available
Please contact us with your requirements
Harsh Environment
www.conxall.com
MADE IN USA
RJ45 Weathertight
Connectors
RJ45
GASKET
HEX NUT
RJ45 FIELD INSTALLABLE
CABLE PLUG ASSEMBLY
RJ45 PANEL HOUSING JACK
CABLE
(NOT INCLUDED)
PANEL
RJ45 FIELD INSTALLABLE CABLE PLUG ASSEMBLY
(THREADED COUPLING)
(QUICK CONNECT COUPLING)
THREADED COUPLING RING
QUICK CONNECT COUPLING RING
RJ45 PLUG
RJ45 PLUG
1.44
36.7
1.29
32.8
2.0
51.7
2.0
51.7
HEX NUT
0.13
3.3
TYP
PANEL
HOUSING
HEX NUT
0.13
3.3
TYP
GASKET
PANEL
GASKET
HOUSING
RJ45 JACK
1.19
30.2
TYP
RJ45 JACK
1.19
30.2
TYP
1 3/8 HEX
[34.9]
1.44
36.5
SQUARE
0.59
14.9
1 3/8 HEX
[34.9]
1.44
36.5
SQUARE
1.55
39.3
1.45
36.9
RJ45 PANEL HOUSING IDC RIGHT ANGLE JACK
RJ45 PANEL HOUSING IDC JACK
(SHOWN WITH NON-SHIELDED CAT 6 JACK)
(SHOWN WITH QUICK CONNECT HOUSING)
(SHOWN WITH SHIELDED CAT 6 JACK)
(SHOWN WITH THREADED HOUSING)
Harsh Environment
0.59
14.9
www.conxall.com
MADE IN USA
RJ45 Weathertight
Connectors
RJ45
Part Number Charts
DCC
RJ6
X
CABLE PLUG ASSEMBLY
PLUG TYPE
DCC
RJ6 = RJ45 CAT 6
DCP
BLANK = UNSHIELDED
S = SHIELDED
310
COUPLING TYPE
SERIES
B = QUICK CONNECT
T = THREADED
310
PLUG SHIELDING
XXX
X
X
XX
JACK TYPE
JACK SHIELDING
COUPLING TYPE
SERIES
RJ5 = RJ45 CAT 5e
RJ6 = RJ45 CAT 6
BLANK = UNSHIELDED
S = SHIELDED
B = QUICK CONNECT
T = THREADED
PANEL HOUSING ASSEMBLY
DCP
X
F = FEED-THRU (TO SAME CONNECTOR)
SD = IDC, STRAIGHT
RD = IDC, RIGHT ANGLE
Assembly Instructions
O-RING
1
PLUG HOUSING
PLUG HOUSING RIDGE
2
O-RING
AFTER
BEFORE
COUPLING RING
SEALING NUT
SEALING RING
3
2) Slide the coupling ring over the plug housing
NOTE: Make sure the front of the coupling ring
can slide past the ridge on the plug housing. If
not, it is inserted the wrong way
AFTER
BEFORE
CABLE (CUSTOMER SUPPLIED)
FRONT END OF CABLE
RJ45 PLUG
4
BEFORE
3) Slide the sealing nut, sealing ring and plug
housing/ coupling ring over the front end of the
cable in the following order:
1st sealing nut
2nd sealing ring
3rd plug housing / coupling ring
4) Terminate the RJ45 plug to the cable
NOTE: See supplemental termination guide
for cable termination instructions
INSERT
5
1) Slide the O-ring onto the front end of the plug
housing until it seats up against the ridge on the
plug housing
AFTER
5) Slide the RJ45 plug into the back end of the
insert until it snaps into place
6
BEFORE
AFTER
7
BEFORE
AFTER
8
BEFORE
AFTER
Harsh Environment
6) Slide the insert/RJ45 plug into the front end of
the plug housing until it snaps into place
7) Push the sealing ring into the rear of the plug
housing
NOTE: No part of the sealing ring should
extend past the rear of the plug housing
8) Screw the sealing nut onto the plug housing
www.conxall.com
MADE IN USA
很抱歉,暂时无法提供与“DCP-RJ6SB-RD”相匹配的价格&库存,您可以联系我们找货
