Crimp
Crimp
2.54
2.54 mm
mm
RA CONNECTOR
Disconnectable
Disconnectable Crimp
Crimp style
style connectors
connectors
pitch
pitch
Features
● Secure lock device
The locking levers are engaged by inserting the receptacle
into the header. This ensures a firm connection that's highly
resistant to impact and vibration.
RA
RA CONNECTOR
CONNECTOR
● Housing lances
The contact retention lances on the resilient housing allow
visual confirmation of contact lock-in for easy and secure
insertion.
● Low insertion force contact
The low insertion force contacts reduce surface finish wear
and reduce the effects of stress relaxation.
● Anti-misinsertion feature
Crimp style receptacles that are designed to
mate with headers conforming to MIL-C-83503.
surface finish wear and resist stress relaxation
very well.
The guide devices of both housing and header prevent
reverse connector insertion.
Specifications
• Current rating: 1.0 A AC/DC (AWG #22)
• Voltage rating: 300 V AC/DC
• Temperature range: -55℃ to +85℃
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 15 mΩ max.
After environmental tests/ 30 mΩ max.
• Insulation resistance: 1,000 MΩ min.
• Withstanding voltage: 1,000 VAC/minute
• Applicable wire: AWG #26 to #22
• Applicable PC board thickness: 1.6 mm
* In using the products,refer to "Handling Precautions for Terminals
and Connectors" described on our website (Technical documents
of Product information page).
* RoHS2 compliance
* Dimensional unit: mm
* Contact JST for details.
Standards
1
Recognized E60389
RA-CON
RA CONNECTOR
Contact
Applicable wire
Model No.
RA-SC1290
11.5
3.4
4.45
1.8
AWG #
Insulation O.D.
(mm)
Q'ty/
reel
0.13 to 0.33
26 to 22
1.3 to 1.7
8,000
Material and Finish
RA CONNECTOR
1
1.5
mm2
Phosphor bronze, tin-plated (reflow treatment)
RoHS2 compliance
Note: Contact JST for gold-plated contacts.
1.55
RA-APP
Housing
8
No. of
circuits
10
16
5 3 1
26
30
3.65
34
R JST
2.54
40
6.2
A
50
60
Dimensions (mm)
A
B
C
Model No.
RA-1011
RA-1611
RA-2011
RA-2611
RA-3011
RA-3411
RA-4011
RA-5011
RA-6011
B
Q'ty/
box
10.16
17.50
8.75
500
17.78
25.12
12.56
500
22.86
30.20
15.10
500
30.48
37.82
18.91
500
35.56
42.90
21.45
200
40.64
47.98
23.99
500
48.26
55.60
27.80
200
60.96
68.30
34.15
200
73.66
81.00
40.50
200
Material and Finish
Glass-filled PBT, UL94V-0, black
C
2.54
RoHS2 compliance
RA-APP
Header
The following headers are applicable to the above Housing.
RA header
No. of circuits
Top entry type
Side entry type
10
RA-H101TD-1190
RA-H101SD-1190
16
RA-H161TD-1190
RA-H161SD-1190
RA-H201TD-1190
RA-H201SD-1190
26
RA-H261TD-1190
RA-H261SD-1190
30
RA-H301TD-1190
34
RA-H341TD-1190
RA-H341SD-1190
40
RA-H401TD-1190
RA-H401SD-1190
50
RA-H501TD-1190
RA-H501SD-1190
60
RA-H601TD-1190
RA-H601SD-1190
RoHS2 compliance This product displays (LF)(SN) on a label.
Note: Contact JST for gold-plated headers.
Crimping machine, Applicator
Contact
RA-SC1290
Crimping
machine
AP-K2N
Crimp applicator
Dies
Crimp applicator with dies
MKS-L
MK/RA-SC12
APLMK RA-SC12
Note: Contact JST for fully automatic crimping applicator.
2
很抱歉,暂时无法提供与“RA-SC1290”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 100+0.25600
- 1000+0.20770
- 3000+0.18070
- 8000+0.14760
- 国内价格
- 1+0.10710
- 1000+0.10140
