7.92mm Contact Pitch High-Current Connectors for Internal
Power Supplies (UL, C-UL and TÜV Listed)
DF22 Series
Positive
Lock
Completely
enclosed
locking system
Apr.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Protection from
shorts circuits
between adjacent
contacts
Fig.1
■Features
1. Rated up to 30A
Single position connector can carry current of 30A with 10
AWG conductor. Please refer to Table #1 for current ratings for
multi-position connectors using other conductor sizes.
Keying for multiple use
●R Type (Guide key : right side, Color : black)
2. Positive Locking Function
Reliable interior lock protects mated connectors from
accidental disconnection. (Fig.1)
3. Prevention of Incorrect Connections
To prevent incorrect connection when using multiple connectors
having the same Number of contacts, 3 product types having
different mating configurations are available. (Fig.2)
4. Molded-in contact retention tabs
Handling of terminated contacts during the crimping is
easier and avoids entangling of wires, since there are
no protruding metal tabs.
●Standard Type (Guide key : inside, Color : natural)
5. Prevention of incorrect board placement
Built-in posts assure correct connector placement and
orientation on the board.
6. Supports resin sealing
Allows potting up to 10mm.
7. Prevention of Short Circuits Between
Adjacent Contacts
●L Type (Guide key : left side, Color : red)
Each Contact is completely surrounded by the housing
wall electrically isolating it from adjacent contacts.
8. Increased Retention Force of Crimped
Contacts
Improved pull-out force design.
9. Full Line of Crimp Socket Contacts
Hirose has released DF22C-*S-7.92C which has easy
to push/release latch design. and DF22B-*S-7.92C/
DF22C-*S-7.92C which has improved electrical
insulation properties.
10. In-line Connections
Wire-to-wire connection is also available. Space is saved
with 2-row (2×2) layout for 4 pos.
*The image on the left show header (the board dip
side), the image on the right show the socket
(cable side).
*The guide key position is indicated in position
facing the mating surface of the header.
Fig.2
11. UL, C-UL, and TÜV Certified.
12. Glow Wire compliance (Compliant with IEC 60695-2-11)
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2020.1⑧
1
DF22 Series●7.92mm Contact Pitch High-Current Connectors for Internal Power Supplies (UL, C-UL and TÜV Listed)
■Product Specifications
No. of contacts
1
Current
2
rating
3
(Note 1)
4
Ratings
5
10 AWG
30A
25A
25A
22A
22A
Voltage
rating
AC/DC
14 AWG
20A
18A
18A
15A
15A
Current rating of
UL Standards
(Ambient temperature : 25ç)
(Note 4)
No. of Contacts
1
2
3
4
5
10 AWG
43A
38A
38A
33A
33A
16 AWG
15A
15A
15A
13A
13A
1000V
Current Rating
See table below
See table above (Δt=30ç)
See table above
UL
C-UL
TÜV
12 AWG
25A
20A
20A
18A
18A
12 AWG
38A
32A
32A
26A
26A
Operating temperature range -55ç to 85ç (Note 2)
Operating humidity range 20% to 80%
Storage temperature range -10ç to 60ç (Note 3)
Storage humidity range 40% to 70% (Note 3)
UL/C-UL/TÜV File No. and Recognition No.
UL
: E52653
C-UL
: E52653
TÜV
: R9950703
Voltage Rating
AC/DC 600V
AC/DC 600V
AC/DC 600V
14 AWG
26A
23A
23A
22A
22A
16 AWG
21A
21A
21A
19A
19A
Item
1. Contact Resistance
2. Insulation Resistance
3. Withstand Voltage
4. Contact Insertion and Extraction Forces
5. Durability
6. Vibration Resistance
7. Shock Resistance
8. Moisture-Resistance
9. Temperature cycles
Specifications
Conditions
No more than 5mø
Measured at 1mA and no higher than 20mV
No less than 1,000Mø
Measured at DC=1000V
No flashover or breakdown
AC 2500 V is applied for 1 minute.
0.3N min., 5N max
Measured with a steel pin of 1.6×0.8±0.002 thickness
Contact resistance : no more than 10mø
30 mating cycles
No electrical discontinuity of 1μs or greater Frequency 10-55 Hz, half amplitude 0.75mm, 10 times in each of the three directions
No electrical discontinuity of 1μs or greater Accelerated velocity : 490 m/s2 for 11 ms, half-sine wave in 3 directions, 3 times for each direction
Temperature : 40 ± 2ç ; humidity : 90 to 95%, left as it is for 96 hours
(-55ç : 30 minutes➝ 5 to 35ç : 5 minutes➝ 85ç : 30 minutes➝ 5 to 35ç : 5 minutes) for 5 cycles
The resin parts should withstand the
Flow : 260ç, 10 sec
10. Solder heat Resistance
temperature and resist melting.
Hand soldering : temperature of soldering iron at 300ç for 3 seconds
Note 1 : This is the maximum current rating while all pins are powered or used as all power lines. If you split the current over multiple
lines, please factor in your own safety margin.
Note 2 : Includes temperature rise caused by current flow.
Note 3 : The storage condition refers to long-term storage of the product on the shelf before assembly. Please use the operating
temperature for temporary storage such as pre-assembly and during shipping.
