RP13A-12PD-15SC
RP13A-12PD-15SC
    HRS(广濑)
    CONN PLUG 15POS FEMALE CRIMP
RP13A-12PD-15SC 数据手册
Plastic Push-Pull Lock Connectors RP13 Series Features 1. Superior mating operability • A secure mating condition is achieved by simply pushing the plug on to the receptacle; Pull back on the locking sleeve to easily un-mate the connector. • Index marks are provided on the plug for easy mating alignment. • Our proprietary guide keys aid with making a correct mating orientation in blind or low light conditions. Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2. Light weight and robust design The strong outer shell is made of glass-reinforced polycarbonate resin, producing light but durable connectors. 3. Available in an anti-static version The anti-static version connects the plug and receptacle housing together in such a way that the surrounding shield guards against the effects of static electricity. 4. Variation Items Number of contacts Connector type Plug termination type Receptacle termination type Receptacle mounting style 13, 15, 20 Plug and jack: Straight, Receptacle: Straight, right angle Crimp Crimp, PCB dip Flange, jam nut Product Specifications Rated current Ratings Standard type : 2A (when using a wire of at least 24 AWG) Anti-static type : 2A (when using a wire of at least 22 AWG) Rated For 13 and 15 contact positions : AC 30V, DC 42V voltage 20 contacts : AC 100V, DC 140V Items Operating temperature range −10 to +60ç Storage temperature range −10 to +60ç Specifications 1. Contact resistance 2. Insulation resistance 3. Withstanding voltage 4. Vibration resistance 5. Shock resistance Conditions For 13 and 15 contact positions : 15mø max. 20 contacts : 30mø max. Measured at DC 1A 1,000Mø min. Measured at DC 250V No flashover or dielectric breakdown. AC 300V for 1 minute No electrical discontinuity for 10µs or greater. No electrical discontinuity for 10µs or greater. 10 to 55Hz/cycle, amplitude : 0.75mm, 3 axis directions, 2 hours each Acceleration : 490m/s2, duration : 11ms, 3 axis directions, 3 cycles each 6. Mating cycles Contact resistance : For 13 and 15 contact positions : 20mø max. For 20 contact positions : 45mø max. 1,000 times 7. Temperature cycle Insulation resistance : 100Mø min. -55ç : 30 minutes ➝ Normal temperature : 10 to 15 minutes ➝ 85ç : 30 minutes ➝ Normal temperature : 10 to 15 minutes, leave total 5 cycles 8. Moisture resistance Insulation resistance : 10Mø min. (at high humidity) 100Mø min. (when dry) Temperature : 40ç, relative humidity : 90 to 95%, leave 96 hours Materials / Finish Items Plug Exterior, insulator Clamp Bushing Exterior, insulator Receptacle Crimp contact Crimp contact Female contact Male contact Female contact Male contact Material Polycarbonate resin Brass Vinyl chloride resin Polycarbonate resin Steel Phosphor bronze Brass Finish ----------------------------------------------------Nickel plating Remarks UL94V-0 --------------------------UL94V-0 Phosphor bronze Silver plating, gold plating -------------- Silver plating In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. --------------------------- 2018.7w 1 RP13 Series●Plastic Push-Pull Lock Connectors ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. Plug RP13A - 12 P A - 13 S C (01) Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. qModel name : RP13A Series wShell size : The shell size is the outer diameter of the mating end of the plug. yContact form S : Female contact P : Male contact eShell type P : Straight plug R : Receptacle J : Jack uContact termination type: A : Straight, PCB dip B : Right-angle, PCB dip C : Contact termination by crimping rShell