ASP-135029-01
ASP-135029-01
    SAMTEC(申泰)
    VITA42SOCKETASSEMBLY
ASP-135029-01 数据手册
REVISION D DO NOT SCALE FROM THIS PRINT NOTES: 1. STANDARD PART SETUP AS ASP NOT AVAILABLE AS STANDARD. 2. C REPRESENTS A CRITICAL DIMENSION. 3. MAXIMUM BURR ALLOWANCE: .038 [.0015]. 4. MINIMUM PUSHOUT FORCE: 2.22N [.5LB]. 5. PARTS TO BE PACKAGED IN TRAYS. 35.50 1.398 REF ((35 POS x .800 [.0315]) + 7.50 [.300]) 32.32 1.272 REF 3 0.20 .008 "A" 70 02 "A" 2.05 .081 REF 3.36 .132 REF 5.60 .220 REF 01 0.800 .0315 (TYP) C1 (TOL NON-ACCUM) 31.13 1.226 69 6.00 .236 REF SECTION "A"-"A" C9 2.58±0.12 .101±.005 14.75±0.50 .581±.020 1 5 "B" C6 5.30 .209 REF 0.50 [.200] x 45° REF (TYP) 2 3.35 .132 REF 5.23 .206 C8 "B" 0.25 .010 REF (TYP) 33.80 1.331 C10 5.335 .2100 1.17 .046 .10[.004] 1.32 .052 REF 0.94 .037 REF 1.04 .041 REF +0.18 2 MAX SWAY (TYP) 30.80 1.213 REF +.007 5.41 - 0.13 .213 - .005 0.64 .025 REF 1.10 .043 REF C2 C3 C4 SECTION "B"-"B" 27.20 1.071 1.32 .052 REF 1.50 .059 REF 'C' DETAIL 'C' SCALE 8 : 1 C5 0.800 .0315 (TYP) (TOL NON ACCUM) ITEM NO. PART NUMBER QUANTITY MATERIAL 1 ERF8-035-05.0-DV-L 1.0000 VECTRA E130i, COLOR: BLACK 2 C-211-05.0-S 70.000 BeCu, 390 HT 3 WT-30-01-F 2.0000 BeCu, #25, 1/2 HT 4 TY-ASP127 1.0000 BLACK HIPS 5 K-500-300 .50000 POLYIMIDE FILM UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS. TOLERANCES ARE: DECIMALS .X: .3[.01] .XX: .13[.005] .XXX: .051[.0020] ANGLES 2 PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:1 PLATING: CONTACT AREA: .000030 GOLD OVER .000050 NICKEL REMAINDER: .000200 REF TIN OVER .000050 NICKEL LATCHES: .000003 GOLD OVER .000050 NICKEL c:\enterprisevault\DWG\MISC\MKTG\ASP-135029-01-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. ERF8 ASSEMBLY ASP-135029-01 BY: J. BROWNING 10/12/2007 SHEET 1 OF 2 ASP-135029-01 37.00 1.457 (KEEPOUT AREA) REVISION D 1.80 .071 (TYP) 27.20 1.071 CONNECTOR OUTLINE 0.800 .0315 (TYP) (TOL NON-ACCUM) 02 1.45±0.08 .057±.003 NPTH (2 PLCS) 70 69 5.60 .220 6.30 .248 (KEEPOUT AREA) CL 01 0.80 .031 (TYP) (TOL. NON-ACCUM) 2.24 .088 (2 PLCS) 70 CL 0.50 .020 (TYP) 27.20 1.071 02 5.60 .220 1.50 .059 33.80 1.331 0.83±0.05 .033±.002 PTH (2 PLCS) ( 1.58 [.062] PAD) TO BE SOLDERED USING PASTE-IN-HOLE TECHNOLOGY 33.80 1.331 30.80 1.213 1.10 .043 (TYP) 1.10 .043 (TYP) 01 69 0.50 .020 (TYP) RECOMMENDED STENCIL LAYOUT RECOMMENDED PCB LAYOUT "F" 'G' 11.87 .467 REF 2.36 .093 REF DETAIL 'G' SCALE 6 : 1 "F" LATCH ENGAGING VIEW SECTION "F"-"F" "E" 'H' DETAIL 'H' SCALE 6 : 1 11.54 .454 REF 2.03 .080 REF PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. "E" PIN ENGAGING VIEW SHEET SCALE: 3:1 SECTION "E"-"E" 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. ERF8 ASSEMBLY ASP-135029-01 BY: J. BROWNING 10/12/2007 SHEET 2 OF 2 c:\enterprisevault\DWG\MISC\MKTG\ASP-135029-01-MKT.SLDDRW
ASP-135029-01 价格&库存
很抱歉,暂时无法提供与“ASP-135029-01”相匹配的价格&库存,您可以联系我们找货
ASP-135029-01
  • 1+91.03777
  • 19+89.03831
  • 38+87.12216
库存:4