Note 4 : Indicates the current that corresponds to the RTI value (temperature at which performance is halved) of the resin when
the ambient temperature is 25ç. When referring to the rated current value of UL standard, please evaluate the product
in the final set to confirm that there are no problems in use.
■Materials / Finish
Product
Sockets
Crimp contacts
Part
Material
Finish
Insulator
Polyamide
Color : Natural white
(Note)
Contacts
High conductivity copper alloy
Tin-lead plated or Gold plated
Insulator
Polyamide (Glass reinforced)
Color : Natural beige
(Note)
Headers
Contacts
Tin-copper plated or Gold plated
Note : Standard Color, colors of the differing coupling forms are black for DF22R and red for DF22L.
Remarks
UL94V-0
---------UL94V-0
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Socket, Header
●Contacts
DF22 B L - 2 S - 7.92 C (**)
q
w
e
r
t
u
q
q Series name : DF22
w Form Type
r Number of contacts : 1 to 5
t Connector type
Sockets
Blank : Standard height, standard lock (Type I)
B : Long type, standard lock (Type III)
C : Long type, ergonomic lock (Type IV)
In-line Plugs
Blank : With panel stop
A : Without panel stop
e Guide key type
S
: Socket
DS
: Double-row socket
P
: Header
EP
: In-line plug
DEP
: Double-row in-line plug
RS/P
: Retainer
y Contact pitch : 7.92 mm
u Type of housing
C
: Crimp housing
DSA
: Straight header
DS
: Right-angle header
No letter : Retainer
Blank : Inside (Color: natural)
R : Right side (Color: black)
L : Left side (Color: red)
2
y
DF22 A - 1416 SCF A
i
o
!0
!1
i Applicable Cable
Blank : UL1430
A
: UL1015
o Applicable Conductor
1416 : 14 to 16 AWG
1012 : 10 to 12 AWG
!0 Packaging
SCF : Socket contacts / reel
SC : Socket contacts / pack
PCF : In-line plug contacts / reel
PC : In-line plug contacts / pack
!1 Plating specifications
A
: Gold plated
Blank : Tin plated
■Diagram of Connector Mating Combinations
Gold-plated products are standard for this product in order to support high current. Be sure to select a gold-plated
product for use in an environment with temperature changes and vibration.
●Wire-to-Board Connection
Crimp socket (Note 2)
DF22#-*S-7.92C
Crimp contact for Socket
DF22(A)-*SC(F)(A)
Retainer (Note 1)
DF22#-*RS/P-7.92
Straight pin header (Note 2)
DF22#-*P-7.92DSA
DF22#-*RS/P-7.92
DF22#-*S-7.92C
Right angle pin header (Note 2)
DF22#-*P-7.92DS
●In-line or Wire-to-Wire Connection
In-line plug
DF22#-*EP-7.92C
Crimp contact for in-line plug
DF22(A)-*PC(F)(A)
Retainer (Note 1)
DF22B/C-*RS/P-7.92
DF22#-*EP-7.92C
DF22B/C*RS/P-7.92
Note 1 : Since this product uses thick wires, a larger load is applied to the connector when inserting/extracting or routing the wires.
Please use a retainer to reduce the load on the connector.
Crimp socket
Applicable Retainer
DF22-*S-7.92C
DF22-*RS/P-7.92
DF22B-*S-7.92C
DF22B/C-*RS/P-7.92
DF22C-*S-7.92C
In-line plug
Applicable Retainer
DF22-*EP-7.92C
DF22B/C-*RS/P-7.92
DF22A-*EP-7.92C
Note 2 : The key difference (L, R) product matches the mating connector of the same key (L, R).
3
■Crimp Sockets (Standard Height Type)
Shown with terminated and contacts installed.
1 Pos.
A
2 to 5 Pos.
8
B
Type 1
Standard lock
7.7
Type 1
Standard lock
10.4
7.7
P=7.92
(11.55)
No. of contacts
indicator
Cavity No.
A
(11.55)
14.5
Contact No. 1
Polarity
mark
1
A
Cavity No.
■ Type I
Height : Standard type, Standard lock
Note : The part number and HRS No. have changed to reflect the
product form change of the 2 to 5 pos. types.
Standard Type (Guide Key : Inside, Color : White) Unit : mm
Part No.
DF22-1S-7.92C(28)
DF22-2S-7.92C(28)
DF22-3S-7.92C(28)
DF22-4S-7.92C(28)
DF22-5S-7.92C(28)
HRS No.
680-1012-2 28
680-1004-4 28
680-1005-7 28
680-1006-0 28
680-1007-2 28
No. of Contacts
1
2
3
4
5
A
B
8.00 ----15.50 7.92
23.42 15.84
31.34 23.76
39.26 31.68
R Type (Guide Key : Right Side, Color : Black)
Part No.
DF22R-1S-7.92C(28)
DF22R-2S-7.92C(28)
DF22R-3S-7.92C(28)
DF22R-4S-7.92C(28)
DF22R-5S-7.92C(28)
HRS No.
680-1026-7 28
680-1027-0 28
680-1028-2 28
680-1029-5 28
680-1030-4 28
No. of Contacts
1
2
3
4
5
L Type (Guide Key : Left Side, Color : Red)
Part No.
