2mm Pitch Connector Directly Mounted on Board
Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
DF4 Series
B202
■Features
1. Cost Saving for Header
Thanks to the insertion/extraction socket and the harness product at
the both connector edges, one of two headers necessary at both edge
sockets can be saved without losing the function to separate
individual boards.
2. Miniature and Multiple Contacts
The miniature connector has broad variations in contact number.
Board mounting height :
Maximum contact number :
4.3mm (Crimping Single row )
32 contacts (Crimping Double row )
3. Board Pre-fixed Mechanism
The insertion state to the board is a light crimping, which enables the
pre-fixed process to the board.
Height 4.3mm
■Applications
Note PC, Small business equipment
Board pre-fixed mechanism
DF4 Series●2mm Pitch Connector Directly Mounted on Board
■Product Specifications
Current rating
Crimping
Cable Size
(Note 1)
Rating
Voltage rating
: 3A
Operating Temperature Range
-30 to +85ç(Note 1)
AWG 26
: 2A
Operating Moisture Range
-40 to 80%
AWG 28
: 1A
Storage Temperature Range
-10 to +60ç(Note 2)
Storage Moisture Range
-40 to 70%
250V AC
Crimping
Item
AWG 24
Specification
Condition
1. Insulation Resistance
1000M ohms Min
500V DC
2. Withstanding voltage
No flashover or insulation breakdown.
650V AC/1 minute
3. Crimping Area Resistance 30m ohms Max.
100mA
4. Vibration
Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2
No damage, cracks, or parts looseness.
hours in each of the 3 directions.
5. Humidity (Steady state) Contact resistance: 30m ohms Max Insulation resistance:500M ohms Min
96 hours at temperature of 40ç and humidity of 90% to 95%
Contact resistance: 30m ohms Max Insulation resistance: 1000M ohms Min Temperature -55 ➝ 5 to 35 ➝ +85 ➝ -5 to 35ç
6. Temperature Cycle
-30 ➝ 5 to 15 ➝ 30
time
➝ -5 to 15 min under
5 cycles.
7. Resistance to Soldering heat No deformation of components affecting performance.
Manual soldering: 300ç for 3 seconds
Flow: 250ç for 10 seconds
Note 1: The rated current will be changed according to cable sizes for use.
Note 2: Includes temperature rise caused by current flow.
Note 3: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and
Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation.
Note 4: Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for
a specific part number shown.
■Material
Product
Part
Material
Finish
Remarks
Crimping Plug
Insulator
Polyamide
Black
UL94V-0
Crimping Contact for Plug
Contact
Brass
Tin plating
■Ordering Information
●Connector
DF4
q
- * P - 2 C
w
e
r
t
q Series Name: DF4
r Contact Pitch: 2mm
w Number of Contact: 2 to 15, 4 to 32
t Connection Type
e Connector Type
C: Crimping socket
P: Single row plug
DP: Double row plug
●Contact
DF4
- 2428- PCF
q
q Applicable cable size
2428 : AWG24 to 28
w
w Packaging Type
PCF: Plug contact/Reel
PC: Plug contact/Bag
B203
■Single Row Crimping Plug
Photo: Contact insertion state.
●Applicable Through-hole Diameter : Ø0.8+0.1
+0
Unit:mm
Part Number
CL No.
Number of Contacts
A
B
Part Number
CL No.
Number of Contacts
A
B
DF4- 2P-2C
544-0003-4
2
04.5
02.0
RoHS
DF4- 9P-2C
544-0010-0
09
18.5
16.0
DF4- 3P-2C
544-0004-7
3
06.5
04.0
DF4-10P-2C
544-0011-2
10
20.5
18.0
DF4- 4P-2C
544-0005-0
4
08.5
06.0
DF4-11P-2C
544-0012-5
11
22.5
20.0
DF4- 5P-2C
544-0006-2
5
10.5
08.0
DF4-12P-2C
544-0013-8
12
24.5
22.0
DF4- 6P-2C
544-0007-5
6
12.5
10.0
DF4-13P-2C
544-0014-0
13
26.5
24.0
DF4- 7P-2C
544-0008-8
7
14.5
12.0
DF4-14P-2C
544-0015-3
14
28.5
26.0
DF4- 8P-2C
544-0009-0
8
16.5
14.0
DF4-15P-2C
544-0016-6
15
30.5
28.0
Yes
RoHS
Yes
Note 1.The quantity at the specific No. "None" is delivered per bag (100pcs.). If needed, please order the products per bag.
