DF3AA-12EP-2C
DF3AA-12EP-2C
    HRS(广濑)
    CONN PLUG HOUSING 12POS 2MM
DF3AA-12EP-2C 数据手册
Applicable standard Operating temperature range -30C to + Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents. Voltage Current Rating 1 Applicable contact 85C(Note 1) 250V AC AWG 24 : 3A AWG 26 : 2A AWG 28 : 1A DF3-EP2428PCF(A) DF3-EP2428PC(A) Storage temperature range -10C to + 60C 30V AC AWG 24 : 3A AWG 26 : 2A 1 AWG 28 : 1A DF3-*S-2C UL1061,1007 AWG24 to 28 UL・CSA Voltage Rating Current Applicable connector Applicable cable Specifications Item Test method Requirements QT AT X X X X X - X - X - X - X - X - Construction General examination Visually and by measuring instrument. Marking Confirmed visually. According to drawing. Electric characteristics Insulation resistance 500V DC. 1000M MIN. Voltage proof 650V AC for 1 min. No flashover or breakdown. Mechanical characteristics Vibration Shock Frequency 10 to 55 Hz, single amplitude 0.75 mm, at 2 h, for 3 directions. 2 490 m/s duration of pulse 11 ms at 3 times for 3 directions. ① No electrical discontinuity of 1s. ② No damage, crack or looseness of parts. Environmental characteristics Rapid change of temperature Damp heat (Steady state) △ count Temperature -55→ 5 to 35→+85→ 5 to 35 c ① Insulation resistance: 1000M MIN. Time 30→ 5 to 15 → 30→ 5 to 15 min ② No damage, crack or looseness of parts. Under 5 cycles. Exposed at 40 ± 2 c, 90 to 95 , 96 h. ① Insulation resistance: 1000M MIN. ② No damage, crack or looseness of parts. description of revisions 1 2 DIS-H-00001155 Remarks Note 1:Including the temperature rise by current. designed MI.SAKIMURA Unless otherwise specified , refer to IEC 60512. Note QT:Qualification Test FORM HD0011-2-1 AT:Assurance Test X:Applicable Test Part no. Hirose electric co., ltd. Code no. date TS.FUKUSHIMA 15.12.04 Approved KJ.KATAYOSE 05.01.05 Checked KI.AKIYAMA 05.01.05 Designed TH.ARAI 05.01.05 Drawn TH.ARAI 05.01.05 Drawing no. Specification sheet checked ELC-162399-00-01 DF3AA-*EP-2C CL543 1 △ 1/1
DF3AA-12EP-2C 价格&库存
很抱歉,暂时无法提供与“DF3AA-12EP-2C”相匹配的价格&库存,您可以联系我们找货