DF22L-1S-7.92C(28)
DF22L-2S-7.92C(28)
DF22L-3S-7.92C(28)
DF22L-4S-7.92C(28)
DF22L-5S-7.92C(28)
HRS No.
680-1031-7 28
680-1032-0 28
680-1033-2 28
680-1034-5 28
680-1035-8 28
No. of Contacts
1
2
3
4
5
Unit : mm
A
B
8.00 ----15.50 7.92
23.42 15.84
31.34 23.76
39.26 31.68
Unit : mm
A
B
8.00 ----15.50 7.92
23.42 15.84
31.34 23.76
39.26 31.68
Note 1 : Bag packaging (100 pcs/pack). Order by number of packs.
Note 2 : Every even number position has a different locking design.
4
3
No. of contacts
indicator
■Crimp Sockets (Height, Long Type)
1 Pos.
2 to 5 Pos.
A
B
Type 4
Height : Long type,
Enhanced
ergonomic lock
Type 3
Height : Long type,
Standard lock
Contact No. 1
(12.75)
23
No. of contacts
indicator
Cavity No.
(12.75)
(11.55)
14.5
7.7
Type 4
Height : Long type,
user-friendly operation
10.4
7.7
P=7.92
8
23
14.5
Polarity
mark
A
A
1
Cavity No.
■ Type III
Height : Long type, Standard lock
HRS No.
680-1097-5
680-1098-8
680-1099-0
680-1100-8
No. of Contacts
2
3
4
5
No. of contacts
indicator
■ Type IV
Height : Long type, Enhanced ergonomic lock
Part No.
DF22B-2S-7.92C
DF22B-3S-7.92C
DF22B-4S-7.92C
DF22B-5S-7.92C
3
A
B
15.50 7.92
23.42 15.84
31.34 23.76
39.26 31.68
Part No.
DF22C-1S-7.92C
DF22C-2S-7.92C
DF22C-3S-7.92C
DF22C-4S-7.92C
HRS No.
680-1101-0
680-1102-3
680-1103-6
680-1104-9
No. of Contacts A
B
1
8.00 ----15.50 7.92
2
23.42 15.84
3
4
31.34 23.76
R Type (Guide Key : Right Side, Color : Black) Unit : mm
Part No.
DF22CR-3S-7.92C
HRS No.
680-1130-9
No. of Contacts A
B
3
23.42 15.84
Part No.
DF22CL-1S-7.92C
DF22CL-3S-7.92C
HRS No.
680-1133-7
680-1135-2
Unit : mm
No. of Contacts A
B
1
8.00 ----23.42 15.84
3
5
■Straight Header
2 to 5 Pos.
A
12.45
9.7
Cavity No.
12.45
1.5
4.05
9.3
A
B
No. of contacts
indicator
Cavity No.
3
10.8
A
1 Pos.
Contact No.1
1.4
9
0.8
3.7
2.3
3.2
3.7
18.1
18.1
Polarity
mark
8.7
3.9
10.8
3.2
1
No. of contacts
indicator
Ø1.5
0.8
3.45
4.35
[Specification number]
(06) : Gold plated, bag packaging
(26) : Gold plated tray packaging (only 1 pos)
(05) : Tin-copper plated bag packaging
(25) : Tin-copper plated tray packaging (only 1 pos)
Unit : mm
B Bag Packaging Tray Packaging Gold plated Tin-copper plated
7.92
15.84
23.76
31.68
Part No.
DF22R-1P-7.92DSA(**)
DF22R-2P-7.92DSA(**)
DF22R-3P-7.92DSA(**)
DF22R-4P-7.92DSA(**)
DF22R-5P-7.92DSA(**)
HRS No. No. of Contacts
680-1036-0 **
1
680-1037-3 **
2
680-1038-6 **
3
680-1039-9 **
4
680-1040-8 **
5
A
----17.22
25.14
33.06
40.98
B
----7.92
15.84
23.76
31.68
Unit : mm
BRecommended PCB Layout
(Board thickness : 1.6±0.1)
1 Pos.
11.1±0.1
8.5
2.5 +0.1
2-R0.5
2 to 5 Pos.
Note 2 : Tray packaging (150 pcs/tray). Order by number of 150.
Note 3 : Every even number position has a different locking design.
6
Unit : mm
7.92
15.84
23.76
31.68
A
----17.22
25.14
33.06
40.98
680-1041-0 **
1
680-1042-3 **
2
680-1043-6 **
3
680-1044-9 **
4
680-1045-1 **
5
Part No.
DF22L-1P-7.92DSA(**)
DF22L-2P-7.92DSA(**)
DF22L-3P-7.92DSA(**)
DF22L-4P-7.92DSA(**)
DF22L-5P-7.92DSA(**)
+0.1
--0.2
3.2±0.05
A
----17.22
25.14
33.06
40.98
3.4±0.1
680-1013-5 **
1
680-1014-8 **
2
680-1015-0 **
3
680-1016-3 **
4
680-1017-6 **
5
E2,#.'¤%#%*
7¤%#%*
Part No.