variation : Connectors are distinguished by A, B, or C iOther specifications : A two-digit character is added to if a variation is made within the series. indicate other specifications as needed. tNumber of contacts Crimp contact RP13A - SC - 2 1 1 qModel name : Indicates the series name. RP13, RP13A, RP19 oContact type : SC : Socket type crimp contact (female) PC : Pin type crimp contact (male) !0Contact form : 1 : Loose piece contacts 2 : Reel contacts 2 !1Barrel form : RP13, RP13A 1 : For 18 to 22 AWG 2 : For 24 to 28 AWG RP19 1 : For 18 to 22 AWG 2 : For 24 to 30 AWG !2Identification of plating : 1 : Gold plating 2 : Silver plating RP13 Series●Plastic Push-Pull Lock Connectors Standard type Standard plug (Minimum dimension) A (Representative example.) RP13A-12PA-13SC(71) Part No. HRS No. RP13A-12PA-13SC(71) RP13A-12PB-13SC(31) RP13A-12PD-13SC(71) RP13A-12PE-13SC(71) RP13A-12PK-13SC(71) RP13A-12PS-13SC(71) RP13A-12PD-15SC(71) RP13A-12PK-15SC(71) RP13A-12PP-15SC(71) 113-0182-4 71 113-0184-0 31 113-0186-5 71 113-0201-7 71 113-1006-7 71 113-1026-4 71 113-0206-0 71 113-0219-2 71 113-1010-4 71 No. of contacts A B ØC Weight 47.2 32 13 52.2 37 47.2 32 52.2 37 15 6.1 5.7 6.1 6.4 7.1 6.0g 8.1 6.1 7.1 7.5 Part No. HRS No. RP13A-12PD-20SC(71) RP13A-12PG-20SC(71) RP13A-12PH-20SC(71) RP13A-12PK-20SC(71) RP13A-12PS-20SC(71) 113-0214-9 71 113-0210-8 71 113-0217-7 71 113-1012-0 71 113-1022-3 71 No. of contacts A B ØC Weight 6.1 7.5 47.2 32 6.4 6.0g 7.1 52.2 37 8.1 52.2 37 20 (Note) Cable clamping, cable rotation, and other forces may vary with the cable construction. Please make sure that your cable is suitable for use with these connectors before usage and production. Receptacle (Flange type) (Crimp type) A 25 3.2 10 3 Ø 14.3 20 1 13 Press-fitted metal flange 12 2-B (Hole is threaded on metal flange portion) 9 Ø1 45 RP13A-12RA-13PC(71) Part No. RP13A-12RA-13PC(71) RP13A-12RA-15PC(71) RP13A-12RA-20PC(71) ° (Representative example.) HRS No. 113-0183-7 71 113-0207-3 71 113-0215-1 71 No. of contacts 13 15 20 A 18.1 B Weight M2.6×0.45 4.0g 16 (Remarks) See page 5 for details on mounting hole dimensions. (Dip type ) A 18.1 3.2 10 25 20 B 1 13 3 0.5×0.3 (Dip post diameter) 12 Ø 14.3 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Ø16.9 ØC B 9 Ø1 Press-fitted metal flange RP13A-12RA-13PA(71) Part No. RP13A-12RA-13PA(71) RP13A-12RA-15PA(71) ° 45 2-M2.6×0.45 (Hole is threaded on metal flange portion) (Representative example.) HRS No. 113-0202-0 71 113-1002-6 71 No. of contacts A B Weight 13 15 21.5 3 5.0g (Remarks) See page 5 for details on mounting dimensions and page 7 for details on dip post arrangement sizes. 3 RP13 Series●Plastic Push-Pull Lock Connectors Receptacle (Jam nut to be fastened) A (Dip type) 18.1 1 9 1 12 Ø 14.3 B 3 13 0.5×0.3 (Dip post diameter) M12×1 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. RP13A-12RB-13PA(71) Part No. A B No. of contacts Weight 21.5 3 13 3.5g HRS No. RP13A-12RB-13PA(71) 113-0203-2 71 (Remarks) See page 5 for details on mounting hole dimensions and page 7 for details on dip post arrangement sizes. Right-angle, dip type E 1 1 (Note) Panel thickness: 1.5mm max. 4× R 17 B C F 20 Ø14.3 1 A 4 (Note) Ø15 mm or more 18 3.5 (Center of the screw hole for mounting the connector) Dip post diameter RP13A-12RC-20PB (Note) The mounting panel thickness should be 1.5mm or less. Mounting hole should be Ø15 mm or more. Part No. HRS No. No. of contacts A B C ØD E F Weight RP13A-12RC-13PB 113-1020-8 13 17.5 8.5 3.5 0.64 23.5 13 4.0g RP13A-12RC-20PB 113-0211-0 20 19.5 10.5 3 0.6 31.5 15 5.0g (Remarks) See page 7 for details on dip post arrangement sizes. A Ø16.9 ØC B (Minimum dimension) Jack (Representative example.) RP13A-12J-13PC(71) Part No. HRS No. RP13A-12J-13PC(71) 113-0166-8 71 RP13A-12JD-15PC(71) 113-1005-4 71 RP13A-12JK-15PC(71) 113-0218-0 71 RP13A-12JG-20PC(71) 113-1004-1 71 No. of contacts A B 13 49.1 34.6 15 54.1 39.6 20 52.6 37.4 ØC Weight 6.1 7.1 4.5g 7.4 (Note) Cable clamping, cable rotation, and other forces may vary with the cable construction. Please make sure that your cable is suitable for use with these connectors before usage and production. 