Through-hole resistors
Fiberglass Cement Resistors
Power Wirewound &
Vertical Lead Type
Normal & Miniature Style [ PSM Series ]
FEATURES
Power Rating
4W, 5W, 7W, 9W, 11W, 17W
Resistance Tolerance
±5%, ±10%
T.C.R
400±50ppm/°C
DERATING CURVE
For resistors operated in ambient temperatures above 70°C, power rating must be derated
in accordance with the curve below.
INTRODUCTION
The PSM Series Resistors are wound on
Fiberglass core. The materials used and the
construction techniques ensure excellent
flame resistance, arc resistance and moisture
resistance as well as self-extinguishing
capabilities. They will withstand the most
rigorous loading test.
70
Rated Load (%)
350 °C
100
80
60
40
As resistors in radio and television receivers,
hazardous conditions such as smoking and
redheat can be completely prevented by the
proper choice of power resistors.
100 150 200 250 300 350
Ambient Temperature (°C)
DIMENSIONS
Unit: mm
STYLE
32±3
max.1.5
L
ød
W
H
PSM400-700
W
H
PSM7WS/17A
* 6mm, reduced solderability in this area
DIMENSION
Normal
Miniature
L
W
H
ød
PSM400
20±1.0
7.0±0.5
8.0±0.4
0.8±0.02
PSM500
25±1.0
7.0±0.5
8.0±0.4
0.8±0.02
PSM7WS
25±1.0
9.0±0.4
10.0±0.4
0.8±0.02
PSM700
38±1.0
7.0±0.5
8.0±0.4
0.8±0.02
PSM900
38±1.0
9.0±0.4
10.0±0.4
0.8±0.02
PSM11A
50±1.5
9.0±0.4
10.0±0.4
0.8±0.02
PSM17A
75±2.0
9.0±0.4
10.0±0.4
0.8±0.02
63
Note:
ELECTRICAL CHARACTERISTICS
STYLE
PSM400
PSM500
PSM7WS
Power Rating at 70°C
4W
5W
7W
Maximum working voltage
PxR
Voltage Proof on Insulation
2000V
Resistance Range
0.1Ω - 9.1KΩ
Operating Temp. Range
-55°C to +350°C
Temperature Coefficient
400±50ppm/°C
0.15Ω - 15KΩ
PSM700
PSM900
PSM11A
PSM17A
9W
11W
17W
0.51Ω - 47KΩ
0.91Ω - 82KΩ
0.33Ω - 33KΩ
Note: Special value is available on request
ENVIRONMENTAL CHARACTERISTICS
PERFORMANCE TEST
TEST METHOD
APPRAISE
Short Time Overload
IEC 60115-1 4.13
10 times rated power for 5 Sec.
±2.0%+0.05Ω
IEC 60115-1 4.7
In V-Block for 60 sec., test voltage as above table
No Breakdown
IEC 60115-1 4.8
Between -40°C to +155°C
By type
Insulation Resistance
IEC 60115-1 4.6
in V-block for 60 Sec.
>10,000MΩ
Solderability
IEC 60115-1 4.17
245±5°C for 3±0.5 Sec.
95% Min. coverage
Solvent Resistance of Marking
IEC 60115-1 4.30
IPA for 5±0.5 Min. with ultrasonic
No deterioration of
coatings and markings
Robustness of Terminations
IEC 60115-1 4.16
Direct load for 10 Sec. in the direction of the terminal leads
≥50N
Periodic-pulse Overload
IEC 60115-1 4.39
4 times RCWV 10,000 cycles (1 Sec. on, 25 Sec. off)
±2.0%+0.05Ω
Damp Heat Steady State
IEC 60115-1 4.24
40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV
±2.0%+0.05Ω
Endurance at 70°C
IEC 60115-1 4.25
70±2°C at RCWV (or Umax., Whichever less) for 1,000 Hr. (1.5Hr.on, 0.5Hr. Off) ±3.0%+0.05Ω
Temperature Cycling
IEC 60115-1 4.19
-55°C Room Temp. +155°C Room Temp. (5 cycles)
±2.0%+0.05Ω
Resistance to Soldering Heat
IEC 60115-1 4.18
260±3°C for 10±1 Sec., immersed to a point 3±0.5mm from the body
±2.0%+0.05Ω
Note: RCWV(Rated Continuous Working Voltage) = Power Rating x Resistance Value or Max. working voltage listed above, whichever less.
Revision: 2020
很抱歉,暂时无法提供与“PSM700KB-33R”相匹配的价格&库存,您可以联系我们找货
