Approval Sheet
for
Precision Power Wirewound Resistor
Ceramic Carrier & Axial Type
PPN Series
±0.5%、±1%、±2% & ±5%
YAGEO CORPORATION
Headquarters: 3F, No.233-1, Pao Chiao Rd., Xindian, Taipei, Taiwan, R.O.C.
Tel: 886-2-6629-9999 Fax: 886-2-6628-8885
URL: www.yageo.com
Page-1
Rev.
Description
Issue Date
Drawn
Approved
00
issue new spec.
May 25, 2012
Feng Ye
Ken Hsu
Description
Precision Power Wirewound Resistors, Ceramic Carrier & Axial Type
Series
PPN
Rev.
Page-2
00
1.
PRODUCT:
PRECISION POWER WIREWOUND RESISTORS, CERAMIC CARRIER&CAOTED&AXIAL TYPE
Body colour:
Grey
2.
PART NUMBER:
Part number of the precision power wirewound resistor is identified by the name, power, tolerance,
packing, temperature coefficient, special type and resistance value.
Example:
PPN
100
J
T
52-
10R
(1)
(2)
(3)
(4)
(5)
(6)
(7)
Series Power Resistance Packing Temperature Special Resistance
Name Rating Tolerance Style
Coefficient
Type
Value
of Resistance
(1) Style: PPN SERIES
(2) Power Rating : 100=1W、160=1.6W、200=2W、250=2.5W、300=3W、350=3.5W、430=4.3W、
500=5W、650=6.5W
(3) Tolerance:
D=±0.5%
(4) Packaging Type:
F=±1%
G=±2%
J=±5%
T=Tape on Box Packing
(5) Temperature Coefficient :”-“=Base on spec.
(6) Special Type:
52-=52.4mm
73-=73mm
(7) Resistance Value:E24 & E96 & E192 Series
Example:0.1R、 1R、10R、100R、……
Page-3
3.
MARKING:
Pinted in clear
Yageo 1210
1W 10R J
4.
ELECTRICAL CHARACTERISTICS
TABLE I
STYLE
Power Rating at 70 ℃
Max. Cont. Work. Voltage
PPN100
1W
PPN160
1.6W
PPN200 PPN250 PPN300 PPN350 PPN430 PPN500 PPN650
2W
2.5W
3W
3.5W
4.3W
5W
6.5W
100
85
P70 × R
Thermal resistancev (℃/W) 125
65
55
Insulation Resistance
Tolerances
Not insulated
Rmin.~Rmax.: ±5%, ±2%, ±1%; R≧1R: ±0.5%
Insulation Voltage (1min.)
Operating Temp. Range
Max. 75V
- 55 ℃ to + 350 ℃
TABLE II Resistance Range and Temperature Coeficient
STYLE
500 +400 ppm/℃
400 ± 50 ppm/℃
Appr.+180 ppm/℃
65
48
±20 ppm/℃
45
35
±10 ppm/℃
PPN100
≧0R01
≤0R024
≧0R027
≤0R091
≧0R1
≤15R
≧16R
≤220R
PPN160
≧0R022
≤0R033
≧0R036
≤0R062
≧0R068
≤0R091
≧0R1
≤160R
≧180R
≤470R
PPN200
≧0R01
≤0R02
≧0R022
≤0R047
≧0R051
≤0R091
≧0R1
≤47R
≧51R
≤750R
PPN250
≧0R01
≤0R027
≧0R03
≤0R075
≧0R082
≤0R091
≧0R1
≤47R
≧51R
≤750R
PPN300
≧0R015
≤0R024
≧0R027
≤0R062
≧0R068
≤0R091
≧0R1
≤68R
≧75R
≤1K
PPN350
≧0R02
≤0R03
≧0R033
≤0R062
≧0R068
≤0R091
≧0R1
≤130R
≧150R
≤1K5
PPN430
≧0R027
≤0R047
≧0R051
≤0R062
≧0R091
≤0R13
≧0R15
≤150R
≧160R
≤2K2
PPN500
≧0R033
≤0R062
≧0R068
≤0R013
≧0R15
≤0R16
≧0R18
≤160R
≧180R
≤2K7
PPN650
≧0R047
≤0R075
≧0R082
≤0R015
≧0R16
≤0R24
≧0R27
≤180R
≧200R
≤3K9
* Below or over this resistance on request.
Page-4
5.
DERATING CURVE
6.
