TIC-L036-11
TIC-L036-11
    TAMURA
    CONN MAGJACK 1PORT 100 BASE-TX
TIC-L036-11 数据手册
Features: 3D Package View 1. Meets IEEE 802.3 and ANSI X3.263 2. Operating Temperature: 0 °C to +85 °C S3L2 3. 1500Vrms Isolation 4. Enhanced Common Mode Attenuation for maximum EMI Suppression 5. Full Product Qualification Tests 3D Package View S1L S2L S3L S4L Product Selection Schematic Identification # P/N Row X Port Package Style 1 TIC-L033-11 1x1 S3L X 2,1,3 4,6,5 1,4,5,2 3,7,8,6 Shd 1ct:1ct 9L 7,8 LED Green and/or Orange 9,10* 2 3 4 5 TIC-L034-11 TIC-L035 -11 TIC- L036- 11 TIC-L037- 11 1x1 1x1 1x1 1x1 S4L S3L2 S2L S2L X X X X 2,1,3 2,1,3 1,3,2 1,3,2 4,6,5 4,6,5 7,6,8 7,6,8 1,4,5,2 1,4,5,2 1,4,5,2 1,4,5,2 3,7,8,6 3,7,8,6 3,7,8,6 3,7,8,6 1ct:1ct 1ct:1ct 1ct:1ct 1ct:1ct 9L 9L 6L 6L1 7,8 7,8 10,9 9,10 9,10* 9,10* 11,12* 11,12* 6 TIC-L040- 11 1x1 S2L X 1,3,2 7,6,8 1,4,5,2 3,7,8,6 Shd Shd 4,5 4,5, Shd 4,5, 1ct:1ct 6L3 11,12 7 8 TIC-L038-11 TIC-L039-11 1x1 1x1 S1L S1L X X 1,3,2 1,3,2 7,6,8 7,6,8 1,4,5,2 1,4,5,2 3,7,8,6 3,7,8,6 4,5 4,5, Shd 1ct:1ct 1ct:1ct 6L 3 6L4 11,12 11,12 Auto Xfmr Input Pins-out Output Pins-out RTN Turn Ratio TX Only SCH # LED Yellow 10,9 9,10 9,10 RCV turn ratio is 1ct:1ct * Bi-directional LEDs, green and orange. Single LED is green. Package Identification Package # Package Style Size LWH inches Package Identification mm S1L Single Port 1.005 x 0.661 x 0.531 25.53 x 16.80 x 13.50 6 Spring taps, 3 Pin -Rows Plastic Mounting tap - Shield Mounting GND tap S2L Single Port 1.005 x 0.661 x 0.531 25.53 x 16.80 x 13.50 No Spring taps, 3 P in-Rows Plastic Mounting tap - Shield Mounting GND tap S3L2 Single Port 1.005 x 0.661 x 0.531 25.53 x 16.80 x 13.50 2 Spring taps, 2 Pin -Rows Shield Mounting GND tap - Plastic Mounting tap S3L Single Port 1.005 x 0.661 x 0.531 25.53 x 16.80 x 13.50 6 Spring taps, 2 Pin -Rows Shield Mounting GND tap - Plastic Mounting tap S4L Single Port 1.005 x 0.661 x 0.531 25.53 x 16.80 x 13.50 No Spring taps, 2 Pin -Rows Shield Mounting GND tap - Plastic Mounting tap 1 of 8 5/19/03 Package Information qty/tray ( pcs ) 50 Quantity qty/box ( pcs ) 250 qty/carton ( pcs ) weight/pcs (g) Weight weight/box ( kg ) weight/carton ( kg ) box size ( cm ) Size carton size ( cm ) 1000 7.2 3.3 14.2 37.5x25.0x20.5 53.5x40.0x44.5 Electrical Specification @ 25 ° C Insertion Loss (dB Max) 1- 100 MHz 1 Return Loss (dB Min) 1-30 MHz -18 60 MHz -16 80 MHz -12 CMRR (dB Min) Crosstalk (dB Min) OCL (µH Min) Hipot (Vrms) Impedance ( Ω) 1-100 MHz -30 1-100 MHz -35 8mA Dc Bias 350 1 minute 1500 100 Mechanical Material Specification Contact RJ Contact Contact Material Phosphor Bronze 0.35 mm thick Plastic Part RJ Joint Contact and LED Contact Shell RJ Housing Set Housing & Insert Thermoplastic PA6T, Black Contact Area Solder Tail Area Underpplating Contact Material Solder Tail Area Underplating Gold Tin/Lead (9:1) Nickel Brass Tin/Lead (9:1) Nickel Thermoplastic PC Transparent 30 µ” Min. 100 µ” Min. 50 µ” Min. 0.35 mm thick 100 µ” Min. 50 µ” Min. UL 94V-0 UL 94V-0 E45587 E52579(M) General Electric Mitsui P.I. Grade: 940A Grade: CH230N Stainless SUS 304-1/2H 0.20 mm thick Product Qualification Tests Test # 1 Test Description Product Performanc e: Complete Electrical Test, Mechanical Measurements and Visual Inspection 2 Low Level Contact Resistance 3 Dielectric Strength 4 Insulation Resistance 5 6 Vibration Mechanical Shock 7 Durability (Repeated mating / unmating) 8 Solderability 9 Thermal Shock 10 Humidity Temperature Cycling 2 of 8 5/19/03 Schematic 6L Schematic 6L1 Schematic 6L4 Schematic 6L3 Schematic 9L 3 of 8 5/19/03 Package S1L 4 of 8 5/19/03 Package S2L 5 of 8 5/19/03 Package S3L 6 of 8 5/19/03 Package S3L2 7 of 8 5/19/03 Package S4L 8 of 8 5/19/03
TIC-L036-11 价格&库存
很抱歉,暂时无法提供与“TIC-L036-11”相匹配的价格&库存,您可以联系我们找货
