1000 Eaton Boulevard
Cleveland, OH 44122
United States
Safe-IT Hospital-Grade Outlet Covers for Wall
Receptacles, Power Strips and Surge Protectors,
Set of 4
Highlights
Removable covers are designed
for repeated use in NEMA 515R outlets
Ideal for childproofing your
home’s wall outlets when
properly installed
Self-locking feature allows easy
installation with no tools
required
Requires Phillips screwdriver for
removal to ensure optimal
security
Set includes 4 outlet covers and
nylon screws to lock covers into
place
MODEL NUMBER: HGOUTLETCVR
Applications
Protect NEMA 5-15R or NEMA 515R-HG outlets against
unauthorized access or connection
of unauthorized equipment
Insert into wall outlets or power strips and lock into place to prevent the connection of unauthorized
devices.
Features
Reusable Covers Protect Unused Outlets Against Unauthorized Access
This set of four hospital-grade outlet covers are safe, easy and convenient to use. These covers meet
healthcare agency requirements. They are also recommended for childproofing your home to prevent
children from accessing electrical outlets.
Nearly Impossible to Remove Without a Tool
The HGOUTLETCVR outlet covers are easy to insert into an AC wall receptacle, power strip or surge
protector. Just push the cover and the included nylon screw into the outlet to lock it tight. Each cover is
designed for repeated use. To remove, use a Phillips-head screwdriver to remove the locking screw.
Compatible with Tripp Lite Power Strips and Surge Protectors
These removable covers protect most standard home and office wall outlets, as well as PS-415HGULTRA, SPS415HGULTRA, PS-410-HGOEMCC, PS-415-HG-OEM, PS-615-HG-OEM,
PS410HGOEMX, PS-415-HG, PS-602-HG, PS-606-HG, PS-615-HG, RS1215-HG, ISOBAR6ULTRAHG,
SPS-615-HG, SPS606HGRA, SPS610HGRA and other power strips with NEMA 5-15R-HG and NEMA 515R outlets.
Specifications
OVERVIEW
UPC Code
037332175991
Accessory Type
Outlet Cover
Accessory Class
PDU Accessories
1/2
System Requirements
Any NEMA 5-15R-HG and NEMA
5-15R outlets, including wall
receptacles and hospital-grade
power strips and surge protectors
Package Includes
(4) Outlet covers
Instruction sheet
Cleveland, OH 44122
United States
PHYSICAL
Shipping Dimensions (hwd / in.)
0.80 x 4.72 x 5.52
Shipping Dimensions (hwd / cm)
2.03 x 11.99 x 14.02
Shipping Weight (lbs.)
0.05
Shipping Weight (kg)
0.02
FEATURES & SPECIFICATIONS
Antimicrobial
Yes
Antibacterial
No
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“HGOUTLETCVR”相匹配的价格&库存,您可以联系我们找货