DF22-1P-7.92DSA(**)
DF22-2P-7.92DSA(**)
DF22-3P-7.92DSA(**)
DF22-4P-7.92DSA(**)
DF22-5P-7.92DSA(**)
1+0.1
Standard Type (Guide Key : Inside, Color : Natural Beige)
A
B
C
P=7.92
1.6
0.8
15.2
24
17.6
9
Contact No.1
Ø1.5
3.5
12.2
9.45
■Right Angle Header
A
5
Cavity No.
No. of contacts
indicator
680-1008-5 **
2
680-1009-8 **
3
680-1010-7 **
4
680-1011-0 **
5
A
19.80
27.72
35.64
43.56
B
C
15.00 7.92
(36)
(35)
22.92 15.84
(06)
(05)
30.84 23.76
(06)
(05)
38.76 31.68
(06)
(05)
Part No.
DF22R-2P-7.92DS(**)
DF22R-3P-7.92DS(**)
DF22R-4P-7.92DS(**)
DF22R-5P-7.92DS(**)
680-1018-9 **
2
680-1019-1 **
3
680-1020-0 **
4
680-1021-3 **
5
A
19.80
27.72
35.64
43.56
Unit : mm
B
C
15.00 7.92
(06)
(05)
22.92 15.84
(06)
(05)
30.84 23.76
(06)
(05)
38.76 31.68
(06)
(05)
Part No.
DF22L-2P-7.92DS(**)
DF22L-3P-7.92DS(**)
DF22L-4P-7.92DS(**)
DF22L-5P-7.92DS(**)
680-1022-6 **
2
680-1023-9 **
3
680-1024-1 **
4
680-1025-4 **
5
A
19.80
27.72
35.64
43.56
5
1.2
[specification number]
(06), (36) : Gold plated
(05), (35) : Tin-copper plated
B±0.05
2-
Unit : mm
B
C
15.00 7.92
(06)
(05)
22.92 15.84
(06)
(05)
30.84 23.76
(06)
(05)
38.76 31.68
(06)
(05)
3.7
C±0.05
Ø1
.6
P=7.92±0.05
+0
0 .1
15.2±0.05
Part No.
DF22-2P-7.92DS(**)
DF22-3P-7.92DS(**)
DF22-4P-7.92DS(**)
DF22-5P-7.92DS(**)
1
0.
+ 0
5
Ø1
■In-line Plug
1 Pos.
2, 3 Pos.
A
B
No. of contacts
indicator
A
34.95
No. of contacts
indicator
Cavity No.
Contact No.1
9.97
12.72
12.72
9.3
34.95
Standard Type (Guide Key : Inside, Color : Natural Beige) Unit : mm
1
10.5
3
3
Part No.
DF22A-1EP-7.92C
DF22A-2EP-7.92C
DF22A-3EP-7.92C
HRS No.
680-1053-0
680-1054-2
680-1055-5
No. of Contacts
1
2
3
A
9.30
18.00
26.00
Unit : mm
B
----7.92
15.84
Cavity No.
A
2
Polarity
mark
1
Part No.
DF22AR-2EP-7.92C
DF22AR-3EP-7.92C
HRS No.
680-1069-0
680-1070-9
No. of Contacts
2
3
A
18.00
26.00
Unit : mm
B
7.92
15.84
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
DF22AL-2EP-7.92C 680-1074-0
2
18.00
7.92
7
■In-line Plug (Panel Lock Type)
A
3
B
No. of contacts
indicator
34.95
20.7
10.5
Cavity No.
A
3
20.7
A 1
Contact No.1
9.97
12.72
8.12
No. of contacts
indicator
Cavity No.
34.95
3
2, 3 Pos.
9.3
12.72
1 Pos.
Polarity
mark
3
16.3
Part No.
DF22L-1EP-7.92C
DF22L-2EP-7.92C
HRS No.
680-1063-3
680-1064-6
No. of Contacts
A
1
9.30
17.22
2
Unit : mm
B
C
----- 16.30
7.92 24.22
13.02
3.5±0.1
2, 3 Pos.
Panel thickness
2.0
1.6
1.2
0.8
X
0.48
0.96
1.44
1.92
(C-0.5-X) +0.1
(A+0.4) +0.1
11±0.2
3.5±0.1
4.16 +0.1
Unit : mm
No. of Contacts
A
B
C
17.22 7.92 24.22
2
25.14 15.84 32.14
3
9.6+0.1
4.835 0
HRS No.
680-1059-6
680-1060-5
(15.8-X) +0.1
Part No.
DF22R-2EP-7.92C
DF22R-3EP-7.92C
1 Pos.
10.27
BPanel Cutout
13.02 +0.1
Unit : mm
No. of Contacts
A
B
C
9.30 ----- 16.30
1
17.22 7.92 24.22
2
25.14 15.84 32.14
3
+0.1
HRS No.
680-1048-0
680-1049-2
680-1050-1
1
C
Part No.
DF22-1EP-7.92C
DF22-2EP-7.92C
DF22-3EP-7.92C
2
Note 1 : Please ensure when mating this connector
that the tapered portions of the panel are
facing outward towards the receptacle
connector’s mating interface.
