CB / MCB Series
Ceramic Housed with Axial Leads Power Resistor
Stackpole Electronics, Inc.
Resistive Product Solutions
Features:
Fireproof power resistor
High thermal conductivity
“M” in MCB stands for metal oxide element
Standoffs may be available (CBF, MCBF) - contact Stackpole for details
100% RoHS compliant and lead free without exemption
Halogen free
REACH compliant
Electrical Specifications - CB
Type/Code
Power Rating (W)
@ 70ºC
Maximum Working
Voltage (V)
Maximum Overload
Voltage (V)
CB2
2
250
500
CB3
3
300
600
CB5
5
350
700
CB7
7
500
1000
CB10
10
700
1400
CB15
15
700
1400
TCR (ppm/ºC)
(1)
Ohmic Range (Ω) and Tolerance
5%, 10%
± 800
± 500
± 200
± 800
± 500
± 200
± 800
± 500
± 200
± 800
± 500
± 200
± 800
± 500
± 200
± 800
± 500
± 200
0.056 - 0.1
0.12 - 0.2
0.22 - 100
0.1
0.12 - 3
3.3 - 100
0.1 - 0.15
0.18 - 0.68
0.75 - 470
0.39 - 0.51
0.56 - 0.82
0.91 - 470
0.51 - 1
1.1 - 2.7
3 - 680
0.56 - 1
1.3 - 3
3.6 - 820
Electrical Specifications - MCB
Type/Code
Power Rating (W)
@ 70 ºC
Maximum Working
Voltage (V)
Maximum Overload
Voltage (V)
MCB3
MCB5
MCB7
MCB10
MCB15
3
5
7
10
15
300
350
500
700
700
600
700
1000
1400
1400
TCR (ppm/ºC) (1)
5%, 10%
110 - 51K
110 - 51K
510 - 51K
750 - 51K
910 - 51K
± 200
(1) Lower TCR may be available for certain values. Contact Stackpole.
Max Voltage Rating = √ P*R
Mechanical Specifications
Type/Code
CB2
CB3, MCB3
A
Body Length
0.709
18.00
0.866
22.00
0.047
1.20
0.047
1.20
B
Height
0.252
6.40
0.315
8.00
0.047
1.20
0.047
1.20
Rev Date: 4/13/2021
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
C
Width
0.252
6.40
0.315
8.00
1
0.047
1.20
0.047
1.20
D
Lead Diameter
0.031
0.80
0.031
0.80
0.004
0.10
0.004
0.10
E
(CBF, MCBF only)
0.299
7.60
0.374
9.50
0.039
1.00
0.039
1.00
F
Lead Length
1.000
25.40
1.000
25.40
min.
min.
min.
min.
Unit
inches
mm
inches
mm
www.seielect.com
marketing@seielect.com
CB / MCB Series
Mechanical Specifications (cont.)
Type/Code
CB5, MCB5
CB7, MCB7
CB10, MCB10
CB15, MCB15
A
Body Length
0.866
22.00
1.378
35.00
1.890
48.00
1.890
48.00
0.047
1.20
0.059
1.50
0.059
1.50
0.059
1.50
B
Height
0.374
9.50
0.374
9.50
0.374
9.50
0.512
13.00
0.039
1.00
0.039
1.00
0.039
1.00
0.047
1.20
C
Width
0.374
9.50
0.374
9.50
0.374
9.50
0.512
13.00
0.039
1.00
0.039
1.00
0.039
1.00
0.047
1.20
D
Lead Diameter
0.031
0.80
0.031
0.80
0.031
0.80
0.031
0.80
E
(CBF, MCBF only)
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.437
11.10
0.500
12.70
0.500
12.70
0.626
15.90
0.039
1.00
0.039
1.00
0.039
1.00
0.039
1.00
F
Lead Length
1.000
25.40
1.000
25.40
1.000
25.40
1.000
25.40
min.
min.
min.
min.
min.
min.
min.
min.
Unit
inches
mm
inches
mm
inches
mm
inches
mm
Performance Characteristics
Test
Moisture Resistance
Thermal Shock
Load Life @ 70°C - 1000 hours
Resistance to Soldering Heat
Short Time Overload - 5 x Pn for 5 seconds
Dielectric Withstanding Voltage
Operating temperature range for CB is -55°C to +275°C
Operating temperature range for MCB is -55°C to +155°C
Test Specification
± 5%
± 2%
± 5%
± 2%
± 2%
± 2%
Power Derating Curve:
Recommended Solder Profile
This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should
be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board
density, geometry, packages used, etc., especially those cells labeled with “*”.
100% Matte Tin / RoHS Compliant Terminations
Soldering iron recommended temperatures: 330°C to 350°C with minimum duration.
Maximum number of reflow cycles: 3.
Rev Date: 4/13/2021
2
www.seielect.com
CB / MCB Series
Wave Soldering
Description
Maximum
Recommended
Minimum
Preheat Time
80 seconds
70 seconds
Temperature Diff.
140°C
120°C
Solder Temp.
260°C
250°C
Dwell Time at Max.
10 seconds
5 seconds
Ramp DN (°C/sec)
N/A
N/A
Temperature Diff. = Defference between final preheat stage and soldering stage.
60 seconds
100°C
240°C
N/A
Convection IR Reflow
Description
Maximum
Recommended
Minimum
Ramp Up (°C/sec)
Dwell Time > 217°C
Solder Temp.
Dwell Time at Max.
Ramp DN (°C/sec)
3°C/sec
150 seconds
260°C
30 seconds
6°C/sec
2°C/sec
90 seconds
245°C
15 seconds
3°C/sec
60 seconds
10 seconds
Recommended Lead Free Resistor Reflow Profile
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
CB
MCB
Description
Package /
Standard
Lead-Free Termination
Termination Series RoHS
Composition
Type
Compliant
General Purpose Ceramic Housed with
Axial Leads Wirewound Resistor
Ceramic Housed General Purpose
Metal Oxide Element Resistor
Rev Date: 4/13/2021
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
Axial
YES
100% Matte Sn
Jan-06
06/01
Axial
YES
100% Matte Sn
Jan-06
06/01
3
www.seielect.com
CB / MCB Series
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
C
Product Series
Code
Description
CB
Standard
MCB
Standard (Metal Oxide)
CBF
With standoff
MCBF With standoff (Metal Oxide)
B
2
Power Rating
Code
W
2
2
3
3
5
5
7
7
10
10
15
15
J
Tolerance
Code Tol
J
5%
K
10%
B
1
Code Description
B
Bulk
Packaging
Product Code
CB2, CB5, CBF5, MCB5
R
Resistance Value
Quantity
1500
CB3, CB7, CB10, CB15,
CBF3, MCB3, MCB7,
CBF10, MCB10, MCB15
1000
CBF15, MCBF15
912
Four characters with
the multiplier used as
the decimal holder.
"L" used as multiplier
of 10-3 for any value
under 0.1 ohm
0.056 ohm = 56L0
0.1 ohm = R100
33 ohm = 33R0
3.32 Kohm = 3K32
Rev Date: 4/13/2021
4
www.seielect.com
很抱歉,暂时无法提供与“CB5JB11R0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1500+1.043321500+0.12666
- 3000+1.038443000+0.12607
- 6000+1.038416000+0.12606
- 7500+1.038407500+0.12606
- 22500+1.0383722500+0.12606
