8
7
4
5
6
1
2
3
REVISIONS
1.470±.020 37.34±0.51
1.135±.010 28.83±0.25
REV.
ECO. NO
DESCRIPTION
DATE
BY
B
2661
UPDATED NOTE & DRAWING FORMAT
9/6/2012
KV
C
2779
UPDATE TITLE & NOTES
5/22/2013
JH
F
.300±.008 7.62±0.20
F
.150 3.81
2X
.150 3.81 THRU
.400 10.16
E
E
.700±.015 17.78±0.38
.030 0.76
A
.550 13.97
INSERTION
DEPTH
.452 11.49
.700 17.78
D
D
.275 6.99
.180±.025 4.57±0.64
.010 0.25
A
.025 0.64
.200 5.08
SECTION A-A
C
C
1.135 28.83
2X
.150 3.81 THRU
.200 5.08
6X
.150 3.81
.300 7.62
PCB LAYOUT RECOMMENDED
B
A
.040 1.02 MIN
NOTES:
1. INSULATOR MATERIAL: BROWN PPS
2. CONTACT MATERIAL: BERYLLIUM COPPER
3. PLATING: .000050" MIN NICKEL UNDERPLATE
CONTACT SURFACE: .000030" GOLD
TERMINATION: .000010" GOLD OVERALL
4. OPERATING TEMPERATURE: -65 C TO +175 C
5. PROCESSING TEMP: 260 C FOR 20 SECONDS MAX
6. UL FLAMMABILITY RATING: 94V-0
7. OPERATING VOLTAGE: 850 VAC MINIMUM AT SEA LEVEL
8. CURRENT RATING: 3 AMP
9. CONTACT RESISTANCE: 30 MILLI OHMS MAX
10. INSULATION RESISTANCE: 5000 MEGA OHMS
11. DURABILITY: 500 CYCLES MIN
12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
13. MODIFICATION: BODY WIDTH .400", .150" MOUNTING HOLES, 1.135" HOLE TO HOLE DIM,
SHORTING CANTILEVER CONTACTS ALL POSITIONS.
8
7
6
5
B
CUSTOMER COPY
Pb
RoHS COMPLIANT
4
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
DIMENSIONS ARE IN INCHES [MM]
03/02/11 JH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
PART NUMBER
SIZE
C
2
TMJ03DKSD-S1512
CAGE CODE
54453
SCALE: 4:1
3
A
TO-254 SOCKET
DWG. NO.
C11667
SHEET 1 OF 1
1
REV
C
FILE NAME: C11667, TMJ03DKSD-S1512
很抱歉,暂时无法提供与“TMJ03DKSD-S1512”相匹配的价格&库存,您可以联系我们找货