8
■In-line Double-row Socket
20.14
17.44
15.5
7.92
23
14.5
Standard lock
Part No.
DF22B-4DS-7.92C
HRS No.
680-1142-8
No. of Contacts
4
Unit : mm
Lock type
Standard lock
(21.29)
Polarity
mark
Contact No.1
1
3
2
4
A
Part No.
DF22BR-4DS-7.92C
HRS No.
680-1156-2
No. of Contacts
4
Unit : mm
Lock type
Standard lock
Cavity No.
No. of contacts
indicator
Part No.
DF22BL-4DS-7.92C
HRS No.
680-1161-2
No. of Contacts
4
Unit : mm
Lock type
Standard lock
Note : Bag packaging (100 pcs/pack). Order by number of packs.
■In-line Double-row Plug
Panel lock type
Without panel lock function
17.22
7.92
17.22
7.92
3
21.79
19.04
21.79
19.04
3
Contact No.1
Contact No.1
10.5
34.95
20.7
4
A
3
1
4
2
10.5
No. of contacts
indicator
Cavity No.
34.95
20.7
24.22
No. of contacts
indicator
Cavity No.
4
A
3
1
4
2
Part No.
DF22-4DEP-7.92C
DF22A-4DEP-7.92C
HRS No.
680-1051-4
680-1056-8
Unit : mm
No. of Contacts
Connector type
4
Panel lock type
4
Part No.
DF22R-4DEP-7.92C
HRS No.
680-1170-3
No. of Contacts
4
Unit : mm
Connector type
Panel lock type
6.3±0.1
19.76 +0.1
11±0.2
9.62+0.1
Unit : mm
No. of Contacts
Connector type
4
Panel lock type
4
19.34 +0.1
HRS No.
680-1175-7
680-1189-1
Polarity
mark
(23.72-X) +0.1
Part No.
DF22L-4DEP-7.92C
DF22AL-4DEP-7.92C
Polarity
mark
BRecommended Panel Cutout
(Panel mount type)
22.09 +0.1
Panel thickness
2.0
1.6
1.2
0.8
X
0.48
0.96
1.44
1.92
17.62 +0.1
9
■Retainer
For Standard height, standard lock (Type I)
For Long type, standard lock (Type III)
Long type, enhanced ergonomic lock (Type IV)
A
B
A
B
2
8.6
3.2
3.2
Cavity No.
Cavity No.
A5
Part No.
DF22-1RS/P-7.92
DF22-2RS/P-7.92
DF22-3RS/P-7.92
DF22-4RS/P-7.92
DF22-5RS/P-7.92
Applicable Socket
7.92
11.6
2
7.92
4
3
2
1
No. of contacts
indicator
HRS No.
No. of Contacts
680-1213-4
1
680-1209-7
2
680-1210-6
3
4
680-1211-9
5
680-1212-1
Unit : mm
A
B
7.04 ----15.50 7.92
23.42 15.84
31.34 23.76
39.26 31.68
A5
Part No.
DF22B/C-1RS/P-7.92
DF22B/C-2RS/P-7.92
DF22B/C-3RS/P-7.92
DF22B/C-4RS/P-7.92
DF22B/C-5RS/P-7.92
DF22-*S-7.92C For Standard height, standard lock
(Type I)
* indicates number of contacts.
packs.
Applicable Socket
4
HRS No.
680-1214-0
680-1200-2
680-1201-5
680-1202-8
680-1203-0
3
2
1
No. of contacts
indicator
No. of Contacts
1
2
3
4
5
Unit : mm
A
B
7.04 ----15.50 7.92
23.42 15.84
31.34 23.76
39.26 31.68
DF22B-*S-7.92C For Long type, standard lock (Type III)
DF22C-*S-7.92C Long type, enhanced ergonomic lock (Type IV)
DF22-*EP-7.92C
DF22A-*EP-7.92C
Note 2 : When connecting retainer into the plug housing, please
note the cavity numbers will line up numerieally, but the
retainer cavity numbers will be upside down compared to
the plug cavity numbers.
10
■Crimp Contact for Socket
BReel Contact ※Applicable Tool : Applicator
For 14 to 16 AWG
Part No.
4.7
2.8
3.8
DF22-1416SCFA
680-1085-6
DF22-1416SCF
680-1000-3
3 0.8
1.6 1.5 2.7 1.4
20.8
17
DF22A-1416SCFA 680-1087-1
DF22A-1416SCF
680-1002-9
Ø1
.5
DF22A-1012SCFA 680-1106-4
P=15.5
t=0.3
DF22A-1012SCF
Part No.