■Crimping Contact
Part Number
CL No.
Packaging Type
Quantity
Finish
DF4-2428PCF(05)
544-0020-3-05
Reel
10,000
Tin plating
DF4-2428PC(05)
544-0021-6-05
Bag
100
Tin plating
RoHS
Yes
●Applicable Cable (Tin plating Annealed copper wire)
Conductor Size
Recommended Cable
AWG24 (11 cores./0.16mm)
AWG 26 (7cores./0.16mm)
AWG 28 (7cores./0.127mm)
UL1061
Jacket Diameter
Ø0.75 to Ø1.2mm
UL1061/1007
Note:If other cables are used instead of the applicable cable, contact Hirose sales
department.
● Strip Length: 1.3 to 1.9mm
BApplicable Crimping Tool
Type
Applicator
Press Main Unit
Manual Crimping Tool
Extraction Tool
CL No.
Applicable Contact
AP105-DF4-2428P
Part Number
901-4539-0
DF4-2428PCF(05)
CM-105
901-0005-4
DF4-TA2428HC
550-0173-6
DF4-2428PC(05)
DF-C-PO (B)
550-0179-2
DF4-2428PCF(05)
Note: If any trouble has occurred due to other tools, which are not designated by Hirose,
Hirose won't guarantee any products.
B204
■Double Row Crimping Plug
● Applicable Through-hole Diameter Ø0.9±0.05
Note:The dip side may be deviated according to the cable thickness and the crimping contact bent up/down.
Unit:mm
Part Number
CL No.
Number of Contacts
A
B
DF4-04DP-2C
544-0078-3
04
04.8
02.0
DF4-06DP-2C
544-0079-6
06
06.8
04.0
DF4-08DP-2C
544-0080-5
08
08.8
06.0
DF4-10DP-2C
544-0081-8
10
10.8
08.0
DF4-12DP-2C
544-0082-0
12
12.8
10.0
DF4-14DP-2C
544-0083-3
14
14.8
12.0
DF4-16DP-2C
544-0084-6
16
16.8
14.0
DF4-18DP-2C
544-0085-9
18
18.8
16.0
DF4-20DP-2C
544-0086-1
18.0
DF4-22DP-2C
544-0087-4
22
22.8
20.0
DF4-24DP-2C
544-0088-7
24
24.8
22.0
DF4-26DP-2C
544-0089-0
26
26.8
24.0
DF4-28DP-2C
544-0090-9
28
28.8
26.0
DF4-30DP-2C
544-0091-1
30
30.8
28.0
DF4-32DP-2C
544-0092-4
32
32.8
30.0
RoHS
YES
B205
BPrecautions
1. Recommended
Flow: 250ç for 3 seconds
1. Soldering Condition
Manual soldering: 290±10ç for 2 seconds
■ If the cable neighboring the connector is bent and unstraightened, secure a large bending radius because the
Jacket will be broken by the solder heat and the contact wire will be exposed.The Jacket in this part will be tore.
■ After the soldering process. If a stress is applied to the cable in the state where the connector and the
cable has heat inside, the Jacket hold area will be loosen. Therefore, carry out the post-soldering
operation after the connector has returned to the room temperature..
B206
2. Cleaning Condition
Refer to Nylon Connector Use Hand book.
Don't use a solvent such ass trichloroethylene which invades the cable Jacket. In addition, avoid heat
cleaning by a solvent.
3. Connection Condition
Refer to the Nylon Connector Use Hand book.
很抱歉,暂时无法提供与“DF4-18DP-2C”相匹配的价格&库存,您可以联系我们找货