DIMENSIONS
STYLE
DIMENSIONS (unit: mm)
Lmax.
ψD* max.
ψd
PPN100
9.0
3.0
0.65
PPN160
9.7
4.0
0.80
14.5
4.5
0.65
PPN250
12.6
5.5
0.80
PPN300
15.0
8.5
0.80
PPN350
17.0
5.5
0.80
PPN430
18.0
8.5
0.80
PPN500
22.0
8.5
0.80
PPN650
27.0
8.5
0.80
PPN200
Page-5
7.
ENVIRONMENTAL CHARACTERISTICS
(1) Voltage Proof
The resistor shall be clamped in the trough of a 90° metal V Block. Apply the insulation voltage specified
in the “Table I “ between the terminals connected together with the block for about 60 seconds.
The resistor shall be able to withstand without breakdown or flashover.
(2) Temperature Coefficient Test
Test of resistors above room temperature 100°C ± 2°C ( Testing Temperature 115°C to 130°C ) at the
constant temperature silicon plate for over 5 minutes. Then measure the resistance value.
The Temperature Coefficient is calculated by the following equation and its value should be within the
range of requested.
Re sistor Temperatur e Coefficient =
R
R0
t
to
R − R0
1
× 10 6
R0
t − t0
= Resistance value under the testing temperature
= Resistance value at the room temperature
= The testing temperature
= Room temperature
(3) Solderability
Immerse the specimen into the solder pot at 235 ± 5 °C for 3 ± 0.5 seconds.
At least 95% solder coverage on the termination.
(4) Solvent Resistance of Marking
The specimen into the appropriate solvent of IPA condition of ultrasonic machine for 5± 0.5 minutes.
The specimen is no deterioration of coatings and color code
(5) Robustness of Terminations
Direct Load – Resistors shall be held by one terminal and the load shall be gradually applied in the
direction of the longitudinal axis of the resistor unit the applied load reached the requirement.
The load shall be held for 10 seconds. The load of weight shall be ≧ 40N
(6) Damp Heat Steady State
Place the specimen in a test chamber at 40 ± 2 °C and 90 ~ 95 % relative humidity. Apply the 0.1 times
rated voltage to the specimen at the 1.5 hours on and 0.5 hour off cycle. The total length of test is 56
days.
The change of the resistance value shall be within ± 1.0 %
(7) Endurance at 70 °C
Placed in the constant temperature chamber of 70 ± 3 °C the resistor shall be connected to the lead wire
at the point of 25mm. Length with each terminal, the resistors shall be arranged not much effected
mutually by the temperature of the resistors and the excessive ventilation shall not be performed, for 90
minutes on and 30 minutes off under this condition the rated D.C. voltage is applied continuously for
1000+48/-0 hours then left at no-load for 1hour, measured at this time the resistance value。
The change of the resistance value shall be within ± 3.0%
There shall be no remarkable change in the appearance and the color code shall be legible after the test..
(8) Resistance to Soldering Heat
The terminal lead shall be dipped into the solder pot at 260 ± 3 °C for 10 ± 1.0 seconds up to 2.5 ~ 3.5
mm.
The change of the resistance value shall be within ± 0.2%
Page-6
8.
9.
PACKAGING
STYLE
Packaging
Pieces
Pack.-code
C
s
PPN100
taped
1000
T
65
5
PPN160
taped
1000
T
65
5
PPN200
taped
1000
T
85
10
PPN250
taped
1000
T
85
10
PPN300
taped
500
T
85
10
PPN350
taped
1000
T
85
10
PPN430
taped
500
T
85
10
PPN500
taped
500
T
85
10
PPN650
taped
500
T
85
10
Plant Address
A.
China Dongguan Plant
7-1, Gaoli Road, Gaoli Industrial Zone
Tangxia Zhen, Dongguan, Guangdong, China
(廣東省東莞市塘廈鎮高麗工業區高麗路 7-1 號)
Tel. 86-769-8772 0275
Fax. 86-769-8772 0275 #4333
B.
China Mudu Plant
No.158, Fengjiang Road,
Mudu New District, Suzhou, Kiangsu, China
(江蘇省蘇州木瀆新區楓江路 158 號)
Tel. 86-512-6651 8889
Fax. 86-512-6651 9889
Page-7
很抱歉,暂时无法提供与“PPN500JT-73-33R”相匹配的价格&库存,您可以联系我们找货