4.7
2.8
4 0.8
1.6 1.3 2.9 1.4
21.8
17
3.8
Ø2
680-1089-7
UL Wire
style size
14 AWG
Gold plated 1430
16 AWG
14 AWG
Tin plated 1430
16 AWG
14 AWG
Gold plated 1015
16 AWG
14 AWG
Tin plated 1015
16 AWG
10 AWG
Gold plated 1015
12 AWG
10 AWG
Tin plated 1015
12 AWG
Applicable cable
Wire
Sectional
Construction
area
2.18mm2
41cores./0.26mm
26cores./0.254mm 1.32mm2
2.18mm2
41cores./0.26mm
2.18mm2
41cores./0.26mm
2.18mm2
41cores./0.26mm
104cores./0.26mm 5.52mm2
65cores./0.26mm
3.45mm2
65cores./0.26mm
3.45mm2
Jacket Quantity
diameter
2.4 to 3.0mm 2500
2.4 to 3.0mm 2500
3.0 to 3.8mm 2000
3.0 to 3.8mm 2000
3.6 to 4.9mm 2000
3.6 to 4.9mm 2000
BBulk Contact (100/pack) ※Applicable Tool : Manual ID tool
For 10 to 12 AWG
t=0.4
P=16.5
HRS No. Finish
DF22-1416SCA
DF22-1416SC
UL
style
680-1190-0 Gold plated 1430
680-1001-6 Tin plated 1430
DF22A-1416SCA
680-1191-0 Gold plated 1015
DF22A-1416SC
680-1003-1 Tin plated 1015
DF22A-1012SCA
680-1107-7 Gold plated 1015
DF22A-1012SC
680-1090-6 Tin plated 1015
Wire
size
16 AWG
16 AWG
14 AWG
16 AWG
14 AWG
16 AWG
10 AWG
12 AWG
10 AWG
12 AWG
Applicable cable
Wire
Sectional
Construction
area
2.18mm2
41cores./0.26mm
2.18mm2
41cores./0.26mm
65cores./0.26mm
3.45mm2
65cores./0.26mm
3.45mm2
Jacket
diameter
2.6mm
2.6mm
3.7mm
3.2mm
3.7mm
3.2mm
4.69mm
4.04mm
4.69mm
4.04mm
Note 1 : The conductor of applicable wire is tin plated annealed copper.
Note 2 : When using other than the applicable wire, contact your nearest
Hirose representative.
●Strip length
3.5 to 4.5mm
■Crimp Contact for In-line Plug
4.7
2.8
1.6
Part No.
DF22-1416PCFA
680-2002-4
DF22-1416PCF
680-1078-0
1.4
DF22A-1416PCFA 680-1194-0
1416
1.5 2.7
DF22A-1416PCF
●Strip length
3.5 to 4.5mm
680-1079-3
UL Wire
style size
14 AWG
Gold plated 1430
16 AWG
14 AWG
Tin plated 1430
16 AWG
14 AWG
Gold plated 1015
16 AWG
14 AWG
Tin plated 1015
16 AWG
Applicable cable
Wire
Sectional
Construction
area
2.18mm2
41cores./0.26mm
2.18mm2
41cores./0.26mm
2.18mm2
41cores./0.26mm
2.18mm2
41cores./0.26mm
Jacket Quantity
diameter
2.4 to 3.0mm 2500
2.4 to 3.0mm 2500
3.0 to 3.8mm 2000
3.0 to 3.8mm 2000
1.6
.5
Ø1
P=15.5
Tool : Applicator
HRS No. Finish
0.8
29
25.2
3.8
3 0.8
HRS No. Finish
t=0.3
Part No.
DF22-1416PCA
DF22-1416PC
DF22A-1416PCA
DF22A-1416PC
HRS No. Finish
UL
style
680-1192-0 Gold plated 1430
680-1080-2 Tin plated 1430
Wire
size
16 AWG
16 AWG
14 AWG
680-1193-0 Gold plated 1015
16 AWG
14 AWG
680-1081-5 Tin plated 1015
16 AWG
Applicable cable
Wire
Sectional Jacket
Construction
area
diameter
26cores./0.254mm 1.32mm2 2.6mm
41cores./0.26mm
2.18mm2 3.7mm
26cores./0.254mm 1.32mm2 3.2mm
2.18mm2 3.7mm
41cores./0.26mm
11
BMated Dimensions
●Socket to Straight Header Connection
●Socket to Right Angle Header
Connection
1 Pos.
DF22B/C--1RS/P--7.92
DF22#--1P--7.92DSA(**)
DF22#--*S--7.92C(28)
DF22#--*P--7.92DS(**)
(26.7)
(28.7)
(23.7)
(25.7)
DF22#--1S--7.92C(28)
(31.6)
(29.6)
(13.5)
DF22--/1RS/P--7.92
DF22B#--1S--7.92C
DF22C#--1S--7.92C
(12.25)
(12.45)
DF22--*RS/P--7.92
(34.6)
(32.6)
DF22B#--*S--7.92C
DF22C#--*S--7.92C
(13.3)
DF22B/C--*RS/P--7.92
(12.45)
DF22--*RS/P--7.92
(13.5)
DF22B#--*S--7.92C
DF22C#--*S--7.92C
(23.7)
(25.7)
(26.7)
(28.7)
DF22#--*P--7.92DSA(**)
(13.0)
DF22#--*EP--7.92C
DF22--*RS/P--7.92C
DF22B/C---*RS/P--7.92
(47.55)
(43.55)
●In-line Double-row socket to In-line Double-row
Plug (Panel lock type) Connection
DF22B#--4DS--7.92C
(47.55)
(43.55)
DF22A#--*EP--7.92C
Double-row Plug Connection
(43.55)
12
DF22B#--4DS--7.92C
(43.55)
DF22C#--4DS--7.92C
(23.3)
DF22C#--4DS--7.92C
(23.3)
DF22#--4DEP--7.92C
DF22B#--*S--7.92C
DF22C#--*S--7.92C
DF22A#--4DEP--7.92C
DF22#--4DEP--7.92C
(43.55)
DF22--RS/P--7.92
(22.1)
(43.55)
DF22A#--*EP--7.92C
DF22B#--*S--7.92C
DF22C#--*S--7.92C
(14.2)
DF22#--*EP--7.92C
(44.55)
(40.55)
(14.2)
(44.55)
(40.55)
●Socket to In-line Plug Connection
(13.0)
●Socket to In-line Plug (Panel lock type)
Connection
(22.1)
2 to 5 Pos.