4 RP13 Series●Plastic Push-Pull Lock Connectors Contact (Male contact) Panel mounting hole dimensions A-A 45° B E A ±30 A D C For 13 and 15 contact positions Plating +0.05 Ø 14.4   B C D E Applicable wire size 0 05 HRS No. 13 contact position for super-thick wires (available for contact position numbers 12 and 13 only) Type Part No. HRS No. Plating B C D E Applicable wire size Loose piece RP13-PC-112 113-0178-7 contacts Silver plating 1.6 2.1 13.9 1.4 18 to 22 AWG Reel contacts RP13-PC-212 113-0140-4 For 20 contact positions Type Part No. HRS No. Plating 20 ± 0. Loose piece contacts RP13-PC-122 113-0179-0 Silver plating Partial gold 1.2 1.35 13.9 1.4 24 to 28 AWG RP13-PC-221 113-0360-0 plating Reel contacts RP13-PC-222 113-0141-7 Silver plating (Flange type) Applicable connector Part No. HRS No. RP13A-12RA-13PC(71) 113-0183-7 71 RP13A-12RA-13PA(71) 113-0202-0 71 RP13A-12RA-15PC(71) 113-0207-3 71 RP13A-12RA-15PA(71) 113-1002-6 71 RP13A-12RA-20PC(71) 113-0215-1 71 B C D E Applicable wire size 7.1  0 +0.1 Loose piece contacts RP19-PC-122 113-0268-8 Silver plating 1.2 1.35 12 1.18 24 to 30 AWG Reel contacts RP19-PC-222 113-0264-7 (Female contact) A-A A +0.1  0 E B Ø12.1 Ø1 A 0.1 + 0   D 3.8 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. 2 +0.  0 2.8 2×Ø +0.05 7.5  0 (Representative example.) Type ′ +0.05 3.1  0 C (The form shown above represents an example.) For 13 and 15 contact positions Type Part No. HRS No. Plating Loose piece RP13A-SC-121 113-0363-9 Partial gold plating contacts RP13A-SC-122 113-0181-1 Silver plating Reel contacts RP13A-SC-221 113-0362-6 Partial gold plating (Jam nut to be tightened) B C D E Applicable wire size Part No. 1.2 1.35 13.9 1.4 24 to 28 AWG RP13A-SC-222 113-0151-0 Silver plating 13 contact position for super-thick wires (available for contact position numbers 12 and 13 only) Type Part No. HRS No. Plating B C D E Applicable wire size Loose piece contacts RP13A-SC-112 113-0180-9 Silver plating 1.6 2.1 13.9 1.4 18 to 22 AWG Reel contacts RP13A-SC-212 113-0150-8 For 20 contact positions Type Part No. HRS No. Plating Applicable connector RP13A-12RB-13PA(71) HRS No. 113-0203-2 71 (Note 1) Above figures show the arrangement viewed from the panel surface. The mating guide of flange type is located on the top position. (Note 2) The applicable panel thickness for the flange type receptacle is 2.7mm max., since this type is mounted from the back surface of the panel. (Note 3) The applicable panel thickness for a hex nut fastening type is 5mm max. and 1mm min. B C D E Applicable wire size Loose piece contacts RP19-SC-122 113-0270-0 Silver plating 1.2 1.35 11 1.18 24 to 30 AWG Reel contacts RP19-SC-222 113-0266-2 (Note 1) Use connectors with gold-plated contacts if the connectors will be subjected to constant vibration. (Note 2) Loose piece contacts are available in 100 piece packs. Reel contacts are available as 10,000 piece reels. 5 RP13 Series●Plastic Push-Pull Lock Connectors RP13A anti-static type 47.2 Ø 16.9 Ø6.1 32 (Minimum dimension) Plug (Representative example.) Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. RP13A-12PA-13PC(71) Part No. HRS No. RP13A-12PA-13PC(71) No. of contacts Weight 13 6.0g 113-4003-5 71 (Note) Cable clamping, cable rotation, and other forces may vary with the cable construction. Please make sure that your cable is suitable for use with these connectors before usage and production. Receptacle (flange type) (Crimp type) 15 25 12 20 φ14.3 φ1 9 2×Ø2.8 (hole) (metal flange) Press-fitted metal flange 45 ° (Representative example.) RP13A-12R-13SC(71) Part No. HRS No. RP13A-12R-13SC(71) No. of contacts Weight 13 4.0g 113-4002-2 71 (Remarks) See page 7 for details on mounting hole dimensions. Contact (Female contact) (Male contact) A-A A-A B E B A E A A A D Type Part No. HRS No. Loose piece RP19-PC-122 113-0268-8 contacts Reel contacts RP19-PC-222 113-0264-7 D C B C D E Applicable wire size 1.2 1.35 12 1.18 24 to 30 AWG Type Part No. HRS No. Loose piece RP19-SC-122 113-0270-0 contacts Reel RP19-SC-212 113-0265-0 contacts RP19-SC-222 113-0266-2 C B C D E Applicable wire size 1.2 1.35 1.6 2.1 24 to 30 AWG 11 1.18 1.2 1.35 (Note 1) Loose piece contacts are available in 100 piece packs. Reel contacts are available as 10,000 piece reels. Only contact positions 12 and 13 can be used with 18 to 20 AWG wire. Other contact positions numbers cannot be used with this wire gauge. (Note 2) When crimping wires gauge 18 to 22 AWG, make sure that the outer insulation diameter is Ø1.79mm or less. For wires gauges 24 to 30 AWG, use an outer insulation diameter of Ø1.15 or less. 6 18 to 22 AWG 24 to 30 AWG RP13 Series●Plastic Push-Pull Lock Connectors Panel mounting hole dimensions (for anti-static type) 45 ° ±30 +0.1 3.1 0 ′ +0.2  0 7.5 0 +0.1 2× φ 2.8 .1 +0 0 (Flange type) (Note 1) Above figures show the arrangement viewed from the panel surface. The mating guide of flange type is located on top the position. (Note 2) The applicable panel thickness for a flange type receptacle is maximum 4.7mm, as this type is mounted from the back surface of the panel. Dip post arrangement sizes for receptacles Straight dip type 13 contacts 7 8 11 12 2 1 8 1.35 14 13 Ø0.6 (15 positions) 1.15 1.4 3.35 9 15 Ø0.6 (13 positions) 2.9 5 12 13 1.15 1.4 3 4 0.9 3 2.75 2 3.75 1 4 1.25 0.95 3 2.3 1.05 2.3 3.15 2.55 3.45 0.6 3.45 15 contacts 1.15 1.15 2.3 2.3 3.45 3.45 (Remarks) 1. The figures shown above for 13 and 15 contact positions are viewed from the receptacle mating end. 2. A machining tolerance of ±0.05 is recommended for the PCB layout dimensions. Right-angle, dip type 13 contacts 20 contacts C.L C.L 11 Use a tapping screw for JIS B 1122 M3. (Screw hole for mounting the connector) 13 11 12 11 8 7 Ø0.9 (13 positions) 4 3 5 5 Use a tapping screw for JIS B 1122 M3. (Screw hole for mounting the connector) 5 1.4 2.3 3.45 1.15 1.4 20 19 13 12 7 6 (20 positions) 16 15 14 1 Ø0.85 1.15 18 17 10 9 8 2 1 4 3 2 2 2 2 2 2 2 11 2 2 2 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 20 ± 0. 1 4 . Ø 14 2.3 0.8 3.45 0.8 2.4 2.4 4 4 (Remarks) 1. The figures shown above are viewed from the contact insertion end. 2. A machining tolerance of ±0.05mm is recommended for the PCB layout dimensions. 7 RP13 Series●Plastic Push-Pull Lock Connectors Applicable tools Type Manual Items Manual crimping tool Part No. HRS No. 150-0024-3 RP13-PC-112 RP13-TC-12 150-0025-6 RP13-PC-121, 122 24 to 28 AWG RP13A-TC-11 150-0026-9 RP13A-SC-112 18 to 22 AWG RP13A-TC-12 150-0027-1 RP13A-SC-121, 122 24 to 28 AWG RP19-TC-11 150-0048-1 RP19-PC-112 RP19-SC-112 18 to 22 AWG RP19-PC-122 RP19-SC-122 24 to 28 AWG Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Cable crimping tool Extraction tool 18 to 22 AWG CM-105C 901-0001-0 ------------------------ ------------------------ AP105-RP13-2 901-2024-0 RP13-PC-221, 222 RP13A-SC-221, 222 24 to 28 AWG AP105-RP19-1 901-2013-3 RP19-SC-212 18 to 22 AWG AP105-RP19-2 901-2014-6 RP19-PC-222 RP19-SC-222 24 to 28 AWG RP13A-TC-01 150-0070-0 ------------------------ Ø4.6~Ø5.8 Ø7~Ø7.5 RP13A-TC-02 150-0071-3 ------------------------ Ø6.3, Ø7.8 Auto Applicator Applicable wire size and applicable cable diameter RP13-TC-11 RP19-TC-12 Automatic crimping press Applicable contact RP13-PC-TP 150-0021-5 Male contact ------------------------ RP13A-SC-TP 150-0022-8 ------------------------ RP6-SC-TP 150-0039-0 Female contact Male/female contact for RP19 RP13A-TC-02 Cable crimping tool (handle shape is shown as an example.) ------------------------ RP13-TC-11 Manual crimping tool RP6-SC-TP RP13-PC-TP RP13A-SC-TP Extraction tools 8 Automatic crimping press (Type CM-105C) RP13 Series●Plastic Push-Pull Lock Connectors Termination/assembly procedure Plug Assembly procedure Cable Cord tube 1. First, pass the terminated cable through the cord tube in the following order: spring, connection sleeve, and cord bushing, and then crimp and terminate the contacts. 2. Assemble the crimped and terminated contacts to the contact holes of the P-insulation P case. At this time, please make sure that the crimped contacts are securely engaged onto the contact holes of the P-insulation P case by lightly pulling the cable. 3. Attach the metal fitting by clamping to it the cord bushing and assemble these into the P-insulation P case. Then crimp the metal fitting by clamping it with the applicable tool. 4. Next, attach in the following order to the P-insulation P case: connection sleeve, spring, and cord. Then align the screw hole of the cord tube and that of the metal fitting for clamping, and tighten the round flat screw to the specified torque of 0.2 N•m (2 kg•cm). 5. After the assembly procedure described above has been completed, test the parts to make sure that the locking collar moves correctly. Round, flat head screw Spring Arrow view A A +3 0 Metal fitting for clamping P-insulation P case 3.3±0.2 2 or more Cord bushing 27.3 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Locking collar Contact Arrangement (Standard type) 2 1 Contact arrangement 4 3 7 4 11 8 12 No. of contacts 13 2 7 6 1 8 12 11 15 13 3 10 14 15 13 4 1 5 10 5 9 16 11 20 17 20 (Anti-static type) 2 3 1 Contact arrangement 7 4 11 8 12 No. of contacts 13 13 (Remarks) 1. The figures shown above are viewed from the receptacle and jack mating end (plug connection end). 9 RP13 Series●Plastic Push-Pull Lock Connectors Precautions This product series uses silver plated contacts. Silver reacts easily to exposure to sulfur gas so the below conditions may cause tarnishing.  ・Dusty environments  ・Area with a high concentration area of gases such as sulfur dioxide gas, hydrogen sulfide gas, nitrogen dioxide gas and so on. Example; In close proximity to factory exhaust, automotive emissions, etc.  ・Close to heaters, or in other areas marked by extreme temperature differences or high humidity.  ・Close to rubber products includes rubber adhesives. The Electrical connection is not affected by tarnishing on a silver surface due to the wiping effect of the contact pins. Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Storage Packing state; Packed in original packing or equivalent container Temperature -10 to +60ç Humidity 85% Max (It is recommended that the product be stored in an area of normal level of temperature and humidity, and free of any temperature fluctuation) Please use this products within 6 months of delivery. (After 6 month, please check the solderbility before use) “Storage” means long-term storage of the unused products in sealed packaging, prior to assembly to PCB. 10 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. RP13 Series●Plastic Push-Pull Lock Connectors MEMO : 11 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. RP13 Series●Plastic Push-Pull Lock Connectors Powered by TCPDF (www.tcpdf.org) USA: HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE 2300 Warrenville Road, Suite 150, Downers Grove, IL 60515 Phone : +1-630-282-6700 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE 2841 Junction Ave, Suite 200 San Jose, CA. 95134 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE) 17197 N. Laurel Park Drive, Suite 253, Livonia, MI 48152 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE 300 Brickstone Square Suite 201, Andover, MA 01810 Phone : +1-978-662-5255 THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Schoenbergstr. 20, 73760 ostfildern Phone : +49-711-456002-1 Fax : +49-711-456002-299 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE Neumeyerstrasse 22-26, 90411 Nurnberg Phone : +49-911 32 68 89 63 Fax : +49-911 32 68 89 69 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE Bayernstr. 3, Haus C 30855 Langenhagen, Germany Phone : +49-511 97 82 61 30 Fax : +49-511 97 82 61 35 http://www.hirose.com/eu/ FRANCE: HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE 130 Avenue Joseph Kessel, Bat E, 78960 Voisins le Bretonneux, France Phone : +33-1-85764886 Fax : +33-1-85764823 http://www.hirose.com/eu/ UNITED KINGDOM: HIROSE ELECTRIC EUROPE BV (UK BRANCH) 4 Newton Court, Kelvin Drive, Knowlhill, Milton Keynes, MK5 8NH Phone : +44-1908 202050 Fax : +44-1908 202058 http://www.hirose.com/eu/ CHINA: HIROSE ELECTRIC (CHINA) CO., LTD. (SHANGHAI, HEADQUARTERS) 18, Enterprise Center Tower 2, 209# Gong He Road, Jing’an District, Shanghai, CHINA 200070 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (CHINA) CO.,LTD. BEIJING BRANCH A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, ChaoYang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (CHINA) CO., LTD. SHENZHEN BRANCH Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre, 5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose.com/cn/ HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose.com/hk/ TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7355 http://www.hirose.com/tw/ KOREA: HIROSE KOREA CO.,LTD. 143, Gongdan 1-daero, Siheung-si, Gyeonggi-do, 15084, Korea Phone : +82-31-496-7000 Fax : +82-31-496-7100 http://www.hirose.co.kr/ SINGAPORE: INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE HIROSE ELECTRIC SINGAPORE PTE. LTD. 03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C, Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India Singapore 079909 Phone : +91-12-660-8018 Phone : +65-6324-6113 Fax : +91-120-4804949 Fax : +65-6324-6123 http://www.hirose.com/sg/ http://www.hirose.com/sg/ INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma Gandhi (MG) Road, Bangalore 560 001, Karnataka, India Phone : +91-80-4120 1907 Fax : +91-80-4120 9908 http://www.hirose.com/sg/ MALAYSIA: THAILAND: PENANG REPRESENTATIVE OFFICE BANGKOK OFFICE (REPRESENTATIVE OFFICE) 73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn Road, Yannawa, Sathorn, Bangkok 10120 Thailand Lepas Penang, 11950, Malaysia Phone : +66-2-686-1255 Phone : +604-648-5536 Fax : +66-2-686-3433 http://www.hirose.com/sg/ http://www.hirose.com/sg/ ® 12 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 07/2018. Contents are subject to change without notice for the purpose of improvements.
RP13A-12PD-15SC 价格&库存
很抱歉,暂时无法提供与“RP13A-12PD-15SC”相匹配的价格&库存,您可以联系我们找货