DF22A#--4DEP--7.92C
BTools
Type
Hirose Press Unit
Applicators Used in
Hirose Press Unit
CM-105C
Part No.
HRS No.
901-0001-0
AP105-DF22-1416
901-4576-7
UL1430
DF22-1416SCF/PCF/SCFA/PCFA
AP105-DF22A-1416
901-4578-2
UL1015
DF22A-1416SCF/PCF/SCFA/PCFA
901-4579-5
UL1430
901-4580-4
901-4582-0
550-0285-0
550-0286-2
550-0288-8
UL1015
UL1015
UL1430
UL1015
UL1015
16 AWG : UL1430
16, 14 AWG : UL1015
10, 12 AWG : UL1015
Applicators Used in Press AP109A-DF22-1416
Units of Other Japanese AP109A-DF22A-1416
Companies (Note 2)
AP109A-DF22A-1012
Applicator Manufactured by CHS893800H-UP
Japan Automatic Machine CHS893900H-UP
(Note 3)
QHS895800H-UP
HT104/DF22-1416
Crimping Tools
HT104/DF22A-1416
HT103/DF22A-1012
Applicable Wire (Note 7)
Applicable Contact (Note 6)
DF22/DF22A-1416SCF/PCF/SCFA/PCFA
DF22A-1012SCF/SCFA(Note 1)
DF22-1416SC/PC/SCA/PCA
DF22A-1416SC/PC/SCA/PCA
DF22A-1012SC/SCA
Note 1 : When crimping DF22A-1012SCF/SCFA use a press of at least 3.5 tons.
Note 2 : Applicators compatible with other Japanese companies (AP109A Applicator) cannot be used with the Hirose Press Unit CM-105C.
An attachment is required when using the applicator. Please contact the press unit manufacturer for inquiries on attachments.
Note 3 : Please contact Japan Automatic Machine (J.A.M.) via their homepage regarding inquiries on the applicator or crimping defects.
(URL: http://www.jam-net.co.jp)
Note 4 : Problems caused by tools other than those specified are not covered by the warranty.
Note 5 : Crimping should be carried out based on the "Crimping Quality Standards" and "Crimping Conditions Table."
Note 6 : Applicable contacts are limited to those listed in the table.
Note 7 : Applicable cables are limited to those listed in the table.
BContact Extraction
■ Contact extraction tool : Flat-bladed screwdriver, 1.4mm blade width
■ Intended crimp Contacts : DF22-1416SC(F), DF22-1416SC(F)A, DF22A-1416SC(F),
DF22A-1416SC(F)A, DF22A-1012SC(F), DF22A-1012SC(F)A,
DF22-1416PC(F), DF22-1416PC(F)A, DF22A-1416PC(F), and DF22A-1416PC(F)A
■ Work Method
(Housing CrossSectional Diagram)
(1)
(2)
Molded-in lance
1. Refer to the drawing No. 1. Insert
correct size screwdriver in the
housing against the molded-in lance.
Push down the lance as shown.
2. Assure that the lance is deflected
to release the contact and pull-out
wire with the crimped contact.
Note : Please do not reuse the reparred housing. Replace it to new one.
Caution
There are parts on the crimp contact that can cause injuries, please use caution when unmating the contacts.
13
BPrecautions
1. Gold-plated products are standard for this product in order to support high current.
Be sure to select a gold-plated product for use in an environment with temperature
2. If this product is used outside the specifications, evaluate it in the final set to confirm that
3. No outdoor use.
4. Notification for harness assembly
1) When inserting the crimping terminal to the crimping socket, please do not tilt the crimping terminal or twist the cable.
Insertion at tilted angles or twisting the cable may cause deformation of the crimping terminal or crimping socket.
2) After inserting the crimping terminal to the crimping socket, please make sure that
the lance has been hooked with pulling the cable lightly. When checking the hook,
please avoid bending the cable for preventing terminal drop-off.
Load
Load
3) Bundle cables/Cabtyre Cables
Recommend bundle and strip position of cables are 100mm or more.
Bundling close to the connectors may cause terminal drop-off, breaking cables
and unstable connection.
More than 100mm
5. Notification for Insertion Extraction
1) Please insert(extract) the crimping socket straight to the mating connector.
Insertion(extraction) at tilted angles applies load concentration to the connector end and may cause deformation
(at connection area, socket and header case, etc). There is firing risk using this kind of deformed connector.
Insertion
Extraction
2) When it is hard to extract, please lightly insert the connector beforehand and then pull it with releasing the lock.
Forced extraction has a risk of connector breakage.
6. Notification of wiring
1) When using a thick cable, short cable length and bending close to the
connector end, these load concentration may cause deformation.
Please note that there is firing risk using deformed connector.
When installing, please refrain from stress concentration such as cable
bending close to the connector end or cable twisting.
Stress concentration;
Cable bending close
to connector
BCurrent Ratings
The current rating listed in the catalog indicates the allowable current per contact. However, in applications requiring
current transmission through all the contacts, about one-third of the listed rating should be applied.
When the current rating for the connector is 3A, and the allowable current of the conductor being used is 1A, then rating
of 1A will be used for the entire assembly.
The connectors should not be mating / unmating when the electrical current is being applied.
Hot swap should not be performed.
14
MEMO :
15
USA:
HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE
2300 Warrenville Road, Suite 150,
Downers Grove, IL 60515
Phone : +1-630-282-6700
http://www.hirose.com/us/
USA:
HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE
2841 Junction Ave, Suite 200
San Jose, CA. 95134
Phone : +1-408-253-9640
Fax : +1-408-253-9641
USA:
HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE)
17197 N. Laurel Park Drive, Suite 253,
Livonia, MI 48152
Phone : +1-734-542-9963
Fax : +1-734-542-9964
USA:
HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE
300 Brickstone Square Suite 201,
Andover, MA 01810
Phone : +1-978-662-5255
THE NETHERLANDS:
HIROSE ELECTRIC EUROPE B.V.
Hogehillweg #8 1101 CC Amsterdam Z-O
Phone : +31-20-6557460
Fax : +31-20-6557469
http://www.hirose.com/eu/
GERMANY:
HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH
Schoenbergstr. 20, 73760 ostfildern
Phone : +49-711-456002-1
Fax : +49-711-456002-299
GERMANY:
HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE
Neumeyerstrasse 22-26, 90411 Nurnberg
Phone : +49-911 32 68 89 63
Fax : +49-911 32 68 89 69
GERMANY:
HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE
Bayernstr. 3, Haus C 30855 Langenhagen, Germany
Phone : +49-511 97 82 61 30
Fax : +49-511 97 82 61 35
FRANCE:
HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE
130 Avenue Joseph Kessel, Bat E, 78960
Voisins le Bretonneux, France
Phone : +33-1-85764886
Fax : +33-1-85764823
UNITED KINGDOM:
HIROSE ELECTRIC EUROPE BV (UK BRANCH)
4 Newton Court, Kelvin Drive, Knowlhill,
Milton Keynes, MK5 8NH
Phone : +44-1908 202050
Fax : +44-1908 202058
CHINA:
HIROSE ELECTRIC (CHINA) CO., LTD. (SHANGHAI, HEADQUARTERS)
18, Enterprise Center Tower 2, 209# Gong He
Road, Jing’an District, Shanghai, CHINA 200070
Phone : +86-21-6391-3355
Fax : +86-21-6391-3335
http://www.hirose.com/cn/
CHINA:
HIROSE ELECTRIC (CHINA) CO.,LTD. BEIJING BRANCH
A1001, Ocean International Center, Building 56# East 4th
Ring Middle Road, ChaoYang District, Beijing, 100025
Phone : +86-10-5165-9332
Fax : +86-10-5908-1381
CHINA:
HIROSE ELECTRIC (CHINA) CO., LTD. SHENZHEN BRANCH
Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre,
5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008
Phone : +86-755-8207-0851
Fax : +86-755-8207-0873
HONG KONG:
HIROSE ELECTRIC HONGKONG TRADING CO., LTD.
Room 1001, West Wing, Tsim Sha Tsui Centre, 66
Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong
Phone : +852-2803-5338
Fax : +852-2591-6560
http://www.hirose.com/hk/
TAIWAN:
HIROSE ELECTRIC TAIWAN CO., LTD.
103 8F, No.87, Zhengzhou Rd., Taipei
Phone : +886-2-2555-7377
Fax : +886-2-2555-7355
http://www.hirose.com/tw/
KOREA:
HIROSE KOREA CO.,LTD.
143, Gongdan 1-daero, Siheung-si,
Gyeonggi-do, 15084, Korea
Phone : +82-31-496-7000
Fax : +82-31-496-7100
http://www.hirose.co.kr/
SINGAPORE:
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE
03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C,
Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India
Singapore 079909
Phone : +91-12-660-8018
Phone : +65-6324-6113
Fax : +91-120-4804949
Fax : +65-6324-6123
http://www.hirose.com/sg/
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE
Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma
Gandhi (MG) Road, Bangalore 560 001, Karnataka, India
Phone : +91-80-4120 1907
Fax : +91-80-4120 9908
MALAYSIA:
THAILAND:
PENANG REPRESENTATIVE OFFICE
BANGKOK OFFICE (REPRESENTATIVE OFFICE)
73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn
Road, Yannawa, Sathorn, Bangkok 10120 Thailand
Lepas Penang, 11950, Malaysia
Phone : +66-2-686-1255
Phone : +604-648-5536
Fax : +66-2-686-3433
16
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 01/2020. Contents are subject to change without notice for the purpose of improvements.
